HiDoes 6961 and 7931 supports extension mobility with UC560? Can't find any documentation which clearly states this...Thanks
Hi Team,I was wondering if there is a way to increase the Wireless Output power (Overclock it in a sense)?I have a client where the SPA-525G2 is located only about 6-7mtrs from the UC-320W, there are about 3 door ways it has to traverse to get to the...
Good afternoon,I've setup a UC560 for remote admin access via the SSL VPN built in to the UC560. My question is how many incorrect tries does someone have to make before it goes into lock out and how long until it allows login again? Also can this be...
Does anyone knows if there is a way to add FAC to a user on the UC320, or if there is a way to block some patterns like for example 9,01900XXXX, but allow others like 9,01800 xxxx etc.RgdsVicente
I have the SPA 8800 connect to my UC320 the FXO ports work fine, but I can't get dial tone on the FXS port. The FXS port on the UC320 works fine and the FXS ports in the UC320 configuration are enabled, but I can't find any additional setting that gi...
Hi all,how can I reserve one of my 4 trunk sip for fax communications with the device connect to the fxs port?For incoming call I can configure the incoming call menu and forward to the fxs port, but for outgoing calls I don't know what I need to do ...
Hi all, I have a silly question. Have installed one UC540. What is the difference betwen CME and CUE and what do these components actually "look" like. This is my understanding so far:CUE is a application that runs within the IOS that handles voicema...
Hiwe have cisco UC540 (8.2)Extension 390 has an AutoAttendant script on CUE.After initial greeting on 390, a call is being forwarded to the extension 280 (B-ACD queue)If we make calls from the local IP-phone to extension 390, everything works fine.If...
WHAT:Today we are announcing the General Availability of the Cisco UC320W 2.1.2 Firmware release. This release addresses a critical compatibility issue with Adobe Flash Player version 11. If you try to access a UC320W that is running a firmware ve...
WHAT:Today we are announcing the release of the Cisco UC320W 2.1.3(0) Limited Deployment Firmware release. This release is available only via the Cloud by installing the attached Platform Modification File (PMF). This is the 2.1.1(7) firmware wi...
Hi All,I wanted to check which IOS version I should use which has CME 8.6 as part of it that is compatiable with the UC520.I have already upgraded the CUE to 8.6 and wanted to do the same for the CME.I am just trying to test out the functionality tha...
hi i am having issue when i start phone vpn setup wizard it throws error http request error (as shown in attched) although i have SPA525g2 and it is registered and i can ping it and open web server of phone
Does anyone have this working?We have had a lot of trouble with it... ironically its T.38 that causes all the problems.If we force G711 in the config... outgoing faxes work fine... but incoming seem to be auto-negotiated to T.38 and fail nearly 100%....
Hello, we´re desingning a voice solution for a customer that has 3 companies in a same building (same location). Each company is going to receive a SIP TRUNK and have it´s own auto attendant. We´re thinking to use an UC540 for each company and interc...
Is there anyway to get MOH playing as soon as a user selects an option from the auto attendant so they get music instead of hearing the ringing?
