We have SIP trunks on a UC560 and we need to edit local number i.e. 123456 to insert the area code before sending out as the SIP provider needs the area code.Is this straight forward?
Hello!I needed help setting up a netowrk. How can I have a sonicwall act as a DHCP server for the UC320 I have?The computers are connected via LAN. And the Sonicwall is connected via WAN.Thanks for your help.
Hi everyone, I have a problem with my UC540, below is my network diagram: Internet---------887----------UC540 I have successfully configured UC540, incoming and outgoing call working perfect, but when I changed IP address on UC540's F0/0 which connec...
Hi all!We have a Cisco 7926 desk phone connected to a Jabra Pro wireless headset. It's connected with a headset cable from the phone to the base station and set up correctly according to the instructions from Jabra. My problem is that when we use the...
We are trying to configure SIP trunks VIA CCA (Latest version) on a UC560 latest version.However the username and password field doesn't save. When you open CCA SIP trunk configuration the fields are blank, fill them in and save, exist and go back i...
I have just got a 3CX phone system and I am trying to install a 7961G phone that I bought second hand. The phone was still full of settings when it arrived so I tried to reset it.I used the 123456789*0# sequence. The phone looks like its upgrading, i...
Hi,We replaced our SPA3102 with a SPA232D.FXO port is connected to our analog line, Internet port is connected to our LAN.The PSTN line on the SPA232D is registered with our Asterisk server so calls go through our analog line.From our IP phones to ou...
I'm using a UC520 right now with 2 x AP521 access points. The building is 16,000 sq ft. I have 2 x Cisco 7925G cordless phones, however I have quite a few dropped calls and I think that could be caused by them handing off between networks. I would...
I've got a couple of SPA504G phones that are rebooting approximately every hour. However I have the parameter <Resync_Periodic ua="na">0</Resync_Periodic> in the configuration template. So it can't be a template configuration issue.I enabled the debu...
Hi, I hope someone can point me in the right direction.Current use case:Using SPA504G handsets registered against a Broadsoft switch. Client wants to be able to park multiple calls (say up to 4) and retrieve by pushing one of the lines on the Attenda...
I currently have a UC520 with 3 x Cisco 7975G phones. I need a few more phones. From what I can see, the 7975G and 9971 are about the same price, however the 9971 is newer. Is there any reason to stick with the 7975G? It looks as if the UC520 wil...
Hi, I have a customer requirement for when a Cisco 78xx IP Phone ring to receive an audio (external speaker) and visual (flashing light not on the phone) indicator. Can someone tell me what product and pieces are needed to make to fulfill these requi...
Hello guys, I've searched a bit through the forum, and I am not sure I understand clearly if what I am doing is not supported, or if it could work and I am doing something wrong.So here is it : Setup :1 UC560 connected to T1 line (main office MO). Ex...
Dear support,I'm continuing to have issues with the disconnect tone detection during a call via fxo trunk.I tried the auto detection tool several times, no way. I get 10 minute long voicemail messages and disconnection problems.I'm attaching a techni...
