SPA504G/freePBX Mark Answered Elsewhere stopped working
hariskar
I had configured my phone as sip extension in freePBX, but now because sip became legacy I configured it as pjsip. Since then Mark Answered Elsewhere does not work. No other problems.
Are there any settings in webui of my phone to check or change to make it work?
Thank you!
Definitely firmware bug. I assume code function like "fetch Reason header line" which returns single line only - and it's not the one recognized as "Answered Elsewhere" event. While you may report it to Cisco, your chances it will be patched in reasonable time are very low.
It seems you are not only user affected. Read suppress_q850_reason_headers
Hope it will help.
22 Replies 22
Martin Aleksandrov
Could you be more specific and explain what exactly is not working?
Martin
hariskar
With "Mark Answered Elsewhere" in freePBS Incoming route settings, when I have an incoming call and someone answers from a phone the other phones show Missed call for that answered call although this shouldn't happen. Some days ago, maybe till the day I changed the configuration of the extensions (phones) on freePBX from sip to pjsip it worked without problems.
Yes, it has been clear already.
Catch SIP packets between freePBX and SPA504G. We are interested to see content of SIP CANCEL packet sent by freePBX to SPA504G (the one not answering the call).
"Mark Answered Elsewhere" was working without problems when phones are configured using sip in freepbx. But because sip is not supported anymore I configured my phones as pjsip. Since then "Mark Answered Elsewhere" does not work. Maybe it is a coinsidence.
Where can I find SIP CANCEL packet sent by freePBX to SPA504G logs to post it here?
You should execute debug sip commands on your freePBX when initiating a call. Depending on your PBX you may have different debug command compared to Cisco. For instance, with Cisco you do have around 10 debug ccsip commands which can give you all the information needed. Those are debug ccsip error, debug ccsip states, debug ccsip events, etc. (a bit of detailed explanation here: https://community.cisco.com/t5/collaboration-voice-and-video/sip-debugging-commands-overview/ta-p/3155271)
So if your freePBX is capable of doing similar debugging you can log these debug outputs and send it over.
Martin
Does this log help? Extesion 31 shows 2 missed calls that was answered on extension 32 or 33.
14158	[2020-10-08 12:00:16] VERBOSE[16347] pbx_variables.c: Setting global variable 'SIPDOMAIN' to '192.168.1.5'
14159	[2020-10-08 12:00:16] VERBOSE[16347] netsock2.c: Using SIP RTP Audio TOS bits 184
14160	[2020-10-08 12:00:16] VERBOSE[16347] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
14161	[2020-10-08 12:00:16] VERBOSE[16347] netsock2.c: Using SIP RTP Audio CoS mark 5
14162	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:1] Macro("PJSIP/31-0000093f", "user-callerid,LIMIT,EXTERNAL,") in new stack
14163	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:1] Set("PJSIP/31-0000093f", "TOUCH_MONITOR=1602147616.3255") in new stack
14164	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:2] Set("PJSIP/31-0000093f", "AMPUSER=31") in new stack
14165	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:3] Set("PJSIP/31-0000093f", "HOTDESCKCHAN=31-0000093f") in new stack
14166	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:4] Set("PJSIP/31-0000093f", "HOTDESKEXTEN=31") in new stack
14167	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:5] Set("PJSIP/31-0000093f", "HOTDESKCALL=0") in new stack
14168	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:6] ExecIf("PJSIP/31-0000093f", "0?Set(HOTDESKCALL=1)") in new stack
14169	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:7] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(name)=)") in new stack
14170	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:8] GotoIf("PJSIP/31-0000093f", "0?report") in new stack
14171	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:9] ExecIf("PJSIP/31-0000093f", "1?Set(REALCALLERIDNUM=31)") in new stack
14172	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:10] Set("PJSIP/31-0000093f", "AMPUSER=31") in new stack
14173	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:11] GotoIf("PJSIP/31-0000093f", "0?limit") in new stack
14174	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:12] Set("PJSIP/31-0000093f", "AMPUSERCIDNAME=grafeio") in new stack
14175	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:13] ExecIf("PJSIP/31-0000093f", "0?Set(__CIDMASQUERADING=TRUE)") in new stack
14176	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:14] GotoIf("PJSIP/31-0000093f", "0?report") in new stack
14177	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:15] Set("PJSIP/31-0000093f", "AMPUSERCID=31") in new stack
14178	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:16] Set("PJSIP/31-0000093f", "__DIAL_OPTIONS=HhTtr") in new stack
14179	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:17] Set("PJSIP/31-0000093f", "CALLERID(all)="grafeio" <31>") in new stack
14180	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:18] ExecIf("PJSIP/31-0000093f", "0?Set(CUSDIAL=)") in new stack
14181	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:19] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(all)="grafeio" <31>)") in new stack
14182	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:20] GotoIf("PJSIP/31-0000093f", "0?limit") in new stack
14183	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:21] ExecIf("PJSIP/31-0000093f", "1?Set(GROUP(concurrency_limit)=31)") in new stack
14184	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:22] ExecIf("PJSIP/31-0000093f", "0?Set(CHANNEL(language)=)") in new stack
14185	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:23] NoOp("PJSIP/31-0000093f", "Macro Depth is 1") in new stack
14186	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:24] GotoIf("PJSIP/31-0000093f", "1?report2:macroerror") in new stack
14187	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-user-callerid,s,25)
14188	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:25] GotoIf("PJSIP/31-0000093f", "1?continue") in new stack
14189	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-user-callerid,s,44)
14190	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:44] Set("PJSIP/31-0000093f", "CALLERID(number)=31") in new stack
14191	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:45] Set("PJSIP/31-0000093f", "CALLERID(name)=grafeio") in new stack
14192	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:46] GotoIf("PJSIP/31-0000093f", "0?cnum") in new stack
14193	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:47] Set("PJSIP/31-0000093f", "CDR(cnam)=grafeio") in new stack
14194	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:48] Set("PJSIP/31-0000093f", "CDR(cnum)=31") in new stack
14195	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-user-callerid:49] Set("PJSIP/31-0000093f", "CHANNEL(language)=en") in new stack
14196	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:2] Gosub("PJSIP/31-0000093f", "sub-record-check,s,1(out,6977529545,force)") in new stack
14197	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:1] GotoIf("PJSIP/31-0000093f", "0?initialized") in new stack
14198	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:2] Set("PJSIP/31-0000093f", "__REC_STATUS=INITIALIZED") in new stack
14199	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:3] Set("PJSIP/31-0000093f", "NOW=1602147616") in new stack
14200	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:4] Set("PJSIP/31-0000093f", "__DAY=08") in new stack
14201	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:5] Set("PJSIP/31-0000093f", "__MONTH=10") in new stack
14202	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:6] Set("PJSIP/31-0000093f", "__YEAR=2020") in new stack
14203	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:7] Set("PJSIP/31-0000093f", "__TIMESTR=20201008-120016") in new stack
14204	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:8] Set("PJSIP/31-0000093f", "__FROMEXTEN=31") in new stack
14205	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:9] Set("PJSIP/31-0000093f", "__MON_FMT=wav") in new stack
14206	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:10] NoOp("PJSIP/31-0000093f", "Recordings initialized") in new stack
14207	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:11] ExecIf("PJSIP/31-0000093f", "0?Set(ARG3=dontcare)") in new stack
14208	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:12] Set("PJSIP/31-0000093f", "REC_POLICY_MODE_SAVE=") in new stack
14209	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:13] ExecIf("PJSIP/31-0000093f", "0?Set(REC_STATUS=NO)") in new stack
14210	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:14] GotoIf("PJSIP/31-0000093f", "3?checkaction") in new stack
14211	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,s,17)
14212	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@sub-record-check:17] GotoIf("PJSIP/31-0000093f", "1?sub-record-check,out,1") in new stack
14213	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,out,1)
14214	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:1] NoOp("PJSIP/31-0000093f", "Outbound Recording Check from 31 to 6977529545") in new stack
14215	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:2] Set("PJSIP/31-0000093f", "RECMODE=dontcare") in new stack
14216	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:3] ExecIf("PJSIP/31-0000093f", "1?Goto(routewins)") in new stack
14217	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,out,7)
14218	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:7] Gosub("PJSIP/31-0000093f", "recordcheck,1(force,out,6977529545)") in new stack
14219	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("PJSIP/31-0000093f", "Starting recording check against force") in new stack
14220	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("PJSIP/31-0000093f", "force") in new stack
14221	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,recordcheck,5)
14222	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:5] Set("PJSIP/31-0000093f", "__REC_POLICY_MODE=FORCE") in new stack
14223	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:6] GotoIf("PJSIP/31-0000093f", "1?startrec") in new stack
14224	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (sub-record-check,recordcheck,16)
14225	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:16] NoOp("PJSIP/31-0000093f", "Starting recording: out, 6977529545") in new stack
14226	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:17] Set("PJSIP/31-0000093f", "__CALLFILENAME=out-6977529545-31-20201008-120016-1602147616.3255") in new stack
14227	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:18] MixMonitor("PJSIP/31-0000093f", "2020/10/08/out-6977529545-31-20201008-120016-1602147616.3255.wav,abi(LOCAL_MIXMON_ID),") in new stack
14228	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:19] Set("PJSIP/31-0000093f", "__MIXMON_ID=0x7f00ac00d220") in new stack
14229	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:20] Set("PJSIP/31-0000093f", "__RECORD_ID=PJSIP/31-0000093f") in new stack
14230	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:21] Set("PJSIP/31-0000093f", "__REC_STATUS=RECORDING") in new stack
14231	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:22] Set("PJSIP/31-0000093f", "CDR(recordingfile)=out-6977529545-31-20201008-120016-1602147616.3255.wav") in new stack
14232	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [recordcheck@sub-record-check:23] Return("PJSIP/31-0000093f", "") in new stack
14233	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [out@sub-record-check:8] Return("PJSIP/31-0000093f", "") in new stack
14234	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:3] ExecIf("PJSIP/31-0000093f", "0 ?Set(CDR(accountcode)=)") in new stack
14235	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:4] Set("PJSIP/31-0000093f", "_ROUTEID=1") in new stack
14236	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:5] Set("PJSIP/31-0000093f", "_ROUTENAME=Calls") in new stack
14237	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:6] Set("PJSIP/31-0000093f", "MOHCLASS=default") in new stack
14238	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:7] Set("PJSIP/31-0000093f", "_CALLERIDNAMEINTERNAL=grafeio") in new stack
14239	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:8] Set("PJSIP/31-0000093f", "_CALLERIDNUMINTERNAL=31") in new stack
14240	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:9] Set("PJSIP/31-0000093f", "_EMAILNOTIFICATION=FALSE") in new stack
14241	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:10] Set("PJSIP/31-0000093f", "_NODEST=") in new stack
14242	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [6977529545@from-internal:11] Macro("PJSIP/31-0000093f", "dialout-trunk,1,6977529545,,off") in new stack
14243	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:1] Set("PJSIP/31-0000093f", "DIAL_TRUNK=1") in new stack
14244	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:2] ExecIf("PJSIP/31-0000093f", "0?Set(DIAL_OPTIONS=Hhtr)") in new stack
14245	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:3] GosubIf("PJSIP/31-0000093f", "0?sub-pincheck,s,1()") in new stack
14246	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:4] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(num)=31)") in new stack
14247	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:5] GotoIf("PJSIP/31-0000093f", "0?disabletrunk,1") in new stack
14248	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:6] Set("PJSIP/31-0000093f", "DIAL_NUMBER=6977529545") in new stack
14249	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:7] Set("PJSIP/31-0000093f", "DIAL_TRUNK_OPTIONS=HhTtr") in new stack
14250	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:8] Set("PJSIP/31-0000093f", "OUTBOUND_GROUP=OUT_1") in new stack
14251	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:9] Set("PJSIP/31-0000093f", "DIAL_TRUNK_OPTIONS=T") in new stack
14252	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:10] GotoIf("PJSIP/31-0000093f", "1?nomax") in new stack
14253	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-dialout-trunk,s,12)
14254	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:12] GotoIf("PJSIP/31-0000093f", "0?skipoutcid") in new stack
14255	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:13] Macro("PJSIP/31-0000093f", "outbound-callerid,1") in new stack
14256	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:1] NoOp("PJSIP/31-0000093f", "31") in new stack
14257	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:2] NoOp("PJSIP/31-0000093f", "") in new stack
14258	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:3] NoOp("PJSIP/31-0000093f", "off") in new stack
14259	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:4] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(name-pres)=)") in new stack
14260	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:5] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(num-pres)=)") in new stack
14261	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:6] Set("PJSIP/31-0000093f", "HOTDESCKCHAN=31-0000093f") in new stack
14262	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:7] Set("PJSIP/31-0000093f", "HOTDESKEXTEN=31") in new stack
14263	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:8] Set("PJSIP/31-0000093f", "HOTDESKCALL=0") in new stack
14264	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:9] ExecIf("PJSIP/31-0000093f", "0?Set(HOTDESKCALL=1)") in new stack
14265	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:10] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(name)=)") in new stack
14266	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:11] Set("PJSIP/31-0000093f", "ALLOWTHISROUTE=NO") in new stack
14267	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:12] ExecIf("PJSIP/31-0000093f", "0?Set(ALLOWTHISROUTE=YES)") in new stack
14268	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:13] ExecIf("PJSIP/31-0000093f", "0?Hangup()") in new stack
14269	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:14] ExecIf("PJSIP/31-0000093f", "0?Set(REALCALLERIDNUM=31)") in new stack
14270	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:15] ExecIf("PJSIP/31-0000093f", "0?Set(AMPUSER=31)") in new stack
14271	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:16] GotoIf("PJSIP/31-0000093f", "1?normcid") in new stack
14272	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-outbound-callerid,s,20)
14273	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:20] Set("PJSIP/31-0000093f", "USEROUTCID=31") in new stack
14274	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:21] Set("PJSIP/31-0000093f", "EMERGENCYCID=") in new stack
14275	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:22] ExecIf("PJSIP/31-0000093f", "0?Set(EMERGENCYCID=)") in new stack
14276	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:23] Set("PJSIP/31-0000093f", "TRUNKOUTCID=+302510620630") in new stack
14277	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:24] GotoIf("PJSIP/31-0000093f", "1?trunkcid") in new stack
14278	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-outbound-callerid,s,30)
14279	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:30] ExecIf("PJSIP/31-0000093f", "1?Set(CALLERID(all)=+302510620630)") in new stack
14280	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:31] ExecIf("PJSIP/31-0000093f", "1?Set(CALLERID(all)=31)") in new stack
14281	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:32] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(all)=)") in new stack
14282	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:33] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERID(all)=31)") in new stack
14283	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:34] Set("PJSIP/31-0000093f", "TIOHIDE=no") in new stack
14284	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:35] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(name-pres)=prohib_passed_screen)") in new stack
14285	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:36] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(num-pres)=prohib_passed_screen)") in new stack
14286	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:37] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(name-pres)=prohib_passed_screen)") in new stack
14287	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:38] ExecIf("PJSIP/31-0000093f", "0?Set(CALLERPRES(num-pres)=prohib_passed_screen)") in new stack
14288	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:39] Set("PJSIP/31-0000093f", "CDR(outbound_cnum)=31") in new stack
14289	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-outbound-callerid:40] Set("PJSIP/31-0000093f", "CDR(outbound_cnam)=") in new stack
14290	[2020-10-08 12:00:16] VERBOSE[12457][C-0000037d] app_mixmonitor.c: Begin MixMonitor Recording PJSIP/31-0000093f
14291	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:14] GosubIf("PJSIP/31-0000093f", "0?sub-flp-1,s,1()") in new stack
