Smart CallConnector error with IE
steven1066
Level 4
Level 4
I have installed the Smart CallConnector for my UC560 and it is working form Outlook, however when I try to use it within IE I get the following error:
HTTP error occured, please contact your administrator.
What do I need to do to correct this?
Thanks in advance,
Steven
17 Replies 17
Alberto Montilla
Dear Steven;
I will escalate your case. Meanwhile, can you please tell us which IE version are you using as well as the OS version?
Alberto
Hi Steve,
Would you please send us the screenshot? Also, would you please try to right-click and disable the IEToolbar to see if the problem is still occurring? We'd like to know if this is a IE problem or IEtoolbar CallConnector issue.
steven1066
Level 4
Level 4
Sorry for the dealy.
No screen shot but it has been tested with XP Pro with SP3 along with IE8 and Firefox 6.
Steven
steven1066
Level 4
Level 4
Product Build Version = 2.01.012
ccPopup version = 2.1.0.115
Good morning,
I have the same problem with a UC540 installed two weeks ago.
Error is :-  HTTP error occurred, please contact your administrator.
When I tested it I was using XP pro with SP3 and I tested with IE 8     and firefox 6 and I got the same http error.
If someone can suggest what I can change on the client please let me know. Thanks in advance.
Stephen
Hi Stephen
It looks like that you have problem update the license to full-licensed. Do you have time for a webEx session so we can troubleshoot together. Please provide us your email address and let us know when would be good for you, then I'll forward you a webEx invitation.
CallConnector Team
Good morning,
Thanks for the reply. I will have a engineer on-site tomorrow. I will
first upgrade the license however what information will I need to
register on the client machines?
TIA
Stephen
Stephen Lockley
Security & IT Technical Consultant
Talkwire LTD
Talkwire Limited
T: 01225 899 861
F: 01225 790 154
M: 07970 692 920
E: stephen.lockley@talkwire.co.uk
W: www.talkwire.co.uk
*CAUTION - This message may contain privileged and confidential
information intended only for the use of the addressee named above. If
you are not the intended recipient of this message you are hereby
notified that any use, dissemination, distribution or reproduction of
this message is prohibited. If you have received this message in error
please notify Talkwire Limited immediately. Any views expressed in this
message are those of the individual sender and may not necessarily
reflect the views of Talkwire Limited or its associated companies.*
Stephen,
glad to hear that this is moving forward for you.
Please keep me posted on the progress by updating this discussion.
Much appreciated.
Steven
Steven,
I will keep you posted tomorrow.
Stephen
Hi Stephen,
We'll need to Click on Update License on the screenshot above and enter PAK-ID/Serial number to update from TRIAL to Full-Licensed.
If you need additional assistance, please send us email at cs-callconnector@external.cisco.com or ucc-beta@external.cisco.com or call us at (408) 335-0124
CallConnector Team
(408) 335-0124
Good evening,
Silly question. Where do I get the PAK-ID/Serial number from?
Stephen
Hi Stephen,
Have you purchased UCC/SCC licenses? From the screenshot, this UCC Client is using TRIAL and has 41 days left. If you purchase license, you should receive a Cisco Software Claim License Certificate.
Good morning,
No we did not get any licenses due to us being told that this was the
free version. I have asked for costs of the licenses.
I will let you know.
Stephen
Stephen,
Cisco Smart CallConnector Toolbar:
The Cisco Smart CallConnector Toolbar is available as a free download to resellers from the Cisco.com download site for Cisco Unified Communications 540 and 560 customers. No ordering required.
Note: this came direct from the data sheet for the toolbar
Cisco Smart CallConnector Advanced Client:
This is an orderable and chargeable item.  You do require a server for this to function.
Steven
