02-05-2020 01:11 PM
I've just acquired a SPA112 'phone adaptor (pre-owned), but it does not seem to be supplying any line feed to the 'phone - no voltage is discernable at the other end of a known-good RJ-11 lead. Have I missed something in the manual, or have I been sold a pup? I have tried setting 'Make Call Without Reg', but this has made no difference.
Solved! Go to Solution.
01-01-2022 02:23 AM
It appears that UK spec telephones with RJ-11 sockets have different wiring specs to US RJ-11 sockets.
UK has A-leg to pin 2, B-leg pin 5 and ringer pin 3; US has tip to pin 3, ring to pin 4.
An interim solution is to use existing line cord from telephone and RJ-11 to BT431 (modem) cord from SPA112 and connect two BT431 plugs together in back-to-back or 'socket doubler' sockets.
02-06-2020 12:40 AM
Analog interface power can't be turned off at all, as far as I know.
Even in the case I'm wrong - it's powered for sure when SPA112 have factory default configuration (because phone can be used to make initial configuration of network settings)..
02-07-2020 12:12 PM
01-01-2022 02:23 AM