14292	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:15] Set("PJSIP/31-0000093f", "OUTNUM=6977529545") in new stack
14293	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:16] Set("PJSIP/31-0000093f", "custom=SIP/Cosmote") in new stack
14294	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:17] ExecIf("PJSIP/31-0000093f", "0?Set(DIAL_TRUNK_OPTIONS=M(setmusic^default)T)") in new stack
14295	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:18] ExecIf("PJSIP/31-0000093f", "0?Set(DIAL_TRUNK_OPTIONS=TM(confirm))") in new stack
14296	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:19] Macro("PJSIP/31-0000093f", "dialout-trunk-predial-hook,") in new stack
14297	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("PJSIP/31-0000093f", "") in new stack
14298	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:20] GotoIf("PJSIP/31-0000093f", "0?skipcrm") in new stack
14299	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:21] Set("PJSIP/31-0000093f", "__CRM_DIRECTION=OUTBOUND") in new stack
14300	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:22] Set("PJSIP/31-0000093f", "__CRM_DESTINATION=6977529545") in new stack
14301	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:23] Set("PJSIP/31-0000093f", "__CRM_SOURCE=31") in new stack
14302	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:24] AGI("PJSIP/31-0000093f", "sangomacrm.agi") in new stack
14303	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi
14304	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] res_agi.c: <PJSIP/31-0000093f>AGI Script sangomacrm.agi completed, returning 0
14305	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:25] Set("PJSIP/31-0000093f", "CHANNEL(hangup_handler_push)=crm-hangup,s,1") in new stack
14306	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:26] NoOp("PJSIP/31-0000093f", "CRM Finished") in new stack
14307	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:27] GotoIf("PJSIP/31-0000093f", "0?bypass,1") in new stack
14308	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:28] ExecIf("PJSIP/31-0000093f", "1?Set(CONNECTEDLINE(num,i)=6977529545)") in new stack
14309	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:29] ExecIf("PJSIP/31-0000093f", "1?Set(CONNECTEDLINE(name,i)=CID:31)") in new stack
14310	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:30] ExecIf("PJSIP/31-0000093f", "0?Set(CONNECTEDLINE(name,i)=CID:(Hidden)31)") in new stack
14311	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:31] GotoIf("PJSIP/31-0000093f", "0?customtrunk") in new stack
14312	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:32] ExecIf("PJSIP/31-0000093f", "0?Set(DIAL_TRUNK_OPTIONS=)") in new stack
14313	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:33] Set("PJSIP/31-0000093f", "HASH(__SIPHEADERS,Alert-Info)=unset") in new stack
14314	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-dialout-trunk:34] Dial("PJSIP/31-0000093f", "SIP/Cosmote/6977529545,300,Tb(func-apply-sipheaders^s^1,(1))U(sub-send-obroute-email^6977529545^6977529545^1^1602147616^^31)") in new stack
14315	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] netsock2.c: Using SIP RTP TOS bits 184
14316	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] netsock2.c: Using SIP RTP CoS mark 5
14317	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] app_stack.c: SIP/Cosmote-00000378 Internal Gosub(func-apply-sipheaders,s,1(1)) start
14318	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("SIP/Cosmote-00000378", "0?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
14319	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("SIP/Cosmote-00000378", "Applying SIP Headers to channel SIP/Cosmote-00000378") in new stack
14320	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:3] Set("SIP/Cosmote-00000378", "TECH=SIP") in new stack
14321	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:4] Set("SIP/Cosmote-00000378", "SIPHEADERKEYS=Alert-Info") in new stack
14322	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:5] While("SIP/Cosmote-00000378", "1") in new stack
14323	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:6] Set("SIP/Cosmote-00000378", "sipheader=unset") in new stack
14324	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:7] ExecIf("SIP/Cosmote-00000378", "1?SIPRemoveHeader(Alert-Info:)") in new stack
14325	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:8] ExecIf("SIP/Cosmote-00000378", "0?Set(PJSIP_HEADER(remove,Alert-Info)=)") in new stack
14326	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:9] ExecIf("SIP/Cosmote-00000378", "0?Set(sipheader=<http://127.0.0.1>;info=unset)") in new stack
14327	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:10] ExecIf("SIP/Cosmote-00000378", "0?Set(sipheader=<http://127.0.0.1>unset)") in new stack
14328	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:11] ExecIf("SIP/Cosmote-00000378", "0?SIPAddHeader(Alert-Info:unset)") in new stack
14329	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:12] ExecIf("SIP/Cosmote-00000378", "0?Set(PJSIP_HEADER(add,Alert-Info)=unset)") in new stack
14330	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:13] EndWhile("SIP/Cosmote-00000378", "") in new stack
14331	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:5] While("SIP/Cosmote-00000378", "0") in new stack
14332	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@func-apply-sipheaders:14] Return("SIP/Cosmote-00000378", "") in new stack
14333	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] app_stack.c: Spawn extension (from-trunk-sip-Cosmote, 6977529545, 1) exited non-zero on 'SIP/Cosmote-00000378'
14334	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] app_stack.c: SIP/Cosmote-00000378 Internal Gosub(func-apply-sipheaders,s,1(1)) complete GOSUB_RETVAL=
14335	[2020-10-08 12:00:16] VERBOSE[12456][C-0000037d] app_dial.c: Called SIP/Cosmote/6977529545
14336	[2020-10-08 12:00:19] VERBOSE[12456][C-0000037d] app_dial.c: SIP/Cosmote-00000378 is making progress passing it to PJSIP/31-0000093f
14337	[2020-10-08 12:00:19] VERBOSE[12456][C-0000037d] app_dial.c: SIP/Cosmote-00000378 is ringing
14338	[2020-10-08 12:00:20] VERBOSE[12456][C-0000037d] app_dial.c: SIP/Cosmote-00000378 is ringing
14339	[2020-10-08 12:00:41] VERBOSE[12456][C-0000037d] app_dial.c: SIP/Cosmote-00000378 is ringing
14340	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_macro.c: Spawn extension (macro-dialout-trunk, s, 34) exited non-zero on 'PJSIP/31-0000093f' in macro 'dialout-trunk'
14341	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Spawn extension (from-internal, 6977529545, 11) exited non-zero on 'PJSIP/31-0000093f'
14342	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [h@from-internal:1] Macro("PJSIP/31-0000093f", "hangupcall") in new stack
14343	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("PJSIP/31-0000093f", "1?theend") in new stack
14344	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx_builtins.c: Goto (macro-hangupcall,s,3)
14345	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("PJSIP/31-0000093f", "0?Set(CDR(recordingfile)=)") in new stack
14346	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:4] NoOp("PJSIP/31-0000093f", "SIP/Cosmote-00000378 montior file= /var/spool/asterisk/monitor/2020/10/08/out-6977529545-31-20201008-120016-1602147616.3255.wav") in new stack
14347	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("PJSIP/31-0000093f", "0?skipagi") in new stack
14348	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:6] AGI("PJSIP/31-0000093f", "attendedtransfer-rec-restart.php,SIP/Cosmote-00000378,/var/spool/asterisk/monitor/2020/10/08/out-6977529545-31-20201008-120016-1602147616.3255.wav") in new stack
14349	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/attendedtransfer-rec-restart.php
14350	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] res_agi.c: <PJSIP/31-0000093f>AGI Script attendedtransfer-rec-restart.php completed, returning 0
14351	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@macro-hangupcall:7] Hangup("PJSIP/31-0000093f", "") in new stack
14352	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'PJSIP/31-0000093f' in macro 'hangupcall'
14353	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Spawn extension (from-internal, h, 1) exited non-zero on 'PJSIP/31-0000093f'
14354	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_stack.c: PJSIP/31-0000093f Internal Gosub(crm-hangup,s,1) start
14355	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/31-0000093f", "Sending Hangup to CRM") in new stack
14356	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/31-0000093f", "HANGUP CAUSE: 127") in new stack
14357	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/31-0000093f", "0?Set(__CRM_VOICEMAIL=)") in new stack
14358	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/31-0000093f", "MASTER CHANNEL: 1602147616.3255 = 1602147616.3255") in new stack
14359	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/31-0000093f", "0?return") in new stack
14360	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:6] Set("PJSIP/31-0000093f", "__CRM_HANGUP=1") in new stack
14361	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:7] AGI("PJSIP/31-0000093f", "sangomacrm.agi") in new stack
14362	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi
14363	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] res_agi.c: <PJSIP/31-0000093f>AGI Script sangomacrm.agi completed, returning 0
14364	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/31-0000093f", "") in new stack
14365	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_stack.c: Spawn extension (from-internal, h, 1) exited non-zero on 'PJSIP/31-0000093f'
14366	[2020-10-08 12:00:43] VERBOSE[12456][C-0000037d] app_stack.c: PJSIP/31-0000093f Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
14367	[2020-10-08 12:00:43] VERBOSE[12457][C-0000037d] app_mixmonitor.c: MixMonitor close filestream (mixed)
14368	[2020-10-08 12:00:43] VERBOSE[12457][C-0000037d] app_mixmonitor.c: End MixMonitor Recording PJSIP/31-0000093f
14369	[2020-10-08 12:01:04] VERBOSE[2276][C-0000037e] netsock2.c: Using SIP RTP TOS bits 184
14370	[2020-10-08 12:01:04] VERBOSE[2276][C-0000037e] netsock2.c: Using SIP RTP CoS mark 5
14371	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:1] Set("SIP/Cosmote-00000379", "GROUP()=OUT_1") in new stack
14372	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:2] Goto("SIP/Cosmote-00000379", "from-trunk,+302510620630,1") in new stack
14373	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (from-trunk,+302510620630,1)
14374	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:1] Set("SIP/Cosmote-00000379", "__DIRECTION=INBOUND") in new stack
14375	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:2] Gosub("SIP/Cosmote-00000379", "sub-record-check,s,1(in,+302510620630,force)") in new stack
14376	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-00000379", "0?initialized") in new stack
14377	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:2] Set("SIP/Cosmote-00000379", "__REC_STATUS=INITIALIZED") in new stack
14378	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:3] Set("SIP/Cosmote-00000379", "NOW=1602147664") in new stack
14379	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:4] Set("SIP/Cosmote-00000379", "__DAY=08") in new stack
14380	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:5] Set("SIP/Cosmote-00000379", "__MONTH=10") in new stack
14381	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:6] Set("SIP/Cosmote-00000379", "__YEAR=2020") in new stack
14382	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:7] Set("SIP/Cosmote-00000379", "__TIMESTR=20201008-120104") in new stack
14383	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:8] Set("SIP/Cosmote-00000379", "__FROMEXTEN=unknown") in new stack
14384	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:9] Set("SIP/Cosmote-00000379", "__MON_FMT=wav") in new stack
14385	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-00000379", "Recordings initialized") in new stack
14386	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-00000379", "0?Set(ARG3=dontcare)") in new stack
14387	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-00000379", "REC_POLICY_MODE_SAVE=") in new stack
14388	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-00000379", "0?Set(REC_STATUS=NO)") in new stack
14389	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-00000379", "2?checkaction") in new stack
14390	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,s,17)
14391	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-00000379", "1?sub-record-check,in,1") in new stack
14392	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,in,1)
14393	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:1] NoOp("SIP/Cosmote-00000379", "Inbound Recording Check to +302510620630") in new stack
14394	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:2] Set("SIP/Cosmote-00000379", "FROMEXTEN=unknown") in new stack
14395	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:3] ExecIf("SIP/Cosmote-00000379", "10?Set(FROMEXTEN=2510516267)") in new stack
14396	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:4] Gosub("SIP/Cosmote-00000379", "recordcheck,1(force,in,+302510620630)") in new stack
14397	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-00000379", "Starting recording check against force") in new stack
14398	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-00000379", "force") in new stack
14399	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,recordcheck,5)
14400	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:5] Set("SIP/Cosmote-00000379", "__REC_POLICY_MODE=FORCE") in new stack
14401	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:6] GotoIf("SIP/Cosmote-00000379", "1?startrec") in new stack
14402	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,recordcheck,16)
14403	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:16] NoOp("SIP/Cosmote-00000379", "Starting recording: in, +302510620630") in new stack
14404	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:17] Set("SIP/Cosmote-00000379", "__CALLFILENAME=in-+302510620630-2510516267-20201008-120104-1602147664.3257") in new stack
14405	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:18] MixMonitor("SIP/Cosmote-00000379", "2020/10/08/in-+302510620630-2510516267-20201008-120104-1602147664.3257.wav,abi(LOCAL_MIXMON_ID),") in new stack
14406	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:19] Set("SIP/Cosmote-00000379", "__MIXMON_ID=0x7f010c03da40") in new stack
14407	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:20] Set("SIP/Cosmote-00000379", "__RECORD_ID=SIP/Cosmote-00000379") in new stack
14408	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:21] Set("SIP/Cosmote-00000379", "__REC_STATUS=RECORDING") in new stack
14409	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:22] Set("SIP/Cosmote-00000379", "CDR(recordingfile)=in-+302510620630-2510516267-20201008-120104-1602147664.3257.wav") in new stack
14410	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:23] Return("SIP/Cosmote-00000379", "") in new stack
14411	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [in@sub-record-check:5] Return("SIP/Cosmote-00000379", "") in new stack
14412	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:3] Set("SIP/Cosmote-00000379", "CHANNEL(tonezone)=gr") in new stack
14413	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:4] Set("SIP/Cosmote-00000379", "__FROM_DID=+302510620630") in new stack
14414	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:5] Set("SIP/Cosmote-00000379", "returnhere=1") in new stack
14415	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:6] Gosub("SIP/Cosmote-00000379", "app-blacklist-check,s,1()") in new stack
14416	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@app-blacklist-check:1] GotoIf("SIP/Cosmote-00000379", "0?blacklisted") in new stack
14417	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@app-blacklist-check:2] Set("SIP/Cosmote-00000379", "CALLED_BLACKLIST=1") in new stack
14418	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@app-blacklist-check:3] Return("SIP/Cosmote-00000379", "") in new stack
14419	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:7] Set("SIP/Cosmote-00000379", "CDR(did)=+302510620630") in new stack
14420	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:8] GotoIf("SIP/Cosmote-00000379", "0?") in new stack
14421	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:9] ExecIf("SIP/Cosmote-00000379", "1 ?Set(CALLERID(name)=2510516267)") in new stack
14422	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:10] Set("SIP/Cosmote-00000379", "__MOHCLASS=") in new stack
14423	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:11] Set("SIP/Cosmote-00000379", "__REVERSAL_REJECT=FALSE") in new stack
14424	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:12] GotoIf("SIP/Cosmote-00000379", "1?post-reverse-charge") in new stack
14425	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (from-trunk,+302510620630,14)
14426	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:14] NoOp("SIP/Cosmote-00000379", "") in new stack
14427	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:15] Set("SIP/Cosmote-00000379", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
14428	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:16] Set("SIP/Cosmote-00000379", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
14429	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:17] Set("SIP/Cosmote-00000379", "CALLERID(name-pres)=allowed_not_screened") in new stack
14430	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:18] Set("SIP/Cosmote-00000379", "CALLERID(num-pres)=allowed_not_screened") in new stack
14431	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:19] Gosub("SIP/Cosmote-00000379", "cidlookup,cidlookup_1,1()") in new stack
14432	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [cidlookup_1@cidlookup:1] AGI("SIP/Cosmote-00000379", "contactmanager.agi, 2510516267,,4") in new stack
14433	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/contactmanager.agi
14434	[2020-10-08 12:01:04] VERBOSE[12705][C-0000037e] app_mixmonitor.c: Begin MixMonitor Recording SIP/Cosmote-00000379
14435	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script contactmanager.agi completed, returning 0
14436	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [cidlookup_1@cidlookup:2] ExecIf("SIP/Cosmote-00000379", "0?Set(CALLERID(name)=Unknown)") in new stack
14437	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [cidlookup_1@cidlookup:3] Return("SIP/Cosmote-00000379", "") in new stack
14438	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:20] Set("SIP/Cosmote-00000379", "CIDSFSCHEME=QUxMfEFMTA==") in new stack
14439	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:21] AGI("SIP/Cosmote-00000379", "/var/www/html/admin/modules/superfecta/agi/superfecta.agi") in new stack
14440	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi
14441	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Executing Scheme..
