12-18-2009 10:23 AM - edited 03-21-2019 01:56 AM
I have a uc520 configured with Skype Sip trunk.
Incoming calls on the trunk are forwarded to the auto attendant.
The auto attendant answer and plays the message Press 1, 2, 3 etc.
However when the calller enters the digits the auto attendant keeps playing the recording.
Any suggestions?
John
Solved! Go to Solution.
12-21-2009 02:43 PM
I think this issue is something we have seen in CCA when the access code for outbound calls is the same as the leading DID digit that we are looking to fix in a future CCA release. Options are:
1. Use a different access code which may not work for you (such as say 8)
2. Add below CLI and seeif this fixes your issue
dial-peer voice 1003 voip
dtmf-relay sip-notify rtp-nte
12-19-2009 03:42 PM
Does DTMF only fail inbound or outbound as well? To diagnose this further would need below:
https://supportforums.cisco.com/docs/DOC-9830
I know Ted Trentler had this issue but turned out to be a Skype gateway issue - check his comment below:
Dimitris, Skype had a mis-configuration on some of their SIP Gateways. They changed the config on all of the affected Gateways.
12-20-2009 12:07 PM
12-20-2009 09:51 PM
Need the config as well (link sent earlier has info on how to gather this) as I can see that the UC500 is not sending the RFC2833 event in the 200 OK to Skype which is not how CCA normally configures the UC500 for Skype for SIP
Snip of logs:
Inbound SIP INVITE from Skype:
024284: Dec 20 20:07:17.020: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:99051000000666@86.40.234.229:5060 SIP/2.0
m=audio 22438 RTP/AVP 18 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=rtpmap:101 telephone-event/8000
a=rtpmap:0 pcmu/8000
a=fmtp:18 annexb=no
Response from UC500 to INVITE is missing 101:
024622: Dec 20 20:07:17.160: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
m=audio 17974 RTP/AVP 0
c=IN IP4 86.40.234.229
a=rtpmap:0 PCMU/8000
a=ptime:20
12-21-2009 06:21 AM
12-21-2009 02:43 PM
12-22-2009 01:14 PM
Changing the access code isnt really and option.
I added the cli and it worked perfectly.
Thanks very much
John
