10-03-2010 01:15 PM - edited 03-21-2019 03:05 AM
Can someone help me with this? In my scrip, I need to give the caller an option to press 8 to repeat the menu all over again. Go back to the top.
How do I do that? I don't want to use the no input option, since I want the user to press something to go back to the menu again.
I thank you in advance.
10-05-2010 08:42 AM
Dear Sir;
Look at chapter 7, page 139 of the admin guide. There is an example of the directory...look at "case input" entry, this is what you need to use.
Regards;
Alberto
10-12-2010 02:42 PM
Thanks for your response. However, I looked at that section and couldn't find an ex
ample matching mine. Basically I want to do the repeat T f
unction, but not by waiting for a timeout. I want to do it by pressing a button.
They didn't have a similar example. Let me know if you have an further ideas or sugg
estion