14442	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Scheme Asked is: ALL
14443	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The DID is: +302510620630
14444	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNUM is: 2510516267
14445	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNAME is: 2510516267
14446	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi:
14447	[2020-10-08 12:01:04] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Starting scheme Default
14448	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: No callerid found
14449	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_NEW: 2510516267
14450	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_OLD: 2510516267
14451	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: CID Determined to be: '2510516267'
14452	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Attempting to set lookupcid
14453	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi completed, returning 0
14454	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:22] Set("SIP/Cosmote-00000379", "CALLERID(name)=2510516267") in new stack
14455	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:23] NoOp("SIP/Cosmote-00000379", "CallerID Entry Point") in new stack
14456	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:24] Set("SIP/Cosmote-00000379", "__CRM_DIRECTION=INBOUND") in new stack
14457	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:25] Set("SIP/Cosmote-00000379", "__CRM_SOURCE=2510516267") in new stack
14458	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:26] Set("SIP/Cosmote-00000379", "__CRM_LINKEDID=1602147664.3257") in new stack
14459	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:27] AGI("SIP/Cosmote-00000379", "sangomacrm.agi,true") in new stack
14460	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi
14461	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script sangomacrm.agi completed, returning 0
14462	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:28] ExecIf("SIP/Cosmote-00000379", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
14463	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [+302510620630@from-trunk:29] Goto("SIP/Cosmote-00000379", "ext-group,1,1") in new stack
14464	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (ext-group,1,1)
14465	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:1] GotoIf("SIP/Cosmote-00000379", "0?cid") in new stack
14466	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:2] PlayTones("SIP/Cosmote-00000379", "ring") in new stack
14467	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:3] Progress("SIP/Cosmote-00000379", "") in new stack
14468	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:4] Macro("SIP/Cosmote-00000379", "user-callerid,") in new stack
14469	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:1] Set("SIP/Cosmote-00000379", "TOUCH_MONITOR=1602147664.3257") in new stack
14470	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:2] Set("SIP/Cosmote-00000379", "AMPUSER=2510516267") in new stack
14471	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:3] Set("SIP/Cosmote-00000379", "HOTDESCKCHAN=Cosmote-00000379") in new stack
14472	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:4] Set("SIP/Cosmote-00000379", "HOTDESKEXTEN=Cosmote") in new stack
14473	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:5] Set("SIP/Cosmote-00000379", "HOTDESKCALL=0") in new stack
14474	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:6] ExecIf("SIP/Cosmote-00000379", "0?Set(HOTDESKCALL=1)") in new stack
14475	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:7] ExecIf("SIP/Cosmote-00000379", "0?Set(CALLERID(name)=)") in new stack
14476	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:8] GotoIf("SIP/Cosmote-00000379", "0?report") in new stack
14477	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:9] ExecIf("SIP/Cosmote-00000379", "1?Set(REALCALLERIDNUM=2510516267)") in new stack
14478	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:10] Set("SIP/Cosmote-00000379", "AMPUSER=") in new stack
14479	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:11] GotoIf("SIP/Cosmote-00000379", "0?limit") in new stack
14480	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:12] Set("SIP/Cosmote-00000379", "AMPUSERCIDNAME=") in new stack
14481	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:13] ExecIf("SIP/Cosmote-00000379", "0?Set(__CIDMASQUERADING=TRUE)") in new stack
14482	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:14] GotoIf("SIP/Cosmote-00000379", "1?report") in new stack
14483	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-user-callerid,s,23)
14484	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:23] NoOp("SIP/Cosmote-00000379", "Macro Depth is 1") in new stack
14485	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:24] GotoIf("SIP/Cosmote-00000379", "1?report2:macroerror") in new stack
14486	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-user-callerid,s,25)
14487	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:25] GotoIf("SIP/Cosmote-00000379", "0?continue") in new stack
14488	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:26] ExecIf("SIP/Cosmote-00000379", "1?Set(__CALLEE_ACCOUNCODE=)") in new stack
14489	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:27] Set("SIP/Cosmote-00000379", "__TTL=64") in new stack
14490	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:28] GotoIf("SIP/Cosmote-00000379", "1?continue") in new stack
14491	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-user-callerid,s,44)
14492	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:44] Set("SIP/Cosmote-00000379", "CALLERID(number)=2510516267") in new stack
14493	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:45] Set("SIP/Cosmote-00000379", "CALLERID(name)=2510516267") in new stack
14494	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:46] GotoIf("SIP/Cosmote-00000379", "0?cnum") in new stack
14495	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:47] Set("SIP/Cosmote-00000379", "CDR(cnam)=2510516267") in new stack
14496	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:48] Set("SIP/Cosmote-00000379", "CDR(cnum)=2510516267") in new stack
14497	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-user-callerid:49] Set("SIP/Cosmote-00000379", "CHANNEL(language)=en") in new stack
14498	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:5] Macro("SIP/Cosmote-00000379", "blkvm-setifempty,") in new stack
14499	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:1] GotoIf("SIP/Cosmote-00000379", "1?init") in new stack
14500	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-blkvm-setifempty,s,4)
14501	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:4] Set("SIP/Cosmote-00000379", "__BLKVM_CHANNEL=SIP/Cosmote-00000379") in new stack
14502	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:5] Set("SIP/Cosmote-00000379", "SHARED(BLKVM,SIP/Cosmote-00000379)=TRUE") in new stack
14503	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:6] Set("SIP/Cosmote-00000379", "GOSUB_RETVAL=TRUE") in new stack
14504	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-setifempty:7] MacroExit("SIP/Cosmote-00000379", "") in new stack
14505	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:6] GotoIf("SIP/Cosmote-00000379", "1?skipov") in new stack
14506	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (ext-group,1,9)
14507	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:9] Set("SIP/Cosmote-00000379", "RRNODEST=") in new stack
14508	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:10] Set("SIP/Cosmote-00000379", "__NODEST=1") in new stack
14509	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:11] GosubIf("SIP/Cosmote-00000379", "0?sub-rgsetcid,s,1()") in new stack
14510	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:12] Gosub("SIP/Cosmote-00000379", "sub-record-check,s,1(rg,1,dontcare)") in new stack
14511	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-00000379", "10?initialized") in new stack
14512	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,s,10)
14513	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-00000379", "Recordings initialized") in new stack
14514	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-00000379", "0?Set(ARG3=dontcare)") in new stack
14515	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-00000379", "REC_POLICY_MODE_SAVE=FORCE") in new stack
14516	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-00000379", "0?Set(REC_STATUS=NO)") in new stack
14517	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-00000379", "2?checkaction") in new stack
14518	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,s,17)
14519	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-00000379", "0?sub-record-check,rg,1") in new stack
14520	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:18] NoOp("SIP/Cosmote-00000379", "Generic rg Recording Check - 2510516267 1") in new stack
14521	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:19] Gosub("SIP/Cosmote-00000379", "recordcheck,1(dontcare,rg,1)") in new stack
14522	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-00000379", "Starting recording check against dontcare") in new stack
14523	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-00000379", "dontcare") in new stack
14524	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (sub-record-check,recordcheck,3)
14525	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [recordcheck@sub-record-check:3] Return("SIP/Cosmote-00000379", "") in new stack
14526	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@sub-record-check:20] Return("SIP/Cosmote-00000379", "") in new stack
14527	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:13] Set("SIP/Cosmote-00000379", "RingGroupMethod=ringall") in new stack
14528	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:14] Set("SIP/Cosmote-00000379", "__ALT_CONFIRM_MSG=") in new stack
14529	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:15] GotoIf("SIP/Cosmote-00000379", "0?RGVQANNOUNCE:NORGVQANNOUNCE") in new stack
14530	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (ext-group,1,18)
14531	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [1@ext-group:18] Macro("SIP/Cosmote-00000379", "dial,120,HhTtrQ(ANSWERED_ELSEWHERE),31-32-33") in new stack
14532	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:1] NoOp("SIP/Cosmote-00000379", "Blind Transfer: , Attended Transfer: , User: , Alert Info: ") in new stack
14533	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:2] Set("SIP/Cosmote-00000379", "__CRM_SOURCE=2510516267") in new stack
14534	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:3] ExecIf("SIP/Cosmote-00000379", "0?Set(ALERT_INFO=)") in new stack
14535	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:4] ExecIf("SIP/Cosmote-00000379", "0?Set(ALERT_INFO=)") in new stack
14536	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:5] ExecIf("SIP/Cosmote-00000379", "0?Set(ALERT_INFO=)") in new stack
14537	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:6] ExecIf("SIP/Cosmote-00000379", "0?Set(CHANNEL(musicclass)=)") in new stack
14538	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:7] AGI("SIP/Cosmote-00000379", "dialparties.agi") in new stack
14539	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi
14540	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Starting New Dialparties.agi
14541	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Caller ID name is '2510516267' number is '2510516267'
14542	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: CW Ignore is:
14543	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: CF Ignore is:
14544	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: CW IN_USE/BUSY is: 1
14545	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Methodology of ring is 'ringall'
14546	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Added extension 31 to extension map
14547	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Added extension 32 to extension map
14548	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Added extension 33 to extension map
14549	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 31 cf is disabled
14550	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 32 cf is disabled
14551	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 33 cf is disabled
14552	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 31 do not disturb is disabled
14553	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 32 do not disturb is disabled
14554	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Extension 33 do not disturb is disabled
14555	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/31
14556	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/31/sip:31@192.168.1.10:5060
14557	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: dbset CALLTRACE/31 to 2510516267
14558	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/32
14559	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/32/sip:32@192.168.1.11:5060
14560	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: dbset CALLTRACE/32 to 2510516267
14561	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/33
14562	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603
14563	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: dbset CALLTRACE/33 to 2510516267
14564	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: Filtered ARG3: 31-32-33
14565	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: RVOL_MODE ''
14566	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: RVOL is:
14567	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: dialparties.agi: RVOLPARENT is:
14568	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script dialparties.agi completed, returning 0
14569	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:8] GotoIf("SIP/Cosmote-00000379", "1?normdial") in new stack
14570	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-dial,s,11)
14571	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:11] NoOp("SIP/Cosmote-00000379", "Returned from dialparties with groups to dial") in new stack
14572	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:12] NoOp("SIP/Cosmote-00000379", "ringall array ") in new stack
14573	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:13] Set("SIP/Cosmote-00000379", "__FMGL_DIAL=") in new stack
14574	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:14] Set("SIP/Cosmote-00000379", "LOOPCNT=3") in new stack
14575	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:15] Set("SIP/Cosmote-00000379", "ITER=1") in new stack
14576	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-00000379", "__EXTTOCALL=31") in new stack
14577	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-00000379", "Working with 31") in new stack
14578	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14579	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14580	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-00000379", "ITER=2") in new stack
14581	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-00000379", "1?ndloopbegin") in new stack
14582	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-dial,s,16)
14583	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-00000379", "__EXTTOCALL=32") in new stack
14584	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-00000379", "Working with 32") in new stack
14585	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14586	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14587	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-00000379", "ITER=3") in new stack
14588	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-00000379", "1?ndloopbegin") in new stack
14589	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-dial,s,16)
14590	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-00000379", "__EXTTOCALL=33") in new stack
14591	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-00000379", "Working with 33") in new stack
14592	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14593	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-00000379", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14594	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-00000379", "ITER=4") in new stack
14595	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-00000379", "0?ndloopbegin") in new stack
14596	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:22] Macro("SIP/Cosmote-00000379", "dial-ringall-predial-hook,") in new stack
14597	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial-ringall-predial-hook:1] MacroExit("SIP/Cosmote-00000379", "") in new stack
14598	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:23] ExecIf("SIP/Cosmote-00000379", "0?Set(CWRING=r(callwaiting)):Set(CWRING=)") in new stack
14599	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:24] ExecIf("SIP/Cosmote-00000379", "0?Set(ds=PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)g)") in new stack
14600	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-dial:25] Dial("SIP/Cosmote-00000379", "PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)b(func-apply-sipheaders^s^1),") in new stack
14601	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/31-00000940 Internal Gosub(func-apply-sipheaders,s,1) start
14602	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/31-00000940", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
14603	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/31-00000940", "Applying SIP Headers to channel PJSIP/31-00000940") in new stack
14604	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/31-00000940", "TECH=PJSIP") in new stack
14605	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/31-00000940", "SIPHEADERKEYS=") in new stack
14606	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/31-00000940", "0") in new stack
14607	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_while.c: Jumping to priority 13
14608	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/31-00000940", "") in new stack
14609	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-00000940'
14610	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/31-00000940 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
14611	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/32-00000941 Internal Gosub(func-apply-sipheaders,s,1) start
14612	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/32-00000941", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
14613	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/32-00000941", "Applying SIP Headers to channel PJSIP/32-00000941") in new stack
14614	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/32-00000941", "TECH=PJSIP") in new stack
14615	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/32-00000941", "SIPHEADERKEYS=") in new stack
14616	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/32-00000941", "0") in new stack
14617	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_while.c: Jumping to priority 13
14618	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/32-00000941", "") in new stack
14619	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/32-00000941'
14620	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/32-00000941 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
14621	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/33-00000942 Internal Gosub(func-apply-sipheaders,s,1) start
14622	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/33-00000942", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
14623	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/33-00000942", "Applying SIP Headers to channel PJSIP/33-00000942") in new stack
14624	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/33-00000942", "TECH=PJSIP") in new stack
14625	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/33-00000942", "SIPHEADERKEYS=") in new stack
14626	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/33-00000942", "0") in new stack
14627	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_while.c: Jumping to priority 13
14628	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/33-00000942", "") in new stack
14629	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-00000942'
14630	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/33-00000942 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
