ā10-06-2020 12:55 AM - edited ā10-06-2020 02:34 AM
I had configured my phone as sip extension in freePBX, but now because sip became legacy I configured it as pjsip. Since then Mark Answered Elsewhere does not work. No other problems.
Are there any settings in webui of my phone to check or change to make it work?
Thank you!
Solved! Go to Solution.
ā12-01-2020 12:28 AM
Definitely firmware bug. I assume code function like "fetch Reason header line" which returns single line only - and it's not the one recognized as "Answered Elsewhere" event. While you may report it to Cisco, your chances it will be patched in reasonable time are very low.
It seems you are not only user affected. Read suppress_q850_reason_headers
Hope it will help.
ā10-06-2020 07:56 AM - edited ā10-06-2020 07:56 AM
Could you be more specific and explain what exactly is not working?
Martin
ā10-06-2020 01:28 PM
With "Mark Answered Elsewhere" in freePBS Incoming route settings, when I have an incoming call and someone answers from a phone the other phones show Missed call for that answered call although this shouldn't happen. Some days ago, maybe till the day I changed the configuration of the extensions (phones) on freePBX from sip to pjsip it worked without problems.
ā10-06-2020 10:18 PM
Yes, it has been clear already.
Catch SIP packets between freePBX and SPA504G. We are interested to see content of SIP CANCEL packet sent by freePBX to SPA504G (the one not answering the call).
ā10-06-2020 11:15 PM - edited ā10-07-2020 12:12 AM
"Mark Answered Elsewhere" was working without problems when phones are configured using sip in freepbx. But because sip is not supported anymore I configured my phones as pjsip. Since then "Mark Answered Elsewhere" does not work. Maybe it is a coinsidence.
Where can I find SIP CANCEL packet sent by freePBX to SPA504G logs to post it here?
ā10-07-2020 12:27 AM
You should execute debug sip commands on your freePBX when initiating a call. Depending on your PBX you may have different debug command compared to Cisco. For instance, with Cisco you do have around 10 debug ccsip commands which can give you all the information needed. Those are debug ccsip error, debug ccsip states, debug ccsip events, etc. (a bit of detailed explanation here: https://community.cisco.com/t5/collaboration-voice-and-video/sip-debugging-commands-overview/ta-p/3155271)
So if your freePBX is capable of doing similar debugging you can log these debug outputs and send it over.
Martin
ā10-08-2020 02:04 AM
Does this log help? Extesion 31 shows 2 missed calls that was answered on extension 32 or 33.
14158 [2020-10-08 12:00:16] VERBOSE[16347] pbx_variables.c: Setting global variable 'SIPDOMAIN' to '192.168.1.5' 14159 [2020-10-08 12:00:16] VERBOSE[16347] netsock2.c: Using SIP RTP Audio TOS bits 184 14160 [2020-10-08 12:00:16] VERBOSE[16347] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 14161 [2020-10-08 12:00:16] VERBOSE[16347] netsock2.c: Using SIP RTP Audio CoS mark 5 14162 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:1] Macro("PJSIP/31-0000093f", "user-callerid,LIMIT,EXTERNAL,") in new stack 14163 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:1] Set("PJSIP/31-0000093f", "TOUCH_MONITOR=1602147616.3255") in new stack 14164 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:2] Set("PJSIP/31-0000093f", "AMPUSER=31") in new stack 14165 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:3] Set("PJSIP/31-0000093f", "HOTDESCKCHAN=31-0000093f") in new stack 14166 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:4] Set("PJSIP/31-0000093f", "HOTDESKEXTEN=31") in new stack 14167 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:5] Set("PJSIP/31-0000093f", "HOTDESKCALL=0") in new stack 14168 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:6] ExecIf("PJSIP/31-0000093f", "0?Set(HOTDESKCALL=1)") in new stack 14169 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:7] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(name)=)") in new stack 14170 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:8] GotoIf("PJSIP/31-0000093f", "0?report") in new stack 14171 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:9] ExecIf("PJSIP/31-0000093f", "1?Set(REALCALLERIDNUM=31)") in new stack 14172 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:10] Set("PJSIP/31-0000093f", "AMPUSER=31") in new stack 14173 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:11] GotoIf("PJSIP/31-0000093f", "0?limit") in new stack 14174 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:12] Set("PJSIP/31-0000093f", "AMPUSERCIDNAME=grafeio") in new stack 14175 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:13] ExecIf("PJSIP/31-0000093f", "0?Set(__CIDMASQUERADING=TRUE)") in new stack 14176 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:14] GotoIf("PJSIP/31-0000093f", "0?report") in new stack 14177 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:15] Set("PJSIP/31-0000093f", "AMPUSERCID=31") in new stack 14178 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:16] Set("PJSIP/31-0000093f", "__DIAL_OPTIONS=HhTtr") in new stack 14179 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:17] Set("PJSIP/31-0000093f", "CALLERID(all)="grafeio" <31>") in new stack 14180 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:18] ExecIf("PJSIP/31-0000093f", "0?Set(CUSDIAL=)") in new stack 14181 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:19] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(all)="grafeio" <31>)") in new stack 14182 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:20] GotoIf("PJSIP/31-0000093f", "0?limit") in new stack 14183 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:21] ExecIf("PJSIP/31-0000093f", "1?Set(GROUP(concurrency_limit)=31)") in new stack 14184 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:22] ExecIf("PJSIP/31-0000093f", "0?Set(CHANNEL(language)=)") in new stack 14185 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:23] NoOp("PJSIP/31-0000093f", "Macro Depth is 1") in new stack 14186 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:24] GotoIf("PJSIP/31-0000093f", "1?report2:macroerror") in new stack 14187 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-user-callerid,s,25) 14188 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:25] GotoIf("PJSIP/31-0000093f", "1?continue") in new stack 14189 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-user-callerid,s,44) 14190 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:44] Set("PJSIP/31-0000093f", "CALLERID(number)=31") in new stack 14191 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:45] Set("PJSIP/31-0000093f", "CALLERID(name)=grafeio") in new stack 14192 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:46] GotoIf("PJSIP/31-0000093f", "0?cnum") in new stack 14193 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:47] Set("PJSIP/31-0000093f", "CDR(cnam)=grafeio") in new stack 14194 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:48] Set("PJSIP/31-0000093f", "CDR(cnum)=31") in new stack 14195 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:49] Set("PJSIP/31-0000093f", "CHANNEL(language)=en") in new stack 14196 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:2] Gosub("PJSIP/31-0000093f", "sub-record-check,s,1(out,6977529545,force)") in new stack 14197 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:1] GotoIf("PJSIP/31-0000093f", "0?initialized") in new stack 14198 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:2] Set("PJSIP/31-0000093f", "__REC_STATUS=INITIALIZED") in new stack 14199 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:3] Set("PJSIP/31-0000093f", "NOW=1602147616") in new stack 14200 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:4] Set("PJSIP/31-0000093f", "__DAY=08") in new stack 14201 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:5] Set("PJSIP/31-0000093f", "__MONTH=10") in new stack 14202 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:6] Set("PJSIP/31-0000093f", "__YEAR=2020") in new stack 14203 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:7] Set("PJSIP/31-0000093f", "__TIMESTR=20201008-120016") in new stack 14204 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:8] Set("PJSIP/31-0000093f", "__FROMEXTEN=31") in new stack 14205 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:9] Set("PJSIP/31-0000093f", "__MON_FMT=wav") in new stack 14206 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:10] NoOp("PJSIP/31-0000093f", "Recordings initialized") in new stack 14207 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:11] ExecIf("PJSIP/31-0000093f", "0?Set(ARG3=dontcare)") in new stack 14208 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:12] Set("PJSIP/31-0000093f", "REC_POLICY_MODE_SAVE=") in new stack 14209 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:13] ExecIf("PJSIP/31-0000093f", "0?Set(REC_STATUS=NO)") in new stack 14210 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:14] GotoIf("PJSIP/31-0000093f", "3?checkaction") in new stack 14211 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,s,17) 14212 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:17] GotoIf("PJSIP/31-0000093f", "1?sub-record-check,out,1") in new stack 14213 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,out,1) 14214 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:1] NoOp("PJSIP/31-0000093f", "Outbound Recording Check from 31 to 6977529545") in new stack 14215 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:2] Set("PJSIP/31-0000093f", "RECMODE=dontcare") in new stack 14216 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:3] ExecIf("PJSIP/31-0000093f", "1?Goto(routewins)") in new stack 14217 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,out,7) 14218 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:7] Gosub("PJSIP/31-0000093f", "recordcheck,1(force,out,6977529545)") in new stack 14219 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("PJSIP/31-0000093f", "Starting recording check against force") in new stack 14220 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("PJSIP/31-0000093f", "force") in new stack 14221 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,recordcheck,5) 14222 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:5] Set("PJSIP/31-0000093f", "__REC_POLICY_MODE=FORCE") in new stack 14223 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:6] GotoIf("PJSIP/31-0000093f", "1?startrec") in new stack 14224 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,recordcheck,16) 14225 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:16] NoOp("PJSIP/31-0000093f", "Starting recording: out, 6977529545") in new stack 14226 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:17] Set("PJSIP/31-0000093f", "__CALLFILENAME=out-6977529545-31-20201008-120016-1602147616.3255") in new stack 14227 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:18] MixMonitor("PJSIP/31-0000093f", "2020/10/08/out-6977529545-31-20201008-120016-1602147616.3255.wav,abi(LOCAL_MIXMON_ID),") in new stack 14228 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:19] Set("PJSIP/31-0000093f", "__MIXMON_ID=0x7f00ac00d220") in new stack 14229 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:20] Set("PJSIP/31-0000093f", "__RECORD_ID=PJSIP/31-0000093f") in new stack 14230 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:21] Set("PJSIP/31-0000093f", "__REC_STATUS=RECORDING") in new stack 14231 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:22] Set("PJSIP/31-0000093f", "CDR(recordingfile)=out-6977529545-31-20201008-120016-1602147616.3255.wav") in new stack 14232 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:23] Return("PJSIP/31-0000093f", "") in new stack 14233 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:8] Return("PJSIP/31-0000093f", "") in new stack 14234 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:3] ExecIf("PJSIP/31-0000093f", "0 ?Set(CDR(accountcode)=)") in new stack 14235 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:4] Set("PJSIP/31-0000093f", "_ROUTEID=1") in new stack 14236 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:5] Set("PJSIP/31-0000093f", "_ROUTENAME=Calls") in new stack 14237 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:6] Set("PJSIP/31-0000093f", "MOHCLASS=default") in new stack 14238 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:7] Set("PJSIP/31-0000093f", "_CALLERIDNAMEINTERNAL=grafeio") in new stack 14239 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:8] Set("PJSIP/31-0000093f", "_CALLERIDNUMINTERNAL=31") in new stack 14240 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:9] Set("PJSIP/31-0000093f", "_EMAILNOTIFICATION=FALSE") in new stack 14241 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:10] Set("PJSIP/31-0000093f", "_NODEST=") in new stack 14242 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:11] Macro("PJSIP/31-0000093f", "dialout-trunk,1,6977529545,,off") in new stack 14243 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:1] Set("PJSIP/31-0000093f", "DIAL_TRUNK=1") in new stack 14244 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:2] ExecIf("PJSIP/31-0000093f", "0?Set(DIAL_OPTIONS=Hhtr)") in new stack 14245 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:3] GosubIf("PJSIP/31-0000093f", "0?sub-pincheck,s,1()") in new stack 14246 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:4] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(num)=31)") in new stack 14247 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:5] GotoIf("PJSIP/31-0000093f", "0?disabletrunk,1") in new stack 14248 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:6] Set("PJSIP/31-0000093f", "DIAL_NUMBER=6977529545") in new stack 14249 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:7] Set("PJSIP/31-0000093f", "DIAL_TRUNK_OPTIONS=HhTtr") in new stack 14250 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:8] Set("PJSIP/31-0000093f", "OUTBOUND_GROUP=OUT_1") in new stack 14251 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:9] Set("PJSIP/31-0000093f", "DIAL_TRUNK_OPTIONS=T") in new stack 14252 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:10] GotoIf("PJSIP/31-0000093f", "1?nomax") in new stack 14253 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-dialout-trunk,s,12) 14254 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:12] GotoIf("PJSIP/31-0000093f", "0?skipoutcid") in new stack 14255 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:13] Macro("PJSIP/31-0000093f", "outbound-callerid,1") in new stack 14256 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:1] NoOp("PJSIP/31-0000093f", "31") in new stack 14257 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:2] NoOp("PJSIP/31-0000093f", "") in new stack 14258 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:3] NoOp("PJSIP/31-0000093f", "off") in new stack 14259 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:4] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(name-pres)=)") in new stack 14260 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:5] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(num-pres)=)") in new stack 14261 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:6] Set("PJSIP/31-0000093f", "HOTDESCKCHAN=31-0000093f") in new stack 14262 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:7] Set("PJSIP/31-0000093f", "HOTDESKEXTEN=31") in new stack 14263 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:8] Set("PJSIP/31-0000093f", "HOTDESKCALL=0") in new stack 14264 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:9] ExecIf("PJSIP/31-0000093f", "0?Set(HOTDESKCALL=1)") in new stack 14265 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:10] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(name)=)") in new stack 14266 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:11] Set("PJSIP/31-0000093f", "ALLOWTHISROUTE=NO") in new stack 14267 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:12] ExecIf("PJSIP/31-0000093f", "0?Set(ALLOWTHISROUTE=YES)") in new stack 14268 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:13] ExecIf("PJSIP/31-0000093f", "0?Hangup()") in new stack 14269 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:14] ExecIf("PJSIP/31-0000093f", "0?Set(REALCALLERIDNUM=31)") in new stack 14270 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:15] ExecIf("PJSIP/31-0000093f", "0?Set(AMPUSER=31)") in new stack 14271 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:16] GotoIf("PJSIP/31-0000093f", "1?normcid") in new stack 14272 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-outbound-callerid,s,20) 14273 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:20] Set("PJSIP/31-0000093f", "USEROUTCID=31") in new stack 14274 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:21] Set("PJSIP/31-0000093f", "EMERGENCYCID=") in new stack 14275 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:22] ExecIf("PJSIP/31-0000093f", "0?Set(EMERGENCYCID=)") in new stack 14276 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:23] Set("PJSIP/31-0000093f", "TRUNKOUTCID=+302510620630") in new stack 14277 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:24] GotoIf("PJSIP/31-0000093f", "1?trunkcid") in new stack 14278 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-outbound-callerid,s,30) 14279 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:30] ExecIf("PJSIP/31-0000093f", "1?Set(CALLERID(all)=+302510620630)") in new stack 14280 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:31] ExecIf("PJSIP/31-0000093f", "1?Set(CALLERID(all)=31)") in new stack 14281 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:32] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(all)=)") in new stack 14282 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:33] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(all)=31)") in new stack 14283 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:34] Set("PJSIP/31-0000093f", "TIOHIDE=no") in new stack 14284 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:35] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(name-pres)=prohib_passed_screen)") in new stack 14285 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:36] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(num-pres)=prohib_passed_screen)") in new stack 14286 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:37] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(name-pres)=prohib_passed_screen)") in new stack 14287 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:38] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(num-pres)=prohib_passed_screen)") in new stack 14288 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:39] Set("PJSIP/31-0000093f", "CDR(outbound_cnum)=31") in new stack 14289 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:40] Set("PJSIP/31-0000093f", "CDR(outbound_cnam)=") in new stack 14290 [2020-10-08 12:00:16] VERBOSE[12457][C-0000037d] app_mixmonitor.c: Begin MixMonitor Recording PJSIP/31-0000093f 14291 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:14] GosubIf("PJSIP/31-0000093f", "0?sub-flp-1,s,1()") in new stack 14292 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:15] Set("PJSIP/31-0000093f", "OUTNUM=6977529545") in new stack 14293 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:16] Set("PJSIP/31-0000093f", "custom=SIP/Cosmote") in new stack 14294 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:17] ExecIf("PJSIP/31-0000093f", "0?Set(DIAL_TRUNK_OPTIONS=M(setmusic^default)T)") in new stack 14295 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:18] ExecIf("PJSIP/31-0000093f", "0?Set(DIAL_TRUNK_OPTIONS=TM(confirm))") in new stack 14296 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:19] Macro("PJSIP/31-0000093f", "dialout-trunk-predial-hook,") in new stack 14297 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("PJSIP/31-0000093f", "") in new stack 14298 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:20] GotoIf("PJSIP/31-0000093f", "0?skipcrm") in new stack 14299 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:21] Set("PJSIP/31-0000093f", "__CRM_DIRECTION=OUTBOUND") in new stack 14300 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:22] Set("PJSIP/31-0000093f", "__CRM_DESTINATION=6977529545") in new stack 14301 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:23] Set("PJSIP/31-0000093f", "__CRM_SOURCE=31") in new stack 14302 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:24] AGI("PJSIP/31-0000093f", "sangomacrm.agi") in new stack 14303 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi 14304 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] res_agi.c: <PJSIP/31-0000093f>AGI Script sangomacrm.agi completed, returning 0 14305 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:25] Set("PJSIP/31-0000093f", "CHANNEL(hangup_handler_push)=crm-hangup,s,1") in new stack 14306 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:26] NoOp("PJSIP/31-0000093f", "CRM Finished") in new stack 14307 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:27] GotoIf("PJSIP/31-0000093f", "0?bypass,1") in new stack 14308 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:28] ExecIf("PJSIP/31-0000093f", "1?Set(CONNECTEDLINE(num,i)=6977529545)") in new stack 14309 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:29] ExecIf("PJSIP/31-0000093f", "1?Set(CONNECTEDLINE(name,i)=CID:31)") in new stack 14310 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:30] ExecIf("PJSIP/31-0000093f", "0?Set(CONNECTEDLINE(name,i)=CID:(Hidden)31)") in new stack 14311 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:31] GotoIf("PJSIP/31-0000093f", "0?customtrunk") in new stack 14312 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:32] ExecIf("PJSIP/31-0000093f", "0?Set(DIAL_TRUNK_OPTIONS=)") in new stack 14313 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:33] Set("PJSIP/31-0000093f", "HASH(__SIPHEADERS,Alert-Info)=unset") in new stack 14314 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:34] Dial("PJSIP/31-0000093f", "SIP/Cosmote/6977529545,300,Tb(func-apply-sipheaders^s^1,(1))U(sub-send-obroute-email^6977529545^6977529545^1^1602147616^^31)") in new stack 14315 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] netsock2.c: Using SIP RTP TOS bits 184 14316 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] netsock2.c: Using SIP RTP CoS mark 5 14317 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] app_stack.c: SIP/Cosmote-00000378 Internal Gosub(func-apply-sipheaders,s,1(1)) start 14318 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("SIP/Cosmote-00000378", "0?