SPA2102: 2 account on 1 line
mprenditore
Hi, I've bought a SPA2102 yesterday, and I've upgraded it to the lastest available firmware version: 5.2.12.
I've configured and tested it and everythings work fine, but I would like to know if there is the possibility to have 2 Voip account on only 1 line. I will explain better that:
Every Voip operators have pro and con, so I've found an operator which let me still have my home number with portability and free national calls, and another witch have very cheap rates for mobile.
Now, I've 6 phone in my house, and I would like to use "OP1" (which one with portability) to receive voice calls and do national calls, and "OP2" to make mobile calls.
If which I know is correct this should be possible by setting DialPlans, but I don't know how.
Anybody can help me to make right my configuration?
Alternatively I should use 2 different lines, one with one OP1 and the other with OP2, but I prefer only 1 line.
Best Regards,
Stefano
In my experience, on SPA2102 there is no way to load two account per line.
One line = one account.
You must use 2 different lines, one with the first provider and the other with your second one.
Regards.