14631	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: Called PJSIP/31/sip:31@192.168.1.10:5060
14632	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: Called PJSIP/32/sip:32@192.168.1.11:5060
14633	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: Called PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603
14634	[2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184
14635	[2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
14636	[2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5
14637	[2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184
14638	[2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
14639	[2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5
14640	[2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184
14641	[2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
14642	[2020-10-08 12:01:05] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5
14643	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/33-00000942 connected line has changed. Saving it until answer for SIP/Cosmote-00000379
14644	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/32-00000941 connected line has changed. Saving it until answer for SIP/Cosmote-00000379
14645	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/31-00000940 connected line has changed. Saving it until answer for SIP/Cosmote-00000379
14646	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/31-00000940 is ringing
14647	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/31-00000940 is ringing
14648	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/33-00000942 is ringing
14649	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/33-00000942 is ringing
14650	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/32-00000941 is ringing
14651	[2020-10-08 12:01:05] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/32-00000941 is ringing
14652	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_dial.c: PJSIP/32-00000941 answered SIP/Cosmote-00000379
14653	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/31-00000940 Internal Gosub(crm-hangup,s,1) start
14654	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/31-00000940", "Sending Hangup to CRM") in new stack
14655	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/31-00000940", "HANGUP CAUSE: 26") in new stack
14656	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/31-00000940", "0?Set(__CRM_VOICEMAIL=)") in new stack
14657	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/31-00000940", "MASTER CHANNEL: 1602147665.3258 = 1602147664.3257") in new stack
14658	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/31-00000940", "1?return") in new stack
14659	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (crm-hangup,s,8)
14660	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/31-00000940", "") in new stack
14661	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-00000940'
14662	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/31-00000940 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
14663	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/33-00000942 Internal Gosub(crm-hangup,s,1) start
14664	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/33-00000942", "Sending Hangup to CRM") in new stack
14665	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/33-00000942", "HANGUP CAUSE: 26") in new stack
14666	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/33-00000942", "0?Set(__CRM_VOICEMAIL=)") in new stack
14667	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/33-00000942", "MASTER CHANNEL: 1602147665.3260 = 1602147664.3257") in new stack
14668	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/33-00000942", "1?return") in new stack
14669	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (crm-hangup,s,8)
14670	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/33-00000942", "") in new stack
14671	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-00000942'
14672	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] app_stack.c: PJSIP/33-00000942 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
14673	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:1] Set("PJSIP/32-00000941", "__MACRO_RESULT=") in new stack
14674	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:2] Set("PJSIP/32-00000941", "CFIGNORE=") in new stack
14675	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:3] Set("PJSIP/32-00000941", "MASTER_CHANNEL(CFIGNORE)=") in new stack
14676	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:4] Set("PJSIP/32-00000941", "FORWARD_CONTEXT=from-internal") in new stack
14677	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:5] Set("PJSIP/32-00000941", "MASTER_CHANNEL(FORWARD_CONTEXT)=from-internal") in new stack
14678	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:6] Macro("PJSIP/32-00000941", "blkvm-clr,") in new stack
14679	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-clr:1] Set("PJSIP/32-00000941", "SHARED(BLKVM,SIP/Cosmote-00000379)=") in new stack
14680	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-clr:2] Set("PJSIP/32-00000941", "GOSUB_RETVAL=") in new stack
14681	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-blkvm-clr:3] MacroExit("PJSIP/32-00000941", "") in new stack
14682	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:7] ExecIf("PJSIP/32-00000941", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(num))=32/sip:32@192.168.1.11:5060)") in new stack
14683	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-auto-blkvm:8] ExecIf("PJSIP/32-00000941", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(name))=)") in new stack
14684	[2020-10-08 12:01:09] VERBOSE[12743][C-0000037e] bridge_channel.c: Channel PJSIP/32-00000941 joined 'simple_bridge' basic-bridge <9b815a2f-716a-466c-b41a-f26bdd3d056a>
14685	[2020-10-08 12:01:09] VERBOSE[12704][C-0000037e] bridge_channel.c: Channel SIP/Cosmote-00000379 joined 'simple_bridge' basic-bridge <9b815a2f-716a-466c-b41a-f26bdd3d056a>
14686	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] bridge_channel.c: Channel PJSIP/32-00000941 left 'simple_bridge' basic-bridge <9b815a2f-716a-466c-b41a-f26bdd3d056a>
14687	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] bridge_channel.c: Channel SIP/Cosmote-00000379 left 'simple_bridge' basic-bridge <9b815a2f-716a-466c-b41a-f26bdd3d056a>
14688	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] app_stack.c: PJSIP/32-00000941 Internal Gosub(crm-hangup,s,1) start
14689	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/32-00000941", "Sending Hangup to CRM") in new stack
14690	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/32-00000941", "HANGUP CAUSE: 16") in new stack
14691	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_macro.c: Spawn extension (macro-dial, s, 25) exited non-zero on 'SIP/Cosmote-00000379' in macro 'dial'
14692	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/32-00000941", "0?Set(__CRM_VOICEMAIL=)") in new stack
14693	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Spawn extension (ext-group, 1, 18) exited non-zero on 'SIP/Cosmote-00000379'
14694	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [h@ext-group:1] Macro("SIP/Cosmote-00000379", "hangupcall,") in new stack
14695	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/Cosmote-00000379", "1?theend") in new stack
14696	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx_builtins.c: Goto (macro-hangupcall,s,3)
14697	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/Cosmote-00000379", "0?Set(CDR(recordingfile)=)") in new stack
14698	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/32-00000941", "MASTER CHANNEL: 1602147665.3259 = 1602147664.3257") in new stack
14699	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/32-00000941", "1?return") in new stack
14700	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx_builtins.c: Goto (crm-hangup,s,8)
14701	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/32-00000941", "") in new stack
14702	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] app_stack.c: Spawn extension (macro-dial, s, 1) exited non-zero on 'PJSIP/32-00000941'
14703	[2020-10-08 12:01:20] VERBOSE[12743][C-0000037e] app_stack.c: PJSIP/32-00000941 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
14704	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/Cosmote-00000379", "PJSIP/33-00000942 montior file= /var/spool/asterisk/monitor/2020/10/08/in-+302510620630-2510516267-20201008-120104-1602147664.3257.wav") in new stack
14705	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/Cosmote-00000379", "0?skipagi") in new stack
14706	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:6] AGI("SIP/Cosmote-00000379", "attendedtransfer-rec-restart.php,PJSIP/33-00000942,/var/spool/asterisk/monitor/2020/10/08/in-+302510620630-2510516267-20201008-120104-1602147664.3257.wav") in new stack
14707	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/attendedtransfer-rec-restart.php
14708	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script attendedtransfer-rec-restart.php completed, returning 0
14709	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/Cosmote-00000379", "") in new stack
14710	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/Cosmote-00000379' in macro 'hangupcall'
14711	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-00000379'
14712	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_stack.c: SIP/Cosmote-00000379 Internal Gosub(crm-hangup,s,1) start
14713	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:1] NoOp("SIP/Cosmote-00000379", "Sending Hangup to CRM") in new stack
14714	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:2] NoOp("SIP/Cosmote-00000379", "HANGUP CAUSE: 16") in new stack
14715	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:3] ExecIf("SIP/Cosmote-00000379", "0?Set(__CRM_VOICEMAIL=)") in new stack
14716	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:4] NoOp("SIP/Cosmote-00000379", "MASTER CHANNEL: 1602147664.3257 = 1602147664.3257") in new stack
14717	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:5] GotoIf("SIP/Cosmote-00000379", "0?return") in new stack
14718	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:6] Set("SIP/Cosmote-00000379", "__CRM_HANGUP=1") in new stack
14719	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:7] AGI("SIP/Cosmote-00000379", "sangomacrm.agi") in new stack
14720	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi
14721	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] res_agi.c: <SIP/Cosmote-00000379>AGI Script sangomacrm.agi completed, returning 0
14722	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] pbx.c: Executing [s@crm-hangup:8] Return("SIP/Cosmote-00000379", "") in new stack
14723	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_stack.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-00000379'
14724	[2020-10-08 12:01:20] VERBOSE[12704][C-0000037e] app_stack.c: SIP/Cosmote-00000379 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
14725	[2020-10-08 12:01:20] VERBOSE[12705][C-0000037e] app_mixmonitor.c: MixMonitor close filestream (mixed)
14726	[2020-10-08 12:01:20] VERBOSE[12705][C-0000037e] app_mixmonitor.c: End MixMonitor Recording SIP/Cosmote-00000379
14727	[2020-10-08 12:01:32] VERBOSE[2276][C-0000037f] netsock2.c: Using SIP RTP TOS bits 184
14728	[2020-10-08 12:01:32] VERBOSE[2276][C-0000037f] netsock2.c: Using SIP RTP CoS mark 5
14729	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:1] Set("SIP/Cosmote-0000037a", "GROUP()=OUT_1") in new stack
14730	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:2] Goto("SIP/Cosmote-0000037a", "from-trunk,+302510620630,1") in new stack
14731	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (from-trunk,+302510620630,1)
14732	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:1] Set("SIP/Cosmote-0000037a", "__DIRECTION=INBOUND") in new stack
14733	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:2] Gosub("SIP/Cosmote-0000037a", "sub-record-check,s,1(in,+302510620630,force)") in new stack
14734	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-0000037a", "0?initialized") in new stack
14735	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:2] Set("SIP/Cosmote-0000037a", "__REC_STATUS=INITIALIZED") in new stack
14736	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:3] Set("SIP/Cosmote-0000037a", "NOW=1602147692") in new stack
14737	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:4] Set("SIP/Cosmote-0000037a", "__DAY=08") in new stack
14738	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:5] Set("SIP/Cosmote-0000037a", "__MONTH=10") in new stack
14739	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:6] Set("SIP/Cosmote-0000037a", "__YEAR=2020") in new stack
14740	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:7] Set("SIP/Cosmote-0000037a", "__TIMESTR=20201008-120132") in new stack
14741	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:8] Set("SIP/Cosmote-0000037a", "__FROMEXTEN=unknown") in new stack
14742	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:9] Set("SIP/Cosmote-0000037a", "__MON_FMT=wav") in new stack
14743	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-0000037a", "Recordings initialized") in new stack
14744	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-0000037a", "0?Set(ARG3=dontcare)") in new stack
14745	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-0000037a", "REC_POLICY_MODE_SAVE=") in new stack
14746	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-0000037a", "0?Set(REC_STATUS=NO)") in new stack
14747	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-0000037a", "2?checkaction") in new stack
14748	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,s,17)
14749	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-0000037a", "1?sub-record-check,in,1") in new stack
14750	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,in,1)
14751	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:1] NoOp("SIP/Cosmote-0000037a", "Inbound Recording Check to +302510620630") in new stack
14752	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:2] Set("SIP/Cosmote-0000037a", "FROMEXTEN=unknown") in new stack
14753	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:3] ExecIf("SIP/Cosmote-0000037a", "10?Set(FROMEXTEN=2513500071)") in new stack
14754	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:4] Gosub("SIP/Cosmote-0000037a", "recordcheck,1(force,in,+302510620630)") in new stack
14755	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-0000037a", "Starting recording check against force") in new stack
14756	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-0000037a", "force") in new stack
14757	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,recordcheck,5)
14758	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:5] Set("SIP/Cosmote-0000037a", "__REC_POLICY_MODE=FORCE") in new stack
14759	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:6] GotoIf("SIP/Cosmote-0000037a", "1?startrec") in new stack
14760	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,recordcheck,16)
14761	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:16] NoOp("SIP/Cosmote-0000037a", "Starting recording: in, +302510620630") in new stack
14762	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:17] Set("SIP/Cosmote-0000037a", "__CALLFILENAME=in-+302510620630-2513500071-20201008-120132-1602147692.3261") in new stack
14763	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:18] MixMonitor("SIP/Cosmote-0000037a", "2020/10/08/in-+302510620630-2513500071-20201008-120132-1602147692.3261.wav,abi(LOCAL_MIXMON_ID),") in new stack
14764	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:19] Set("SIP/Cosmote-0000037a", "__MIXMON_ID=0x7f00c8054bc0") in new stack
14765	[2020-10-08 12:01:32] VERBOSE[12877][C-0000037f] app_mixmonitor.c: Begin MixMonitor Recording SIP/Cosmote-0000037a
14766	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:20] Set("SIP/Cosmote-0000037a", "__RECORD_ID=SIP/Cosmote-0000037a") in new stack
14767	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:21] Set("SIP/Cosmote-0000037a", "__REC_STATUS=RECORDING") in new stack
14768	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:22] Set("SIP/Cosmote-0000037a", "CDR(recordingfile)=in-+302510620630-2513500071-20201008-120132-1602147692.3261.wav") in new stack
14769	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:23] Return("SIP/Cosmote-0000037a", "") in new stack
14770	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [in@sub-record-check:5] Return("SIP/Cosmote-0000037a", "") in new stack
14771	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:3] Set("SIP/Cosmote-0000037a", "CHANNEL(tonezone)=gr") in new stack
14772	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:4] Set("SIP/Cosmote-0000037a", "__FROM_DID=+302510620630") in new stack
14773	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:5] Set("SIP/Cosmote-0000037a", "returnhere=1") in new stack
14774	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:6] Gosub("SIP/Cosmote-0000037a", "app-blacklist-check,s,1()") in new stack
14775	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@app-blacklist-check:1] GotoIf("SIP/Cosmote-0000037a", "0?blacklisted") in new stack
14776	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@app-blacklist-check:2] Set("SIP/Cosmote-0000037a", "CALLED_BLACKLIST=1") in new stack
14777	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@app-blacklist-check:3] Return("SIP/Cosmote-0000037a", "") in new stack
14778	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:7] Set("SIP/Cosmote-0000037a", "CDR(did)=+302510620630") in new stack
14779	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:8] GotoIf("SIP/Cosmote-0000037a", "0?") in new stack
14780	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:9] ExecIf("SIP/Cosmote-0000037a", "1 ?Set(CALLERID(name)=2513500071)") in new stack
14781	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:10] Set("SIP/Cosmote-0000037a", "__MOHCLASS=") in new stack
14782	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:11] Set("SIP/Cosmote-0000037a", "__REVERSAL_REJECT=FALSE") in new stack
14783	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:12] GotoIf("SIP/Cosmote-0000037a", "1?post-reverse-charge") in new stack
14784	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (from-trunk,+302510620630,14)
14785	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:14] NoOp("SIP/Cosmote-0000037a", "") in new stack
14786	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:15] Set("SIP/Cosmote-0000037a", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
14787	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:16] Set("SIP/Cosmote-0000037a", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
14788	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:17] Set("SIP/Cosmote-0000037a", "CALLERID(name-pres)=allowed_not_screened") in new stack
14789	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:18] Set("SIP/Cosmote-0000037a", "CALLERID(num-pres)=allowed_not_screened") in new stack
14790	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:19] Gosub("SIP/Cosmote-0000037a", "cidlookup,cidlookup_1,1()") in new stack
14791	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [cidlookup_1@cidlookup:1] AGI("SIP/Cosmote-0000037a", "contactmanager.agi, 2513500071,,4") in new stack
14792	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/contactmanager.agi
14793	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script contactmanager.agi completed, returning 0
14794	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [cidlookup_1@cidlookup:2] ExecIf("SIP/Cosmote-0000037a", "0?Set(CALLERID(name)=Unknown)") in new stack
14795	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [cidlookup_1@cidlookup:3] Return("SIP/Cosmote-0000037a", "") in new stack
14796	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:20] Set("SIP/Cosmote-0000037a", "CIDSFSCHEME=QUxMfEFMTA==") in new stack
14797	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:21] AGI("SIP/Cosmote-0000037a", "/var/www/html/admin/modules/superfecta/agi/superfecta.agi") in new stack
14798	[2020-10-08 12:01:32] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi
14799	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Executing Scheme..