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 14319 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("SIP/Cosmote-00000378", "Applying SIP Headers to channel SIP/Cosmote-00000378") in new stack 14320 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:3] Set("SIP/Cosmote-00000378", "TECH=SIP") in new stack 14321 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:4] Set("SIP/Cosmote-00000378", "SIPHEADERKEYS=Alert-Info") in new stack 14322 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:5] While("SIP/Cosmote-00000378", "1") in new stack 14323 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:6] Set("SIP/Cosmote-00000378", "sipheader=unset") in new stack 14324 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:7] ExecIf("SIP/Cosmote-00000378", "1?SIPRemoveHeader(Alert-Info:)") in new stack 14325 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:8] ExecIf("SIP/Cosmote-00000378", "0?Set(PJSIP_HEADER(remove,Alert-Info)=)") in new stack 14326 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:9] ExecIf("SIP/Cosmote-00000378", "0?Set(sipheader=<http://127.0.0.1>;info=unset)") in new stack 14327 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:10] ExecIf("SIP/Cosmote-00000378", "0?Set(sipheader=<http://127.0.0.1>unset)") in new stack 14328 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:11] ExecIf("SIP/Cosmote-00000378", "0?SIPAddHeader(Alert-Info:unset)") in new stack 14329 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:12] ExecIf("SIP/Cosmote-00000378", "0?Set(PJSIP_HEADER(add,Alert-Info)=unset)") in new stack 14330 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:13] EndWhile("SIP/Cosmote-00000378", "") in new stack 14331 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:5] While("SIP/Cosmote-00000378", "0") in new stack 14332 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:14] Return("SIP/Cosmote-00000378", "") in new stack 14333 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] app_stack.c: Spawn extension (from-trunk-sip-Cosmote, 6977529545, 1) exited non-zero on 'SIP/Cosmote-00000378' 14334 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] app_stack.c: SIP/Cosmote-00000378 Internal Gosub(func-apply-sipheaders,s,1(1)) complete GOSUB_RETVAL= 14335 [2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] app_dial.c: Called SIP/Cosmote/6977529545 14336 [2020-10-08 12:00:19] VERBOSE[12456][C-0000037d] app_dial.c: SIP/Cosmote-00000378 is making progress passing it to PJSIP/31-0000093f 14337 [2020-10-08 12:00:19] VERBOSE[12456][C-0000037d] app_dial.c: SIP/Cosmote-00000378 is ringing 14338 [2020-10-08 12:00:20] VERBOSE[12456][C-0000037d] app_dial.c: SIP/Cosmote-00000378 is ringing 14339 [2020-10-08 12:00:41] VERBOSE[12456][C-0000037d] app_dial.c: SIP/Cosmote-00000378 is ringing 14340 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_macro.c: Spawn extension (macro-dialout-trunk, s, 34) exited non-zero on 'PJSIP/31-0000093f' in macro 'dialout-trunk' 14341 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Spawn extension (from-internal, 6977529545, 11) exited non-zero on 'PJSIP/31-0000093f' 14342 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [h@from-internal:1] Macro("PJSIP/31-0000093f", "hangupcall") in new stack 14343 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("PJSIP/31-0000093f", "1?theend") in new stack 14344 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-hangupcall,s,3) 14345 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("PJSIP/31-0000093f", "0?Set(CDR(recordingfile)=)") in new stack 14346 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:4] NoOp("PJSIP/31-0000093f", "SIP/Cosmote-00000378 montior file= /var/spool/asterisk/monitor/2020/10/08/out-6977529545-31-20201008-120016-1602147616.3255.wav") in new stack 14347 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("PJSIP/31-0000093f", "0?skipagi") in new stack 14348 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:6] AGI("PJSIP/31-0000093f", "attendedtransfer-rec-restart.php,SIP/Cosmote-00000378,/var/spool/asterisk/monitor/2020/10/08/out-6977529545-31-20201008-120016-1602147616.3255.wav") in new stack 14349 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/attendedtransfer-rec-restart.php 14350 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] res_agi.c: <PJSIP/31-0000093f>AGI Script attendedtransfer-rec-restart.php completed, returning 0 14351 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:7] Hangup("PJSIP/31-0000093f", "") in new stack 14352 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'PJSIP/31-0000093f' in macro 'hangupcall' 14353 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Spawn extension (from-internal, h, 1) exited non-zero on 'PJSIP/31-0000093f' 14354 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_stack.c: PJSIP/31-0000093f Internal Gosub(crm-hangup,s,1) start 14355 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/31-0000093f", "Sending Hangup to CRM") in new stack 14356 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/31-0000093f", "HANGUP CAUSE: 127") in new stack 14357 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/31-0000093f", "0?Set(__CRM_VOICEMAIL=)") in new stack 14358 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/31-0000093f", "MASTER CHANNEL: 1602147616.3255 = 1602147616.3255") in new stack 14359 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/31-0000093f", "0?return") in new stack 14360 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:6] Set("PJSIP/31-0000093f", "__CRM_HANGUP=1") in new stack 14361 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:7] AGI("PJSIP/31-0000093f", "sangomacrm.agi") in new stack 14362 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi 14363 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] res_agi.c: <PJSIP/31-0000093f>AGI Script sangomacrm.agi completed, returning 0 14364 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/31-0000093f", "") in new stack 14365 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_stack.c: Spawn extension (from-internal, h, 1) exited non-zero on 'PJSIP/31-0000093f' 14366 [2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_stack.c: PJSIP/31-0000093f Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 14367 [2020-10-08 12:00:43] VERBOSE[12457][C-0000037d] app_mixmonitor.c: MixMonitor close filestream (mixed) 14368 [2020-10-08 12:00:43] VERBOSE[12457][C-0000037d] app_mixmonitor.c: End MixMonitor Recording PJSIP/31-0000093f 14369 [2020-10-08 12:01:04] VERBOSE[2276][C-0000037e] netsock2.c: Using SIP RTP TOS bits 184 14370 [2020-10-08 12:01:04] VERBOSE[2276][C-0000037e] netsock2.c: Using SIP RTP CoS mark 5 14371 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:1] Set("SIP/Cosmote-00000379", "GROUP()=OUT_1") in new stack 14372 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:2] Goto("SIP/Cosmote-00000379", "from-trunk,+302510620630,1") in new stack 14373 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (from-trunk,+302510620630,1) 14374 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:1] Set("SIP/Cosmote-00000379", "__DIRECTION=INBOUND") in new stack 14375 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:2] Gosub("SIP/Cosmote-00000379", "sub-record-check,s,1(in,+302510620630,force)") in new stack 14376 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-00000379", "0?initialized") in new stack 14377 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:2] Set("SIP/Cosmote-00000379", "__REC_STATUS=INITIALIZED") in new stack 14378 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:3] Set("SIP/Cosmote-00000379", "NOW=1602147664") in new stack 14379 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:4] Set("SIP/Cosmote-00000379", "__DAY=08") in new stack 14380 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:5] Set("SIP/Cosmote-00000379", "__MONTH=10") in new stack 14381 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:6] Set("SIP/Cosmote-00000379", "__YEAR=2020") in new stack 14382 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:7] Set("SIP/Cosmote-00000379", "__TIMESTR=20201008-120104") in new stack 14383 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:8] Set("SIP/Cosmote-00000379", "__FROMEXTEN=unknown") in new stack 14384 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:9] Set("SIP/Cosmote-00000379", "__MON_FMT=wav") in new stack 14385 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-00000379", "Recordings initialized") in new stack 14386 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-00000379", "0?Set(ARG3=dontcare)") in new stack 14387 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-00000379", "REC_POLICY_MODE_SAVE=") in new stack 14388 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-00000379", "0?Set(REC_STATUS=NO)") in new stack 14389 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-00000379", "2?checkaction") in new stack 14390 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,s,17) 14391 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-00000379", "1?sub-record-check,in,1") in new stack 14392 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,in,1) 14393 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:1] NoOp("SIP/Cosmote-00000379", "Inbound Recording Check to +302510620630") in new stack 14394 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:2] Set("SIP/Cosmote-00000379", "FROMEXTEN=unknown") in new stack 14395 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:3] ExecIf("SIP/Cosmote-00000379", "10?Set(FROMEXTEN=2510516267)") in new stack 14396 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:4] Gosub("SIP/Cosmote-00000379", "recordcheck,1(force,in,+302510620630)") in new stack 14397 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-00000379", "Starting recording check against force") in new stack 14398 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-00000379", "force") in new stack 14399 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,recordcheck,5) 14400 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:5] Set("SIP/Cosmote-00000379", "__REC_POLICY_MODE=FORCE") in new stack 14401 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:6] GotoIf("SIP/Cosmote-00000379", "1?startrec") in new stack 14402 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,recordcheck,16) 14403 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:16] NoOp("SIP/Cosmote-00000379", "Starting recording: in, +302510620630") in new stack 14404 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:17] Set("SIP/Cosmote-00000379", "__CALLFILENAME=in-+302510620630-2510516267-20201008-120104-1602147664.3257") in new stack 14405 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:18] MixMonitor("SIP/Cosmote-00000379", "2020/10/08/in-+302510620630-2510516267-20201008-120104-1602147664.3257.wav,abi(LOCAL_MIXMON_ID),") in new stack 14406 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:19] Set("SIP/Cosmote-00000379", "__MIXMON_ID=0x7f010c03da40") in new stack 14407 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:20] Set("SIP/Cosmote-00000379", "__RECORD_ID=SIP/Cosmote-00000379") in new stack 14408 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:21] Set("SIP/Cosmote-00000379", "__REC_STATUS=RECORDING") in new stack 14409 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:22] Set("SIP/Cosmote-00000379", "CDR(recordingfile)=in-+302510620630-2510516267-20201008-120104-1602147664.3257.wav") in new stack 14410 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:23] Return("SIP/Cosmote-00000379", "") in new stack 14411 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:5] Return("SIP/Cosmote-00000379", "") in new stack 14412 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:3] Set("SIP/Cosmote-00000379", "CHANNEL(tonezone)=gr") in new stack 14413 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:4] Set("SIP/Cosmote-00000379", "__FROM_DID=+302510620630") in new stack 14414 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:5] Set("SIP/Cosmote-00000379", "returnhere=1") in new stack 14415 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:6] Gosub("SIP/Cosmote-00000379", "app-blacklist-check,s,1()") in new stack 14416 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@app-blacklist-check:1] GotoIf("SIP/Cosmote-00000379", "0?blacklisted") in new stack 14417 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@app-blacklist-check:2] Set("SIP/Cosmote-00000379", "CALLED_BLACKLIST=1") in new stack 14418 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@app-blacklist-check:3] Return("SIP/Cosmote-00000379", "") in new stack 14419 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:7] Set("SIP/Cosmote-00000379", "CDR(did)=+302510620630") in new stack 14420 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:8] GotoIf("SIP/Cosmote-00000379", "0?") in new stack 14421 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:9] ExecIf("SIP/Cosmote-00000379", "1 ?Set(CALLERID(name)=2510516267)") in new stack 14422 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:10] Set("SIP/Cosmote-00000379", "__MOHCLASS=") in new stack 14423 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:11] Set("SIP/Cosmote-00000379", "__REVERSAL_REJECT=FALSE") in new stack 14424 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:12] GotoIf("SIP/Cosmote-00000379", "1?post-reverse-charge") in new stack 14425 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (from-trunk,+302510620630,14) 14426 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:14] NoOp("SIP/Cosmote-00000379", "") in new stack 14427 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:15] Set("SIP/Cosmote-00000379", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack 14428 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:16] Set("SIP/Cosmote-00000379", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack 14429 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:17] Set("SIP/Cosmote-00000379", "CALLERID(name-pres)=allowed_not_screened") in new stack 14430 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:18] Set("SIP/Cosmote-00000379", "CALLERID(num-pres)=allowed_not_screened") in new stack 14431 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:19] Gosub("SIP/Cosmote-00000379", "cidlookup,cidlookup_1,1()") in new stack 14432 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [cidlookup_1@cidlookup:1] AGI("SIP/Cosmote-00000379", "contactmanager.agi, 2510516267,,4") in new stack 14433 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/contactmanager.agi 14434 [2020-10-08 12:01:04] VERBOSE[12705][C-0000037e] app_mixmonitor.c: Begin MixMonitor Recording SIP/Cosmote-00000379 14435 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script contactmanager.agi completed, returning 0 14436 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [cidlookup_1@cidlookup:2] ExecIf("SIP/Cosmote-00000379", "0?Set(CALLERID(name)=Unknown)") in new stack 14437 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [cidlookup_1@cidlookup:3] Return("SIP/Cosmote-00000379", "") in new stack 14438 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:20] Set("SIP/Cosmote-00000379", "CIDSFSCHEME=QUxMfEFMTA==") in new stack 14439 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:21] AGI("SIP/Cosmote-00000379", "/var/www/html/admin/modules/superfecta/agi/superfecta.agi") in new stack 14440 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi 14441 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Executing Scheme.. 14442 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Scheme Asked is: ALL 14443 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The DID is: +302510620630 14444 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNUM is: 2510516267 14445 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNAME is: 2510516267 14446 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: 14447 [2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Starting scheme Default 14448 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: No callerid found 14449 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_NEW: 2510516267 14450 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_OLD: 2510516267 14451 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: CID Determined to be: '2510516267' 14452 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Attempting to set lookupcid 14453 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi completed, returning 0 14454 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:22] Set("SIP/Cosmote-00000379", "CALLERID(name)=2510516267") in new stack 14455 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:23] NoOp("SIP/Cosmote-00000379", "CallerID Entry Point") in new stack 14456 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:24] Set("SIP/Cosmote-00000379", "__CRM_DIRECTION=INBOUND") in new stack 14457 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:25] Set("SIP/Cosmote-00000379", "__CRM_SOURCE=2510516267") in new stack 14458 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:26] Set("SIP/Cosmote-00000379", "__CRM_LINKEDID=1602147664.3257") in new stack 14459 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:27] AGI("SIP/Cosmote-00000379", "sangomacrm.agi,true") in new stack 14460 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi 14461 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script sangomacrm.agi completed, returning 0 14462 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:28] ExecIf("SIP/Cosmote-00000379", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 14463 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:29] Goto("SIP/Cosmote-00000379", "ext-group,1,1") in new stack 14464 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (ext-group,1,1) 14465 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:1] GotoIf("SIP/Cosmote-00000379", "0?cid") in new stack 14466 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:2] PlayTones("SIP/Cosmote-00000379", "ring") in new stack 14467 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:3] Progress("SIP/Cosmote-00000379", "") in new stack 14468 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:4] Macro("SIP/Cosmote-00000379", "user-callerid,") in new stack 14469 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:1] Set("SIP/Cosmote-00000379", "TOUCH_MONITOR=1602147664.3257") in new stack 14470 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:2] Set("SIP/Cosmote-00000379", "AMPUSER=2510516267") in new stack 14471 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:3] Set("SIP/Cosmote-00000379", "HOTDESCKCHAN=Cosmote-00000379") in new stack 14472 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:4] Set("SIP/Cosmote-00000379", "HOTDESKEXTEN=Cosmote") in new stack 14473 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:5] Set("SIP/Cosmote-00000379", "HOTDESKCALL=0") in new stack 14474 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:6] ExecIf("SIP/Cosmote-00000379", "0?Set(HOTDESKCALL=1)") in new stack 14475 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:7] ExecIf("SIP/Cosmote-00000379", "0?Set(CALLERID(name)=)") in new stack 14476 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:8] GotoIf("SIP/Cosmote-00000379", "0?report") in new stack 14477 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:9] ExecIf("SIP/Cosmote-00000379", "1?Set(REALCALLERIDNUM=2510516267)") in new stack 14478 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:10] Set("SIP/Cosmote-00000379", "AMPUSER=") in new stack 14479 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:11] GotoIf("SIP/Cosmote-00000379", "0?limit") in new stack 14480 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:12] Set("SIP/Cosmote-00000379", "AMPUSERCIDNAME=") in new stack 14481 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:13] ExecIf("SIP/Cosmote-00000379", "0?Set(__CIDMASQUERADING=TRUE)") in new stack 14482 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:14] GotoIf("SIP/Cosmote-00000379", "1?report") in new stack 14483 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-user-callerid,s,23) 14484 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:23] NoOp("SIP/Cosmote-00000379", "Macro Depth is 1") in new stack 14485 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:24] GotoIf("SIP/Cosmote-00000379", "1?report2:macroerror") in new stack 14486 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-user-callerid,s,25) 14487 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:25] GotoIf("SIP/Cosmote-00000379", "0?continue") in new stack 14488 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:26] ExecIf("SIP/Cosmote-00000379", "1?Set(__CALLEE_ACCOUNCODE=)") in new stack 14489 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:27] Set("SIP/Cosmote-00000379", "__TTL=64") in new stack 14490 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:28] GotoIf("SIP/Cosmote-00000379", "1?continue") in new stack 14491 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-user-callerid,s,44) 14492 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:44] Set("SIP/Cosmote-00000379", "CALLERID(number)=2510516267") in new stack 14493 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:45] Set("SIP/Cosmote-00000379", "CALLERID(name)=2510516267") in new stack 14494 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:46] GotoIf("SIP/Cosmote-00000379", "0?cnum") in new stack 14495 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:47] Set("SIP/Cosmote-00000379", "CDR(cnam)=2510516267") in new stack 14496 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:48] Set("SIP/Cosmote-00000379", "CDR(cnum)=2510516267") in new stack 14497 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:49] Set("SIP/Cosmote-00000379", "CHANNEL(language)=en") in new stack 14498 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:5] Macro("SIP/Cosmote-00000379", "blkvm-setifempty,") in new stack 14499 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:1] GotoIf("SIP/Cosmote-00000379", "1?init") in new stack 14500 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-blkvm-setifempty,s,4) 14501 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:4] Set("SIP/Cosmote-00000379", "__BLKVM_CHANNEL=SIP/Cosmote-00000379") in new stack 14502 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:5] Set("SIP/Cosmote-00000379", "SHARED(BLKVM,SIP/Cosmote-00000379)=TRUE") in new stack 14503 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:6] Set("SIP/Cosmote-00000379", "GOSUB_RETVAL=TRUE") in new stack 14504 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:7] MacroExit("SIP/Cosmote-00000379", "") in new stack 14505 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:6] GotoIf("SIP/Cosmote-00000379", "1?skipov") in new stack 14506 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (ext-group,1,9) 14507 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:9] Set("SIP/Cosmote-00000379", "RRNODEST=") in new stack 14508 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:10] Set("SIP/Cosmote-00000379", "__NODEST=1") in new stack 14509 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:11] GosubIf("SIP/Cosmote-00000379", "0?sub-rgsetcid,s,1()") in new stack 14510 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:12] Gosub("SIP/Cosmote-00000379", "sub-record-check,s,1(rg,1,dontcare)") in new stack 14511 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-00000379", "10?initialized") in new stack 14512 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,s,10) 14513 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-00000379", "Recordings initialized") in new stack 14514 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-00000379", "0?Set(ARG3=dontcare)") in new stack 14515 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-00000379", "REC_POLICY_MODE_SAVE=FORCE") in new stack 14516 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-00000379", "0?Set(REC_STATUS=NO)") in new stack 14517 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-00000379", "2?checkaction") in new stack 14518 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,s,17) 14519 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-00000379", "0?sub-record-check,rg,1") in new stack 14520 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:18] NoOp("SIP/Cosmote-00000379", "Generic rg Recording Check - 2510516267 1") in new stack 14521 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:19] Gosub("SIP/Cosmote-00000379", "recordcheck,1(dontcare,rg,1)") in new stack 14522 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-00000379", "Starting recording check against dontcare") in new stack 14523 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-00000379", "dontcare") in new stack 14524 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,recordcheck,3) 