What is the appropriate header to send to a 525 to get it to 'auto-answer'?Assuming that the config settings are correct (Auto_Answer_Page = Yes, etc.), we have the following - * On the 504, if the incoming INVITE contains the header "Alert-Info...
After upgrading UC520 from Pack 7.0.3 to 8.1.0, MWI stopped workingExtension 222MWI On A800...MWI off A801...below is debug output from CUE2307 06/30 08:21:01.515 voicemail mwi "refreshMWI" 222 02307 06/30 08:21:01.541 voicemail mwi "setMessageWaitin...
Hi forumI'm testing a SPA504G. Seems mostly working quite well, but small problem with 2 channels.I have single voip line with 2 channels from voip provider.I need to have both channels active using Ext 1 and Ext 2 buttons, so that conference calls ...
Hello, I have a uc560 running and all is well. All phones registered under "show ephone reg". I can pull up the gui under /ccme.html and i see everything but phones. I can pull up the CUE gui and go under users and see the phones listed with thei...
Hi Is the ATA PAP2T compatible with the Cisco Callmanager Express, if yes wich versionthanks
I have a problem with a Voip solution between a SPA3102 and a PAP2T through a radio link. The communication disconnects/falls at random between minute 1 and minute 5. I tried the service quality and CCQ changes from 100% to 95% with only a 80 K bandw...
HelloI have an office with 3 analog lines, this lines are grouped in a PBX managed by the Telco company.I have connected 3 spa3102 to each one of these lines, and configured also sip extensions to an asterisk server.The sip part works very well, howe...
Anyone have or know where I can get the system requirements or email systems supported for the voicemail to email intergration? I was wondering what email systems this works with. for example verisons of exchange. I heard that you can't use a gma...
Hello,I was hoping to gain some assistance in editing the SPA504G's startup configuration file to disable the PC Port.I've edited a good amount of other settings in the XML configuration, however, I'm not sure what XML command I'd need to send in ord...
Hi all,We have a customer who has an existing UC540 and would like to purchase a PA system to interface into UC540. Can anyone recommend a particular model that interfaces seemlessly (FXS ports). Customer is located in Australia.Many Thanks
I have new one for you all! I have an auto attendant on a UC320W current firmware 2.0.9 (3) and when someone calls in using a Droid phone it does not recognize the tone when a user presses any key. Iphones, windows phones and landline based phones ...
Hi everyone.I'm looking for a cheap VoIP solution to make calls between 2 sites. These are actually been done using two 2800 ISR routers with VICs, acting as h.323 gateways. The sad story is that they have to go , because they're owned by our MPLS pr...
We have a company background on the phones but there is a space from right side for link buttons labels. I wonder if it would be possible to use on these labels narrow font as on softkey labels, to add more text and not overlap our company background...
We have a switchboard that is operated by three individuals using the attendent console application. Calls are routed using script and time of day. I'm looking to see if there is a way that if all operators were to leave for an emergency that a but...
Well, I have lots of the phones and I want effectively control and change their configurations.I decided to split configs to an overall config file (general parameters applied to all devices) and private config file with parameters especial for a ...
