02-04-2013 12:24 PM - edited 03-21-2019 06:56 AM
I have a system in Key Mode, and cannot seem to figure out how to get an analog phone that's plugged into the FXS Port to make an outgoing call.
02-04-2013 12:48 PM
Hi Russ,
The key system mode supports shared fxo line at the SPA5xx phones to make the outbound calls. It's not supported at FXS port analog phone since it doesn't have multiple phone buttons as SPA5xx phone does.
Best regards,
Wendy Yang
02-04-2013 12:50 PM
I hate to be picky, but was that even in English?
02-04-2013 01:14 PM
Hi Russ,
In pure key system mode the FXS port (and SPA502 phone) can't be configured as a member of a Shared FXO Line. There is no way to directly reach these phones on an inbound call. They can however, be used to make out bound calls if the system is configured in blended mode and the option 'Include in Outbound calls' is checked on the Shared FXO Lines page. In this scenario the FXS phone would dial 9 + address and the system will let the FXS use an idle FXO that has that capability enabled.
Hope this helps.
Chris
02-05-2013 06:37 AM
Christopher,
Thanks. I'll try the blended mode and see if that's what I'm wanting. I majorly want the FXS phone for outbound calls and the ability to transfer a call to it, so I'm thinking that should work.
Russ