14525 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:3] Return("SIP/Cosmote-00000379", "") in new stack 14526 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:20] Return("SIP/Cosmote-00000379", "") in new stack 14527 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:13] Set("SIP/Cosmote-00000379", "RingGroupMethod=ringall") in new stack 14528 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:14] Set("SIP/Cosmote-00000379", "__ALT_CONFIRM_MSG=") in new stack 14529 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:15] GotoIf("SIP/Cosmote-00000379", "0?RGVQANNOUNCE:NORGVQANNOUNCE") in new stack 14530 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (ext-group,1,18) 14531 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:18] Macro("SIP/Cosmote-00000379", "dial,120,HhTtrQ(ANSWERED_ELSEWHERE),31-32-33") in new stack 14532 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:1] NoOp("SIP/Cosmote-00000379", "Blind Transfer: , Attended Transfer: , User: , Alert Info: ") in new stack 14533 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:2] Set("SIP/Cosmote-00000379", "__CRM_SOURCE=2510516267") in new stack 14534 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:3] ExecIf("SIP/Cosmote-00000379", "0?Set(ALERT_INFO=)") in new stack 14535 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:4] ExecIf("SIP/Cosmote-00000379", "0?Set(ALERT_INFO=)") in new stack 14536 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:5] ExecIf("SIP/Cosmote-00000379", "0?Set(ALERT_INFO=)") in new stack 14537 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:6] ExecIf("SIP/Cosmote-00000379", "0?Set(CHANNEL(musicclass)=)") in new stack 14538 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:7] AGI("SIP/Cosmote-00000379", "dialparties.agi") in new stack 14539 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi 14540 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Starting New Dialparties.agi 14541 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Caller ID name is '2510516267' number is '2510516267' 14542 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: CW Ignore is: 14543 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: CF Ignore is: 14544 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: CW IN_USE/BUSY is: 1 14545 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Methodology of ring is 'ringall' 14546 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Added extension 31 to extension map 14547 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Added extension 32 to extension map 14548 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Added extension 33 to extension map 14549 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 31 cf is disabled 14550 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 32 cf is disabled 14551 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 33 cf is disabled 14552 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 31 do not disturb is disabled 14553 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 32 do not disturb is disabled 14554 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 33 do not disturb is disabled 14555 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/31 14556 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/31/sip:31@192.168.1.10:5060 14557 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: dbset CALLTRACE/31 to 2510516267 14558 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/32 14559 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/32/sip:32@192.168.1.11:5060 14560 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: dbset CALLTRACE/32 to 2510516267 14561 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/33 14562 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603 14563 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: dbset CALLTRACE/33 to 2510516267 14564 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Filtered ARG3: 31-32-33 14565 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: RVOL_MODE '' 14566 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: RVOL is: 14567 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: RVOLPARENT is: 14568 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script dialparties.agi completed, returning 0 14569 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:8] GotoIf("SIP/Cosmote-00000379", "1?normdial") in new stack 14570 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-dial,s,11) 14571 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:11] NoOp("SIP/Cosmote-00000379", "Returned from dialparties with groups to dial") in new stack 14572 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:12] NoOp("SIP/Cosmote-00000379", "ringall array ") in new stack 14573 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:13] Set("SIP/Cosmote-00000379", "__FMGL_DIAL=") in new stack 14574 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:14] Set("SIP/Cosmote-00000379", "LOOPCNT=3") in new stack 14575 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:15] Set("SIP/Cosmote-00000379", "ITER=1") in new stack 14576 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-00000379", "__EXTTOCALL=31") in new stack 14577 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-00000379", "Working with 31") in new stack 14578 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14579 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14580 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-00000379", "ITER=2") in new stack 14581 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-00000379", "1?ndloopbegin") in new stack 14582 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-dial,s,16) 14583 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-00000379", "__EXTTOCALL=32") in new stack 14584 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-00000379", "Working with 32") in new stack 14585 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14586 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14587 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-00000379", "ITER=3") in new stack 14588 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-00000379", "1?ndloopbegin") in new stack 14589 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-dial,s,16) 14590 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-00000379", "__EXTTOCALL=33") in new stack 14591 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-00000379", "Working with 33") in new stack 14592 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14593 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14594 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-00000379", "ITER=4") in new stack 14595 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-00000379", "0?ndloopbegin") in new stack 14596 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:22] Macro("SIP/Cosmote-00000379", "dial-ringall-predial-hook,") in new stack 14597 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial-ringall-predial-hook:1] MacroExit("SIP/Cosmote-00000379", "") in new stack 14598 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:23] ExecIf("SIP/Cosmote-00000379", "0?Set(CWRING=r(callwaiting)):Set(CWRING=)") in new stack 14599 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:24] ExecIf("SIP/Cosmote-00000379", "0?Set(ds=PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)g)") in new stack 14600 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:25] Dial("SIP/Cosmote-00000379", "PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)b(func-apply-sipheaders^s^1),") in new stack 14601 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/31-00000940 Internal Gosub(func-apply-sipheaders,s,1) start 14602 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/31-00000940", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 14603 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/31-00000940", "Applying SIP Headers to channel PJSIP/31-00000940") in new stack 14604 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/31-00000940", "TECH=PJSIP") in new stack 14605 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/31-00000940", "SIPHEADERKEYS=") in new stack 14606 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/31-00000940", "0") in new stack 14607 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_while.c: Jumping to priority 13 14608 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/31-00000940", "") in new stack 14609 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-00000940' 14610 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/31-00000940 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL= 14611 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/32-00000941 Internal Gosub(func-apply-sipheaders,s,1) start 14612 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/32-00000941", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 14613 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/32-00000941", "Applying SIP Headers to channel PJSIP/32-00000941") in new stack 14614 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/32-00000941", "TECH=PJSIP") in new stack 14615 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/32-00000941", "SIPHEADERKEYS=") in new stack 14616 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/32-00000941", "0") in new stack 14617 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_while.c: Jumping to priority 13 14618 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/32-00000941", "") in new stack 14619 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/32-00000941' 14620 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/32-00000941 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL= 14621 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/33-00000942 Internal Gosub(func-apply-sipheaders,s,1) start 14622 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/33-00000942", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 14623 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/33-00000942", "Applying SIP Headers to channel PJSIP/33-00000942") in new stack 14624 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/33-00000942", "TECH=PJSIP") in new stack 14625 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/33-00000942", "SIPHEADERKEYS=") in new stack 14626 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/33-00000942", "0") in new stack 14627 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_while.c: Jumping to priority 13 14628 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/33-00000942", "") in new stack 14629 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-00000942' 14630 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/33-00000942 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL= 14631 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: Called PJSIP/31/sip:31@192.168.1.10:5060 14632 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: Called PJSIP/32/sip:32@192.168.1.11:5060 14633 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: Called PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603 14634 [2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 14635 [2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 14636 [2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5 14637 [2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 14638 [2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 14639 [2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5 14640 [2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 14641 [2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 14642 [2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5 14643 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/33-00000942 connected line has changed. Saving it until answer for SIP/Cosmote-00000379 14644 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/32-00000941 connected line has changed. Saving it until answer for SIP/Cosmote-00000379 14645 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/31-00000940 connected line has changed. Saving it until answer for SIP/Cosmote-00000379 14646 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/31-00000940 is ringing 14647 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/31-00000940 is ringing 14648 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/33-00000942 is ringing 14649 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/33-00000942 is ringing 14650 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/32-00000941 is ringing 14651 [2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/32-00000941 is ringing 14652 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/32-00000941 answered SIP/Cosmote-00000379 14653 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/31-00000940 Internal Gosub(crm-hangup,s,1) start 14654 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/31-00000940", "Sending Hangup to CRM") in new stack 14655 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/31-00000940", "HANGUP CAUSE: 26") in new stack 14656 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/31-00000940", "0?Set(__CRM_VOICEMAIL=)") in new stack 14657 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/31-00000940", "MASTER CHANNEL: 1602147665.3258 = 1602147664.3257") in new stack 14658 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/31-00000940", "1?return") in new stack 14659 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (crm-hangup,s,8) 14660 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/31-00000940", "") in new stack 14661 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-00000940' 14662 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/31-00000940 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 14663 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/33-00000942 Internal Gosub(crm-hangup,s,1) start 14664 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/33-00000942", "Sending Hangup to CRM") in new stack 14665 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/33-00000942", "HANGUP CAUSE: 26") in new stack 14666 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/33-00000942", "0?Set(__CRM_VOICEMAIL=)") in new stack 14667 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/33-00000942", "MASTER CHANNEL: 1602147665.3260 = 1602147664.3257") in new stack 14668 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/33-00000942", "1?return") in new stack 14669 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (crm-hangup,s,8) 14670 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/33-00000942", "") in new stack 14671 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-00000942' 14672 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/33-00000942 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 14673 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:1] Set("PJSIP/32-00000941", "__MACRO_RESULT=") in new stack 14674 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:2] Set("PJSIP/32-00000941", "CFIGNORE=") in new stack 14675 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:3] Set("PJSIP/32-00000941", "MASTER_CHANNEL(CFIGNORE)=") in new stack 14676 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:4] Set("PJSIP/32-00000941", "FORWARD_CONTEXT=from-internal") in new stack 14677 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:5] Set("PJSIP/32-00000941", "MASTER_CHANNEL(FORWARD_CONTEXT)=from-internal") in new stack 14678 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:6] Macro("PJSIP/32-00000941", "blkvm-clr,") in new stack 14679 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-clr:1] Set("PJSIP/32-00000941", "SHARED(BLKVM,SIP/Cosmote-00000379)=") in new stack 14680 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-clr:2] Set("PJSIP/32-00000941", "GOSUB_RETVAL=") in new stack 14681 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-clr:3] MacroExit("PJSIP/32-00000941", "") in new stack 14682 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:7] ExecIf("PJSIP/32-00000941", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(num))=32/sip:32@192.168.1.11:5060)") in new stack 14683 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:8] ExecIf("PJSIP/32-00000941", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(name))=)") in new stack 14684 [2020-10-08 12:01:09] VERBOSE[12743][C-0000037e] bridge_channel.c: Channel PJSIP/32-00000941 joined 'simple_bridge' basic-bridge <9b815a2f-716a-466c-b41a-f26bdd3d056a> 14685 [2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] bridge_channel.c: Channel SIP/Cosmote-00000379 joined 'simple_bridge' basic-bridge <9b815a2f-716a-466c-b41a-f26bdd3d056a> 14686 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] bridge_channel.c: Channel PJSIP/32-00000941 left 'simple_bridge' basic-bridge <9b815a2f-716a-466c-b41a-f26bdd3d056a> 14687 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] bridge_channel.c: Channel SIP/Cosmote-00000379 left 'simple_bridge' basic-bridge <9b815a2f-716a-466c-b41a-f26bdd3d056a> 14688 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] app_stack.c: PJSIP/32-00000941 Internal Gosub(crm-hangup,s,1) start 14689 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/32-00000941", "Sending Hangup to CRM") in new stack 14690 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/32-00000941", "HANGUP CAUSE: 16") in new stack 14691 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_macro.c: Spawn extension (macro-dial, s, 25) exited non-zero on 'SIP/Cosmote-00000379' in macro 'dial' 14692 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/32-00000941", "0?Set(__CRM_VOICEMAIL=)") in new stack 14693 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Spawn extension (ext-group, 1, 18) exited non-zero on 'SIP/Cosmote-00000379' 14694 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [h@ext-group:1] Macro("SIP/Cosmote-00000379", "hangupcall,") in new stack 14695 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/Cosmote-00000379", "1?theend") in new stack 14696 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-hangupcall,s,3) 14697 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/Cosmote-00000379", "0?Set(CDR(recordingfile)=)") in new stack 14698 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/32-00000941", "MASTER CHANNEL: 1602147665.3259 = 1602147664.3257") in new stack 14699 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/32-00000941", "1?return") in new stack 14700 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx_builtins.c: Goto (crm-hangup,s,8) 14701 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/32-00000941", "") in new stack 14702 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] app_stack.c: Spawn extension (macro-dial, s, 1) exited non-zero on 'PJSIP/32-00000941' 14703 [2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] app_stack.c: PJSIP/32-00000941 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 14704 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/Cosmote-00000379", "PJSIP/33-00000942 montior file= /var/spool/asterisk/monitor/2020/10/08/in-+302510620630-2510516267-20201008-120104-1602147664.3257.wav") in new stack 14705 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/Cosmote-00000379", "0?skipagi") in new stack 14706 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:6] AGI("SIP/Cosmote-00000379", "attendedtransfer-rec-restart.php,PJSIP/33-00000942,/var/spool/asterisk/monitor/2020/10/08/in-+302510620630-2510516267-20201008-120104-1602147664.3257.wav") in new stack 14707 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/attendedtransfer-rec-restart.php 14708 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script attendedtransfer-rec-restart.php completed, returning 0 14709 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/Cosmote-00000379", "") in new stack 14710 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/Cosmote-00000379' in macro 'hangupcall' 14711 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-00000379' 14712 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_stack.c: SIP/Cosmote-00000379 Internal Gosub(crm-hangup,s,1) start 14713 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:1] NoOp("SIP/Cosmote-00000379", "Sending Hangup to CRM") in new stack 14714 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:2] NoOp("SIP/Cosmote-00000379", "HANGUP CAUSE: 16") in new stack 14715 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:3] ExecIf("SIP/Cosmote-00000379", "0?Set(__CRM_VOICEMAIL=)") in new stack 14716 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:4] NoOp("SIP/Cosmote-00000379", "MASTER CHANNEL: 1602147664.3257 = 1602147664.3257") in new stack 14717 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:5] GotoIf("SIP/Cosmote-00000379", "0?return") in new stack 14718 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:6] Set("SIP/Cosmote-00000379", "__CRM_HANGUP=1") in new stack 14719 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:7] AGI("SIP/Cosmote-00000379", "sangomacrm.agi") in new stack 14720 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi 14721 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script sangomacrm.agi completed, returning 0 14722 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:8] Return("SIP/Cosmote-00000379", "") in new stack 14723 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-00000379' 14724 [2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_stack.c: SIP/Cosmote-00000379 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 14725 [2020-10-08 12:01:20] VERBOSE[12705][C-0000037e] app_mixmonitor.c: MixMonitor close filestream (mixed) 14726 [2020-10-08 12:01:20] VERBOSE[12705][C-0000037e] app_mixmonitor.c: End MixMonitor Recording SIP/Cosmote-00000379 14727 [2020-10-08 12:01:32] VERBOSE[2276][C-0000037f] netsock2.c: Using SIP RTP TOS bits 184 14728 [2020-10-08 12:01:32] VERBOSE[2276][C-0000037f] netsock2.c: Using SIP RTP CoS mark 5 14729 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:1] Set("SIP/Cosmote-0000037a", "GROUP()=OUT_1") in new stack 14730 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:2] Goto("SIP/Cosmote-0000037a", "from-trunk,+302510620630,1") in new stack 14731 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (from-trunk,+302510620630,1) 14732 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:1] Set("SIP/Cosmote-0000037a", "__DIRECTION=INBOUND") in new stack 14733 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:2] Gosub("SIP/Cosmote-0000037a", "sub-record-check,s,1(in,+302510620630,force)") in new stack 14734 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-0000037a", "0?initialized") in new stack 14735 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:2] Set("SIP/Cosmote-0000037a", "__REC_STATUS=INITIALIZED") in new stack 14736 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:3] Set("SIP/Cosmote-0000037a", "NOW=1602147692") in new stack 14737 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:4] Set("SIP/Cosmote-0000037a", "__DAY=08") in new stack 14738 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:5] Set("SIP/Cosmote-0000037a", "__MONTH=10") in new stack 14739 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:6] Set("SIP/Cosmote-0000037a", "__YEAR=2020") in new stack 14740 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:7] Set("SIP/Cosmote-0000037a", "__TIMESTR=20201008-120132") in new stack 14741 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:8] Set("SIP/Cosmote-0000037a", "__FROMEXTEN=unknown") in new stack 14742 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:9] Set("SIP/Cosmote-0000037a", "__MON_FMT=wav") in new stack 14743 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-0000037a", "Recordings