14800	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Scheme Asked is: ALL
14801	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The DID is: +302510620630
14802	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNUM is: 2513500071
14803	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNAME is: 2513500071
14804	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi:
14805	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Starting scheme Default
14806	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: No callerid found
14807	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_NEW: 2513500071
14808	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_OLD: 2513500071
14809	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: CID Determined to be: '2513500071'
14810	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Attempting to set lookupcid
14811	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi completed, returning 0
14812	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:22] Set("SIP/Cosmote-0000037a", "CALLERID(name)=2513500071") in new stack
14813	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:23] NoOp("SIP/Cosmote-0000037a", "CallerID Entry Point") in new stack
14814	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:24] Set("SIP/Cosmote-0000037a", "__CRM_DIRECTION=INBOUND") in new stack
14815	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:25] Set("SIP/Cosmote-0000037a", "__CRM_SOURCE=2513500071") in new stack
14816	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:26] Set("SIP/Cosmote-0000037a", "__CRM_LINKEDID=1602147692.3261") in new stack
14817	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:27] AGI("SIP/Cosmote-0000037a", "sangomacrm.agi,true") in new stack
14818	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi
14819	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script sangomacrm.agi completed, returning 0
14820	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:28] ExecIf("SIP/Cosmote-0000037a", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
14821	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [+302510620630@from-trunk:29] Goto("SIP/Cosmote-0000037a", "ext-group,1,1") in new stack
14822	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (ext-group,1,1)
14823	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:1] GotoIf("SIP/Cosmote-0000037a", "0?cid") in new stack
14824	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:2] PlayTones("SIP/Cosmote-0000037a", "ring") in new stack
14825	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:3] Progress("SIP/Cosmote-0000037a", "") in new stack
14826	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:4] Macro("SIP/Cosmote-0000037a", "user-callerid,") in new stack
14827	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:1] Set("SIP/Cosmote-0000037a", "TOUCH_MONITOR=1602147692.3261") in new stack
14828	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:2] Set("SIP/Cosmote-0000037a", "AMPUSER=2513500071") in new stack
14829	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:3] Set("SIP/Cosmote-0000037a", "HOTDESCKCHAN=Cosmote-0000037a") in new stack
14830	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:4] Set("SIP/Cosmote-0000037a", "HOTDESKEXTEN=Cosmote") in new stack
14831	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:5] Set("SIP/Cosmote-0000037a", "HOTDESKCALL=0") in new stack
14832	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:6] ExecIf("SIP/Cosmote-0000037a", "0?Set(HOTDESKCALL=1)") in new stack
14833	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:7] ExecIf("SIP/Cosmote-0000037a", "0?Set(CALLERID(name)=)") in new stack
14834	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:8] GotoIf("SIP/Cosmote-0000037a", "0?report") in new stack
14835	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:9] ExecIf("SIP/Cosmote-0000037a", "1?Set(REALCALLERIDNUM=2513500071)") in new stack
14836	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:10] Set("SIP/Cosmote-0000037a", "AMPUSER=") in new stack
14837	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:11] GotoIf("SIP/Cosmote-0000037a", "0?limit") in new stack
14838	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:12] Set("SIP/Cosmote-0000037a", "AMPUSERCIDNAME=") in new stack
14839	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:13] ExecIf("SIP/Cosmote-0000037a", "0?Set(__CIDMASQUERADING=TRUE)") in new stack
14840	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:14] GotoIf("SIP/Cosmote-0000037a", "1?report") in new stack
14841	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-user-callerid,s,23)
14842	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:23] NoOp("SIP/Cosmote-0000037a", "Macro Depth is 1") in new stack
14843	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:24] GotoIf("SIP/Cosmote-0000037a", "1?report2:macroerror") in new stack
14844	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-user-callerid,s,25)
14845	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:25] GotoIf("SIP/Cosmote-0000037a", "0?continue") in new stack
14846	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:26] ExecIf("SIP/Cosmote-0000037a", "1?Set(__CALLEE_ACCOUNCODE=)") in new stack
14847	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:27] Set("SIP/Cosmote-0000037a", "__TTL=64") in new stack
14848	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:28] GotoIf("SIP/Cosmote-0000037a", "1?continue") in new stack
14849	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-user-callerid,s,44)
14850	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:44] Set("SIP/Cosmote-0000037a", "CALLERID(number)=2513500071") in new stack
14851	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:45] Set("SIP/Cosmote-0000037a", "CALLERID(name)=2513500071") in new stack
14852	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:46] GotoIf("SIP/Cosmote-0000037a", "0?cnum") in new stack
14853	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:47] Set("SIP/Cosmote-0000037a", "CDR(cnam)=2513500071") in new stack
14854	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:48] Set("SIP/Cosmote-0000037a", "CDR(cnum)=2513500071") in new stack
14855	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-user-callerid:49] Set("SIP/Cosmote-0000037a", "CHANNEL(language)=en") in new stack
14856	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:5] Macro("SIP/Cosmote-0000037a", "blkvm-setifempty,") in new stack
14857	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:1] GotoIf("SIP/Cosmote-0000037a", "1?init") in new stack
14858	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-blkvm-setifempty,s,4)
14859	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:4] Set("SIP/Cosmote-0000037a", "__BLKVM_CHANNEL=SIP/Cosmote-0000037a") in new stack
14860	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:5] Set("SIP/Cosmote-0000037a", "SHARED(BLKVM,SIP/Cosmote-0000037a)=TRUE") in new stack
14861	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:6] Set("SIP/Cosmote-0000037a", "GOSUB_RETVAL=TRUE") in new stack
14862	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-setifempty:7] MacroExit("SIP/Cosmote-0000037a", "") in new stack
14863	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:6] GotoIf("SIP/Cosmote-0000037a", "1?skipov") in new stack
14864	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (ext-group,1,9)
14865	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:9] Set("SIP/Cosmote-0000037a", "RRNODEST=") in new stack
14866	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:10] Set("SIP/Cosmote-0000037a", "__NODEST=1") in new stack
14867	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:11] GosubIf("SIP/Cosmote-0000037a", "0?sub-rgsetcid,s,1()") in new stack
14868	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:12] Gosub("SIP/Cosmote-0000037a", "sub-record-check,s,1(rg,1,dontcare)") in new stack
14869	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-0000037a", "10?initialized") in new stack
14870	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,s,10)
14871	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-0000037a", "Recordings initialized") in new stack
14872	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-0000037a", "0?Set(ARG3=dontcare)") in new stack
14873	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-0000037a", "REC_POLICY_MODE_SAVE=FORCE") in new stack
14874	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-0000037a", "0?Set(REC_STATUS=NO)") in new stack
14875	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-0000037a", "2?checkaction") in new stack
14876	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,s,17)
14877	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-0000037a", "0?sub-record-check,rg,1") in new stack
14878	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:18] NoOp("SIP/Cosmote-0000037a", "Generic rg Recording Check - 2513500071 1") in new stack
14879	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:19] Gosub("SIP/Cosmote-0000037a", "recordcheck,1(dontcare,rg,1)") in new stack
14880	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-0000037a", "Starting recording check against dontcare") in new stack
14881	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-0000037a", "dontcare") in new stack
14882	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (sub-record-check,recordcheck,3)
14883	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [recordcheck@sub-record-check:3] Return("SIP/Cosmote-0000037a", "") in new stack
14884	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@sub-record-check:20] Return("SIP/Cosmote-0000037a", "") in new stack
14885	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:13] Set("SIP/Cosmote-0000037a", "RingGroupMethod=ringall") in new stack
14886	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:14] Set("SIP/Cosmote-0000037a", "__ALT_CONFIRM_MSG=") in new stack
14887	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:15] GotoIf("SIP/Cosmote-0000037a", "0?RGVQANNOUNCE:NORGVQANNOUNCE") in new stack
14888	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (ext-group,1,18)
14889	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [1@ext-group:18] Macro("SIP/Cosmote-0000037a", "dial,120,HhTtrQ(ANSWERED_ELSEWHERE),31-32-33") in new stack
14890	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:1] NoOp("SIP/Cosmote-0000037a", "Blind Transfer: , Attended Transfer: , User: , Alert Info: ") in new stack
14891	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:2] Set("SIP/Cosmote-0000037a", "__CRM_SOURCE=2513500071") in new stack
14892	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:3] ExecIf("SIP/Cosmote-0000037a", "0?Set(ALERT_INFO=)") in new stack
14893	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:4] ExecIf("SIP/Cosmote-0000037a", "0?Set(ALERT_INFO=)") in new stack
14894	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:5] ExecIf("SIP/Cosmote-0000037a", "0?Set(ALERT_INFO=)") in new stack
14895	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:6] ExecIf("SIP/Cosmote-0000037a", "0?Set(CHANNEL(musicclass)=)") in new stack
14896	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:7] AGI("SIP/Cosmote-0000037a", "dialparties.agi") in new stack
14897	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi
14898	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Starting New Dialparties.agi
14899	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Caller ID name is '2513500071' number is '2513500071'
14900	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: CW Ignore is:
14901	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: CF Ignore is:
14902	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: CW IN_USE/BUSY is: 1
14903	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Methodology of ring is 'ringall'
14904	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Added extension 31 to extension map
14905	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Added extension 32 to extension map
14906	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Added extension 33 to extension map
14907	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 31 cf is disabled
14908	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 32 cf is disabled
14909	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 33 cf is disabled
14910	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 31 do not disturb is disabled
14911	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 32 do not disturb is disabled
14912	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Extension 33 do not disturb is disabled
14913	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/31
14914	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/31/sip:31@192.168.1.10:5060
14915	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: dbset CALLTRACE/31 to 2513500071
14916	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/32
14917	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/32/sip:32@192.168.1.11:5060
14918	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: dbset CALLTRACE/32 to 2513500071
14919	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/33
14920	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603
14921	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: dbset CALLTRACE/33 to 2513500071
14922	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: Filtered ARG3: 31-32-33
14923	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: RVOL_MODE ''
14924	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: RVOL is:
14925	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: dialparties.agi: RVOLPARENT is:
14926	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script dialparties.agi completed, returning 0
14927	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:8] GotoIf("SIP/Cosmote-0000037a", "1?normdial") in new stack
14928	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-dial,s,11)
14929	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:11] NoOp("SIP/Cosmote-0000037a", "Returned from dialparties with groups to dial") in new stack
14930	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:12] NoOp("SIP/Cosmote-0000037a", "ringall array ") in new stack
14931	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:13] Set("SIP/Cosmote-0000037a", "__FMGL_DIAL=") in new stack
14932	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:14] Set("SIP/Cosmote-0000037a", "LOOPCNT=3") in new stack
14933	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:15] Set("SIP/Cosmote-0000037a", "ITER=1") in new stack
14934	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000037a", "__EXTTOCALL=31") in new stack
14935	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000037a", "Working with 31") in new stack
14936	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14937	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14938	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000037a", "ITER=2") in new stack
14939	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000037a", "1?ndloopbegin") in new stack
14940	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-dial,s,16)
14941	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000037a", "__EXTTOCALL=32") in new stack
14942	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000037a", "Working with 32") in new stack
14943	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14944	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14945	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000037a", "ITER=3") in new stack
14946	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000037a", "1?ndloopbegin") in new stack
14947	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-dial,s,16)
14948	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000037a", "__EXTTOCALL=33") in new stack
14949	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000037a", "Working with 33") in new stack
14950	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14951	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000037a", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
14952	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000037a", "ITER=4") in new stack
14953	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000037a", "0?ndloopbegin") in new stack
14954	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:22] Macro("SIP/Cosmote-0000037a", "dial-ringall-predial-hook,") in new stack
14955	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial-ringall-predial-hook:1] MacroExit("SIP/Cosmote-0000037a", "") in new stack
14956	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:23] ExecIf("SIP/Cosmote-0000037a", "0?Set(CWRING=r(callwaiting)):Set(CWRING=)") in new stack
14957	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:24] ExecIf("SIP/Cosmote-0000037a", "0?Set(ds=PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)g)") in new stack
14958	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-dial:25] Dial("SIP/Cosmote-0000037a", "PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)b(func-apply-sipheaders^s^1),") in new stack
14959	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/31-00000943 Internal Gosub(func-apply-sipheaders,s,1) start
14960	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/31-00000943", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
14961	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/31-00000943", "Applying SIP Headers to channel PJSIP/31-00000943") in new stack
14962	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/31-00000943", "TECH=PJSIP") in new stack
14963	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/31-00000943", "SIPHEADERKEYS=") in new stack
14964	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/31-00000943", "0") in new stack
14965	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_while.c: Jumping to priority 13
14966	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/31-00000943", "") in new stack
14967	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-00000943'
14968	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/31-00000943 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
14969	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/32-00000944 Internal Gosub(func-apply-sipheaders,s,1) start
14970	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/32-00000944", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
14971	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/32-00000944", "Applying SIP Headers to channel PJSIP/32-00000944") in new stack
14972	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/32-00000944", "TECH=PJSIP") in new stack
14973	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/32-00000944", "SIPHEADERKEYS=") in new stack
14974	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/32-00000944", "0") in new stack
14975	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_while.c: Jumping to priority 13
14976	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/32-00000944", "") in new stack
14977	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/32-00000944'
14978	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/32-00000944 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
14979	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/33-00000945 Internal Gosub(func-apply-sipheaders,s,1) start
14980	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/33-00000945", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
14981	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/33-00000945", "Applying SIP Headers to channel PJSIP/33-00000945") in new stack
14982	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/33-00000945", "TECH=PJSIP") in new stack
14983	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/33-00000945", "SIPHEADERKEYS=") in new stack
14984	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/33-00000945", "0") in new stack
14985	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_while.c: Jumping to priority 13
14986	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/33-00000945", "") in new stack
14987	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-00000945'
14988	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/33-00000945 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
14989	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: Called PJSIP/31/sip:31@192.168.1.10:5060
14990	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: Called PJSIP/32/sip:32@192.168.1.11:5060
