Recovering static routing setting 10.1.10.1 for CUE
ytamagawa
I'd like to recover connectivity with CUE.
I deleted default static routing setting 10.1.10.1 for CUE by my mistake.
I tried to configure like followings.
UC520#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
UC520(config)#interface Loopback0
UC520(config-if)#description $FW_INSIDE$
UC520(config-if)#ip address 10.1.10.2 255.255.255.252
% 10.1.10.0 overlaps with Vlan101
UC520(config-if)#ip access-group 101 in
UC520(config-if)#ip nat inside
UC520(config-if)#ip virtual-reassembly
UC520(config-if)#interface Integrated-Service-Engine0/0
UC520(config-if)#description cue is initialized with default IMAP group
UC520(config-if)#ip unnumbered Loopback0
UC520(config-if)#service-module ip address 10.1.10.1 255.255.255.252
Need IP address to be configured on interface Integrated-Service-Engine0/0
It seems like ip adress setting failed because of overlapping with Vlan101. Also CUE Connectivity Diagnostics says "IP address needs to be configured on interface Integrated-Service-Engine0/0"
Use reset only to recover from shutdown or failed state
Warning: May lose data on the the NVRAM, nonvolatile file system or unsaved configuration!
Do you want to reset?[confirm]
Trying to reload Service Module Integrated-Service-Engine0/0.
UC520#service-module Integrated-Service-Engine 0/0 session
UC520#
I'm a beginer of IOS, Cisco products and also English. I can barely use CCA. Thank you.
paolo bevilacqua
Check in flash there should be a default configuration file with basic settings.
paolo bevilacqua
