SPA phone locks up when accessing external directory
Brandon Svec
Level 7
Level 7
I was playing around with phone menus and noticed that if I press the dir soft key and then go to the corporate directory (3) and then to the external directory (2) and press dial soft key the phone will lock up and require power off and on to restore.  This was with a SPA508G.  Now this was with an empty screen since I had not entries in my external directory so there was no need for me to press dial, but it locks up the phone regardless.
Brandon
-- please remember to rate and mark answered helpful posts --
Hi Brandon,
Thank you for your feedback and reporting this problem.  Using your details instructions, I was able to reproduce the problem and have opened a bug with design to get this problem fixed.
Chris Edgeworth
