SIP Trunk between UC320 and CUCM
David Lee
Has anyone had any luck with creating a SIP Trunk between a UC320 and CUCM?  We have a location that we recently just acquired that has a UC320 running on site and for simplistic and ease of transition it would be easier if we could just create a SIP trunk between our CUCM 10.5.2 cluster and the UC320 at the location ( ON-NET connection of course).  I have been able to to configure the Trunk on CUCM and when I call extensions on the UC320, it goes through with no problem, but something is not right on the UC320 side.  When I try to dial extensions that belong to the CUCM the calls fail.  I'm certain having a UC500 or CME would be a lot easier since it has CLI and I could just program some dial-peers, but it seems that the UC320 is very limited on it or that my understanding of it is limited.
Ratheesh Kumar
Hi there
Just wondering did you configure inbound call routing on UC320.
https://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=4dda2957c5c944ea86f2a3ceb77a44d5_Configure_Inbound_Call_Route_on_the_UC320W.xml&pid=2&converted=0
This troubleshooting guide could be handy for you.
https://supportforums.cisco.com/t5/small-business-support-documents/uc320w-troubleshooting-guide/ta-p/3295200
Can you also get the troubleshooting error logs from UC320
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
