SPA122 - provisioning - long time before getting file from Profile_Rule
firmaleon
Recently we have configured provisioning for SPA122 and we're trying to do something to fasten provisioning...
We're connecting new out-of-box ATAs to our local network. ATA is getting IP and DHCP option 66 (tftp-server) from our dhcp server.... It takes about 5-6 minutes before SPA requests for spa122.cfg file from tftp server...
Whole provisioning process (initial config, firmware upgrade to 1.2.0.023 beta firmware and then full config from web server) took more than 10 minutes. With spa 2102 it tooks max 2 minutes (without firmware upgrade), so it was a lot faster...
Try to adjust this value:
60
Regards.
Ok. But It doesn't fix the gap between assigning ip address from dhcp server and requesting spa122.cfg file by ATA... As i said before that gap is about 5-6 minutes.
I have managed to force spa122 to take spa122.cfg and its configuration file in 1,5 minutes but i still have a problem later. It takes 7 minutes for firmware upgrade, and the worst is that same spa122 upgrades firmware every time even if that firmware is already on it. Spa2102 takes same firmware only once! How to deal with that?
Here is mine spa122.cfg file, hope it helps...
http://www.sipura.net/xsd/SPA122" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.sipura.net/xsd/SPA122 http://www.sipura.net/xsd/SPA122/SPA122-1-2-0-028.xsd">
/spa$SN.cfg
Please help with firmware issue!