initialized") in new stack 14744 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-0000037a", "0?Set(ARG3=dontcare)") in new stack 14745 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-0000037a", "REC_POLICY_MODE_SAVE=") in new stack 14746 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-0000037a", "0?Set(REC_STATUS=NO)") in new stack 14747 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-0000037a", "2?checkaction") in new stack 14748 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,s,17) 14749 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-0000037a", "1?sub-record-check,in,1") in new stack 14750 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,in,1) 14751 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:1] NoOp("SIP/Cosmote-0000037a", "Inbound Recording Check to +302510620630") in new stack 14752 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:2] Set("SIP/Cosmote-0000037a", "FROMEXTEN=unknown") in new stack 14753 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:3] ExecIf("SIP/Cosmote-0000037a", "10?Set(FROMEXTEN=2513500071)") in new stack 14754 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:4] Gosub("SIP/Cosmote-0000037a", "recordcheck,1(force,in,+302510620630)") in new stack 14755 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-0000037a", "Starting recording check against force") in new stack 14756 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-0000037a", "force") in new stack 14757 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,recordcheck,5) 14758 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:5] Set("SIP/Cosmote-0000037a", "__REC_POLICY_MODE=FORCE") in new stack 14759 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:6] GotoIf("SIP/Cosmote-0000037a", "1?startrec") in new stack 14760 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,recordcheck,16) 14761 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:16] NoOp("SIP/Cosmote-0000037a", "Starting recording: in, +302510620630") in new stack 14762 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:17] Set("SIP/Cosmote-0000037a", "__CALLFILENAME=in-+302510620630-2513500071-20201008-120132-1602147692.3261") in new stack 14763 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:18] MixMonitor("SIP/Cosmote-0000037a", "2020/10/08/in-+302510620630-2513500071-20201008-120132-1602147692.3261.wav,abi(LOCAL_MIXMON_ID),") in new stack 14764 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:19] Set("SIP/Cosmote-0000037a", "__MIXMON_ID=0x7f00c8054bc0") in new stack 14765 [2020-10-08 12:01:32] VERBOSE[12877][C-0000037f] app_mixmonitor.c: Begin MixMonitor Recording SIP/Cosmote-0000037a 14766 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:20] Set("SIP/Cosmote-0000037a", "__RECORD_ID=SIP/Cosmote-0000037a") in new stack 14767 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:21] Set("SIP/Cosmote-0000037a", "__REC_STATUS=RECORDING") in new stack 14768 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:22] Set("SIP/Cosmote-0000037a", "CDR(recordingfile)=in-+302510620630-2513500071-20201008-120132-1602147692.3261.wav") in new stack 14769 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:23] Return("SIP/Cosmote-0000037a", "") in new stack 14770 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:5] Return("SIP/Cosmote-0000037a", "") in new stack 14771 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:3] Set("SIP/Cosmote-0000037a", "CHANNEL(tonezone)=gr") in new stack 14772 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:4] Set("SIP/Cosmote-0000037a", "__FROM_DID=+302510620630") in new stack 14773 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:5] Set("SIP/Cosmote-0000037a", "returnhere=1") in new stack 14774 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:6] Gosub("SIP/Cosmote-0000037a", "app-blacklist-check,s,1()") in new stack 14775 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@app-blacklist-check:1] GotoIf("SIP/Cosmote-0000037a", "0?blacklisted") in new stack 14776 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@app-blacklist-check:2] Set("SIP/Cosmote-0000037a", "CALLED_BLACKLIST=1") in new stack 14777 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@app-blacklist-check:3] Return("SIP/Cosmote-0000037a", "") in new stack 14778 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:7] Set("SIP/Cosmote-0000037a", "CDR(did)=+302510620630") in new stack 14779 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:8] GotoIf("SIP/Cosmote-0000037a", "0?") in new stack 14780 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:9] ExecIf("SIP/Cosmote-0000037a", "1 ?Set(CALLERID(name)=2513500071)") in new stack 14781 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:10] Set("SIP/Cosmote-0000037a", "__MOHCLASS=") in new stack 14782 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:11] Set("SIP/Cosmote-0000037a", "__REVERSAL_REJECT=FALSE") in new stack 14783 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:12] GotoIf("SIP/Cosmote-0000037a", "1?post-reverse-charge") in new stack 14784 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (from-trunk,+302510620630,14) 14785 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:14] NoOp("SIP/Cosmote-0000037a", "") in new stack 14786 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:15] Set("SIP/Cosmote-0000037a", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack 14787 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:16] Set("SIP/Cosmote-0000037a", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack 14788 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:17] Set("SIP/Cosmote-0000037a", "CALLERID(name-pres)=allowed_not_screened") in new stack 14789 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:18] Set("SIP/Cosmote-0000037a", "CALLERID(num-pres)=allowed_not_screened") in new stack 14790 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:19] Gosub("SIP/Cosmote-0000037a", "cidlookup,cidlookup_1,1()") in new stack 14791 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [cidlookup_1@cidlookup:1] AGI("SIP/Cosmote-0000037a", "contactmanager.agi, 2513500071,,4") in new stack 14792 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/contactmanager.agi 14793 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script contactmanager.agi completed, returning 0 14794 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [cidlookup_1@cidlookup:2] ExecIf("SIP/Cosmote-0000037a", "0?Set(CALLERID(name)=Unknown)") in new stack 14795 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [cidlookup_1@cidlookup:3] Return("SIP/Cosmote-0000037a", "") in new stack 14796 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:20] Set("SIP/Cosmote-0000037a", "CIDSFSCHEME=QUxMfEFMTA==") in new stack 14797 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:21] AGI("SIP/Cosmote-0000037a", "/var/www/html/admin/modules/superfecta/agi/superfecta.agi") in new stack 14798 [2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi 14799 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Executing Scheme.. 14800 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Scheme Asked is: ALL 14801 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The DID is: +302510620630 14802 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNUM is: 2513500071 14803 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNAME is: 2513500071 14804 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: 14805 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Starting scheme Default 14806 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: No callerid found 14807 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_NEW: 2513500071 14808 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_OLD: 2513500071 14809 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: CID Determined to be: '2513500071' 14810 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Attempting to set lookupcid 14811 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi completed, returning 0 14812 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:22] Set("SIP/Cosmote-0000037a", "CALLERID(name)=2513500071") in new stack 14813 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:23] NoOp("SIP/Cosmote-0000037a", "CallerID Entry Point") in new stack 14814 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:24] Set("SIP/Cosmote-0000037a", "__CRM_DIRECTION=INBOUND") in new stack 14815 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:25] Set("SIP/Cosmote-0000037a", "__CRM_SOURCE=2513500071") in new stack 14816 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:26] Set("SIP/Cosmote-0000037a", "__CRM_LINKEDID=1602147692.3261") in new stack 14817 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:27] AGI("SIP/Cosmote-0000037a", "sangomacrm.agi,true") in new stack 14818 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi 14819 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script sangomacrm.agi completed, returning 0 14820 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:28] ExecIf("SIP/Cosmote-0000037a", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 14821 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:29] Goto("SIP/Cosmote-0000037a", "ext-group,1,1") in new stack 14822 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (ext-group,1,1) 14823 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:1] GotoIf("SIP/Cosmote-0000037a", "0?cid") in new stack 14824 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:2] PlayTones("SIP/Cosmote-0000037a", "ring") in new stack 14825 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:3] Progress("SIP/Cosmote-0000037a", "") in new stack 14826 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:4] Macro("SIP/Cosmote-0000037a", "user-callerid,") in new stack 14827 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:1] Set("SIP/Cosmote-0000037a", "TOUCH_MONITOR=1602147692.3261") in new stack 14828 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:2] Set("SIP/Cosmote-0000037a", "AMPUSER=2513500071") in new stack 14829 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:3] Set("SIP/Cosmote-0000037a", "HOTDESCKCHAN=Cosmote-0000037a") in new stack 14830 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:4] Set("SIP/Cosmote-0000037a", "HOTDESKEXTEN=Cosmote") in new stack 14831 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:5] Set("SIP/Cosmote-0000037a", "HOTDESKCALL=0") in new stack 14832 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:6] ExecIf("SIP/Cosmote-0000037a", "0?Set(HOTDESKCALL=1)") in new stack 14833 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:7] ExecIf("SIP/Cosmote-0000037a", "0?Set(CALLERID(name)=)") in new stack 14834 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:8] GotoIf("SIP/Cosmote-0000037a", "0?report") in new stack 14835 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:9] ExecIf("SIP/Cosmote-0000037a", "1?Set(REALCALLERIDNUM=2513500071)") in new stack 14836 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:10] Set("SIP/Cosmote-0000037a", "AMPUSER=") in new stack 14837 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:11] GotoIf("SIP/Cosmote-0000037a", "0?limit") in new stack 14838 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:12] Set("SIP/Cosmote-0000037a", "AMPUSERCIDNAME=") in new stack 14839 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:13] ExecIf("SIP/Cosmote-0000037a", "0?Set(__CIDMASQUERADING=TRUE)") in new stack 14840 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:14] GotoIf("SIP/Cosmote-0000037a", "1?report") in new stack 14841 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-user-callerid,s,23) 14842 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:23] NoOp("SIP/Cosmote-0000037a", "Macro Depth is 1") in new stack 14843 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:24] GotoIf("SIP/Cosmote-0000037a", "1?report2:macroerror") in new stack 14844 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-user-callerid,s,25) 14845 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:25] GotoIf("SIP/Cosmote-0000037a", "0?continue") in new stack 14846 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:26] ExecIf("SIP/Cosmote-0000037a", "1?Set(__CALLEE_ACCOUNCODE=)") in new stack 14847 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:27] Set("SIP/Cosmote-0000037a", "__TTL=64") in new stack 14848 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:28] GotoIf("SIP/Cosmote-0000037a", "1?continue") in new stack 14849 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-user-callerid,s,44) 14850 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:44] Set("SIP/Cosmote-0000037a", "CALLERID(number)=2513500071") in new stack 14851 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:45] Set("SIP/Cosmote-0000037a", "CALLERID(name)=2513500071") in new stack 14852 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:46] GotoIf("SIP/Cosmote-0000037a", "0?cnum") in new stack 14853 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:47] Set("SIP/Cosmote-0000037a", "CDR(cnam)=2513500071") in new stack 14854 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:48] Set("SIP/Cosmote-0000037a", "CDR(cnum)=2513500071") in new stack 14855 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:49] Set("SIP/Cosmote-0000037a", "CHANNEL(language)=en") in new stack 14856 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:5] Macro("SIP/Cosmote-0000037a", "blkvm-setifempty,") in new stack 14857 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:1] GotoIf("SIP/Cosmote-0000037a", "1?init") in new stack 14858 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-blkvm-setifempty,s,4) 14859 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:4] Set("SIP/Cosmote-0000037a", "__BLKVM_CHANNEL=SIP/Cosmote-0000037a") in new stack 14860 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:5] Set("SIP/Cosmote-0000037a", "SHARED(BLKVM,SIP/Cosmote-0000037a)=TRUE") in new stack 14861 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:6] Set("SIP/Cosmote-0000037a", "GOSUB_RETVAL=TRUE") in new stack 14862 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:7] MacroExit("SIP/Cosmote-0000037a", "") in new stack 14863 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:6] GotoIf("SIP/Cosmote-0000037a", "1?skipov") in new stack 14864 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (ext-group,1,9) 14865 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:9] Set("SIP/Cosmote-0000037a", "RRNODEST=") in new stack 14866 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:10] Set("SIP/Cosmote-0000037a", "__NODEST=1") in new stack 14867 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:11] GosubIf("SIP/Cosmote-0000037a", "0?sub-rgsetcid,s,1()") in new stack 14868 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:12] Gosub("SIP/Cosmote-0000037a", "sub-record-check,s,1(rg,1,dontcare)") in new stack 14869 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-0000037a", "10?initialized") in new stack 14870 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,s,10) 14871 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-0000037a", "Recordings initialized") in new stack 14872 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-0000037a", "0?Set(ARG3=dontcare)") in new stack 14873 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-0000037a", "REC_POLICY_MODE_SAVE=FORCE") in new stack 14874 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-0000037a", "0?Set(REC_STATUS=NO)") in new stack 14875 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-0000037a", "2?checkaction") in new stack 14876 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,s,17) 14877 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-0000037a", "0?sub-record-check,rg,1") in new stack 14878 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:18] NoOp("SIP/Cosmote-0000037a", "Generic rg Recording Check - 2513500071 1") in new stack 14879 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:19] Gosub("SIP/Cosmote-0000037a", "recordcheck,1(dontcare,rg,1)") in new stack 14880 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-0000037a", "Starting recording check against dontcare") in new stack 14881 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-0000037a", "dontcare") in new stack 14882 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,recordcheck,3) 14883 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:3] Return("SIP/Cosmote-0000037a", "") in new stack 14884 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:20] Return("SIP/Cosmote-0000037a", "") in new stack 14885 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:13] Set("SIP/Cosmote-0000037a", "RingGroupMethod=ringall") in new stack 14886 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:14] Set("SIP/Cosmote-0000037a", "__ALT_CONFIRM_MSG=") in new stack 14887 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:15] GotoIf("SIP/Cosmote-0000037a", "0?RGVQANNOUNCE:NORGVQANNOUNCE") in new stack 14888 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (ext-group,1,18) 14889 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:18] Macro("SIP/Cosmote-0000037a", "dial,120,HhTtrQ(ANSWERED_ELSEWHERE),31-32-33") in new stack 14890 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:1] NoOp("SIP/Cosmote-0000037a", "Blind Transfer: , Attended Transfer: , User: , Alert Info: ") in new stack 14891 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:2] Set("SIP/Cosmote-0000037a", "__CRM_SOURCE=2513500071") in new stack 14892 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:3] ExecIf("SIP/Cosmote-0000037a", "0?Set(ALERT_INFO=)") in new stack 14893 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:4] ExecIf("SIP/Cosmote-0000037a", "0?Set(ALERT_INFO=)") in new stack 14894 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:5] ExecIf("SIP/Cosmote-0000037a", "0?Set(ALERT_INFO=)") in new stack 14895 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:6] ExecIf("SIP/Cosmote-0000037a", "0?Set(CHANNEL(musicclass)=)") in new stack 14896 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:7] AGI("SIP/Cosmote-0000037a", "dialparties.agi") in new stack 14897 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi 14898 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Starting New Dialparties.agi 14899 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Caller ID name is '2513500071' number is '2513500071' 14900 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: CW Ignore is: 14901 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: CF Ignore is: 14902 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: CW IN_USE/BUSY is: 1 14903 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Methodology of ring is 'ringall' 14904 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Added extension 31 to extension map 14905 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Added extension 32 to extension map 14906 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Added extension 33 to extension map 14907 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 31 cf is disabled 14908 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 32 cf is disabled 14909 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 33 cf is disabled 14910 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 31 do not disturb is disabled 14911 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 32 do not disturb is disabled 14912 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 33 do not disturb is disabled 14913 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/31 14914 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/31/sip:31@192.168.1.10:5060 14915 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: dbset CALLTRACE/31 to 2513500071 14916 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/32 14917 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/32/sip:32@192.168.1.11:5060 14918 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: dbset CALLTRACE/32 to 2513500071 14919 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/33 14920 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603 14921 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: dbset CALLTRACE/33 to 2513500071 14922 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Filtered ARG3: 31-32-33 14923 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: RVOL_MODE '' 14924 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: RVOL is: 14925 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: RVOLPARENT is: 14926 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script dialparties.agi completed, returning 0 14927 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:8] GotoIf("SIP/Cosmote-0000037a", "1?normdial") in new stack 14928 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-dial,s,11) 14929 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:11] NoOp("SIP/Cosmote-0000037a", "Returned from dialparties with groups to dial") in new stack 14930 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:12] NoOp("SIP/Cosmote-0000037a", "ringall array ") in new stack 14931 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:13] Set("SIP/Cosmote-0000037a", "__FMGL_DIAL=") in new stack 14932 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:14] Set("SIP/Cosmote-0000037a", "LOOPCNT=3") in new stack 14933 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:15] Set("SIP/Cosmote-0000037a", "ITER=1") in new stack 14934 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000037a", "__EXTTOCALL=31") in new stack 14935 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000037a", "Working with 31") in new stack 14936 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14937 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14938 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000037a", "ITER=2") in new stack 14939 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000037a", "1?ndloopbegin") in new stack 14940 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-dial,s,16) 14941 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000037a", "__EXTTOCALL=32") in new stack 14942 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000037a", "Working with 32") in new stack 14943 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14944 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14945 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000037a", "ITER=3") in new stack 14946 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000037a", "1?ndloopbegin") in new stack 14947 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-dial,s,16) 14948 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000037a", "__EXTTOCALL=33") in new stack 14949 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000037a", "Working with 33") in new stack 14950 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14951 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 14952 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000037a", "ITER=4") in new stack 14953 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000037a", "0?ndloopbegin") in new stack 14954 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:22] Macro("SIP/Cosmote-0000037a", "dial-ringall-predial-hook,") in new stack 14955 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial-ringall-predial-hook:1] MacroExit("SIP/Cosmote-0000037a", "") in new stack 14956 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:23] ExecIf("SIP/Cosmote-0000037a", "0?Set(CWRING=r(callwaiting)):Set(CWRING=)") in new stack 14957 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:24] ExecIf("SIP/Cosmote-0000037a", "0?Set(ds=PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)g)") in