03-22-2012 11:12 AM - edited 03-21-2019 09:45 AM
http://172.26.0.102/admin/upgrade?http://<MI_IP_SERVER>/firmware/SPA1xx_1.1.0_011.bin
Not Found (404)
File not found.
doesn work. I have try with and without /admin/. In the apache logs there is not a log. This Not Found comes from the spa.
This is very useful function because the user does not need to log into the spa or download the firmware to his/her computer.
Thank you, Diego
03-22-2012 02:58 PM
Hi Diego,
I don't have a solution for you, but can offer a workaround.
1. Add an upgrade rule to the ATA's configuration file.
2. Use the resync rule that I describe here:
https://supportforums.cisco.com/message/3594099#3594099
The ATA will resync and find that it needs to upgrade, it will then upgrade and you'll be set.
Patrick
03-23-2012 05:59 AM
yes we already have this in Upgrade Rule:
( $SWVER < 1.1.0)? http://
is that is nice to upgrade first and then configure: all the parameters are understood, etc..
But thank you.