14991	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: Called PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603
14992	[2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184
14993	[2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
14994	[2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5
14995	[2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184
14996	[2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
14997	[2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5
14998	[2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184
14999	[2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
15000	[2020-10-08 12:01:33] VERBOSE[8093] netsock2.c: Using SIP RTP Audio CoS mark 5
15001	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/33-00000945 connected line has changed. Saving it until answer for SIP/Cosmote-0000037a
15002	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/32-00000944 connected line has changed. Saving it until answer for SIP/Cosmote-0000037a
15003	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/31-00000943 connected line has changed. Saving it until answer for SIP/Cosmote-0000037a
15004	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/31-00000943 is ringing
15005	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/31-00000943 is ringing
15006	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/32-00000944 is ringing
15007	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/32-00000944 is ringing
15008	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/33-00000945 is ringing
15009	[2020-10-08 12:01:33] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/33-00000945 is ringing
15010	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_dial.c: PJSIP/33-00000945 answered SIP/Cosmote-0000037a
15011	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/31-00000943 Internal Gosub(crm-hangup,s,1) start
15012	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/31-00000943", "Sending Hangup to CRM") in new stack
15013	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/31-00000943", "HANGUP CAUSE: 26") in new stack
15014	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/31-00000943", "0?Set(__CRM_VOICEMAIL=)") in new stack
15015	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/31-00000943", "MASTER CHANNEL: 1602147693.3262 = 1602147692.3261") in new stack
15016	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/31-00000943", "1?return") in new stack
15017	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (crm-hangup,s,8)
15018	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/31-00000943", "") in new stack
15019	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-00000943'
15020	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/31-00000943 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
15021	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/32-00000944 Internal Gosub(crm-hangup,s,1) start
15022	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/32-00000944", "Sending Hangup to CRM") in new stack
15023	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/32-00000944", "HANGUP CAUSE: 26") in new stack
15024	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/32-00000944", "0?Set(__CRM_VOICEMAIL=)") in new stack
15025	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/32-00000944", "MASTER CHANNEL: 1602147693.3263 = 1602147692.3261") in new stack
15026	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/32-00000944", "1?return") in new stack
15027	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (crm-hangup,s,8)
15028	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/32-00000944", "") in new stack
15029	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/32-00000944'
15030	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] app_stack.c: PJSIP/32-00000944 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
15031	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:1] Set("PJSIP/33-00000945", "__MACRO_RESULT=") in new stack
15032	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:2] Set("PJSIP/33-00000945", "CFIGNORE=") in new stack
15033	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:3] Set("PJSIP/33-00000945", "MASTER_CHANNEL(CFIGNORE)=") in new stack
15034	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:4] Set("PJSIP/33-00000945", "FORWARD_CONTEXT=from-internal") in new stack
15035	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:5] Set("PJSIP/33-00000945", "MASTER_CHANNEL(FORWARD_CONTEXT)=from-internal") in new stack
15036	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:6] Macro("PJSIP/33-00000945", "blkvm-clr,") in new stack
15037	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-clr:1] Set("PJSIP/33-00000945", "SHARED(BLKVM,SIP/Cosmote-0000037a)=") in new stack
15038	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-clr:2] Set("PJSIP/33-00000945", "GOSUB_RETVAL=") in new stack
15039	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-blkvm-clr:3] MacroExit("PJSIP/33-00000945", "") in new stack
15040	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:7] ExecIf("PJSIP/33-00000945", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(num))=33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603)") in new stack
15041	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-auto-blkvm:8] ExecIf("PJSIP/33-00000945", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(name))=)") in new stack
15042	[2020-10-08 12:01:35] VERBOSE[12915][C-0000037f] bridge_channel.c: Channel PJSIP/33-00000945 joined 'simple_bridge' basic-bridge <5b5d6b94-a8a6-41ae-ad77-75fadbb69d5b>
15043	[2020-10-08 12:01:35] VERBOSE[12876][C-0000037f] bridge_channel.c: Channel SIP/Cosmote-0000037a joined 'simple_bridge' basic-bridge <5b5d6b94-a8a6-41ae-ad77-75fadbb69d5b>
15044	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] bridge_channel.c: Channel PJSIP/33-00000945 left 'simple_bridge' basic-bridge <5b5d6b94-a8a6-41ae-ad77-75fadbb69d5b>
15045	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] app_stack.c: PJSIP/33-00000945 Internal Gosub(crm-hangup,s,1) start
15046	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/33-00000945", "Sending Hangup to CRM") in new stack
15047	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/33-00000945", "HANGUP CAUSE: 16") in new stack
15048	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] bridge_channel.c: Channel SIP/Cosmote-0000037a left 'simple_bridge' basic-bridge <5b5d6b94-a8a6-41ae-ad77-75fadbb69d5b>
15049	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/33-00000945", "0?Set(__CRM_VOICEMAIL=)") in new stack
15050	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/33-00000945", "MASTER CHANNEL: 1602147693.3264 = 1602147692.3261") in new stack
15051	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] app_macro.c: Spawn extension (macro-dial, s, 25) exited non-zero on 'SIP/Cosmote-0000037a' in macro 'dial'
15052	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Spawn extension (ext-group, 1, 18) exited non-zero on 'SIP/Cosmote-0000037a'
15053	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [h@ext-group:1] Macro("SIP/Cosmote-0000037a", "hangupcall,") in new stack
15054	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/Cosmote-0000037a", "1?theend") in new stack
15055	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx_builtins.c: Goto (macro-hangupcall,s,3)
15056	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/33-00000945", "1?return") in new stack
15057	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx_builtins.c: Goto (crm-hangup,s,8)
15058	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/33-00000945", "") in new stack
15059	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] app_stack.c: Spawn extension (macro-dial, s, 1) exited non-zero on 'PJSIP/33-00000945'
15060	[2020-10-08 12:01:49] VERBOSE[12915][C-0000037f] app_stack.c: PJSIP/33-00000945 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
15061	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/Cosmote-0000037a", "0?Set(CDR(recordingfile)=)") in new stack
15062	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/Cosmote-0000037a", "PJSIP/33-00000945 montior file= /var/spool/asterisk/monitor/2020/10/08/in-+302510620630-2513500071-20201008-120132-1602147692.3261.wav") in new stack
15063	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/Cosmote-0000037a", "0?skipagi") in new stack
15064	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:6] AGI("SIP/Cosmote-0000037a", "attendedtransfer-rec-restart.php,PJSIP/33-00000945,/var/spool/asterisk/monitor/2020/10/08/in-+302510620630-2513500071-20201008-120132-1602147692.3261.wav") in new stack
15065	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/attendedtransfer-rec-restart.php
15066	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script attendedtransfer-rec-restart.php completed, returning 0
15067	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/Cosmote-0000037a", "") in new stack
15068	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/Cosmote-0000037a' in macro 'hangupcall'
15069	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000037a'
15070	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] app_stack.c: SIP/Cosmote-0000037a Internal Gosub(crm-hangup,s,1) start
15071	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:1] NoOp("SIP/Cosmote-0000037a", "Sending Hangup to CRM") in new stack
15072	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:2] NoOp("SIP/Cosmote-0000037a", "HANGUP CAUSE: 16") in new stack
15073	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:3] ExecIf("SIP/Cosmote-0000037a", "0?Set(__CRM_VOICEMAIL=)") in new stack
15074	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:4] NoOp("SIP/Cosmote-0000037a", "MASTER CHANNEL: 1602147692.3261 = 1602147692.3261") in new stack
15075	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:5] GotoIf("SIP/Cosmote-0000037a", "0?return") in new stack
15076	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:6] Set("SIP/Cosmote-0000037a", "__CRM_HANGUP=1") in new stack
15077	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:7] AGI("SIP/Cosmote-0000037a", "sangomacrm.agi") in new stack
15078	[2020-10-08 12:01:49] VERBOSE[12876][C-0000037f] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi
15079	[2020-10-08 12:01:50] VERBOSE[12876][C-0000037f] res_agi.c: <SIP/Cosmote-0000037a>AGI Script sangomacrm.agi completed, returning 0
15080	[2020-10-08 12:01:50] VERBOSE[12876][C-0000037f] pbx.c: Executing [s@crm-hangup:8] Return("SIP/Cosmote-0000037a", "") in new stack
15081	[2020-10-08 12:01:50] VERBOSE[12876][C-0000037f] app_stack.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000037a'
15082	[2020-10-08 12:01:50] VERBOSE[12876][C-0000037f] app_stack.c: SIP/Cosmote-0000037a Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
15083	[2020-10-08 12:01:50] VERBOSE[12877][C-0000037f] app_mixmonitor.c: MixMonitor close filestream (mixed)
15084	[2020-10-08 12:01:50] VERBOSE[12877][C-0000037f] app_mixmonitor.c: End MixMonitor Recording SIP/Cosmote-0000037a
This does not help much. You have to catch the pjsip logging to find eventually where is the "sip cancel" and decide whether the problem is with the phone or the FreePBX so try any external call answered by an internal extension. Meanwhile, check out on your FreePBX if you have “Enforce RFC7462” option in Advanced Settings. Try toggling that to see if this will fix the problem with the Mark Answered Elsewhere.
Martin
You can catch it on the wire by a packet catcher program. Your LAN administrator will help you with it if necessary. Or try "sip set debug peer ..." command on freePBX command line. The log you provided bellow contain no content of SIP packets.
See also sip answered elsewhere recorded as a missed call
It seems they are discussing the same issue you have. They claimed it to be freePBX/PJSIP bug. It may be patched in most recent version of freePBX. Consider to ask freePBX experts for help.
“Enforce RFC7462” was enabled, I disabled it, no difference, I re-enabled it, no difference.
With debug sip set to on here is the log during aswered call..
<--- SIP read from UDP:195.167.16.54:5060 --->
31259	hello
31260	<------------->
31261	[2020-10-08 14:04:23] VERBOSE[2276] chan_sip.c: Reliably Transmitting (NAT) to 195.167.16.54:5060:
31262	OPTIONS sip:ims.otenet.gr SIP/2.0
31263	Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK14887b42;rport
31264	Max-Forwards: 70
31265	From: "Unknown" <sip:+302510620630@192.168.1.5:5160>;tag=as66a91bca
31266	To: <sip:ims.otenet.gr>
31267	Contact: <sip:+302510620630@192.168.1.5:5160>
31268	Call-ID: 0561f4db1ce4029e6470e3245152202f@192.168.1.5:5160
31269	CSeq: 102 OPTIONS
31270	User-Agent: FPBX-15.0.16.75(13.36.0)
31271	Date: Thu, 08 Oct 2020 11:04:23 GMT
31272	Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
31273	Supported: replaces, timer
31274	Content-Length: 0
31275
31276
31277	---
31278	[2020-10-08 14:04:23] VERBOSE[2276] chan_sip.c:
31279	<--- SIP read from UDP:195.167.16.54:5060 --->
31280	SIP/2.0 604 Does Not Exist Anywhere
31281	Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK14887b42;received=80.106.83.137;rport=5160
31282	Call-ID: 0561f4db1ce4029e6470e3245152202f@192.168.1.5:5160
31283	From: "Unknown"<sip:+302510620630@192.168.1.5:5160>;tag=as66a91bca
31284	To: <sip:ims.otenet.gr>;tag=plxqzzoc
31285	CSeq: 102 OPTIONS
31286	Warning: 399 5244.684.I.261.12.344.0.13.24839.0.0.ims.otenet.gr "Unknown caller"
31287	Content-Length: 0
31288
31289	<------------->
31290	[2020-10-08 14:04:23] VERBOSE[2276] chan_sip.c: --- (8 headers 0 lines) ---
31291	[2020-10-08 14:04:23] VERBOSE[2276] chan_sip.c: Really destroying SIP dialog '0561f4db1ce4029e6470e3245152202f@192.168.1.5:5160' Method: OPTIONS
31292	[2020-10-08 14:04:35] VERBOSE[2276] chan_sip.c:
31293	<--- SIP read from UDP:195.167.16.54:5060 --->
31294	hello
31295	<------------->
31296	[2020-10-08 14:05:04] VERBOSE[2276] chan_sip.c:
31297	<--- SIP read from UDP:195.167.16.54:5060 --->
31298	hello
31299	<------------->
31300	[2020-10-08 14:05:23] VERBOSE[2276] chan_sip.c: Reliably Transmitting (NAT) to 195.167.16.54:5060:
31301	OPTIONS sip:ims.otenet.gr SIP/2.0
31302	Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK5f7230f4;rport
31303	Max-Forwards: 70
31304	From: "Unknown" <sip:+302510620630@192.168.1.5:5160>;tag=as2acd6a1c
31305	To: <sip:ims.otenet.gr>
31306	Contact: <sip:+302510620630@192.168.1.5:5160>
31307	Call-ID: 5f4ea2e401aebe017ebced1438f77c5c@192.168.1.5:5160
31308	CSeq: 102 OPTIONS
31309	User-Agent: FPBX-15.0.16.75(13.36.0)
31310	Date: Thu, 08 Oct 2020 11:05:23 GMT
31311	Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
31312	Supported: replaces, timer
31313	Content-Length: 0
31314
31315
31316	---
31317	[2020-10-08 14:05:23] VERBOSE[2276] chan_sip.c:
31318	<--- SIP read from UDP:195.167.16.54:5060 --->
31319	SIP/2.0 604 Does Not Exist Anywhere
31320	Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK5f7230f4;received=80.106.83.137;rport=5160
31321	Call-ID: 5f4ea2e401aebe017ebced1438f77c5c@192.168.1.5:5160
31322	From: "Unknown"<sip:+302510620630@192.168.1.5:5160>;tag=as2acd6a1c
31323	To: <sip:ims.otenet.gr>;tag=d17m7dmz
31324	CSeq: 102 OPTIONS
31325	Warning: 399 5244.684.I.261.12.314.0.13.24839.0.0.ims.otenet.gr "Unknown caller"
31326	Content-Length: 0
31327
31328	<------------->
31329	[2020-10-08 14:05:23] VERBOSE[2276] chan_sip.c: --- (8 headers 0 lines) ---
31330	[2020-10-08 14:05:23] VERBOSE[2276] chan_sip.c: Really destroying SIP dialog '5f4ea2e401aebe017ebced1438f77c5c@192.168.1.5:5160' Method: OPTIONS
31331	[2020-10-08 14:05:33] VERBOSE[2276] chan_sip.c:
31332	<--- SIP read from UDP:195.167.16.54:5060 --->
31333	hello
31334	<------------->
31335	[2020-10-08 14:05:40] VERBOSE[2276] chan_sip.c:
31336	<--- SIP read from UDP:195.167.16.54:5060 --->
31337	INVITE sip:+302510620630@192.168.1.5:5160 SIP/2.0
31338	Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36
31339	Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14
31340	From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14
31341	To: <sip:+302510620630@NAT.OTE.GR;user=phone>
31342	CSeq: 1 INVITE
31343	Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,PRACK,UPDATE
31344	Contact: <sip:195.167.16.54:5060;Hpt=8eb2_16;CxtId=4;TRC=ffffffff-ffffffff>
31345	Max-Forwards: 63
31346	Supported: 100rel
31347	P-Asserted-Identity: <sip:+306944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>
31348	P-Called-Party-ID: <tel:+302510620630>
31349	P-Early-Media: gated
31350	Content-Length: 232
31351	Content-Type: application/sdp
31352
31353	v=0
31354	o=- 2980790 2980790 IN IP4 195.167.22.126
31355	s=SBC call
31356	c=IN IP4 195.167.22.126
31357	t=0 0
31358	m=audio 20234 RTP/AVP 8 18
31359	b=RS:1000
31360	b=RR:3000
31361	a=rtpmap:8 PCMA/8000
31362	a=rtpmap:18 G729/8000
31363	a=fmtp:18 annexb=no
31364	a=ptime:20
31365	a=sendrecv
31366	<------------->
31367	[2020-10-08 14:05:40] VERBOSE[2276] chan_sip.c: --- (15 headers 13 lines) ---
31368	[2020-10-08 14:05:40] VERBOSE[2276] chan_sip.c: Sending to 195.167.16.54:5060 (NAT)
31369	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Sending to 195.167.16.54:5060 (NAT)
31370	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Using INVITE request as basis request - asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14
31371	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found peer 'Cosmote' for '6944314710' from 195.167.16.54:5060
31372	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] netsock2.c: Using SIP RTP TOS bits 184
31373	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] netsock2.c: Using SIP RTP CoS mark 5
31374	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Got SDP version 2980790 and unique parts [- 2980790 IN IP4 195.167.22.126]
31375	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found RTP audio format 8
31376	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found RTP audio format 18
31377	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found audio description format PCMA for ID 8
31378	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Found audio description format G729 for ID 18
31379	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Capabilities: us - (g722|alaw), peer - audio=(alaw|g729)/video=(nothing)/text=(nothing), combined - (alaw)
31380	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Non-codec capabilities (dtmf): us - 0x1 (telephone-event|), peer - 0x0 (nothing), combined - 0x0 (nothing)
31381	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Peer audio RTP is at port 195.167.22.126:20234
31382	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c: Looking for +302510620630 in from-trunk-sip-Cosmote (domain 192.168.1.5)
31383	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] sip/route.c: sip_route_dump: route/path hop: <sip:195.167.16.54:5060;Hpt=8eb2_16;CxtId=4;TRC=ffffffff-ffffffff>
31384	[2020-10-08 14:05:40] VERBOSE[2276][C-000003a4] chan_sip.c:
31385	<--- Transmitting (NAT) to 195.167.16.54:5060 --->
31386	SIP/2.0 100 Trying
31387	Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060
31388	From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14
31389	To: <sip:+302510620630@NAT.OTE.GR;user=phone>
31390	Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14
31391	CSeq: 1 INVITE
31392	Server: FPBX-15.0.16.75(13.36.0)
31393	Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
31394	Supported: replaces, timer
31395	Contact: <sip:+302510620630@192.168.1.5:5160>
31396	Content-Length: 0
31397
31398
31399	<------------>
31400	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:1] Set("SIP/Cosmote-0000039f", "GROUP()=OUT_1") in new stack
31401	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk-sip-Cosmote:2] Goto("SIP/Cosmote-0000039f", "from-trunk,+302510620630,1") in new stack
31402	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (from-trunk,+302510620630,1)
31403	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:1] Set("SIP/Cosmote-0000039f", "__DIRECTION=INBOUND") in new stack
31404	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:2] Gosub("SIP/Cosmote-0000039f", "sub-record-check,s,1(in,+302510620630,force)") in new stack
31405	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-0000039f", "0?initialized") in new stack
31406	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:2] Set("SIP/Cosmote-0000039f", "__REC_STATUS=INITIALIZED") in new stack
