SPA3102 - Connecting to PSTN line but not dialing
mecitbilir78
I want to make calls from my Dect phone connected to the FXS port of the SPA3102 thru FXO port. The PSTN line is connected to the FXO port. I have added the plan "<#,:>xx.<:@gw0>" to the dial plan of Line 1. When i dial "#" and after hearind dial tone "xxxxxxx" from phone, i see that SPA3102 is connected to PSTN on the Info Tab of administration page. But it never dial the number on PSTN line, and i don't receive any calls, ring at the opposite side. For about 15 seconds, it gives dial tone and then busy tone to me.
I can receive calls from pstn line, and i can make calls thru VOIP.
Can you please help me, what configuration should i change?
7 Replies 7
Alberto Montilla
Dear Sir;
If there any way you can provide us with the syslog information of the ATA? there could be multiple causes for your issue, the easiest is to check the syslog.
Alberto
Thank you for your quick answer.
I have attached the syslog which was generated while trying to call thru PSTN.
I hope it will be useful.
Dear Sir;
This must be a config issue as I see calls going and coming, so not actually an issue of the device. Could you please send me the configuration of the device in admin/advanced mode? (same the full html page). Please send it via a private message.
Alberto
Exact same problem, the log shows that the 3102 is trying to dial via the non configured "sip gatway" of the PSTN interface instead of the POTS port.
Can somone explain how to set up the PSTN screen in order for the calls to gw0 to be routed on the POTS
Gabriel
DIAL Plan:
011x.<:@gw1>|0<:@gw0>|[2-79]11<:@gw0>||xx*|*xx|xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.
|<#9,:>xx.<:@gw0>)
Log:
Nov 15 08:47:56 192.168.1.101 [0]Off Hook
Nov 15 08:47:58 192.168.1.101 2. Report digit # (1)(40 ms)
Nov 15 08:47:59 192.168.1.101 2. Report digit 9 (1)(40 ms)
Nov 15 08:47:59 192.168.1.101 [0]PlayOutDial 1
Nov 15 08:48:00 192.168.1.101 2. Report digit 9 (1)(40 ms)
Nov 15 08:48:01 192.168.1.101 2. Report digit 0 (1)(40 ms)
Nov 15 08:48:01 192.168.1.101 2. Report digit 5 (1)(40 ms)
Nov 15 08:48:01 192.168.1.101 2. Report digit 8 (1)(40 ms)
Nov 15 08:48:02 192.168.1.101 2. Report digit 8 (1)(40 ms)
Nov 15 08:48:02 192.168.1.101 2. Report digit 1 (1)(40 ms)
Nov 15 08:48:02 192.168.1.101 2. Report digit 7 (1)(40 ms)
Nov 15 08:48:03 192.168.1.101 2. Report digit 1 (1)(40 ms)
Nov 15 08:48:03 192.168.1.101 2. Report digit 3 (1)(40 ms)
Nov 15 08:48:06 192.168.1.101 Calling:9058817133@127.0.0.1:5061
Nov 15 08:48:06 192.168.1.101 [0:0]AUD ALLOC CALL (port=16396)
Nov 15 08:48:06 192.168.1.101 [0:0]RTP Rx Up
Nov 15 08:48:06 192.168.1.101 [0]->127.0.0.1:5061(897)
Nov
15 08:48:06 192.168.1.101 ;tag=b4961bf514264e1bo0 To:
<9058817133> Remote-Party-ID: 9994172560
<>9994172560@CMTor1.ciktel.com>;screen=yes;party=calling
Call-ID: ae518c7d-734a5733@192.168.1.101 CSeq: 101 INVITE Max-Forwards:
70 Contact: 9994172560 <9994172560>
Expires: 120 User-Agent: Linksys/SPA3102-5.1.10(GW) Content-Length: 251
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura, replaces Content-Type: application/sdp v=0 o=-
3853 3853 IN IP4 192.168.1.101 s=- c=IN IP4 192.168.1.101 t=0 0 m=audio
16396 RTP/AVP 0 100 101 a=rtpmap:0 PCMU/8000 a=rtpmap:100 NSE/8000
a=fmtp:100 192-193 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15
a=ptime:30 a=sendrecv
Dear Sir;
Can you please set the rule|<#9,:>xx.<:@gw0>) on the left of the dial plan (at the beginning), just want to make sure the dial plan is reading first another entry which may be in conflict.