new stack 14958 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:25] Dial("SIP/Cosmote-0000037a", "PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)b(func-apply-sipheaders^s^1),") in new stack 14959 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/31-00000943 Internal Gosub(func-apply-sipheaders,s,1) start 14960 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/31-00000943", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 14961 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/31-00000943", "Applying SIP Headers to channel PJSIP/31-00000943") in new stack 14962 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/31-00000943", "TECH=PJSIP") in new stack 14963 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/31-00000943", "SIPHEADERKEYS=") in new stack 14964 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/31-00000943", "0") in new stack 14965 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_while.c: Jumping to priority 13 14966 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/31-00000943", "") in new stack 14967 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-00000943' 14968 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/31-00000943 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL= 14969 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/32-00000944 Internal Gosub(func-apply-sipheaders,s,1) start 14970 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/32-00000944", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 14971 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/32-00000944", "Applying SIP Headers to channel PJSIP/32-00000944") in new stack 14972 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/32-00000944", "TECH=PJSIP") in new stack 14973 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/32-00000944", "SIPHEADERKEYS=") in new stack 14974 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/32-00000944", "0") in new stack 14975 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_while.c: Jumping to priority 13 14976 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/32-00000944", "") in new stack 14977 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/32-00000944' 14978 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/32-00000944 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL= 14979 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/33-00000945 Internal Gosub(func-apply-sipheaders,s,1) start 14980 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/33-00000945", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 14981 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/33-00000945", "Applying SIP Headers to channel PJSIP/33-00000945") in new stack 14982 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/33-00000945", "TECH=PJSIP") in new stack 14983 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/33-00000945", "SIPHEADERKEYS=") in new stack 14984 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/33-00000945", "0") in new stack 14985 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_while.c: Jumping to priority 13 14986 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/33-00000945", "") in new stack 14987 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-00000945' 14988 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/33-00000945 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL= 14989 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: Called PJSIP/31/sip:31@192.168.1.10:5060 14990 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: Called PJSIP/32/sip:32@192.168.1.11:5060 14991 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: Called PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603 14992 [2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 14993 [2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 14994 [2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5 14995 [2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 14996 [2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 14997 [2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5 14998 [2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 14999 [2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 15000 [2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5 15001 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/33-00000945 connected line has changed. Saving it until answer for SIP/Cosmote-0000037a 15002 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/32-00000944 connected line has changed. Saving it until answer for SIP/Cosmote-0000037a 15003 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/31-00000943 connected line has changed. Saving it until answer for SIP/Cosmote-0000037a 15004 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/31-00000943 is ringing 15005 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/31-00000943 is ringing 15006 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/32-00000944 is ringing 15007 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/32-00000944 is ringing 15008 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/33-00000945 is ringing 15009 [2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/33-00000945 is ringing 15010 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/33-00000945 answered SIP/Cosmote-0000037a 15011 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/31-00000943 Internal Gosub(crm-hangup,s,1) start 15012 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/31-00000943", "Sending Hangup to CRM") in new stack 15013 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/31-00000943", "HANGUP CAUSE: 26") in new stack 15014 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/31-00000943", "0?Set(__CRM_VOICEMAIL=)") in new stack 15015 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/31-00000943", "MASTER CHANNEL: 1602147693.3262 = 1602147692.3261") in new stack 15016 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/31-00000943", "1?return") in new stack 15017 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (crm-hangup,s,8) 15018 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/31-00000943", "") in new stack 15019 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-00000943' 15020 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/31-00000943 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 15021 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/32-00000944 Internal Gosub(crm-hangup,s,1) start 15022 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/32-00000944", "Sending Hangup to CRM") in new stack 15023 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/32-00000944", "HANGUP CAUSE: 26") in new stack 15024 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/32-00000944", "0?Set(__CRM_VOICEMAIL=)") in new stack 15025 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/32-00000944", "MASTER CHANNEL: 1602147693.3263 = 1602147692.3261") in new stack 15026 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/32-00000944", "1?return") in new stack 15027 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (crm-hangup,s,8) 15028 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/32-00000944", "") in new stack 15029 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/32-00000944' 15030 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/32-00000944 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 15031 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:1] Set("PJSIP/33-00000945", "__MACRO_RESULT=") in new stack 15032 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:2] Set("PJSIP/33-00000945", "CFIGNORE=") in new stack 15033 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:3] Set("PJSIP/33-00000945", "MASTER_CHANNEL(CFIGNORE)=") in new stack 15034 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:4] Set("PJSIP/33-00000945", "FORWARD_CONTEXT=from-internal") in new stack 15035 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:5] Set("PJSIP/33-00000945", "MASTER_CHANNEL(FORWARD_CONTEXT)=from-internal") in new stack 15036 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:6] Macro("PJSIP/33-00000945", "blkvm-clr,") in new stack 15037 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-clr:1] Set("PJSIP/33-00000945", "SHARED(BLKVM,SIP/Cosmote-0000037a)=") in new stack 15038 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-clr:2] Set("PJSIP/33-00000945", "GOSUB_RETVAL=") in new stack 15039 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-clr:3] MacroExit("PJSIP/33-00000945", "") in new stack 15040 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:7] ExecIf("PJSIP/33-00000945", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(num))=33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603)") in new stack 15041 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:8] ExecIf("PJSIP/33-00000945", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(name))=)") in new stack 15042 [2020-10-08 12:01:35] VERBOSE[12915][C-0000037f] bridge_channel.c: Channel PJSIP/33-00000945 joined 'simple_bridge' basic-bridge <5b5d6b94-a8a6-41ae-ad77-75fadbb69d5b> 15043 [2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] bridge_channel.c: Channel SIP/Cosmote-0000037a joined 'simple_bridge' basic-bridge <5b5d6b94-a8a6-41ae-ad77-75fadbb69d5b> 15044 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] bridge_channel.c: Channel PJSIP/33-00000945 left 'simple_bridge' basic-bridge <5b5d6b94-a8a6-41ae-ad77-75fadbb69d5b> 15045 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] app_stack.c: PJSIP/33-00000945 Internal Gosub(crm-hangup,s,1) start 15046 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/33-00000945", "Sending Hangup to CRM") in new stack 15047 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/33-00000945", "HANGUP CAUSE: 16") in new stack 15048 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] bridge_channel.c: Channel SIP/Cosmote-0000037a left 'simple_bridge' basic-bridge <5b5d6b94-a8a6-41ae-ad77-75fadbb69d5b> 15049 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/33-00000945", "0?Set(__CRM_VOICEMAIL=)") in new stack 15050 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/33-00000945", "MASTER CHANNEL: 1602147693.3264 = 1602147692.3261") in new stack 15051 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] app_macro.c: Spawn extension (macro-dial, s, 25) exited non-zero on 'SIP/Cosmote-0000037a' in macro 'dial' 15052 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Spawn extension (ext-group, 1, 18) exited non-zero on 'SIP/Cosmote-0000037a' 15053 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [h@ext-group:1] Macro("SIP/Cosmote-0000037a", "hangupcall,") in new stack 15054 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/Cosmote-0000037a", "1?theend") in new stack 15055 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-hangupcall,s,3) 15056 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/33-00000945", "1?return") in new stack 15057 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx_builtins.c: Goto (crm-hangup,s,8) 15058 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/33-00000945", "") in new stack 15059 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] app_stack.c: Spawn extension (macro-dial, s, 1) exited non-zero on 'PJSIP/33-00000945' 15060 [2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] app_stack.c: PJSIP/33-00000945 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 15061 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/Cosmote-0000037a", "0?Set(CDR(recordingfile)=)") in new stack 15062 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/Cosmote-0000037a", "PJSIP/33-00000945 montior file= /var/spool/asterisk/monitor/2020/10/08/in-+302510620630-2513500071-20201008-120132-1602147692.3261.wav") in new stack 15063 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/Cosmote-0000037a", "0?skipagi") in new stack 15064 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:6] AGI("SIP/Cosmote-0000037a", "attendedtransfer-rec-restart.php,PJSIP/33-00000945,/var/spool/asterisk/monitor/2020/10/08/in-+302510620630-2513500071-20201008-120132-1602147692.3261.wav") in new stack 15065 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/attendedtransfer-rec-restart.php 15066 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script attendedtransfer-rec-restart.php completed, returning 0 15067 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/Cosmote-0000037a", "") in new stack 15068 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/Cosmote-0000037a' in macro 'hangupcall' 15069 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000037a' 15070 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] app_stack.c: SIP/Cosmote-0000037a Internal Gosub(crm-hangup,s,1) start 15071 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:1] NoOp("SIP/Cosmote-0000037a", "Sending Hangup to CRM") in new stack 15072 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:2] NoOp("SIP/Cosmote-0000037a", "HANGUP CAUSE: 16") in new stack 15073 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:3] ExecIf("SIP/Cosmote-0000037a", "0?Set(__CRM_VOICEMAIL=)") in new stack 15074 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:4] NoOp("SIP/Cosmote-0000037a", "MASTER CHANNEL: 1602147692.3261 = 1602147692.3261") in new stack 15075 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:5] GotoIf("SIP/Cosmote-0000037a", "0?return") in new stack 15076 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:6] Set("SIP/Cosmote-0000037a", "__CRM_HANGUP=1") in new stack 15077 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:7] AGI("SIP/Cosmote-0000037a", "sangomacrm.agi") in new stack 15078 [2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi 15079 [2020-10-08 12:01:50] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script sangomacrm.agi completed, returning 0 15080 [2020-10-08 12:01:50] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:8] Return("SIP/Cosmote-0000037a", "") in new stack 15081 [2020-10-08 12:01:50] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000037a' 15082 [2020-10-08 12:01:50] VERBOSE[12876][C-0000037f] app_stack.c: SIP/Cosmote-0000037a Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 15083 [2020-10-08 12:01:50] VERBOSE[12877][C-0000037f] app_mixmonitor.c: MixMonitor close filestream (mixed) 15084 [2020-10-08 12:01:50] VERBOSE[12877][C-0000037f] app_mixmonitor.c: End MixMonitor Recording SIP/Cosmote-0000037a
ā10-08-2020 03:16 AM
This does not help much. You have to catch the pjsip logging to find eventually where is the "sip cancel" and decide whether the problem is with the phone or the FreePBX so try any external call answered by an internal extension. Meanwhile, check out on your FreePBX if you have āEnforce RFC7462ā option in Advanced Settings. Try toggling that to see if this will fix the problem with the Mark Answered Elsewhere.
Martin
ā10-08-2020 03:07 AM
You can catch it on the wire by a packet catcher program. Your LAN administrator will help you with it if necessary. Or try "sip set debug peer ..." command on freePBX command line. The log you provided bellow contain no content of SIP packets.
See also sip answered elsewhere recorded as a missed call
It seems they are discussing the same issue you have. They claimed it to be freePBX/PJSIP bug. It may be patched in most recent version of freePBX. Consider to ask freePBX experts for help.
ā10-08-2020 04:11 AM - edited ā10-08-2020 04:13 AM
āEnforce RFC7462ā was enabled, I disabled it, no difference, I re-enabled it, no difference.
With debug sip set to on here is the log during aswered call..
<--- SIP read from UDP:195.167.16.54:5060 ---> 31259 hello 31260 <-------------> 31261 [2020-10-08 14:04:23] VERBOSE[2276] chan_sip.c: Reliably Transmitting (NAT) to 195.167.16.54:5060: 31262 OPTIONS sip:ims.otenet.gr SIP/2.0 31263 Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK14887b42;rport 31264 Max-Forwards: 70 31265 From: "Unknown" <sip:+302510620630@192.168.1.5:5160>;tag=as66a91bca 31266 To: <sip:ims.otenet.gr> 31267 Contact: <sip:+302510620630@192.168.1.5:5160> 31268 Call-ID: 0561f4db1ce4029e6470e3245152202f@192.168.1.5:5160 31269 CSeq: 102 OPTIONS 31270 User-Agent: FPBX-15.0.16.75(13.36.0) 31271 Date: Thu, 08 Oct 2020 11:04:23 GMT 31272 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE 31273 Supported: replaces, timer 31274 Content-Length: 0 31275 31276 31277 --- 31278 [2020-10-08 14:04:23] VERBOSE[2276] chan_sip.c: 31279 <--- SIP read from UDP:195.167.16.54:5060 ---> 31280 SIP/2.0 604 Does Not Exist Anywhere 31281 Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK14887b42;received=80.106.83.137;rport=5160 31282 Call-ID: 0561f4db1ce4029e6470e3245152202f@192.168.1.5:5160 31283 From: "Unknown"<sip:+302510620630@192.168.1.5:5160>;tag=as66a91bca 31284 To: <sip:ims.otenet.gr>;tag=plxqzzoc 31285 CSeq: 102 OPTIONS 31286 Warning: 399 5244.684.I.261.12.344.0.13.24839.0.0.ims.otenet.gr "Unknown caller" 31287 Content-Length: 0 31288 31289 <-------------> 31290 [2020-10-08 14:04:23] VERBOSE[2276] chan_sip.c: --- (8 headers 0 lines) --- 31291 [2020-10-08 14:04:23] VERBOSE[2276] chan_sip.c: Really destroying SIP dialog '0561f4db1ce4029e6470e3245152202f@192.168.1.5:5160' Method: OPTIONS 31292 [2020-10-08 14:04:35] VERBOSE[2276] chan_sip.c: 31293 <--- SIP read from UDP:195.167.16.54:5060 ---> 31294 hello 31295 <-------------> 31296 [2020-10-08 14:05:04] VERBOSE[2276] chan_sip.c: 31297 <--- SIP read from UDP:195.167.16.54:5060 ---> 31298 hello 31299 <-------------> 31300 [2020-10-08 14:05:23] VERBOSE[2276] chan_sip.c: Reliably Transmitting (NAT) to 195.167.16.54:5060: 31301 OPTIONS sip:ims.otenet.gr SIP/2.0 31302 Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK5f7230f4;rport 31303 Max-Forwards: 70 31304 From: "Unknown" <sip:+302510620630@192.168.1.5:5160>;tag=as2acd6a1c 31305 To: <sip:ims.otenet.gr> 31306 Contact: <sip:+302510620630@192.168.1.5:5160> 31307 Call-ID: 5f4ea2e401aebe017ebced1438f77c5c@192.168.1.5:5160 31308 CSeq: 102 OPTIONS 31309 User-Agent: FPBX-15.0.16.75(13.36.0) 31310 Date: Thu, 08 Oct 2020 11:05:23 GMT 31311 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE 31312 Supported: replaces, timer 31313 Content-Length: 0 31314 31315 31316 --- 31317 [2020-10-08 14:05:23] VERBOSE[2276] chan_sip.c: 31318 <--- SIP read from UDP:195.167.16.54:5060 ---> 31319 SIP/2.0 604 Does Not Exist Anywhere 31320 Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK5f7230f4;received=80.106.83.137;rport=5160 31321 Call-ID: 5f4ea2e401aebe017ebced1438f77c5c@192.168.1.5:5160 31322 From: "Unknown"<sip:+302510620630@192.168.1.5:5160>;tag=as2acd6a1c 31323 To: <sip:ims.otenet.gr>;tag=d17m7dmz 31324 CSeq: 102 OPTIONS 31325 Warning: 399 5244.684.I.261.12.314.0.13.24839.0.0.ims.otenet.gr "Unknown caller" 31326 Content-Length: 0 31327 31328 <-------------> 31329 [2020-10-08 14:05:23] VERBOSE[2276] chan_sip.c: --- (8 headers 0 lines) --- 31330 [2020-10-08 14:05:23] VERBOSE[2276] chan_sip.c: Really destroying SIP dialog '5f4ea2e401aebe017ebced1438f77c5c@192.168.1.5:5160' Method: OPTIONS 31331 [2020-10-08 14:05:33] VERBOSE[2276] chan_sip.c: 31332 <--- SIP read from UDP:195.167.16.54:5060 ---> 31333 hello 31334 <-------------> 31335 [2020-10-08 14:05:40] VERBOSE[2276] chan_sip.c: 31336 <--- SIP read from UDP:195.167.16.54:5060 ---> 31337 INVITE sip:+302510620630@192.168.1.5:5160 SIP/2.0 31338 Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36 31339 Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14 31340 From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14 31341 To: <sip:+302510620630@NAT.OTE.GR;user=phone> 31342 CSeq: 1 INVITE 31343 Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,PRACK,UPDATE 31344 Contact: <sip:195.167.16.54:5060;Hpt=8eb2_16;CxtId=4;TRC=ffffffff-ffffffff> 31345 Max-Forwards: 63 31346 Supported: 100rel 31347 P-Asserted-Identity: <sip:+306944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone> 31348 P-Called-Party-ID: <tel:+302510620630> 31349 P-Early-Media: gated 31350 Content-Length: 232 31351 Content-Type: application/sdp 31352 31353 v=0 31354 o=- 2980790 2980790 IN IP4 195.167.22.126 31355 s=SBC call 31356 c=IN IP4 195.167.22.126 31357 t=0 0 31358 m=audio 20234 RTP/AVP 8 18 31359 b=RS:1000 31360 b=RR:3000 31361 a=rtpmap:8 PCMA/8000 31362 a=rtpmap:18 G729/8000 31363 a=fmtp:18 annexb=no 31364 a=ptime:20 31365 a=sendrecv 31366 <-------------> 31367 [2020-10-08 14:05:40] VERBOSE[2276] chan_sip.c: --- (15 headers 13 lines) --- 31368 [2020-10-08 14:05:40] VERBOSE[2276] chan_sip.c: Sending to 195.167.16.54:5060 (NAT) 31369 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Sending to 195.167.16.54:5060 (NAT) 31370 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Using INVITE request as basis request - asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14 31371 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found peer 'Cosmote' for '6944314710' from 195.167.16.54:5060 31372 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] netsock2.c: Using SIP RTP TOS bits 184 31373 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] netsock2.c: Using SIP RTP CoS mark 5 31374 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Got SDP version 2980790 and unique parts [- 2980790 IN IP4 195.167.22.126] 31375 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found RTP audio format 8 31376 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found RTP audio format 18 31377 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found audio description format PCMA for ID 8 31378 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found audio description format G729 for ID 18 31379 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Capabilities: us - (g722|alaw), peer - audio=(alaw|g729)/video=(nothing)/text=(nothing), combined - (alaw) 31380 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Non-codec capabilities (dtmf): us - 0x1 (telephone-event|), peer - 0x0 (nothing), combined - 0x0 (nothing) 31381 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Peer audio RTP is at port 195.167.22.126:20234 31382 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Looking for +302510620630 in from-trunk-sip-Cosmote (domain 192.168.1.5) 31383 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] sip/route.c: sip_route_dump: route/path hop: <sip:195.167.16.54:5060;Hpt=8eb2_16;CxtId=4;TRC=ffffffff-ffffffff> 31384 [2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: 31385 <--- Transmitting (NAT) to 195.167.16.54:5060 ---> 31386 SIP/2.0 100 Trying 31387 Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060 31388 From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14 31389 To: <sip:+302510620630@NAT.OTE.GR;user=phone> 31390 Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14 31391 CSeq: 1 INVITE 31392 Server: FPBX-15.0.16.75(13.36.0) 31393 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE 31394 Supported: replaces, timer 31395 Contact: <sip:+302510620630@192.168.1.5:5160> 31396 Content-Length: 0 31397 31398 31399 <------------> 31400 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:1] Set("SIP/Cosmote-0000039f", "GROUP()=OUT_1") in new stack 31401 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:2] Goto("SIP/Cosmote-0000039f", "from-trunk,+302510620630,1") in new stack 31402 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (from-trunk,+302510620630,1) 31403 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:1] Set("SIP/Cosmote-0000039f", "__DIRECTION=INBOUND") in new stack 31404 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:2] Gosub("SIP/Cosmote-0000039f", "sub-record-check,s,1(in,+302510620630,force)") in new stack 31405 