31407	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:3] Set("SIP/Cosmote-0000039f", "NOW=1602155140") in new stack
31408	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:4] Set("SIP/Cosmote-0000039f", "__DAY=08") in new stack
31409	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:5] Set("SIP/Cosmote-0000039f", "__MONTH=10") in new stack
31410	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:6] Set("SIP/Cosmote-0000039f", "__YEAR=2020") in new stack
31411	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:7] Set("SIP/Cosmote-0000039f", "__TIMESTR=20201008-140540") in new stack
31412	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:8] Set("SIP/Cosmote-0000039f", "__FROMEXTEN=unknown") in new stack
31413	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:9] Set("SIP/Cosmote-0000039f", "__MON_FMT=wav") in new stack
31414	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-0000039f", "Recordings initialized") in new stack
31415	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-0000039f", "0?Set(ARG3=dontcare)") in new stack
31416	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-0000039f", "REC_POLICY_MODE_SAVE=") in new stack
31417	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-0000039f", "0?Set(REC_STATUS=NO)") in new stack
31418	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-0000039f", "2?checkaction") in new stack
31419	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,s,17)
31420	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-0000039f", "1?sub-record-check,in,1") in new stack
31421	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,in,1)
31422	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:1] NoOp("SIP/Cosmote-0000039f", "Inbound Recording Check to +302510620630") in new stack
31423	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:2] Set("SIP/Cosmote-0000039f", "FROMEXTEN=unknown") in new stack
31424	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:3] ExecIf("SIP/Cosmote-0000039f", "10?Set(FROMEXTEN=6944314710)") in new stack
31425	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:4] Gosub("SIP/Cosmote-0000039f", "recordcheck,1(force,in,+302510620630)") in new stack
31426	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-0000039f", "Starting recording check against force") in new stack
31427	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-0000039f", "force") in new stack
31428	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,recordcheck,5)
31429	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:5] Set("SIP/Cosmote-0000039f", "__REC_POLICY_MODE=FORCE") in new stack
31430	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:6] GotoIf("SIP/Cosmote-0000039f", "1?startrec") in new stack
31431	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,recordcheck,16)
31432	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:16] NoOp("SIP/Cosmote-0000039f", "Starting recording: in, +302510620630") in new stack
31433	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:17] Set("SIP/Cosmote-0000039f", "__CALLFILENAME=in-+302510620630-6944314710-20201008-140540-1602155140.3413") in new stack
31434	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:18] MixMonitor("SIP/Cosmote-0000039f", "2020/10/08/in-+302510620630-6944314710-20201008-140540-1602155140.3413.wav,abi(LOCAL_MIXMON_ID),") in new stack
31435	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:19] Set("SIP/Cosmote-0000039f", "__MIXMON_ID=0x3a1b370") in new stack
31436	[2020-10-08 14:05:40] VERBOSE[11797][C-000003a4] app_mixmonitor.c: Begin MixMonitor Recording SIP/Cosmote-0000039f
31437	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:20] Set("SIP/Cosmote-0000039f", "__RECORD_ID=SIP/Cosmote-0000039f") in new stack
31438	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:21] Set("SIP/Cosmote-0000039f", "__REC_STATUS=RECORDING") in new stack
31439	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:22] Set("SIP/Cosmote-0000039f", "CDR(recordingfile)=in-+302510620630-6944314710-20201008-140540-1602155140.3413.wav") in new stack
31440	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:23] Return("SIP/Cosmote-0000039f", "") in new stack
31441	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [in@sub-record-check:5] Return("SIP/Cosmote-0000039f", "") in new stack
31442	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:3] Set("SIP/Cosmote-0000039f", "CHANNEL(tonezone)=gr") in new stack
31443	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:4] Set("SIP/Cosmote-0000039f", "__FROM_DID=+302510620630") in new stack
31444	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:5] Set("SIP/Cosmote-0000039f", "returnhere=1") in new stack
31445	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:6] Gosub("SIP/Cosmote-0000039f", "app-blacklist-check,s,1()") in new stack
31446	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@app-blacklist-check:1] GotoIf("SIP/Cosmote-0000039f", "0?blacklisted") in new stack
31447	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@app-blacklist-check:2] Set("SIP/Cosmote-0000039f", "CALLED_BLACKLIST=1") in new stack
31448	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@app-blacklist-check:3] Return("SIP/Cosmote-0000039f", "") in new stack
31449	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:7] Set("SIP/Cosmote-0000039f", "CDR(did)=+302510620630") in new stack
31450	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:8] GotoIf("SIP/Cosmote-0000039f", "0?") in new stack
31451	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:9] ExecIf("SIP/Cosmote-0000039f", "1 ?Set(CALLERID(name)=6944314710)") in new stack
31452	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:10] Set("SIP/Cosmote-0000039f", "__MOHCLASS=") in new stack
31453	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:11] Set("SIP/Cosmote-0000039f", "__REVERSAL_REJECT=FALSE") in new stack
31454	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:12] GotoIf("SIP/Cosmote-0000039f", "1?post-reverse-charge") in new stack
31455	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (from-trunk,+302510620630,14)
31456	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:14] NoOp("SIP/Cosmote-0000039f", "") in new stack
31457	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:15] Set("SIP/Cosmote-0000039f", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
31458	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:16] Set("SIP/Cosmote-0000039f", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
31459	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:17] Set("SIP/Cosmote-0000039f", "CALLERID(name-pres)=allowed_not_screened") in new stack
31460	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:18] Set("SIP/Cosmote-0000039f", "CALLERID(num-pres)=allowed_not_screened") in new stack
31461	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:19] Gosub("SIP/Cosmote-0000039f", "cidlookup,cidlookup_1,1()") in new stack
31462	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] pbx.c: Executing [cidlookup_1@cidlookup:1] AGI("SIP/Cosmote-0000039f", "contactmanager.agi, 6944314710,,4") in new stack
31463	[2020-10-08 14:05:40] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/contactmanager.agi
31464	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script contactmanager.agi completed, returning 0
31465	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [cidlookup_1@cidlookup:2] ExecIf("SIP/Cosmote-0000039f", "0?Set(CALLERID(name)=Unknown)") in new stack
31466	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [cidlookup_1@cidlookup:3] Return("SIP/Cosmote-0000039f", "") in new stack
31467	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:20] Set("SIP/Cosmote-0000039f", "CIDSFSCHEME=QUxMfEFMTA==") in new stack
31468	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:21] AGI("SIP/Cosmote-0000039f", "/var/www/html/admin/modules/superfecta/agi/superfecta.agi") in new stack
31469	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi
31470	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Executing Scheme..
31471	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Scheme Asked is: ALL
31472	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The DID is: +302510620630
31473	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNUM is: 6944314710
31474	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: The CNAME is: 6944314710
31475	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi:
31476	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Starting scheme Default
31477	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: No callerid found
31478	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_NEW: 6944314710
31479	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Setting channel variable SUPERFECTA_OLD: 6944314710
31480	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: CID Determined to be: '6944314710'
31481	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: /var/www/html/admin/modules/superfecta/agi/superfecta.agi: Attempting to set lookupcid
31482	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script /var/www/html/admin/modules/superfecta/agi/superfecta.agi completed, returning 0
31483	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:22] Set("SIP/Cosmote-0000039f", "CALLERID(name)=6944314710") in new stack
31484	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:23] NoOp("SIP/Cosmote-0000039f", "CallerID Entry Point") in new stack
31485	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:24] Set("SIP/Cosmote-0000039f", "__CRM_DIRECTION=INBOUND") in new stack
31486	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:25] Set("SIP/Cosmote-0000039f", "__CRM_SOURCE=6944314710") in new stack
31487	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:26] Set("SIP/Cosmote-0000039f", "__CRM_LINKEDID=1602155140.3413") in new stack
31488	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:27] AGI("SIP/Cosmote-0000039f", "sangomacrm.agi,true") in new stack
31489	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi
31490	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script sangomacrm.agi completed, returning 0
31491	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:28] ExecIf("SIP/Cosmote-0000039f", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
31492	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [+302510620630@from-trunk:29] Goto("SIP/Cosmote-0000039f", "ext-group,1,1") in new stack
31493	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (ext-group,1,1)
31494	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:1] GotoIf("SIP/Cosmote-0000039f", "0?cid") in new stack
31495	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:2] PlayTones("SIP/Cosmote-0000039f", "ring") in new stack
31496	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:3] Progress("SIP/Cosmote-0000039f", "") in new stack
31497	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] chan_sip.c: Audio is at 12316
31498	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] chan_sip.c: Adding codec alaw to SDP
31499	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] chan_sip.c:
31500	<--- Transmitting (NAT) to 195.167.16.54:5060 --->
31501	SIP/2.0 183 Session Progress
31502	Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060
31503	From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14
31504	To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1
31505	Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14
31506	CSeq: 1 INVITE
31507	Server: FPBX-15.0.16.75(13.36.0)
31508	Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
31509	Supported: replaces, timer
31510	Contact: <sip:+302510620630@192.168.1.5:5160>
31511	Content-Type: application/sdp
31512	Content-Length: 192
31513
31514	v=0
31515	o=root 895944538 895944538 IN IP4 192.168.1.5
31516	s=Asterisk PBX 13.36.0
31517	c=IN IP4 192.168.1.5
31518	t=0 0
31519	m=audio 12316 RTP/AVP 8
31520	a=rtpmap:8 PCMA/8000
31521	a=ptime:20
31522	a=maxptime:150
31523	a=sendrecv
31524
31525	<------------>
31526	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:4] Macro("SIP/Cosmote-0000039f", "user-callerid,") in new stack
31527	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:1] Set("SIP/Cosmote-0000039f", "TOUCH_MONITOR=1602155140.3413") in new stack
31528	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:2] Set("SIP/Cosmote-0000039f", "AMPUSER=6944314710") in new stack
31529	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:3] Set("SIP/Cosmote-0000039f", "HOTDESCKCHAN=Cosmote-0000039f") in new stack
31530	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:4] Set("SIP/Cosmote-0000039f", "HOTDESKEXTEN=Cosmote") in new stack
31531	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:5] Set("SIP/Cosmote-0000039f", "HOTDESKCALL=0") in new stack
31532	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:6] ExecIf("SIP/Cosmote-0000039f", "0?Set(HOTDESKCALL=1)") in new stack
31533	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:7] ExecIf("SIP/Cosmote-0000039f", "0?Set(CALLERID(name)=)") in new stack
31534	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:8] GotoIf("SIP/Cosmote-0000039f", "0?report") in new stack
31535	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:9] ExecIf("SIP/Cosmote-0000039f", "1?Set(REALCALLERIDNUM=6944314710)") in new stack
31536	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:10] Set("SIP/Cosmote-0000039f", "AMPUSER=") in new stack
31537	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:11] GotoIf("SIP/Cosmote-0000039f", "0?limit") in new stack
31538	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:12] Set("SIP/Cosmote-0000039f", "AMPUSERCIDNAME=") in new stack
31539	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:13] ExecIf("SIP/Cosmote-0000039f", "0?Set(__CIDMASQUERADING=TRUE)") in new stack
31540	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:14] GotoIf("SIP/Cosmote-0000039f", "1?report") in new stack
31541	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-user-callerid,s,23)
31542	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:23] NoOp("SIP/Cosmote-0000039f", "Macro Depth is 1") in new stack
31543	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:24] GotoIf("SIP/Cosmote-0000039f", "1?report2:macroerror") in new stack
31544	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-user-callerid,s,25)
31545	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:25] GotoIf("SIP/Cosmote-0000039f", "0?continue") in new stack
31546	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:26] ExecIf("SIP/Cosmote-0000039f", "1?Set(__CALLEE_ACCOUNCODE=)") in new stack
31547	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:27] Set("SIP/Cosmote-0000039f", "__TTL=64") in new stack
31548	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:28] GotoIf("SIP/Cosmote-0000039f", "1?continue") in new stack
31549	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-user-callerid,s,44)
31550	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:44] Set("SIP/Cosmote-0000039f", "CALLERID(number)=6944314710") in new stack
31551	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:45] Set("SIP/Cosmote-0000039f", "CALLERID(name)=6944314710") in new stack
31552	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:46] GotoIf("SIP/Cosmote-0000039f", "0?cnum") in new stack
31553	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:47] Set("SIP/Cosmote-0000039f", "CDR(cnam)=6944314710") in new stack
31554	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:48] Set("SIP/Cosmote-0000039f", "CDR(cnum)=6944314710") in new stack
31555	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-user-callerid:49] Set("SIP/Cosmote-0000039f", "CHANNEL(language)=en") in new stack
31556	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:5] Macro("SIP/Cosmote-0000039f", "blkvm-setifempty,") in new stack
31557	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:1] GotoIf("SIP/Cosmote-0000039f", "1?init") in new stack
31558	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-blkvm-setifempty,s,4)
31559	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:4] Set("SIP/Cosmote-0000039f", "__BLKVM_CHANNEL=SIP/Cosmote-0000039f") in new stack
31560	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:5] Set("SIP/Cosmote-0000039f", "SHARED(BLKVM,SIP/Cosmote-0000039f)=TRUE") in new stack
31561	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:6] Set("SIP/Cosmote-0000039f", "GOSUB_RETVAL=TRUE") in new stack
31562	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-setifempty:7] MacroExit("SIP/Cosmote-0000039f", "") in new stack
31563	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:6] GotoIf("SIP/Cosmote-0000039f", "1?skipov") in new stack
31564	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (ext-group,1,9)
31565	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:9] Set("SIP/Cosmote-0000039f", "RRNODEST=") in new stack
31566	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:10] Set("SIP/Cosmote-0000039f", "__NODEST=1") in new stack
31567	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:11] GosubIf("SIP/Cosmote-0000039f", "0?sub-rgsetcid,s,1()") in new stack
31568	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:12] Gosub("SIP/Cosmote-0000039f", "sub-record-check,s,1(rg,1,dontcare)") in new stack
31569	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:1] GotoIf("SIP/Cosmote-0000039f", "10?initialized") in new stack
31570	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,s,10)
31571	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:10] NoOp("SIP/Cosmote-0000039f", "Recordings initialized") in new stack
31572	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:11] ExecIf("SIP/Cosmote-0000039f", "0?Set(ARG3=dontcare)") in new stack
31573	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:12] Set("SIP/Cosmote-0000039f", "REC_POLICY_MODE_SAVE=FORCE") in new stack
31574	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:13] ExecIf("SIP/Cosmote-0000039f", "0?Set(REC_STATUS=NO)") in new stack
31575	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:14] GotoIf("SIP/Cosmote-0000039f", "2?checkaction") in new stack
31576	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,s,17)
31577	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:17] GotoIf("SIP/Cosmote-0000039f", "0?sub-record-check,rg,1") in new stack
31578	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:18] NoOp("SIP/Cosmote-0000039f", "Generic rg Recording Check - 6944314710 1") in new stack
31579	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:19] Gosub("SIP/Cosmote-0000039f", "recordcheck,1(dontcare,rg,1)") in new stack
31580	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:1] NoOp("SIP/Cosmote-0000039f", "Starting recording check against dontcare") in new stack
31581	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:2] Goto("SIP/Cosmote-0000039f", "dontcare") in new stack
31582	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (sub-record-check,recordcheck,3)
31583	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [recordcheck@sub-record-check:3] Return("SIP/Cosmote-0000039f", "") in new stack
31584	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@sub-record-check:20] Return("SIP/Cosmote-0000039f", "") in new stack
31585	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:13] Set("SIP/Cosmote-0000039f", "RingGroupMethod=ringall") in new stack
31586	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:14] Set("SIP/Cosmote-0000039f", "__ALT_CONFIRM_MSG=") in new stack
31587	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:15] GotoIf("SIP/Cosmote-0000039f", "0?RGVQANNOUNCE:NORGVQANNOUNCE") in new stack
31588	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (ext-group,1,18)
31589	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [1@ext-group:18] Macro("SIP/Cosmote-0000039f", "dial,120,HhTtrQ(ANSWERED_ELSEWHERE),31-32-33") in new stack
31590	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:1] NoOp("SIP/Cosmote-0000039f", "Blind Transfer: , Attended Transfer: , User: , Alert Info: ") in new stack
31591	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:2] Set("SIP/Cosmote-0000039f", "__CRM_SOURCE=6944314710") in new stack
31592	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:3] ExecIf("SIP/Cosmote-0000039f", "0?Set(ALERT_INFO=)") in new stack
31593	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:4] ExecIf("SIP/Cosmote-0000039f", "0?Set(ALERT_INFO=)") in new stack
31594	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:5] ExecIf("SIP/Cosmote-0000039f", "0?Set(ALERT_INFO=)") in new stack
