SPA400 do not detect french CallerID
h.eiselt
I am using a SPA400 on France Telecom PSTN line.
But it gets only from ~ each second incoming call the CID.
Before I used a SPA3102 without any problem.
I tried to use the same values of the SPA3102 in the SPA400.
But in the SPA400 I do not have the same values, which I need to setup correctly the CID detection.
Here the values which works fine with a  SPA3102 in France :
"Ring1  Cadence" : 2.25(.25/2);60(2/3.5)
"Ring Waveform" : Sinusoid
"Ring Frequency" : 50
"Ring Voltage" : 70
"FXS Port Impedance" :  270+750||150nF
"Caller ID Method" : Bellcore
"Caller ID FSK Standard" : bell  202.
In the SPA400 I changed only the
"Impedance:" 270+750||150nF
How can I configure the SPA400 correctly with the values for France ?
25 Replies 25
Thank you my friend
i'll give it a try and i will let you know if it works
i've tested over 10 different configurations without results
After a lot of days and testing different settings
I still can’t get CID working (SPA400)
The only setting that seemed to do something was
changing “Caller ID/CP Tone Method” to European (FSK)
it was displaying our lines number instead of anonymous caller
but then I get delay on first ring (line rings 4-5 times before it gets to the phones)
as I read Hellenic Telecommunications Organization (OTE) uses FSK for CID
Dear Sir;
Please ensure SPA400 is configured according to the following document.
/docs/DOC-9873
Regards;
Alberto
Dear Sir,
I can confirm that this doc settings did/do NOT work for France on France Telecom PSTN lines nor on the ISP Routers FXO port.
Dear Sir;
Thanks for the highlight, will get the team to double check the values.
Alberto
Does anyone can Solve the problem for french caller ID ???
configuration : SPA400 - SPA9000 - SPA962...
Dear Sir;
With the BETA firmware France caller ID works with the proper configuration (ETSI FSK).
Regards;
Alberto
Dear Mr Montilla,
Thank you for your answer, but of couse, before ask you, I try the firmware 1.1.2.3, But I can't find the configuration "ETSI -FSK", there is "ETSI-DTMF" or "European (FSK)" (see file "Caller ID-CP Tone Methode List.jpg)
I join you my Voice parameter... If it's correct, is it possible than the problem come from the SPA9000 or the ip-phone (like SPA62 ?) ?
Nicolas MERIAN
Dear Sir;
Please use European (FSK). Submit and reboot the unit.
Alberto
Mr Montilla,
Of course I already try with the "EuropeanFSK"... And It doesn't wwork.
How can I check if :
1. the SPA400 correctly receive the CallerID from FranceTelecom ?
2. the SPA9000 correctly receive the CallerID from the SPA400 ?
3. The SPA962 correclty receive the CallerID from the SPA9000 ?
Maybe the SPA400 is correctly configure, but the SPA9000 and/or the SPA962 aren't...
Nicolas MERIAN
News : Apparently the SPA900 doesn't receive the CallerID from the SPA400 (see attachement : SPA9000 PBX Statuts during an incoming call)
Ce message a été modifié par: nmerian le 17 Septembre 2010
News 2 : I also send you the syslog of the SPA400 during an incoming call : Telephony, SIP and DSP, all information...
Mister Montilla ??
Can you check my configuration and tell me why it doesn't work please ??
regards,
Nicolas MERIAN
