Remote working
abillington
Is it possible to use an SRP500-series as a remote worker router to connect to a UC540, and use the SRP's FXS ports as an extension on the main UC dial-plan? Don't suppose it's documented anywhere ... feeling lazy ...
Alberto Montilla
Dear Sir;
This configuration is not supported. Supported configuration is to use:
(1) SR520 with ATA or phone
(2) SPA525G2
Alberto
looked at those, neither of those solutions will fit budget: the SRP-based setup would. By "not supported" do you mean "not supported" or "won't work"? The SRP500 product overview has "system-level testing and validation" saying "SIP trunking for UC 500 and SPA9000".
The price difference between the SRP and the SR520/ATA combination is just too great: I think the only way I could get it working anywhere close to budget using either of the two configs that are supported is if a PC attached to the SPA525G2 can use the phone's VPN for connecting to the office network, with the same SNMP capabilities as the SRP. Not looking likely ....
Were you able to get this working?
We are about to try.
