Hi All, I need to setup UC540 in a existing network using the existing DHCP server, the dhcp provides also the default gateway to the clients, this gateway is an adsl modem.Is posible to do this setup with the setup wizard for the uc540 in the i...
My ATA232D is connected to Ubiquity Edgerouter X. I have other SIP phones on my network that can send and receive calls without issue. Since a few days I can not connect to incoming calls. Outgoing calls are still possible.
I have no changes to the...
There is a way to connect CP-8961(last sip firmware) to SPA-3102 without pbx/asteris/any other server side sip)?
I configured spa PSTN line for IP dialing so I can call in/out on PSTN line with softphone.
Now I want to connect my CP-8961 to spa (over...
Hello,I,ve problems with CCA 2.2(5) making a backup of the config and installing new software. So I found the nice articel "CCA Prerequisites for UC500 connection - check list" and tried it. I'm stuck at check routing CUE->PC. I can't ping the defaul...
Hi everyone,
I'm using a Cisco SPA 112 for a few months now without any problems. I recently changed my ISP and now I can't call one (quite usual) specific telephone number. Everything else works perfectly fine. I can call all other numbers I tried...
We are using the multicast paging feature as our emergency all page on our SPA50X phones. However, when someone is on a call it does not barge in. Is it possible to force the page?
Hi There
I am trying to set the physical hold key on a spa514g to map to a PSK that I have defined.
I have followed the instructions on this page however it doesn't change the physical hold key.
https://www.cisco.com/c/en/us/td/docs/voice_ip_c...
We have two UC540s. Both devices are configured with identical dial-peers for voice mail.
When a call from UC540-A is made to a DN on UC540-B, if it goes unanswered and is set to forward to the voice mail pilot, the call is directed to the dial-pee...
I'm replacing my relative's ISP provided all-in-one cable modem/wireless router/VoIP with their own cable modem and firewall/router (separate devices). I've purchased a Cisco SPA 112 phone adapter so they can keep their VoIP as well. The ISP is tel...
i have a netgear ac1200 and a cisco spa 112, on some but not all calls there is a delay when i answer the phone sometime up to 30 seconds before i can hear the other person and they can hear me, i miss quite a few of these calls because the caller pu...
I've run into a weird issue with receiving faxes via SPA 112 and wanted to see if anybody has any ideas. We have t.38 enabled with the passthru method set to reinvite. We've done the normal stuff such as disabling ECM on the fax machine and ...
Hi, so I have a customer who wants to have his phone such that he has one extension that rings the phone and another extension that only flashes the line button like when the phone is in DND mode. It's like DND but different, applied only to a single...
Hi, I have a SPA 122 and want to integrate third party PA system and has requirement that dial tone should not be present on the port. I have configured and registered SPA 122 but PA system does not works as it has a dial tone.
Any way to disable dia...
I've read every other post concerning this issue.
I have tried with chrome and Iexplorer 11.
I can't see the quick setup menu.
I can't see the menu item to upgrade the firmware.
What can I do
I tried finding iexplorer 8 but the link is ...
