outside dial tone
sohenko
does anyone know if it is at all possible to configure the system so that the tone that's heard when the phone is off hook is swaped with the one thats heard when 9 is dialed? client hated the default.
There is currently no way to change either one.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
I just thought of something that might help. You may want to try different network locales under telephony service to see if the defaults for other countries give you a better, more likable dialtone:
UC500#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
UC500(config)#telephony-service
UC500(config-telephony)#network-locale ?
  <0-4>  network locale index 0 to 4 (0 is default)
  AT     Austria
  CA     Canada
  CH     Switzerland
  DE     Germany
  DK     Denmark
  ES     Spain
  FR     France
  GB     United Kingdom
  IT     Italy
  JP     Japan
  NL     Netherlands
  NO     Norway
  PT     Portugal
  RU     Russian Federation
  SE     Sweden
  US     United States
Make sure you reboot the phones. Also, some phone models may require a load change. You can try to use CCA to localize the system
Marcos
