Guys,So there is a website talking about the 560, why wouldn't it be on the partner site to have us reading this.http://www.ciscogame.com/data/pub/akce_cbsw09_uc_tohorak.pdfThanks guys!Also I assume the 541N is the new N ap for SBS as well?
Hi all,I trying to upgrade a UC520 which was delivered with 12.4.11XW to the newest ios release (required for call accounting and SNR). When I try to download 12.4.20T2 which is marked as latest release, cisco recommend to download 12.4.20T3. 20T3 is...
Hello, Most our clients have SPA 2102 boxes and we are using T38 protocol for faxing. Everything is OK, when faxing with speed 9600 , but the problem appears if another side supports only 4800 speed. For example, one my client wants send fax to B nu...
Hi experts, I've a WRP400 configured via XML provisioning system.Phone configuration via provisioning works right while Router configuration is not applied. I've used wrp400-2-00-05-spc-win32-i386.exe tool to generate XML script. Where is the mistake...
hello all,i have voicemail enable to my UC520 but when a phone receive voice mail there are no alert to known this and the date of the voice mail is not okhow i can solve thisthanks
hey,sorry but i face the same problem and i really get confused, my CME version is 7.0 , so if we suppose that my CME IP address is : 192.168.11.1so what is the url exactly should be?thanks in advance
Hi,I had a client ask me if they could have access to the UC system to do moves, adds, changes, and I am unsure of the answer. Preferrably we would do those, but is there a way to give them restricted access to CCA or CUE to add a phone for example?T...
when using port 8443 (example) for httpaccess page at http://192.168.140.8:8443/go to Wi-Fi (or bluetooth or..... )when you want to go back to Voice it links incorrectly to http://192.168.140.8/
Hello,I want to make calls from my Dect phone connected to the FXS port of the SPA3102 thru FXO port. The PSTN line is connected to the FXO port. I have added the plan "<#,:>xx.<:@gw0>" to the dial plan of Line 1. When i dial "#" and after hearind di...
Hello,now I wan't to try receiving faxes.I adjusted my SPA3102 with the HowTo from 3CX to work as an ATA device on the fax extension with 3CX. I can dail numbers and the other fax machine is answering and I can receive calls from other fax machines. ...
Hi all,I'm now working on the planning of an IP Telephony solution, now the customer is asking me about the max ammount of analog phones i can conect to a single physical line of a FXS port ot ATA or VG, since the actual solution allows them to conne...
Hopfully some one at Cisco will see this post.I am the proud owner of a spa3102 and registered with the support website, but still I do not get support !!!It seems tht the questions asked or problem reported are treated as non comital discussion even...
I tried to copy the original Cisco flash 128MB device to disk on two different WinXP Pro machines with both a Belkin and a Sony Flash reader/writer butthe process fails uniformly with a "blue screen freeze." The fault lies with fastfat.sys according...
I'm having a problem with a UC520 not routing properly.I currently have 3 vlans. The two created by the UC,plus an addition vlan for retail customers.I'm able to connect and route data between the data and the retail, but when I try to get to the int...
I have a UC520 that intermittantly gives a fast busy signal when picking up a phone to make a call. It will clear, then happen again. I have reset the box several times, but the issue comes back. Any ideas?
