Pickup-Group UC540 does not work
Hello!
We have a UC540 (UC540W-BRI-K9). On this we have configured following:
Incoming call -> Hunt group pilot 511 -> extensions 203, 204. If nobody picks up the call, it will be forwarded to hunt group pilot 512. After there also no one pick up the call, it will be forwarded to BACD (wish of customer..).
For the phones we have configured this:
ephone-dn  293  dual-line
no call-waiting beep
number 204 secondary xxx no-reg primary
pickup-group 1
label 204
description xxx
name xxx
call-forward busy 203
call-forward night-service 6204
call-forward noan 502 timeout 20
night-service bell
ephone-dn  294  dual-line
number 203 secondary xxx no-reg primary
pickup-group 1
label 203
description xxx
name xxx
call-forward all 204
call-forward night-service 6203
call-forward noan 501 timeout 20
night-service bell
This two phones are in pickup-group nr 1. But if extension 204 rings, 203 cannot pickup via GPickUp button.
I don't know why. This two numbers are very interlaced.
Can someone help me please? We have this problem since a half year.
Thank you very much!
Daniel
Hi Daniel,
Try to pickup the call using GPickUp button and then press * (asterisk).
Best regards,
Alexander
*Please rate helpful posts.
5 Replies 5
Hi Daniel,
Best regards,
Alexander
Hi Alexander,
thank you for reply. I will test it. Hope it helps
Thanks and regards,
Daniel
David Trad
Hi Daniel,
Curious as to how many Pickup groups you have?
Also is this a CLI configured system? I notice the no call-waiting beep settings which is not achievable with CCA 3.1.1 (Well wasn't last time I checked).
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi David!
Glad to hear from you.
There  are about 4 or 5 pickup groups. Yes, this is a CLI configured system  because of some failures. (First CCA, after TAC -> CLI).
Best wishes,
Daniel
Hey!
I think the problem is resolved. Customer gave no reply if it helps.Hope it is a good sign.
Else I will ask again
Thank you!
Daniel
