10-11-2013 11:38 AM - edited 03-21-2019 07:50 AM
Good Day Everyone,
I have 4 brand new SAP 303 phones. Two of them worked fine. The other two get stuck in the "Initializing Network" stage and do not get an IP adress. I used the same port to provision the otehr phone so it isnt that. I have already tried turning off CDP and LLDP under Vlan settings as suggested in another discussion and no luck.
Any ideas?
Best Regards,
Eduardo
10-12-2013 02:35 PM
Either:
device didn't sent DHCP DISCOVER or REQUEST
or
such request is not delivered to DHCP server
or
DHCP server did not replied to the request
or
reply has not been delivered to device
or
reply is not recognized by device
Catch the packets on the wire and check DHCP server logs to identify which case apply to you. It will help you with further analysis.
05-02-2016 01:40 AM
Ciao Dan, can you suggest me a free software to do this?
05-02-2016 02:32 AM
It depend on operating system running on computer you have. But either tcpdump or wireshark should be correct answer for most of them.
Remember - if you have switched LAN the switch needs to be configured to deliver packets to computer running the software. Software can't catch packet not delivered to the computer running it, of course.
Ask your LAN administrator for help in doubt.
05-02-2016 02:59 AM
hello,
i solved the problem connecting to another router/lan/dhcp server
the problem was on the begininng lan
thanks for your suggestions
regards
05-02-2016 12:53 AM
i have the same problem...
did you solve it?
05-02-2016 01:30 AM
Same issue, same response. Follow the advice above.
07-12-2023 06:03 AM
Old thread, but I restarted the DHCP Server service and the phone came right up.
03-28-2024 02:19 AM - edited 04-06-2024 12:31 AM
I have four Cisco IP phones, and while two of them are functioning flawlessly, the other two seem to be stuck at the "Initializing Network" stage and fail to obtain an IP address. Strangely, I've provisioned all phones using the same port, ruling out any physical connectivity issues. Despite attempting to troubleshoot by disabling CDP and LLDP under VLAN settings as suggested in similar discussions of patchouli leaves.
