Sip Trunk with CME
Leonardo Santana
Its possible to establish a Sip trunk with CME in be3000?
Leonardo Santana
*** Rate All Helpful Responses***
11 Replies 11
Nico Yang
Test IOS:
c2800nm-adventerprisek9_ivs-mz.151-4.M6.bin
c2800nm-adventerprisek9-mz.124-24.T5.bin
c2800nm-adventerprisek9-mz.124-9.T.bin
CME:
dial-peer voice 100 voip
destination-pattern 6...    //   Extension number in  BE3000    or  (destination-pattern 6444) 6444  is  AA in BE3000
session protocol sipv2
session target ipv4:192.168.200.253 //BE3000 IP address
dtmf-relay sip-notify
codec g711ulaw
no vad
BE3000:
connect--pstn-- add --sip trunk-CUBE(add CME)  next  --next --next
http://tools.cisco.com/s2slv2/ViewDocument?docName=EXT-AS-585953
https://supportforums.cisco.com/message/4009904#4009904
Emmanuel Valdez
Level 3
Level 3
Yes you can through a CUBE.
Regards.
Hi Emanuel.
I have the same problem connecting 2921 router with CME to a BE3000.
Can you help with configuration needed in the Router in order to enable CUBE and establish a SIP connection between the two?
Thank you.
Danny.
Hi Danny,
You can enable CUBE feature with the following commands:
voice service voip
 ip address trusted list
  ipv4 x.x.x.x y.y.y.y
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 redirect ip2ip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server expires max 3600 min 3600
I recommend you setup the ip address trusted list to avoid a toll fraud, where x.x.x.x is the ip address from a host or network and y.y.y.y is the subnet mask.
Setup a voice class codec, for example:
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711alaw
 codec preference 3 g711ulaw
Configure yours outbound and inbound dial peers like these:
 description *****Calls to CUCMBE3K*****
 destination-pattern 17[4-9].
 session target ipv4:z.z.z.z
 voice-class codec 1
 dtmf-relay h245-alphanumeric rtp-nte sip-notify
 ip qos dscp cs3 signaling
 incoming called-number .T
 no vad
Where z.z.z.z is the IP address from CUCMBE3K
Please rate useful information.
Regards.
Hi Emanuel,
Thank U for your reply. I will try to configure the Router with your configuration.
Best regards,
Danny.
tom golan
were you able to establish SIP trunk between them?
When you say "through CUBE", does it mean that i need an additional hardware besides the CME?
Thanks in advance,
Tom.
Hi tomgolan88,
A voice router can be CUBE and CME at the same time, but it is recomended that voice router will be a ISR G2 or a ISR with IOS version 15.1 at least,
You can check these information,
http://www.cisco.com/c/en/us/solutions/enterprise/interoperability-portal/networking_solutions_products_genericcontent0900aecd805bd13d.html
Regards.
dannyg
I need to connect CME and BE3000, without CUBE.
Is it possible?
Hi dannyg@bynet.co.il,
A CUBE is a requirement to integrate your BE3K, so you have to enable CUBE feature on your CME.
Conclusion, is it possible, what are you CME version and hardware?
Regards.
Hi Emmanuel
I have a Cisco 2921 with CME 7.1.
How is that I can establish a SIP Trunk between 2 CMEs without CUBE, and between CME and BE3K I need CUBE?
It won't work without CUBE or this is an unsupported scenario?
Danny
Hi dannyg@bynet.co.li,
In Mexico there is only a option to make a SIP Trunk through CUBE, so in my case I could integrate a SIP Provider for PSTN and CME enabling the CUBE feature on ISR.
I recommend you to upgrade the IOS on your 2921 to have at least CME 10.0.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucmbe3k/8_6_3/system/BE3K_BK_C30C50F6_00_cucm-be3000-admin-guide/BE3K_BK_C30C50F6_00_cucm-be3000-admin-guide_chapter_01.html#BE3K_TP_SAEB67BA_00
Regards.
