Multisite UC500
sabbinanti
I have two sites, one with a UC560 an another with a UC540. I manually created a VPN tunnle and setup dial peer. The two sites can use 4 digit dialing and have access to the PSTN from each site. Calls from IP Phone to IP Phone work just fine.
However, call forwarding to voicemail (NOAN or otherwise), access to the conference bridge or even dialing CUE directly from the site with the UC540 to the site with the UC560 fails as unknown number.
When calling from the site with the UC560 to the site with the UC540, this is not a problem.
S.
Hello Sebastian,
Please try to use codec g711ulaw between sites under the dial peers.
HTH,
Alex
*Please rate helpful posts
5 Replies 5
Hello Sebastian,
HTH,
Alex
David Trad
Hi Sebastion,
You either have a Codec Mismatch issue going on, or transcoding is not working properly.
If you do what Alex says, and it works properly in both directions, you can then further investigate using different codecs to reduce bandwidth, but for testing purposes putting everything on G-711uLaw is the best methodology in diagnosing the problem
Cheers,
David Trad.
**If you don't want to rate a post that is fine, I'll just find out where you live and hunt you down**
^^ That's a joke just in case you didn't get it :)
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
I think I already have that set as the primary codec. Please view below
UC540:
dial-peer voice 2205 voip
description to Conference Bridge
destination-pattern 707[1-2]
session target ipv4:10.10.200.250
voice-class h323 1
dtmf-relay h245-alphanumeric
fax protocol cisco
no vad
dial-peer voice 2206 voip
description to US Pilot
destination-pattern 399.
voice-class h323 1
fax protocol cisco
no vad
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
sip no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
call start slow
UC560
voice service voip
clid substitute name
sip
tel-config to-hdr phone-context
registrar server
voice class codec 1
voice class h323 1
call start slow
dial-peer voice 2400 voip
description to Denmark
destination-pattern 24..
session target ipv4:192.168.10.1
voice-class h323 1
fax protocol cisco
no vad
Hello Sebastian,
This is set to deault codec which is G729 because it is not set under the dial peers.
So under :
you should include :
voice-class codec 1
or directly
codec g711ulaw
HTH,
Alex
Still doesn't work. Any Debugging I can try?
S.