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-0000039f", "0?initialized") in new stack 31406 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:2] Set("SIP/Cosmote-0000039f", "__REC_STATUS=INITIALIZED") in new stack 31407 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:3] Set("SIP/Cosmote-0000039f", "NOW=1602155140") in new stack 31408 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:4] Set("SIP/Cosmote-0000039f", "__DAY=08") in new stack 31409 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:5] Set("SIP/Cosmote-0000039f", "__MONTH=10") in new stack 31410 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:6] Set("SIP/Cosmote-0000039f", "__YEAR=2020") in new stack 31411 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:7] Set("SIP/Cosmote-0000039f", "__TIMESTR=20201008-140540") in new stack 31412 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:8] Set("SIP/Cosmote-0000039f", "__FROMEXTEN=unknown") in new stack 31413 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:9] Set("SIP/Cosmote-0000039f", "__MON_FMT=wav") in new stack 31414 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-0000039f", "Recordings initialized") in new stack 31415 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-0000039f", "0?Set(ARG3=dontcare)") in new stack 31416 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-0000039f", "REC_POLICY_MODE_SAVE=") in new stack 31417 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-0000039f", "0?Set(REC_STATUS=NO)") in new stack 31418 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-0000039f", "2?checkaction") in new stack 31419 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,s,17) 31420 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-0000039f", "1?sub-record-check,in,1") in new stack 31421 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,in,1) 31422 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:1] NoOp("SIP/Cosmote-0000039f", "Inbound Recording Check to +302510620630") in new stack 31423 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:2] Set("SIP/Cosmote-0000039f", "FROMEXTEN=unknown") in new stack 31424 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:3] ExecIf("SIP/Cosmote-0000039f", "10?Set(FROMEXTEN=6944314710)") in new stack 31425 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:4] Gosub("SIP/Cosmote-0000039f", "recordcheck,1(force,in,+302510620630)") in new stack 31426 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-0000039f", "Starting recording check against force") in new stack 31427 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-0000039f", "force") in new stack 31428 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,recordcheck,5) 31429 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:5] Set("SIP/Cosmote-0000039f", "__REC_POLICY_MODE=FORCE") in new stack 31430 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:6] GotoIf("SIP/Cosmote-0000039f", "1?startrec") in new stack 31431 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,recordcheck,16) 31432 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:16] NoOp("SIP/Cosmote-0000039f", "Starting recording: in, +302510620630") in new stack 31433 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:17] Set("SIP/Cosmote-0000039f", "__CALLFILENAME=in-+302510620630-6944314710-20201008-140540-1602155140.3413") in new stack 31434 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:18] MixMonitor("SIP/Cosmote-0000039f", "2020/10/08/in-+302510620630-6944314710-20201008-140540-1602155140.3413.wav,abi(LOCAL_MIXMON_ID),") in new stack 31435 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:19] Set("SIP/Cosmote-0000039f", "__MIXMON_ID=0x3a1b370") in new stack 31436 [2020-10-08 14:05:40] VERBOSE[11797][C-000003a4] app_mixmonitor.c: Begin MixMonitor Recording SIP/Cosmote-0000039f 31437 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:20] Set("SIP/Cosmote-0000039f", "__RECORD_ID=SIP/Cosmote-0000039f") in new stack 31438 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:21] Set("SIP/Cosmote-0000039f", "__REC_STATUS=RECORDING") in new stack 31439 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:22] Set("SIP/Cosmote-0000039f", "CDR(recordingfile)=in-+302510620630-6944314710-20201008-140540-1602155140.3413.wav") in new stack 31440 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:23] Return("SIP/Cosmote-0000039f", "") in new stack 31441 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:5] Return("SIP/Cosmote-0000039f", "") in new stack 31442 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:3] Set("SIP/Cosmote-0000039f", "CHANNEL(tonezone)=gr") in new stack 31443 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:4] Set("SIP/Cosmote-0000039f", "__FROM_DID=+302510620630") in new stack 31444 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:5] Set("SIP/Cosmote-0000039f", "returnhere=1") in new stack 31445 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:6] Gosub("SIP/Cosmote-0000039f", "app-blacklist-check,s,1()") in new stack 31446 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@app-blacklist-check:1] GotoIf("SIP/Cosmote-0000039f", "0?blacklisted") in new stack 31447 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@app-blacklist-check:2] Set("SIP/Cosmote-0000039f", "CALLED_BLACKLIST=1") in new stack 31448 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@app-blacklist-check:3] Return("SIP/Cosmote-0000039f", "") in new stack 31449 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:7] Set("SIP/Cosmote-0000039f", "CDR(did)=+302510620630") in new stack 31450 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:8] GotoIf("SIP/Cosmote-0000039f", "0?") in new stack 31451 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:9] ExecIf("SIP/Cosmote-0000039f", "1 ?Set(CALLERID(name)=6944314710)") in new stack 31452 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:10] Set("SIP/Cosmote-0000039f", "__MOHCLASS=") in new stack 31453 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:11] Set("SIP/Cosmote-0000039f", "__REVERSAL_REJECT=FALSE") in new stack 31454 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:12] GotoIf("SIP/Cosmote-0000039f", "1?post-reverse-charge") in new stack 31455 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (from-trunk,+302510620630,14) 31456 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:14] NoOp("SIP/Cosmote-0000039f", "") in new stack 31457 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:15] Set("SIP/Cosmote-0000039f", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack 31458 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:16] Set("SIP/Cosmote-0000039f", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack 31459 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:17] Set("SIP/Cosmote-0000039f", "CALLERID(name-pres)=allowed_not_screened") in new stack 31460 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:18] Set("SIP/Cosmote-0000039f", "CALLERID(num-pres)=allowed_not_screened") in new stack 31461 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:19] Gosub("SIP/Cosmote-0000039f", "cidlookup,cidlookup_1,1()") in new stack 31462 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [cidlookup_1@cidlookup:1] AGI("SIP/Cosmote-0000039f", "contactmanager.agi, 6944314710,,4") in new stack 31463 [2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/contactmanager.agi 31464 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script contactmanager.agi completed, returning 0 31465 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [cidlookup_1@cidlookup:2] ExecIf("SIP/Cosmote-0000039f", "0?Set(CALLERID(name)=Unknown)") in new stack 31466 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [cidlookup_1@cidlookup:3] Return("SIP/Cosmote-0000039f", "") in new stack 31467 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:20] Set("SIP/Cosmote-0000039f", "CIDSFSCHEME=QUxMfEFMTA==") in new stack 31468 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:21] AGI("SIP/Cosmote-0000039f", "/var/www/html/admin/modules/superfecta/agi/superfecta.agi") in new stack 31469 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi 31470 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Executing Scheme.. 31471 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Scheme Asked is: ALL 31472 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The DID is: +302510620630 31473 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNUM is: 6944314710 31474 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNAME is: 6944314710 31475 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: 31476 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Starting scheme Default 31477 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: No callerid found 31478 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_NEW: 6944314710 31479 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_OLD: 6944314710 31480 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: CID Determined to be: '6944314710' 31481 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Attempting to set lookupcid 31482 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi completed, returning 0 31483 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:22] Set("SIP/Cosmote-0000039f", "CALLERID(name)=6944314710") in new stack 31484 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:23] NoOp("SIP/Cosmote-0000039f", "CallerID Entry Point") in new stack 31485 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:24] Set("SIP/Cosmote-0000039f", "__CRM_DIRECTION=INBOUND") in new stack 31486 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:25] Set("SIP/Cosmote-0000039f", "__CRM_SOURCE=6944314710") in new stack 31487 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:26] Set("SIP/Cosmote-0000039f", "__CRM_LINKEDID=1602155140.3413") in new stack 31488 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:27] AGI("SIP/Cosmote-0000039f", "sangomacrm.agi,true") in new stack 31489 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi 31490 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script sangomacrm.agi completed, returning 0 31491 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:28] ExecIf("SIP/Cosmote-0000039f", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 31492 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:29] Goto("SIP/Cosmote-0000039f", "ext-group,1,1") in new stack 31493 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (ext-group,1,1) 31494 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:1] GotoIf("SIP/Cosmote-0000039f", "0?cid") in new stack 31495 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:2] PlayTones("SIP/Cosmote-0000039f", "ring") in new stack 31496 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:3] Progress("SIP/Cosmote-0000039f", "") in new stack 31497 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] chan_sip.c: Audio is at 12316 31498 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] chan_sip.c: Adding codec alaw to SDP 31499 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] chan_sip.c: 31500 <--- Transmitting (NAT) to 195.167.16.54:5060 ---> 31501 SIP/2.0 183 Session Progress 31502 Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060 31503 From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14 31504 To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1 31505 Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14 31506 CSeq: 1 INVITE 31507 Server: FPBX-15.0.16.75(13.36.0) 31508 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE 31509 Supported: replaces, timer 31510 Contact: <sip:+302510620630@192.168.1.5:5160> 31511 Content-Type: application/sdp 31512 Content-Length: 192 31513 31514 v=0 31515 o=root 895944538 895944538 IN IP4 192.168.1.5 31516 s=Asterisk PBX 13.36.0 31517 c=IN IP4 192.168.1.5 31518 t=0 0 31519 m=audio 12316 RTP/AVP 8 31520 a=rtpmap:8 PCMA/8000 31521 a=ptime:20 31522 a=maxptime:150 31523 a=sendrecv 31524 31525 <------------> 31526 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:4] Macro("SIP/Cosmote-0000039f", "user-callerid,") in new stack 31527 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:1] Set("SIP/Cosmote-0000039f", "TOUCH_MONITOR=1602155140.3413") in new stack 31528 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:2] Set("SIP/Cosmote-0000039f", "AMPUSER=6944314710") in new stack 31529 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:3] Set("SIP/Cosmote-0000039f", "HOTDESCKCHAN=Cosmote-0000039f") in new stack 31530 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:4] Set("SIP/Cosmote-0000039f", "HOTDESKEXTEN=Cosmote") in new stack 31531 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:5] Set("SIP/Cosmote-0000039f", "HOTDESKCALL=0") in new stack 31532 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:6] ExecIf("SIP/Cosmote-0000039f", "0?Set(HOTDESKCALL=1)") in new stack 31533 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:7] ExecIf("SIP/Cosmote-0000039f", "0?Set(CALLERID(name)=)") in new stack 31534 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:8] GotoIf("SIP/Cosmote-0000039f", "0?report") in new stack 31535 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:9] ExecIf("SIP/Cosmote-0000039f", "1?Set(REALCALLERIDNUM=6944314710)") in new stack 31536 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:10] Set("SIP/Cosmote-0000039f", "AMPUSER=") in new stack 31537 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:11] GotoIf("SIP/Cosmote-0000039f", "0?limit") in new stack 31538 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:12] Set("SIP/Cosmote-0000039f", "AMPUSERCIDNAME=") in new stack 31539 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:13] ExecIf("SIP/Cosmote-0000039f", "0?Set(__CIDMASQUERADING=TRUE)") in new stack 31540 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:14] GotoIf("SIP/Cosmote-0000039f", "1?report") in new stack 31541 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-user-callerid,s,23) 31542 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:23] NoOp("SIP/Cosmote-0000039f", "Macro Depth is 1") in new stack 31543 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:24] GotoIf("SIP/Cosmote-0000039f", "1?report2:macroerror") in new stack 31544 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-user-callerid,s,25) 31545 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:25] GotoIf("SIP/Cosmote-0000039f", "0?continue") in new stack 31546 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:26] ExecIf("SIP/Cosmote-0000039f", "1?Set(__CALLEE_ACCOUNCODE=)") in new stack 31547 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:27] Set("SIP/Cosmote-0000039f", "__TTL=64") in new stack 31548 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:28] GotoIf("SIP/Cosmote-0000039f", "1?continue") in new stack 31549 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-user-callerid,s,44) 31550 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:44] Set("SIP/Cosmote-0000039f", "CALLERID(number)=6944314710") in new stack 31551 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:45] Set("SIP/Cosmote-0000039f", "CALLERID(name)=6944314710") in new stack 31552 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:46] GotoIf("SIP/Cosmote-0000039f", "0?cnum") in new stack 31553 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:47] Set("SIP/Cosmote-0000039f", "CDR(cnam)=6944314710") in new stack 31554 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:48] Set("SIP/Cosmote-0000039f", "CDR(cnum)=6944314710") in new stack 31555 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:49] Set("SIP/Cosmote-0000039f", "CHANNEL(language)=en") in new stack 31556 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:5] Macro("SIP/Cosmote-0000039f", "blkvm-setifempty,") in new stack 31557 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:1] GotoIf("SIP/Cosmote-0000039f", "1?init") in new stack 31558 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-blkvm-setifempty,s,4) 31559 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:4] Set("SIP/Cosmote-0000039f", "__BLKVM_CHANNEL=SIP/Cosmote-0000039f") in new stack 31560 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:5] Set("SIP/Cosmote-0000039f", "SHARED(BLKVM,SIP/Cosmote-0000039f)=TRUE") in new stack 31561 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:6] Set("SIP/Cosmote-0000039f", "GOSUB_RETVAL=TRUE") in new stack 31562 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:7] MacroExit("SIP/Cosmote-0000039f", "") in new stack 31563 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:6] GotoIf("SIP/Cosmote-0000039f", "1?skipov") in new stack 31564 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (ext-group,1,9) 31565 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:9] Set("SIP/Cosmote-0000039f", "RRNODEST=") in new stack 31566 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:10] Set("SIP/Cosmote-0000039f", "__NODEST=1") in new stack 31567 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:11] GosubIf("SIP/Cosmote-0000039f", "0?sub-rgsetcid,s,1()") in new stack 31568 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:12] Gosub("SIP/Cosmote-0000039f", "sub-record-check,s,1(rg,1,dontcare)") in new stack 31569 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-0000039f", "10?initialized") in new stack 31570 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,s,10) 31571 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-0000039f", "Recordings initialized") in new stack 31572 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-0000039f", "0?Set(ARG3=dontcare)") in new stack 31573 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-0000039f", "REC_POLICY_MODE_SAVE=FORCE") in new stack 31574 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-0000039f", "0?Set(REC_STATUS=NO)") in new stack 31575 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-0000039f", "2?checkaction") in new stack 31576 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,s,17) 31577 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-0000039f", "0?sub-record-check,rg,1") in new stack 31578 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:18] NoOp("SIP/Cosmote-0000039f", "Generic rg Recording Check - 6944314710 1") in new stack 31579 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:19] Gosub("SIP/Cosmote-0000039f", "recordcheck,1(dontcare,rg,1)") in new stack 31580 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-0000039f", "Starting recording check against dontcare") in new stack 31581 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-0000039f", "dontcare") in new stack 31582 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,recordcheck,3) 31583 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:3] Return("SIP/Cosmote-0000039f", "") in new stack 31584 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:20] Return("SIP/Cosmote-0000039f", "") in new stack 31585 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:13] Set("SIP/Cosmote-0000039f", "RingGroupMethod=ringall") in new stack 31586 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:14] Set("SIP/Cosmote-0000039f", "__ALT_CONFIRM_MSG=") in new stack 31587 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:15] GotoIf("SIP/Cosmote-0000039f", "0?RGVQANNOUNCE:NORGVQANNOUNCE") in new stack 31588 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (ext-group,1,18) 31589 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:18] Macro("SIP/Cosmote-0000039f", "dial,120,HhTtrQ(ANSWERED_ELSEWHERE),31-32-33") in new stack 31590 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:1] NoOp("SIP/Cosmote-0000039f", "Blind Transfer: , Attended Transfer: , User: , Alert Info: ") in new stack 31591 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:2] Set("SIP/Cosmote-0000039f", "__CRM_SOURCE=6944314710") in new stack 31592 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:3] ExecIf("SIP/Cosmote-0000039f", "0?Set(ALERT_INFO=)") in new stack 31593 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:4] ExecIf("SIP/Cosmote-0000039f", "0?Set(ALERT_INFO=)") in new stack 31594 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:5] ExecIf("SIP/Cosmote-0000039f", "0?Set(ALERT_INFO=)") in new stack 31595 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:6] ExecIf("SIP/Cosmote-0000039f", "0?Set(CHANNEL(musicclass)=)") in new stack 31596 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:7] AGI("SIP/Cosmote-0000039f", "dialparties.agi") in new stack 31597 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi 31598 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Starting New Dialparties.agi 31599 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Caller ID name is '6944314710' number is '6944314710' 31600 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: CW Ignore is: 31601 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: CF Ignore is: 31602 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: CW IN_USE/BUSY is: 1 31603 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Methodology of ring is 'ringall' 31604 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Added extension 31 to extension map 31605 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Added extension 32 to extension map 31606 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Added extension 33 to extension map 31607 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 31 cf is disabled 31608 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 32 cf is disabled 31609 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 33 cf is disabled 31610 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 31 do not disturb is disabled 31611 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 32 do not disturb is disabled 31612 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 33 do not disturb is disabled 31613 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/31 31614 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/31/sip:31@192.168.1.10:5060 31615 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: dbset CALLTRACE/31 to 6944314710 31616 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/32 31617 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/32/sip:32@192.168.1.11:5060 31618 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: dbset CALLTRACE/32 to 6944314710 31619 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/33 31620 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603 31621 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: dbset CALLTRACE/33 to 6944314710 31622 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Filtered ARG3: 31-32-33 31623 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: RVOL_MODE '' 31624 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: RVOL is: 31625 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: RVOLPARENT is: 31626 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script dialparties.agi completed, returning 0 31627 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:8] GotoIf("SIP/Cosmote-0000039f", "1?normdial") in new stack 31628 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-dial,s,11) 31629 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:11] NoOp("SIP/Cosmote-0000039f", "Returned from dialparties with groups to dial") in new stack 31630 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:12] NoOp("SIP/Cosmote-0000039f", "ringall array ") in new stack 31631 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:13] Set("SIP/Cosmote-0000039f", "__FMGL_DIAL=") in new stack 31632 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:14] Set("SIP/Cosmote-0000039f", "LOOPCNT=3") in new stack 31633 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:15] Set("SIP/Cosmote-0000039f", "ITER=1") in