PSTN line through SPA112 with 3cx
faisalbandesha
Any body can help me to configure PSTN line with SPA112 for calling through 3cx IP PBX. How can i call through this PSTN number. My scenario is like this.
---> PSTN Line is connected SPA112 in port 1 instead
----> SPA112 Connected to 3cx through LAN
How can i call from 3cx extension through PSTN line to any number locally. File is given bellow for Allo Analog Gatway. kindly guide me for cisco SPA112.
j.huizinga
Level 6
Level 6
SPA112 has two FXS ports, don't think works with PSTN lines
j.huizinga
Level 6
Level 6
I don't think so it can be used for PSTN
No, it cannot, that device has FXS ports, no FXO ports
 Includes two standard telephone ports, each with an independent phone number, for use with fax machines or analog phone devices
http://www.cisco.com/c/en/us/products/collateral/unified-communications/small-business-voice-gateways-ata/datasheet_C78-691106.html
java
if this helps, please rate
