SPA112 SIP brute force attack
glstewart23
Last week, my SPA112 was suddenly unable to receive incoming calls. The LAN traffic light was flashing continuously and SIP stats were showing over 1 GB data received per day.
My VOIP provider, CallCentric, ran through several troubleshooting steps over the course of a day but was unable to resolve the issue.
I discovered that the SPA112 device was the victim of a SIP brute force attack.
I initially assigned the device to a new IP address, which restored my ability to receive calls, but the attack on the original IP address continued. The UDP traffic was flooding my DSL connection.
I was able to reconfigure my router to drop the incoming traffic, but as an experiment, I reassigned the attacked IP address to a PC and used Wireshark to discover what the packets were and where they were coming from. In the following trace, I have replaced the attacker's IP address with <ATTACKER-IP> and the SPA112's IP address (attacked address) with <SPA112-IP>.
No.     Time        Source                Destination           Protocol Length Info
  34002 222.535423  <ATTACKER-IP>        <SPA112-IP>         SIP      401    Request: REGISTER sip:<SPA112-IP>
Frame 34002: 401 bytes on wire (3208 bits), 401 bytes captured (3208 bits)
Ethernet II, Src: Motorola_fc:d5:10 (00:1c:fb:fc:d5:10), Dst: HewlettP_b9:da:59 (18:a9:05:b9:da:59)
Internet Protocol Version 4, Src: <ATTACKER-IP> (<ATTACKER-IP>), Dst: <SPA112-IP> (<SPA112-IP>)
User Datagram Protocol, Src Port: alesquery (5074), Dst Port: sip (5060)
Session Initiation Protocol
    Request-Line: REGISTER sip:<SPA112-IP> SIP/2.0
        Method: REGISTER
        Request-URI: sip:<SPA112-IP>
        [Resent Packet: False]
    Message Header
        Via: SIP/2.0/UDP 127.0.0.1:5074;branch=z9hG4bK-3910607681;rport
        Content-Length: 0
            SIP Display info: "3775708062"
            SIP from address: sip:3775708062@<SPA112-IP>
                SIP from address User Part: 3775708062
                SIP from address Host Part: <SPA112-IP>
        Accept: application/sdp
        User-Agent: friendly-scanner
        To: "3775708062" <sip:3775708062@<SPA112-IP>>
            SIP to address: sip:3775708062@<SPA112-IP>
                SIP to address User Part: 3775708062
                SIP to address Host Part: <SPA112-IP>
        Contact: sip:123@1.1.1.1
            Contact-URI: sip:123@1.1.1.1
        CSeq: 1 REGISTER
        Call-ID: 211458778
        Max-Forwards: 70
I googled the packet contents and discovered the attacker was likely using "SIPvicious" (as evidenced by "friendly-scanner").
I was able to use the Ruby script on the following web site to stop the SIP brute force attack.
http://jcs.org/notaweblog/2010/04/11/properly_stopping_a_sip_flood/
I replaced
s.bind(nil, 5061)
with
s.bind("<SPA112-IP>",5060)
and ran the script with
ruby stopsip.rb
Sure enough, the traffic stopped, and has not returned.
Here's the entire script. Replace <SPA112-IP> with the attacked IP address.
[stopsip.rb]
require "socket"
s = UDPSocket.new
while true
  packet = s.recvfrom(1024)
  via = packet[0].match(/Via: (.+);rport/)[1]
  from = packet[0].match(/From: (.+)/)[1]
  to = packet[0].match(/To: (.+)/)[1]
  call_id = packet[0].match(/Call-ID: (.+)/)[1]
  cseq = packet[0].match(/CSeq: (\d+) REGISTER/)[1]
  remote_ip = packet[1][3]
  remote_port = packet[1][1].to_i
  puts packet.inspect
  if packet[0].match(/^REGISTER /)
    ret = "SIP/2.0 200 OK\r\n" +
      "Via: #{via};received=#{remote_ip}\r\n" +
      "From: #{from}\r\n" +
      "To: #{to}\r\n" +
      "Call-ID: #{call_id}\r\n" +
      "CSeq: #{cseq.to_i + 1} REGISTER\r\n" +
      "\r\n"
    puts "sending to #{remote_ip}:#{remote_port}:\n#{ret}"
    s.send(ret, 0, remote_ip, remote_port)
  end
end
I have since discovered an option on the SPA112, under Voice, Line 1, called Restrict Source IP. It was set to No (default), and I have changed it to Yes. We'll see if this option helps avoid future attacks. At least I know what to do next time.
nseto
Level 6
Level 6
Thanks for the info.
For others, who want the info on the Restrict Source IP, the admin guide states...
If Lines 1 and 2 use the same SIP Port value and the
Restrict Source IP feature is enabled, the proxy IP address
for Lines 1 and 2 is treated as an acceptable IP address for
both lines. To enable the Restrict Source IP feature, select
yes. Otherwise, select no. If configured, the PAP2T will
drop all packets sent to its SIP Ports originated from an
untrusted IP address. A source IP address is untrusted if it
does not match any of the IP addresses resolved from the
configured Proxy (or Outbound Proxy if Use Outbound
Proxy is yes).
The default is no.
Very Interesting!  Good to know.
I just set my SPA2102 to Restrict Source IP to see if I notice any issues.
Tks for bringing this up.