new stack 31634 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000039f", "__EXTTOCALL=31") in new stack 31635 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000039f", "Working with 31") in new stack 31636 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 31637 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 31638 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000039f", "ITER=2") in new stack 31639 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000039f", "1?ndloopbegin") in new stack 31640 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-dial,s,16) 31641 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000039f", "__EXTTOCALL=32") in new stack 31642 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000039f", "Working with 32") in new stack 31643 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 31644 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 31645 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000039f", "ITER=3") in new stack 31646 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000039f", "1?ndloopbegin") in new stack 31647 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-dial,s,16) 31648 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000039f", "__EXTTOCALL=33") in new stack 31649 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000039f", "Working with 33") in new stack 31650 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 31651 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack 31652 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000039f", "ITER=4") in new stack 31653 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000039f", "0?ndloopbegin") in new stack 31654 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:22] Macro("SIP/Cosmote-0000039f", "dial-ringall-predial-hook,") in new stack 31655 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial-ringall-predial-hook:1] MacroExit("SIP/Cosmote-0000039f", "") in new stack 31656 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:23] ExecIf("SIP/Cosmote-0000039f", "0?Set(CWRING=r(callwaiting)):Set(CWRING=)") in new stack 31657 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:24] ExecIf("SIP/Cosmote-0000039f", "0?Set(ds=PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)g)") in new stack 31658 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:25] Dial("SIP/Cosmote-0000039f", "PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)b(func-apply-sipheaders^s^1),") in new stack 31659 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/31-000009b6 Internal Gosub(func-apply-sipheaders,s,1) start 31660 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/31-000009b6", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 31661 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/31-000009b6", "Applying SIP Headers to channel PJSIP/31-000009b6") in new stack 31662 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/31-000009b6", "TECH=PJSIP") in new stack 31663 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/31-000009b6", "SIPHEADERKEYS=") in new stack 31664 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/31-000009b6", "0") in new stack 31665 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_while.c: Jumping to priority 13 31666 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/31-000009b6", "") in new stack 31667 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-000009b6' 31668 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/31-000009b6 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL= 31669 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/32-000009b7 Internal Gosub(func-apply-sipheaders,s,1) start 31670 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/32-000009b7", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 31671 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/32-000009b7", "Applying SIP Headers to channel PJSIP/32-000009b7") in new stack 31672 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/32-000009b7", "TECH=PJSIP") in new stack 31673 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/32-000009b7", "SIPHEADERKEYS=") in new stack 31674 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/32-000009b7", "0") in new stack 31675 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_while.c: Jumping to priority 13 31676 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/32-000009b7", "") in new stack 31677 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/32-000009b7' 31678 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/32-000009b7 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL= 31679 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/33-000009b8 Internal Gosub(func-apply-sipheaders,s,1) start 31680 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/33-000009b8", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack 31681 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/33-000009b8", "Applying SIP Headers to channel PJSIP/33-000009b8") in new stack 31682 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/33-000009b8", "TECH=PJSIP") in new stack 31683 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/33-000009b8", "SIPHEADERKEYS=") in new stack 31684 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/33-000009b8", "0") in new stack 31685 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_while.c: Jumping to priority 13 31686 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/33-000009b8", "") in new stack 31687 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-000009b8' 31688 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/33-000009b8 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL= 31689 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: Called PJSIP/31/sip:31@192.168.1.10:5060 31690 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: Called PJSIP/32/sip:32@192.168.1.11:5060 31691 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: Called PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603 31692 [2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184 31693 [2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 31694 [2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio CoS mark 5 31695 [2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184 31696 [2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 31697 [2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio CoS mark 5 31698 [2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184 31699 [2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field. 31700 [2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio CoS mark 5 31701 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/33-000009b8 connected line has changed. Saving it until answer for SIP/Cosmote-0000039f 31702 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/32-000009b7 connected line has changed. Saving it until answer for SIP/Cosmote-0000039f 31703 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/31-000009b6 connected line has changed. Saving it until answer for SIP/Cosmote-0000039f 31704 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/31-000009b6 is ringing 31705 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/31-000009b6 is ringing 31706 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/33-000009b8 is ringing 31707 [2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/33-000009b8 is ringing 31708 [2020-10-08 14:05:42] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/32-000009b7 is ringing 31709 [2020-10-08 14:05:42] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/32-000009b7 is ringing 31710 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/32-000009b7 answered SIP/Cosmote-0000039f 31711 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/31-000009b6 Internal Gosub(crm-hangup,s,1) start 31712 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/31-000009b6", "Sending Hangup to CRM") in new stack 31713 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/31-000009b6", "HANGUP CAUSE: 26") in new stack 31714 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/31-000009b6", "0?Set(__CRM_VOICEMAIL=)") in new stack 31715 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/31-000009b6", "MASTER CHANNEL: 1602155141.3414 = 1602155140.3413") in new stack 31716 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/31-000009b6", "1?return") in new stack 31717 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (crm-hangup,s,8) 31718 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/31-000009b6", "") in new stack 31719 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-000009b6' 31720 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/31-000009b6 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 31721 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/33-000009b8 Internal Gosub(crm-hangup,s,1) start 31722 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/33-000009b8", "Sending Hangup to CRM") in new stack 31723 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/33-000009b8", "HANGUP CAUSE: 26") in new stack 31724 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/33-000009b8", "0?Set(__CRM_VOICEMAIL=)") in new stack 31725 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/33-000009b8", "MASTER CHANNEL: 1602155141.3416 = 1602155140.3413") in new stack 31726 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/33-000009b8", "1?return") in new stack 31727 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (crm-hangup,s,8) 31728 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/33-000009b8", "") in new stack 31729 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-000009b8' 31730 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/33-000009b8 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 31731 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:1] Set("PJSIP/32-000009b7", "__MACRO_RESULT=") in new stack 31732 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:2] Set("PJSIP/32-000009b7", "CFIGNORE=") in new stack 31733 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:3] Set("PJSIP/32-000009b7", "MASTER_CHANNEL(CFIGNORE)=") in new stack 31734 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:4] Set("PJSIP/32-000009b7", "FORWARD_CONTEXT=from-internal") in new stack 31735 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:5] Set("PJSIP/32-000009b7", "MASTER_CHANNEL(FORWARD_CONTEXT)=from-internal") in new stack 31736 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:6] Macro("PJSIP/32-000009b7", "blkvm-clr,") in new stack 31737 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-clr:1] Set("PJSIP/32-000009b7", "SHARED(BLKVM,SIP/Cosmote-0000039f)=") in new stack 31738 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-clr:2] Set("PJSIP/32-000009b7", "GOSUB_RETVAL=") in new stack 31739 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-clr:3] MacroExit("PJSIP/32-000009b7", "") in new stack 31740 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:7] ExecIf("PJSIP/32-000009b7", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(num))=32/sip:32@192.168.1.11:5060)") in new stack 31741 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:8] ExecIf("PJSIP/32-000009b7", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(name))=)") in new stack 31742 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] chan_sip.c: Audio is at 12316 31743 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] chan_sip.c: Adding codec alaw to SDP 31744 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] chan_sip.c: 31745 <--- Reliably Transmitting (NAT) to 195.167.16.54:5060 ---> 31746 SIP/2.0 200 OK 31747 Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060 31748 From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14 31749 To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1 31750 Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14 31751 CSeq: 1 INVITE 31752 Server: FPBX-15.0.16.75(13.36.0) 31753 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE 31754 Supported: replaces, timer 31755 Contact: <sip:+302510620630@192.168.1.5:5160> 31756 Content-Type: application/sdp 31757 Content-Length: 192 31758 31759 v=0 31760 o=root 895944538 895944538 IN IP4 192.168.1.5 31761 s=Asterisk PBX 13.36.0 31762 c=IN IP4 192.168.1.5 31763 t=0 0 31764 m=audio 12316 RTP/AVP 8 31765 a=rtpmap:8 PCMA/8000 31766 a=ptime:20 31767 a=maxptime:150 31768 a=sendrecv 31769 31770 <------------> 31771 [2020-10-08 14:05:56] VERBOSE[11847][C-000003a4] bridge_channel.c: Channel PJSIP/32-000009b7 joined 'simple_bridge' basic-bridge <76d7119a-e294-4d3b-afe2-910169279666> 31772 [2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] bridge_channel.c: Channel SIP/Cosmote-0000039f joined 'simple_bridge' basic-bridge <76d7119a-e294-4d3b-afe2-910169279666> 31773 [2020-10-08 14:05:56] VERBOSE[2276] chan_sip.c: Retransmitting #1 (NAT) to 195.167.16.54:5060: 31774 SIP/2.0 200 OK 31775 Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060 31776 From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14 31777 To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1 31778 Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14 31779 CSeq: 1 INVITE 31780 Server: FPBX-15.0.16.75(13.36.0) 31781 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE 31782 Supported: replaces, timer 31783 Contact: <sip:+302510620630@192.168.1.5:5160> 31784 Content-Type: application/sdp 31785 Content-Length: 192 31786 31787 v=0 31788 o=root 895944538 895944538 IN IP4 192.168.1.5 31789 s=Asterisk PBX 13.36.0 31790 c=IN IP4 192.168.1.5 31791 t=0 0 31792 m=audio 12316 RTP/AVP 8 31793 a=rtpmap:8 PCMA/8000 31794 a=ptime:20 31795 a=maxptime:150 31796 a=sendrecv 31797 31798 --- 31799 [2020-10-08 14:05:56] VERBOSE[2276] chan_sip.c: 31800 <--- SIP read from UDP:195.167.16.54:5060 ---> 31801 ACK sip:+302510620630@192.168.1.5:5160 SIP/2.0 31802 Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bK5ibfh2iekxbe3k6f3cw47ccbw;Role=3;Hpt=8eb2_36 31803 Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14 31804 From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14 31805 To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1 31806 CSeq: 1 ACK 31807 Max-Forwards: 63 31808 Content-Length: 0 31809 31810 <-------------> 31811 [2020-10-08 14:05:56] VERBOSE[2276] chan_sip.c: --- (8 headers 0 lines) --- 31812 [2020-10-08 14:06:02] VERBOSE[2276] chan_sip.c: 31813 <--- SIP read from UDP:195.167.16.54:5060 ---> 31814 hello 31815 <-------------> 31816 Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14 31817 From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14 31818 To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1 31819 CSeq: 2 BYE 31820 Max-Forwards: 63 31821 Reason: Q.850;cause=16 31822 Content-Length: 0 31823 31824 <-------------> 31825 [2020-10-08 14:06:17] VERBOSE[2276] chan_sip.c: --- (9 headers 0 lines) --- 31826 [2020-10-08 14:06:17] VERBOSE[2276][C-000003a4] chan_sip.c: Sending to 195.167.16.54:5060 (NAT) 31827 [2020-10-08 14:06:17] VERBOSE[2276][C-000003a4] chan_sip.c: Scheduling destruction of SIP dialog 'asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14' in 6976 ms (Method: BYE) 31828 [2020-10-08 14:06:17] VERBOSE[2276][C-000003a4] chan_sip.c: 31829 <--- Transmitting (NAT) to 195.167.16.54:5060 ---> 31830 SIP/2.0 200 OK 31831 Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bK7kwex4chb2fc0x6x7xi07cbcc;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060 31832 From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14 31833 To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1 31834 Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14 31835 CSeq: 2 BYE 31836 Server: FPBX-15.0.16.75(13.36.0) 31837 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE 31838 Supported: replaces, timer 31839 Content-Length: 0 31840 31841 31842 <------------> 31843 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] bridge_channel.c: Channel SIP/Cosmote-0000039f left 'simple_bridge' basic-bridge <76d7119a-e294-4d3b-afe2-910169279666> 31844 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] app_macro.c: Spawn extension (macro-dial, s, 25) exited non-zero on 'SIP/Cosmote-0000039f' in macro 'dial' 31845 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Spawn extension (ext-group, 1, 18) exited non-zero on 'SIP/Cosmote-0000039f' 31846 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [h@ext-group:1] Macro("SIP/Cosmote-0000039f", "hangupcall,") in new stack 31847 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/Cosmote-0000039f", "1?theend") in new stack 31848 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-hangupcall,s,3) 31849 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/Cosmote-0000039f", "0?Set(CDR(recordingfile)=)") in new stack 31850 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] bridge_channel.c: Channel PJSIP/32-000009b7 left 'simple_bridge' basic-bridge <76d7119a-e294-4d3b-afe2-910169279666> 31851 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] app_stack.c: PJSIP/32-000009b7 Internal Gosub(crm-hangup,s,1) start 31852 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/32-000009b7", "Sending Hangup to CRM") in new stack 31853 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/32-000009b7", "HANGUP CAUSE: 16") in new stack 31854 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/32-000009b7", "0?Set(__CRM_VOICEMAIL=)") in new stack 31855 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/32-000009b7", "MASTER CHANNEL: 1602155141.3415 = 1602155140.3413") in new stack 31856 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/32-000009b7", "1?return") in new stack 31857 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx_builtins.c: Goto (crm-hangup,s,8) 31858 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/32-000009b7", "") in new stack 31859 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] app_stack.c: Spawn extension (macro-dial, s, 1) exited non-zero on 'PJSIP/32-000009b7' 31860 [2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] app_stack.c: PJSIP/32-000009b7 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 31861 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/Cosmote-0000039f", "PJSIP/33-000009b8 montior file= /var/spool/asterisk/monitor/2020/10/08/in-+302510620630-6944314710-20201008-140540-1602155140.3413.wav") in new stack 31862 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/Cosmote-0000039f", "0?skipagi") in new stack 31863 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:6] AGI("SIP/Cosmote-0000039f", "attendedtransfer-rec-restart.php,PJSIP/33-000009b8,/var/spool/asterisk/monitor/2020/10/08/in-+302510620630-6944314710-20201008-140540-1602155140.3413.wav") in new stack 31864 [2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/attendedtransfer-rec-restart.php 31865 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script attendedtransfer-rec-restart.php completed, returning 0 31866 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/Cosmote-0000039f", "") in new stack 31867 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/Cosmote-0000039f' in macro 'hangupcall' 31868 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000039f' 31869 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: SIP/Cosmote-0000039f Internal Gosub(crm-hangup,s,1) start 31870 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:1] NoOp("SIP/Cosmote-0000039f", "Sending Hangup to CRM") in new stack 31871 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:2] NoOp("SIP/Cosmote-0000039f", "HANGUP CAUSE: 16") in new stack 31872 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:3] ExecIf("SIP/Cosmote-0000039f", "0?Set(__CRM_VOICEMAIL=)") in new stack 31873 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:4] NoOp("SIP/Cosmote-0000039f", "MASTER CHANNEL: 1602155140.3413 = 1602155140.3413") in new stack 31874 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:5] GotoIf("SIP/Cosmote-0000039f", "0?return") in new stack 31875 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:6] Set("SIP/Cosmote-0000039f", "__CRM_HANGUP=1") in new stack 31876 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:7] AGI("SIP/Cosmote-0000039f", "sangomacrm.agi") in new stack 31877 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi 31878 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script sangomacrm.agi completed, returning 0 31879 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:8] Return("SIP/Cosmote-0000039f", "") in new stack 31880 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000039f' 31881 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: SIP/Cosmote-0000039f Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 31882 [2020-10-08 14:06:18] VERBOSE[11797][C-000003a4] app_mixmonitor.c: MixMonitor close filestream (mixed) 31883 [2020-10-08 14:06:18] VERBOSE[11797][C-000003a4] app_mixmonitor.c: End MixMonitor Recording SIP/Cosmote-0000039f 31884 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000039f' 31885 [2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: SIP/Cosmote-0000039f Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL= 31886 [2020-10-08 14:06:18] VERBOSE[11797][C-000003a4] app_mixmonitor.c: MixMonitor close filestream (mixed) 31887 [2020-10-08 14:06:18] VERBOSE[11797][C-000003a4] app_mixmonitor.c: End MixMonitor Recording SIP/Cosmote-0000039f 31888 [2020-10-08 14:06:23] VERBOSE[2276] chan_sip.c: Reliably Transmitting (NAT) to 195.167.16.54:5060: 31889 OPTIONS sip:ims.otenet.gr SIP/2.0 31890 Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK4ec5aa78;rport 31891 Max-Forwards: 70 31892 From: "Unknown" <sip:+302510620630@192.168.1.5:5160>;tag=as14dcbd6a 31893 To: <sip:ims.otenet.gr> 31894 Contact: <sip:+302510620630@192.168.1.5:5160> 31895 Call-ID: 4681e72212c44cc67141f99a672420aa@192.168.1.5:5160 31896 CSeq: 102 OPTIONS 31897 User-Agent: FPBX-15.0.16.75(13.36.0) 31898 Date: Thu, 08 Oct 2020 11:06:23 GMT 31899 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE 31900 Supported: replaces, timer 31901 Content-Length: 0 31902 31903 31904 --- 31905 [2020-10-08 14:06:23] VERBOSE[2276] chan_sip.c: 31906 <--- SIP read from UDP:195.167.16.54:5060 ---> 31907 SIP/2.0 604 Does Not Exist Anywhere 31908 Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK4ec5aa78;received=80.106.83.137;rport=5160 31909 Call-ID: 4681e72212c44cc67141f99a672420aa@192.168.1.5:5160 31910 From: "Unknown"<sip:+302510620630@192.168.1.5:5160>;tag=as14dcbd6a 31911 To: <sip:ims.otenet.gr>;tag=t3ngwaia 31912 CSeq: 102 OPTIONS 31913 Warning: 399 5244.684.I.261.12.342.0.13.24839.0.0.ims.otenet.gr "Unknown caller" 31914 Content-Length: 0 31915 31916 <-------------> 31917 [2020-10-08 14:06:23] VERBOSE[2276] chan_sip.c: --- (8 headers 0 lines) --- 31918 [2020-10-08 14:06:23] VERBOSE[2276] chan_sip.c: Really destroying SIP dialog '4681e72212c44cc67141f99a672420aa@192.168.1.5:5160' Method: OPTIONS 31919 [2020-10-08 14:06:24] VERBOSE[2276] chan_sip.c: Really destroying SIP dialog 'asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14' Method: BYE 31920 [2020-10-08 14:06:31] VERBOSE[2276] chan_sip.c: 31921 <--- SIP read from UDP:195.167.16.54:5060 ---> 31922 hello 31923 <------------->
ā10-08-2020 05:16 AM
You captured SIP dialog between freePBX and the phone answering the call. It's not the phone you have issue with (unless I missed the topic). I wish to see SIP dialog (especially SIP CANCEL packet) between freePBX and the phone that stops ringing with no answer (because call has been answered elsewhere).
ā11-26-2020 01:18 AM - edited ā11-26-2020 01:29 AM
Does this capture from Wireshark help? 192.168.1.10 is my ip phone that shows answered calls as missed. I see in line 8379 SIP CANCEL.