Alberto
Thank for your attention,
Done as suggested, see trace below. Still the call that supposed to go out on gw0 / POTS port is sent to "127.0.0.1:5061"
Just in case I attached the config of the ATA.
dial plan is re ordered:
(011x.<:@gw1>|0<:@gw0>|[2-79]11<:@gw0>||xx*|*xx|xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.|<#9,:>xx.<:@gw0>)
To:
(<#9,:>xx.<:@gw0>|011x.<:@gw1>|0<:@gw0>|[2-79]11<:@gw0>||xx*|*xx|xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
Trace:
Nov 17 07:26:07 192.168.1.101 DLG Terminated 2eb858
Nov 17 07:26:07 192.168.1.101 [0]Off Hook
Nov 17 07:26:08 192.168.1.101 2. Report digit # (1)(40 ms)
Nov 17 07:26:09 192.168.1.101 2. Report digit 9 (1)(40 ms)
Nov 17 07:26:09 192.168.1.101 [0]PlayOutDial 1
Nov 17 07:26:10 192.168.1.101 2. Report digit 4 (1)(40 ms)
Nov 17 07:26:10 192.168.1.101 2. Report digit 1 (1)(40 ms)
Nov 17 07:26:10 192.168.1.101 2. Report digit 6 (1)(40 ms)
Nov 17 07:26:12 192.168.1.101 2. Report digit 5 (1)(40 ms)
Nov 17 07:26:13 192.168.1.101 2. Report digit 8 (1)(40 ms)
Nov 17 07:26:13 192.168.1.101 2. Report digit 5 (1)(40 ms)
Nov 17 07:26:15 192.168.1.101 2. Report digit 5 (1)(40 ms)
Nov 17 07:26:15 192.168.1.101 2. Report digit 8 (1)(40 ms)
Nov 17 07:26:17 192.168.1.101 2. Report digit 0 (1)(40 ms)
Nov 17 07:26:17 192.168.1.101 2. Report digit 2 (1)(40 ms)
Nov 17 07:26:20 192.168.1.101 Calling:4165855802@127.0.0.1:5061
Nov 17 07:26:20 192.168.1.101 [0:0]AUD ALLOC CALL (port=16404)
Nov 17 07:26:20 192.168.1.101 [0:0]RTP Rx Up
Nov 17 07:26:20 192.168.1.101 [0]->127.0.0.1:5061(899)
Nov 17 07:26:20 192.168.1.101 ;tag=971df0d4879af597o0  To: <>4165855802@127.0.0.1:5061>  Remote-Party-ID: 9994172560 <>9994172560@CMTor1.ciktel.com>;screen=yes;party=calling  Call-ID: 77e23b58-fc0d8ce3@192.168.1.101  CSeq: 101 INVITE  Max-Forwards: 70  Contact: 9994172560 <9994172560>  Expires: 120  User-Agent: Linksys/SPA3102-5.1.10(GW)  Content-Length: 253  Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER  Supported: x-sipura, replaces  Content-Type: application/sdp    v=0  o=- 73180 73180 IN IP4 192.168.1.101  s=-  c=IN IP4 192.168.1.101  t=0 0  m=audio 16404 RTP/AVP 0 100 101  a=rtpmap:0 PCMU/8000  a=rtpmap:100 NSE/8000  a=fmtp:100 192-193  a=rtpmap:101 telephone-event/8000  a=fmtp:101 0-15  a=ptime:30  a=sendrecv
Dear Sir;
I would suggest you do the following:
(1) Please downgrade the device to 5.1.7 and then factory reset it (this would require you type in again your dial plan and configuration, so please save the config before doing the factory reset).
(2) Reconfigure the device and try again.
There is a bug on 5.1.10 which may be causing the issue, so I suggest we continue the debug on 5.1.7 to ensure this is not related to this other bug.
The config is showing like the PSTN line is not connected.
Alberto
