spa122 - ignore password parameters in provisioning file
rpingar
Hi we are testing spa122 to implement it into our voip network.
The problem we have found is about password parameters ignored in xml provisiong file, the same using the spc.
The two parameters are:
<Web_Login_Admin_Password>voip_test</Web_Login_Admin_Password>
<Web_Login_Guest_Password>convergenze</Web_Login_Guest_Password>
After the profile is loaded no change in password about the two users.
I am not able to log any error from the ata when it load the profile.
Any help is appreciated.
regards
Ros
6 Replies 6
nseto
Level 6
Level 6
Check to see that
is around those parameters.
HI
cant find any documentation on this , spc xml does not include anything.
The xml below is accepted but ignored (web admin password not set)
        aaaaaa
        gggggg
    1234
    Yes
Try this:
    1234
    Yes
        aaaaaa
        gggggg
Regards.
Hi All,
The parameter does not get applied in 1.1.0(011) firmware. I've filed CDETS# CSCtz76693 against this issue. The fix is in firmware that is yet to be released.
Patrick
we have 1.2.0(33) and it is working fine,
in earlier relase we experienced the issue.
regards
Ing. Rosario Pingaro
Presidente
mobile +39 348 8329287
diretto +39 0828 1996000
rpingar@convergenze.it Convergenze S.p.a.Via Magna Graecia, 71 - 84047 Capaccio Scalo (SA)
numero verde 800 987 787
fax +39 0828 1962100
info@convergenze.it
www.convergenze.it
Convergenze spa - D. Lgs 196/2003
Il presente messaggio contiene informazioni confidenziali, indirizzate esclusivamente alle persone sopra indicate. Se il ricevente non è tra dette persone, non dovrà intraprendere alcuna azione, tipo copia, stampa o trasmettere il suo contenuto a terzi ed i relativi allegati, ma solo informare il mittente dell'errore e cancellare il messaggio. Il destinatario dovrà altresì accertarsi che gli allegati non contengano virus prima di aprirli.
    1234
    Yes
        aaaaaa
        gggggg
From our development team -
That’s not legal xml. There must be a single root node above those 2 nodes or an XML parser will reject it as invalid XML.
Our XML is generated dynamically using a rules based engine