14 0.514953 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n 15 0.515013 192.168.1.2 192.168.1.10 ICMP 128 Destination unreachable (Port unreachable) 16 0.515468 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n 17 0.516010 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 18 0.516881 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 19 0.517335 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949de350 949de3a0 bcts:1 nRef:0\n 20 0.517643 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949de350 949de3a0 bcts:1 nRef:0\n 21 0.524978 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 9 state:3 \n 22 0.525358 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 9 state:3 \n 23 0.525738 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 24 0.526058 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 25 0.527050 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c8130 clean 0 9498c590 9498c5e0 bcts:1 nRef:0\n 26 0.527392 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c8130 clean 0 9498c590 9498c5e0 bcts:1 nRef:0\n 97 2.884972 192.168.1.10 192.168.1.2 Syslog 60 LOCAL2.DEBUG: CC:Clean Up\n 98 2.885027 192.168.1.2 192.168.1.10 ICMP 87 Destination unreachable (Port unreachable) 99 2.885708 192.168.1.10 192.168.1.2 Syslog 69 LOCAL2.DEBUG: --- OBJ POOL STAT ---\n 100 2.886122 192.168.1.10 192.168.1.2 Syslog 71 LOCAL2.DEBUG: OP:? = 6 ( 8 1356) 101 2.886999 192.168.1.10 192.168.1.2 Syslog 60 LOCAL2.DEBUG: \n 7821 10.524867 192.168.1.10 192.168.1.2 Syslog 78 LOCAL3.DEBUG: regTimerCallBack 51 bTryAltReg\n 7822 10.524925 192.168.1.2 192.168.1.10 ICMP 106 Destination unreachable (Port unreachable) 7823 10.525688 192.168.1.10 192.168.1.2 Syslog 75 LOCAL3.DEBUG: #### create TS 1 0x949c9c10\n 7824 10.528228 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n 7825 10.529339 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n 7826 10.529999 192.168.1.10 192.168.1.2 Syslog 650 NOTIFY sip:192.168.1.5 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-352ac0dd\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nCSeq: 121839 NOTIFY\r\nMax-Forwards: 70\r\nAuthorization: Digest username="31",realm="asterisk",nonce="1606382095/4ef5caa98ec89c54d7a4993d8601031e",uri="sip:192.168.1.5",algorithm=MD5,response="aeb8b619fbb850c162ec603729590e75",opaque="528c3b9c588a9533",qop=auth,nc=00000002,cnonce="96ad59f6"\r\nContact: <sip:31@192.168.1.10:5060>\r\nEvent: keep-alive\r\nUser-Agent: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n 7827 10.530707 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 7828 10.531433 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 7829 10.533570 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 7830 10.533946 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 7831 10.534625 192.168.1.10 192.168.1.2 Syslog 377 SIP/2.0 501 Not Implemented\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;rport=5060;received=192.168.1.10;branch=z9hG4bK-352ac0dd\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>;tag=z9hG4bK-352ac0dd\r\nCSeq: 121839 NOTIFY\r\nServer: FPBX-15.0.16.81(13.36.0)\r\nContent-Length: 0\r\n\r\n 7832 10.535028 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 7833 10.535427 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 7834 10.535899 192.168.1.10 192.168.1.2 Syslog 101 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n 7835 10.536237 192.168.1.10 192.168.1.2 Syslog 101 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n 7836 10.537039 192.168.1.10 192.168.1.2 Syslog 69 LOCAL3.DEBUG: SIP_regTsEventProc 27\n 7837 10.537458 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: start TMR K\n 7838 10.537814 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: start TMR K\n 7839 10.538638 192.168.1.10 192.168.1.2 Syslog 69 LOCAL3.DEBUG: SIP_regTsEventProc 31\n 7842 11.024819 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n 7843 11.025165 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n 7854 13.444836 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c5d00 clean 0 949c76e0 949c77c0 bcts:0 nRef:0\n 7855 13.444895 192.168.1.2 192.168.1.10 ICMP 133 Destination unreachable (Port unreachable) 7856 13.445348 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c5d00 clean 0 949c76e0 949c77c0 bcts:0 nRef:0\n 7867 15.544850 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n 7868 15.544910 192.168.1.2 192.168.1.10 ICMP 128 Destination unreachable (Port unreachable) 7869 15.545378 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n 7870 15.545919 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 7871 15.546259 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 7872 15.547167 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949c7850 949c78a0 bcts:1 nRef:0\n 7873 15.547509 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949c7850 949c78a0 bcts:1 nRef:0\n 7926 25.544876 192.168.1.10 192.168.1.2 Syslog 78 LOCAL3.DEBUG: regTimerCallBack 51 bTryAltReg\n 7927 25.544901 192.168.1.2 192.168.1.10 ICMP 106 Destination unreachable (Port unreachable) 7928 25.545710 192.168.1.10 192.168.1.2 Syslog 75 LOCAL3.DEBUG: #### create TS 1 0x949c9c10\n 7929 25.548506 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n 7930 25.549178 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n 7931 25.549744 192.168.1.10 192.168.1.2 Syslog 650 NOTIFY sip:192.168.1.5 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-b5a9f004\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nCSeq: 121840 NOTIFY\r\nMax-Forwards: 70\r\nAuthorization: Digest username="31",realm="asterisk",nonce="1606382095/4ef5caa98ec89c54d7a4993d8601031e",uri="sip:192.168.1.5",algorithm=MD5,response="caa58181846ac2088a70de10444fe565",opaque="528c3b9c588a9533",qop=auth,nc=00000003,cnonce="96ad59f6"\r\nContact: <sip:31@192.168.1.10:5060>\r\nEvent: keep-alive\r\nUser-Agent: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n 7932 25.550070 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 7933 25.551133 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 7934 25.553324 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 7935 25.553698 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 7936 25.554116 192.168.1.10 192.168.1.2 Syslog 377 SIP/2.0 501 Not Implemented\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;rport=5060;received=192.168.1.10;branch=z9hG4bK-b5a9f004\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>;tag=z9hG4bK-b5a9f004\r\nCSeq: 121840 NOTIFY\r\nServer: FPBX-15.0.16.81(13.36.0)\r\nContent-Length: 0\r\n\r\n 7937 25.554783 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 7938 25.555169 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 7939 25.555637 192.168.1.10 192.168.1.2 Syslog 101 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n 7940 25.555978 192.168.1.10 192.168.1.2 Syslog 101 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n 7941 25.556843 192.168.1.10 192.168.1.2 Syslog 69 LOCAL3.DEBUG: SIP_regTsEventProc 27\n 7942 25.557262 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: start TMR K\n 7943 25.557610 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: start TMR K\n 7944 25.558137 192.168.1.10 192.168.1.2 Syslog 69 LOCAL3.DEBUG: SIP_regTsEventProc 31\n 7945 26.044766 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n 7946 26.045118 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n 7979 30.564767 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n 7980 30.564795 192.168.1.2 192.168.1.10 ICMP 128 Destination unreachable (Port unreachable) 7981 30.565419 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n 7982 30.565810 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 7983 30.566138 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 7985 30.567050 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 9498c400 9498c450 bcts:1 nRef:0\n 7986 30.567399 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 9498c400 9498c450 bcts:1 nRef:0\n 8259 37.137348 192.168.1.10 192.168.1.2 Syslog 70 LOCAL2.DEBUG: SDP RTPMAP 111 --> 130\n 8260 37.137399 192.168.1.2 192.168.1.10 ICMP 98 Destination unreachable (Port unreachable) 8261 37.138967 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8262 37.139322 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8263 37.139900 192.168.1.10 192.168.1.2 Syslog 1052 INVITE sip:31@192.168.1.10:5060 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;rport;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nTo: <sip:31@192.168.1.10>\r\nContact: <sip:asterisk@192.168.1.5:5060>\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 INVITE\r\nAllow: OPTIONS, SUBSCRIBE, NOTIFY, PUBLISH, INVITE, ACK, BYE, CANCEL, UPDATE, PRACK, REGISTER, MESSAGE, REFER\r\nSupported: 100rel, timer, replaces, norefersub\r\nSession-Expires: 1800\r\nMin-SE: 90\r\nP-Asserted-Identity: "6949719941" <sip:6949719941@192.168.1.5>\r\nMax-Forwards: 70\r\nUser-Agent: FPBX-15.0.16.81(13.36.0)\r\nContent-Type: application/sdp\r\nContent-Length: 279\r\n\r\nv=0\r\no=- 613651335 613651335 IN IP4 192.168.1.5\r\ns=Asterisk\r\nc=IN IP4 192.168.1.5\r\nt=0 0\r\nm=audio 11878 RTP/AVP 0 8 3 111 9\r\na=rtpmap:0 PCMU/8000\r\na=rtpmap:8 PCMA/8000\r\na=rtpmap:3 GSM/8000\r\na=rtpmap:111 G726-32/8000\r\na=rtpmap:9 G722/8000\r\na=ptime:20\r\na=maxptime:150\r\na=sendrecv\r\n 8264 37.140576 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8265 37.141264 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8266 37.143961 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{343)\n 8267 37.144571 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{343)\n 8268 37.144998 192.168.1.10 192.168.1.2 Syslog 385 SIP/2.0 100 Trying\r\nTo: <sip:31@192.168.1.10>\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 INVITE\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nServer: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n 8269 37.145389 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8270 37.145760 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8271 37.146677 192.168.1.10 192.168.1.2 Syslog 80 LOCAL3.DEBUG: >>>> SIP: SIP_getRemotePartyId 0\n 8272 37.147109 192.168.1.10 192.168.1.2 Syslog 102 LOCAL3.DEBUG: ucCallerIdHeader 0 bUseFromOnly 0 bNoFrom 0 bPrivacy 0\n 8273 37.147502 192.168.1.10 192.168.1.2 Syslog 105 LOCAL3.DEBUG: SIP_getRemotePartyId(), 1 pna->uri.hp.strHose=192.168.1.5\n 8274 37.147948 192.168.1.10 192.168.1.2 Syslog 94 LOCAL3.DEBUG: SIP_getRemotePartyId(), 1 pna->uri.hp.usPort=0\n 8275 37.148675 192.168.1.10 192.168.1.2 Syslog 97 LOCAL3.DEBUG: SIP_getRemotePartyId(), 1 lid=0 call_log_domain=0\n 8276 37.149075 192.168.1.10 192.168.1.2 Syslog 99 LOCAL3.DEBUG: SIP_getRemotePartyId(), 1 cinf->strPhone=6949719941\n 8277 37.149466 192.168.1.10 192.168.1.2 Syslog 105 LOCAL3.DEBUG: [SIP_getRemotePartyId] name="6949719941" phone=6949719941\n 8278 37.149929 192.168.1.10 192.168.1.2 Syslog 84 LOCAL3.DEBUG: [SIP_getRemotePartyId] splash attr=0\n 8279 37.151025 192.168.1.10 192.168.1.2 Syslog 89 LOCAL3.DEBUG: [SIP_getRemotePartyId] try to call id_map\n 8280 37.151485 192.168.1.10 192.168.1.2 Syslog 99 LOCAL3.DEBUG: SIP_getRemotePartyId(), 4 cinf->strPhone=6949719941\n 8281 37.151880 192.168.1.10 192.168.1.2 Syslog 97 LOCAL3.DEBUG: SIP_getRemotePartyId(), cinf->strPhone=6949719941\n 8282 37.152486 192.168.1.10 192.168.1.2 Syslog 96 LOCAL3.DEBUG: SIP_getRemotePartyId(), cinf->strName=6949719941\n 8283 37.152947 192.168.1.10 192.168.1.2 Syslog 81 LOCAL3.DEBUG: <<<< 2 SIP: SIP_getRemotePartyId \n 8284 37.153558 192.168.1.10 192.168.1.2 Syslog 92 LOCAL0.INFO: +++++ find idle call i = 0, caid=0 (asked 0)\n 8285 37.153907 192.168.1.10 192.168.1.2 Syslog 92 LOCAL0.INFO: +++++ find idle call i = 0, caid=0 (asked 0)\n 8286 37.154768 192.168.1.10 192.168.1.2 Syslog 71 LOCAL0.INFO: [0]CC:NewCallState 10/0\n 8287 37.155120 192.168.1.10 192.168.1.2 Syslog 71 LOCAL0.INFO: [0]CC:NewCallState 10/0\n 8288 37.155535 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8289 37.155906 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8290 37.157518 192.168.1.10 192.168.1.2 Syslog 97 LOCAL3.DEBUG: [CCTRL]record lcr phone=6949719941 exten=0 type=0\n 8291 37.158055 192.168.1.10 192.168.1.2 Syslog 72 LOCAL0.INFO: START_RING in CC_refresh\n 8292 37.158722 192.168.1.10 192.168.1.2 Syslog 72 LOCAL0.INFO: START_RING in CC_refresh\n 8293 37.173715 192.168.1.10 192.168.1.2 Syslog 70 LOCAL2.DEBUG: SDP RTPMAP 111 --> 130\n 8294 37.175004 192.168.1.10 192.168.1.2 Syslog 72 LOCAL1.DEBUG: In InitRemoteVoipMetrics\n 8295 37.176282 192.168.1.10 192.168.1.2 Syslog 66 LOCAL1.DEBUG: In InitVoipMetrics\n 8296 37.177245 192.168.1.10 192.168.1.2 Syslog 80 LOCAL2.DEBUG: [0:0]AUD ALLOC CALL (port=16456)\n 8297 37.179501 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{404)\n 8298 37.179787 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{404)\n 8299 37.180553 192.168.1.10 192.168.1.2 Syslog 446 SIP/2.0 180 Ringing\r\nTo: <sip:31@192.168.1.10>;tag=2740b794e6461544i0\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 INVITE\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nContact: <sip:31@192.168.1.10:5060>\r\nServer: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n 8300 37.181277 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8301 37.181657 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8325 40.564826 192.168.1.10 192.168.1.2 Syslog 78 LOCAL3.DEBUG: regTimerCallBack 51 bTryAltReg\n 8326 40.564886 192.168.1.2 192.168.1.10 ICMP 106 Destination unreachable (Port unreachable) 8327 40.565820 192.168.1.10 192.168.1.2 Syslog 75 LOCAL3.DEBUG: #### create TS 1 0x949c9c10\n 8328 40.569453 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n 8329 40.569788 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n 8330 40.570879 192.168.1.10 192.168.1.2 Syslog 650 NOTIFY sip:192.168.1.5 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-d022af1e\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nCSeq: 121841 NOTIFY\r\nMax-Forwards: 70\r\nAuthorization: Digest username="31",realm="asterisk",nonce="1606382095/4ef5caa98ec89c54d7a4993d8601031e",uri="sip:192.168.1.5",algorithm=MD5,response="1abacb1a1e33cbff8fbb8e3df475b821",opaque="528c3b9c588a9533",qop=auth,nc=00000004,cnonce="96ad59f6"\r\nContact: <sip:31@192.168.1.10:5060>\r\nEvent: keep-alive\r\nUser-Agent: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n 8331 40.571635 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8332 40.572130 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8333 40.574664 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8334 40.575055 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8335 40.575528 192.168.1.10 192.168.1.2 Syslog 531 SIP/2.0 401 Unauthorized\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;rport=5060;received=192.168.1.10;branch=z9hG4bK-d022af1e\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>;tag=z9hG4bK-d022af1e\r\nCSeq: 121841 NOTIFY\r\nWWW-Authenticate: Digest realm="asterisk",nonce="1606382140/0478c70f3207912a9692ff956501dc4c",opaque="0038606e68597775",stale=true,algorithm=md5,qop="auth"\r\nServer: FPBX-15.0.16.81(13.36.0)\r\nContent-Length: 0\r\n\r\n 8336 40.575898 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8337 40.576768 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8338 40.577197 192.168.1.10 192.168.1.2 Syslog 101 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n 8339 40.577548 192.168.1.10 192.168.1.2 Syslog 101 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n 8340 40.578016 192.168.1.10 192.168.1.2 Syslog 69 LOCAL3.DEBUG: SIP_regTsEventProc 27\n 8341 40.578885 192.168.1.10 192.168.1.2 Syslog 124 LOCAL3.DEBUG: SIP_getAuthState callid=d04af86c-375ac0a0@192.168.1.10 realm=asterisk type=0\n 8342 40.579339 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: start TMR K\n 8343 40.579682 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: start TMR K\n 8344 40.580182 192.168.1.10 192.168.1.2 Syslog 69 LOCAL3.DEBUG: SIP_regTsEventProc 31\n 8345 40.581471 192.168.1.10 192.168.1.2 Syslog 78 LOCAL3.DEBUG: regTimerCallBack 51 bTryAltReg\n 8346 40.581980 192.168.1.10 192.168.1.2 Syslog 75 LOCAL3.DEBUG: #### create TS 1 0x949c8130\n 8347 40.584172 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n 8348 40.584989 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n 8349 40.585678 192.168.1.10 192.168.1.2 Syslog 650 NOTIFY sip:192.168.1.5 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-76604572\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nCSeq: 121842 NOTIFY\r\nMax-Forwards: 70\r\nAuthorization: Digest username="31",realm="asterisk",nonce="1606382140/0478c70f3207912a9692ff956501dc4c",uri="sip:192.168.1.5",algorithm=MD5,response="82ffd4317cddb47689715904526296ef",opaque="0038606e68597775",qop=auth,nc=00000001,cnonce="74f47497"\r\nContact: <sip:31@192.168.1.10:5060>\r\nEvent: keep-alive\r\nUser-Agent: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n 8350 40.586038 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8351 40.586842 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8352 40.589499 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8353 40.589871 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8354 40.590656 192.168.1.10 192.168.1.2 Syslog 377 SIP/2.0 501 Not Implemented\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;rport=5060;received=192.168.1.10;branch=z9hG4bK-76604572\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>;tag=z9hG4bK-76604572\r\nCSeq: 121842 NOTIFY\r\nServer: FPBX-15.0.16.81(13.36.0)\r\nContent-Length: 0\r\n\r\n 8355 40.591384 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8356 40.591758 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8357 40.592428 192.168.1.10 192.168.1.2 Syslog 101 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 27 state:1 \n 8358 40.592846 192.168.1.10 192.168.1.2 Syslog 101 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 27 state:1 \n 8359 40.593267 192.168.1.10 192.168.1.2 Syslog 69 LOCAL3.DEBUG: SIP_regTsEventProc 27\n 8360 40.593678 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: start TMR K\n 8361 40.594022 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: start TMR K\n 8362 40.594740 192.168.1.10 192.168.1.2 Syslog 69 LOCAL3.DEBUG: SIP_regTsEventProc 31\n 8367 41.074740 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n 8368 41.075117 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n 8369 41.084710 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 3 state:3 \n 8370 41.085034 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 3 state:3 \n 8376 42.086855 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8377 42.086916 192.168.1.2 192.168.1.10 ICMP 102 Destination unreachable (Port unreachable) 8378 42.087365 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8379 42.088083 192.168.1.10 192.168.1.2 Syslog 518 CANCEL sip:31@192.168.1.10:5060 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;rport;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nTo: <sip:31@192.168.1.10>\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 CANCEL\r\nReason: SIP;cause=200;text="Call completed elsewhere"\r\nReason: Q.850;cause=26\r\nMax-Forwards: 70\r\nUser-Agent: FPBX-15.0.16.81(13.36.0)\r\nContent-Length: 0\r\n\r\n 8380 42.089097 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8381 42.089483 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8382 42.092173 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{378)\n 8383 42.092779 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{378)\n 8384 42.093206 192.168.1.10 192.168.1.2 Syslog 420 SIP/2.0 487 Request Terminated\r\nTo: <sip:31@192.168.1.10>;tag=2740b794e6461544i0\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 INVITE\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nServer: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n 8385 42.093908 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8386 42.094579 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8387 42.097093 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{362)\n 8388 42.097440 192.168.1.10 192.168.1.2 Syslog 79 LOCAL0.INFO: [0:5060]->192.168.1.5:5060{362)\n 8389 42.097908 192.168.1.10 192.168.1.2 Syslog 404 SIP/2.0 200 OK\r\nTo: <sip:31@192.168.1.10>;tag=2740b794e6461544i0\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 CANCEL\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nServer: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n 8390 42.098668 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8391 42.099043 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8392 42.099953 192.168.1.10 192.168.1.2 Syslog 65 LOCAL2.DEBUG: [0:0]AUD Rel Call\n 8393 42.119413 192.168.1.10 192.168.1.2 Syslog 90 LOCAL3.DEBUG: [CCTRL]record lcr phone=6949719941 exten=0\n 8394 42.119847 192.168.1.10 192.168.1.2 Syslog 71 LOCAL0.INFO: [0]CC:NewCallState 0/10\n 8395 42.120524 192.168.1.10 192.168.1.2 Syslog 71 LOCAL0.INFO: [0]CC:NewCallState 0/10\n 8396 42.121266 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8397 42.121649 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8398 42.137098 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8399 42.137454 192.168.1.10 192.168.1.2 Syslog 74 LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n 8400 42.137949 192.168.1.10 192.168.1.2 Syslog 456 ACK sip:31@192.168.1.10:5060 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;rport;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nTo: <sip:31@192.168.1.10>;tag=2740b794e6461544i0\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 ACK\r\nMax-Forwards: 70\r\nUser-Agent: FPBX-15.0.16.81(13.36.0)\r\nContent-Length: 0\r\n\r\n 8401 42.138690 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8402 42.139066 192.168.1.10 192.168.1.2 Syslog 60 LOCAL0.INFO: \n 8438 45.584701 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n 8439 45.584761 192.168.1.2 192.168.1.10 ICMP 128 Destination unreachable (Port unreachable) 8440 45.585210 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n 8441 45.585747 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 8442 45.586078 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 8443 45.587005 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949c76c0 949de200 bcts:1 nRef:0\n 8444 45.587347 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949c76c0 949de200 bcts:1 nRef:0\n 8445 45.594862 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 9 state:3 \n 8446 45.595234 192.168.1.10 192.168.1.2 Syslog 100 LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 9 state:3 \n 8447 45.595609 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 8448 45.595939 192.168.1.10 192.168.1.2 Syslog 61 LOCAL0.INFO: Timer K Fires\n 8449 45.596878 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c8130 clean 0 9498c5a0 9498c5f0 bcts:1 nRef:0\n 8450 45.597221 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c8130 clean 0 9498c5a0 9498c5f0 bcts:1 nRef:0\n 8483 47.144819 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c5d00 clean 0 949c77f0 9498c440 bcts:0 nRef:0\n 8484 47.144880 192.168.1.2 192.168.1.10 ICMP 133 Destination unreachable (Port unreachable) 8485 47.145340 192.168.1.10 192.168.1.2 Syslog 105 LOCAL0.INFO: +++ ts 0x949c5d00 clean 0 949c77f0 9498c440 bcts:0 nRef:0\n
ā11-26-2020 02:11 AM
192.168.1.10 -> 192.168.1.2 CANCEL sip:31@192.168.1.10:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.5:5060;rport;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f From: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07 To: <sip:31@192.168.1.10> Call-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1 CSeq: 26799 CANCEL Reason: SIP;cause=200;text="Call completed elsewhere" Reason: Q.850;cause=26 Max-Forwards: 70 User-Agent: FPBX-15.0.16.81(13.36.0) Content-Length: 0
Looks good. Phone's firmware is recent enough (7.6.2g while feature has been implemented in 7.4.7), CANCEL contain SIP;cause=200;text="Call completed elsewhere" reason. So the last condition - have you the line in question configured as "shared" (Share Call Appearance = shared) ? It doesn't work for private (non shared) lines.
ā11-26-2020 03:02 AM - edited ā11-26-2020 03:28 AM
Thank you for reply!
In Phone/Line Key 1/Share Call Appearance my setting in all phones was private (with this setting I had no problem when extension was configured as chan_sip in freepbx).
I changed this setting to Shared in all my phones but still Answered calls appear as Missed... So the problem remains..
PS. There is also an option Voice/Ext 1/Share Line Appearance/Share Ext: which is also set to Private. Is it OK?
ā11-28-2020 12:31 AM
Since freepbx is sending correctly SIP Cancel, SPA504G is responsible for still showing missed calls? Any idea what setting could interfere with that? Thank you.