31595	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:6] ExecIf("SIP/Cosmote-0000039f", "0?Set(CHANNEL(musicclass)=)") in new stack
31596	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:7] AGI("SIP/Cosmote-0000039f", "dialparties.agi") in new stack
31597	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi
31598	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Starting New Dialparties.agi
31599	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Caller ID name is '6944314710' number is '6944314710'
31600	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: CW Ignore is:
31601	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: CF Ignore is:
31602	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: CW IN_USE/BUSY is: 1
31603	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Methodology of ring is 'ringall'
31604	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Added extension 31 to extension map
31605	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Added extension 32 to extension map
31606	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Added extension 33 to extension map
31607	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 31 cf is disabled
31608	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 32 cf is disabled
31609	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 33 cf is disabled
31610	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 31 do not disturb is disabled
31611	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 32 do not disturb is disabled
31612	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Extension 33 do not disturb is disabled
31613	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/31
31614	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/31/sip:31@192.168.1.10:5060
31615	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: dbset CALLTRACE/31 to 6944314710
31616	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/32
31617	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/32/sip:32@192.168.1.11:5060
31618	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: dbset CALLTRACE/32 to 6944314710
31619	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Discovered PJSIP Endpoint PJSIP/33
31620	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Ended up with real PJSIP Dial string PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603
31621	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: dbset CALLTRACE/33 to 6944314710
31622	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: Filtered ARG3: 31-32-33
31623	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: RVOL_MODE ''
31624	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: RVOL is:
31625	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: dialparties.agi: RVOLPARENT is:
31626	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script dialparties.agi completed, returning 0
31627	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:8] GotoIf("SIP/Cosmote-0000039f", "1?normdial") in new stack
31628	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-dial,s,11)
31629	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:11] NoOp("SIP/Cosmote-0000039f", "Returned from dialparties with groups to dial") in new stack
31630	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:12] NoOp("SIP/Cosmote-0000039f", "ringall array ") in new stack
31631	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:13] Set("SIP/Cosmote-0000039f", "__FMGL_DIAL=") in new stack
31632	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:14] Set("SIP/Cosmote-0000039f", "LOOPCNT=3") in new stack
31633	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:15] Set("SIP/Cosmote-0000039f", "ITER=1") in new stack
31634	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000039f", "__EXTTOCALL=31") in new stack
31635	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000039f", "Working with 31") in new stack
31636	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
31637	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
31638	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000039f", "ITER=2") in new stack
31639	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000039f", "1?ndloopbegin") in new stack
31640	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-dial,s,16)
31641	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000039f", "__EXTTOCALL=32") in new stack
31642	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000039f", "Working with 32") in new stack
31643	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
31644	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
31645	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000039f", "ITER=3") in new stack
31646	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000039f", "1?ndloopbegin") in new stack
31647	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-dial,s,16)
31648	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:16] Set("SIP/Cosmote-0000039f", "__EXTTOCALL=33") in new stack
31649	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:17] NoOp("SIP/Cosmote-0000039f", "Working with 33") in new stack
31650	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:18] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
31651	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:19] ExecIf("SIP/Cosmote-0000039f", "0?Set(HASH(__SIPHEADERS,Alert-Info)=Normal;volume=)") in new stack
31652	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:20] Set("SIP/Cosmote-0000039f", "ITER=4") in new stack
31653	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:21] GotoIf("SIP/Cosmote-0000039f", "0?ndloopbegin") in new stack
31654	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:22] Macro("SIP/Cosmote-0000039f", "dial-ringall-predial-hook,") in new stack
31655	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial-ringall-predial-hook:1] MacroExit("SIP/Cosmote-0000039f", "") in new stack
31656	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:23] ExecIf("SIP/Cosmote-0000039f", "0?Set(CWRING=r(callwaiting)):Set(CWRING=)") in new stack
31657	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:24] ExecIf("SIP/Cosmote-0000039f", "0?Set(ds=PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)g)") in new stack
31658	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-dial:25] Dial("SIP/Cosmote-0000039f", "PJSIP/31/sip:31@192.168.1.10:5060&PJSIP/32/sip:32@192.168.1.11:5060&PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603,120,HhtrQ(ANSWERED_ELSEWHERE)M(auto-blkvm)b(func-apply-sipheaders^s^1),") in new stack
31659	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/31-000009b6 Internal Gosub(func-apply-sipheaders,s,1) start
31660	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/31-000009b6", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
31661	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/31-000009b6", "Applying SIP Headers to channel PJSIP/31-000009b6") in new stack
31662	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/31-000009b6", "TECH=PJSIP") in new stack
31663	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/31-000009b6", "SIPHEADERKEYS=") in new stack
31664	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/31-000009b6", "0") in new stack
31665	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_while.c: Jumping to priority 13
31666	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/31-000009b6", "") in new stack
31667	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-000009b6'
31668	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/31-000009b6 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
31669	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/32-000009b7 Internal Gosub(func-apply-sipheaders,s,1) start
31670	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/32-000009b7", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
31671	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/32-000009b7", "Applying SIP Headers to channel PJSIP/32-000009b7") in new stack
31672	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/32-000009b7", "TECH=PJSIP") in new stack
31673	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/32-000009b7", "SIPHEADERKEYS=") in new stack
31674	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/32-000009b7", "0") in new stack
31675	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_while.c: Jumping to priority 13
31676	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/32-000009b7", "") in new stack
31677	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/32-000009b7'
31678	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/32-000009b7 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
31679	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/33-000009b8 Internal Gosub(func-apply-sipheaders,s,1) start
31680	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:1] ExecIf("PJSIP/33-000009b8", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
31681	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:2] NoOp("PJSIP/33-000009b8", "Applying SIP Headers to channel PJSIP/33-000009b8") in new stack
31682	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:3] Set("PJSIP/33-000009b8", "TECH=PJSIP") in new stack
31683	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:4] Set("PJSIP/33-000009b8", "SIPHEADERKEYS=") in new stack
31684	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:5] While("PJSIP/33-000009b8", "0") in new stack
31685	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_while.c: Jumping to priority 13
31686	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@func-apply-sipheaders:14] Return("PJSIP/33-000009b8", "") in new stack
31687	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-000009b8'
31688	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/33-000009b8 Internal Gosub(func-apply-sipheaders,s,1) complete GOSUB_RETVAL=
31689	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: Called PJSIP/31/sip:31@192.168.1.10:5060
31690	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: Called PJSIP/32/sip:32@192.168.1.11:5060
31691	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: Called PJSIP/33/sip:33@192.168.1.1:5060;uniq=C4A4C199895A79C69D685E3240603
31692	[2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184
31693	[2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
31694	[2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio CoS mark 5
31695	[2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184
31696	[2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
31697	[2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio CoS mark 5
31698	[2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184
31699	[2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio TOS bits 184 in TCLASS field.
31700	[2020-10-08 14:05:41] VERBOSE[12478] netsock2.c: Using SIP RTP Audio CoS mark 5
31701	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/33-000009b8 connected line has changed. Saving it until answer for SIP/Cosmote-0000039f
31702	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/32-000009b7 connected line has changed. Saving it until answer for SIP/Cosmote-0000039f
31703	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/31-000009b6 connected line has changed. Saving it until answer for SIP/Cosmote-0000039f
31704	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/31-000009b6 is ringing
31705	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/31-000009b6 is ringing
31706	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/33-000009b8 is ringing
31707	[2020-10-08 14:05:41] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/33-000009b8 is ringing
31708	[2020-10-08 14:05:42] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/32-000009b7 is ringing
31709	[2020-10-08 14:05:42] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/32-000009b7 is ringing
31710	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_dial.c: PJSIP/32-000009b7 answered SIP/Cosmote-0000039f
31711	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/31-000009b6 Internal Gosub(crm-hangup,s,1) start
31712	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/31-000009b6", "Sending Hangup to CRM") in new stack
31713	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/31-000009b6", "HANGUP CAUSE: 26") in new stack
31714	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/31-000009b6", "0?Set(__CRM_VOICEMAIL=)") in new stack
31715	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/31-000009b6", "MASTER CHANNEL: 1602155141.3414 = 1602155140.3413") in new stack
31716	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/31-000009b6", "1?return") in new stack
31717	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (crm-hangup,s,8)
31718	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/31-000009b6", "") in new stack
31719	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/31-000009b6'
31720	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/31-000009b6 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
31721	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/33-000009b8 Internal Gosub(crm-hangup,s,1) start
31722	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/33-000009b8", "Sending Hangup to CRM") in new stack
31723	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/33-000009b8", "HANGUP CAUSE: 26") in new stack
31724	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/33-000009b8", "0?Set(__CRM_VOICEMAIL=)") in new stack
31725	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/33-000009b8", "MASTER CHANNEL: 1602155141.3416 = 1602155140.3413") in new stack
31726	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/33-000009b8", "1?return") in new stack
31727	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (crm-hangup,s,8)
31728	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/33-000009b8", "") in new stack
31729	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (from-internal, 1, 1) exited non-zero on 'PJSIP/33-000009b8'
31730	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] app_stack.c: PJSIP/33-000009b8 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
31731	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:1] Set("PJSIP/32-000009b7", "__MACRO_RESULT=") in new stack
31732	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:2] Set("PJSIP/32-000009b7", "CFIGNORE=") in new stack
31733	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:3] Set("PJSIP/32-000009b7", "MASTER_CHANNEL(CFIGNORE)=") in new stack
31734	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:4] Set("PJSIP/32-000009b7", "FORWARD_CONTEXT=from-internal") in new stack
31735	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:5] Set("PJSIP/32-000009b7", "MASTER_CHANNEL(FORWARD_CONTEXT)=from-internal") in new stack
31736	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:6] Macro("PJSIP/32-000009b7", "blkvm-clr,") in new stack
31737	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-clr:1] Set("PJSIP/32-000009b7", "SHARED(BLKVM,SIP/Cosmote-0000039f)=") in new stack
31738	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-clr:2] Set("PJSIP/32-000009b7", "GOSUB_RETVAL=") in new stack
31739	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-blkvm-clr:3] MacroExit("PJSIP/32-000009b7", "") in new stack
31740	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:7] ExecIf("PJSIP/32-000009b7", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(num))=32/sip:32@192.168.1.11:5060)") in new stack
31741	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-auto-blkvm:8] ExecIf("PJSIP/32-000009b7", "0?Set(MASTER_CHANNEL(CONNECTEDLINE(name))=)") in new stack
31742	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] chan_sip.c: Audio is at 12316
31743	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] chan_sip.c: Adding codec alaw to SDP
31744	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] chan_sip.c:
31745	<--- Reliably Transmitting (NAT) to 195.167.16.54:5060 --->
31746	SIP/2.0 200 OK
31747	Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060
31748	From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14
31749	To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1
31750	Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14
31751	CSeq: 1 INVITE
31752	Server: FPBX-15.0.16.75(13.36.0)
31753	Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
31754	Supported: replaces, timer
31755	Contact: <sip:+302510620630@192.168.1.5:5160>
31756	Content-Type: application/sdp
31757	Content-Length: 192
31758
31759	v=0
31760	o=root 895944538 895944538 IN IP4 192.168.1.5
31761	s=Asterisk PBX 13.36.0
31762	c=IN IP4 192.168.1.5
31763	t=0 0
31764	m=audio 12316 RTP/AVP 8
31765	a=rtpmap:8 PCMA/8000
31766	a=ptime:20
31767	a=maxptime:150
31768	a=sendrecv
31769
31770	<------------>
31771	[2020-10-08 14:05:56] VERBOSE[11847][C-000003a4] bridge_channel.c: Channel PJSIP/32-000009b7 joined 'simple_bridge' basic-bridge <76d7119a-e294-4d3b-afe2-910169279666>
31772	[2020-10-08 14:05:56] VERBOSE[11796][C-000003a4] bridge_channel.c: Channel SIP/Cosmote-0000039f joined 'simple_bridge' basic-bridge <76d7119a-e294-4d3b-afe2-910169279666>
31773	[2020-10-08 14:05:56] VERBOSE[2276] chan_sip.c: Retransmitting #1 (NAT) to 195.167.16.54:5060:
31774	SIP/2.0 200 OK
31775	Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bKeb4bw4xbk6c4b2xkxew7h3be6;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060
31776	From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14
31777	To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1
31778	Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14
31779	CSeq: 1 INVITE
31780	Server: FPBX-15.0.16.75(13.36.0)
31781	Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
31782	Supported: replaces, timer
31783	Contact: <sip:+302510620630@192.168.1.5:5160>
31784	Content-Type: application/sdp
31785	Content-Length: 192
31786
31787	v=0
31788	o=root 895944538 895944538 IN IP4 192.168.1.5
31789	s=Asterisk PBX 13.36.0
31790	c=IN IP4 192.168.1.5
31791	t=0 0
31792	m=audio 12316 RTP/AVP 8
31793	a=rtpmap:8 PCMA/8000
31794	a=ptime:20
31795	a=maxptime:150
31796	a=sendrecv
31797
31798	---
31799	[2020-10-08 14:05:56] VERBOSE[2276] chan_sip.c:
31800	<--- SIP read from UDP:195.167.16.54:5060 --->
31801	ACK sip:+302510620630@192.168.1.5:5160 SIP/2.0
31802	Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bK5ibfh2iekxbe3k6f3cw47ccbw;Role=3;Hpt=8eb2_36
31803	Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14
31804	From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14
31805	To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1
31806	CSeq: 1 ACK
31807	Max-Forwards: 63
31808	Content-Length: 0
31809
31810	<------------->
31811	[2020-10-08 14:05:56] VERBOSE[2276] chan_sip.c: --- (8 headers 0 lines) ---
31812	[2020-10-08 14:06:02] VERBOSE[2276] chan_sip.c:
31813	<--- SIP read from UDP:195.167.16.54:5060 --->
31814	hello
31815	<------------->
31816	Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14
31817	From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14
31818	To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1
31819	CSeq: 2 BYE
31820	Max-Forwards: 63
31821	Reason: Q.850;cause=16
31822	Content-Length: 0
31823
31824	<------------->
31825	[2020-10-08 14:06:17] VERBOSE[2276] chan_sip.c: --- (9 headers 0 lines) ---
31826	[2020-10-08 14:06:17] VERBOSE[2276][C-000003a4] chan_sip.c: Sending to 195.167.16.54:5060 (NAT)
31827	[2020-10-08 14:06:17] VERBOSE[2276][C-000003a4] chan_sip.c: Scheduling destruction of SIP dialog 'asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14' in 6976 ms (Method: BYE)
31828	[2020-10-08 14:06:17] VERBOSE[2276][C-000003a4] chan_sip.c:
31829	<--- Transmitting (NAT) to 195.167.16.54:5060 --->
31830	SIP/2.0 200 OK
31831	Via: SIP/2.0/UDP 195.167.16.54:5060;branch=z9hG4bK7kwex4chb2fc0x6x7xi07cbcc;Role=3;Hpt=8eb2_36;received=195.167.16.54;rport=5060
31832	From: <sip:6944314710@BC00.TSSPS1.PIREOS.IMS.VODAFONE.GR;user=phone>;tag=fse6nwun-CC-14
31833	To: <sip:+302510620630@NAT.OTE.GR;user=phone>;tag=as7b2f5dc1
31834	Call-ID: asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14
31835	CSeq: 2 BYE
31836	Server: FPBX-15.0.16.75(13.36.0)
31837	Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
31838	Supported: replaces, timer
31839	Content-Length: 0
31840
31841
31842	<------------>
31843	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] bridge_channel.c: Channel SIP/Cosmote-0000039f left 'simple_bridge' basic-bridge <76d7119a-e294-4d3b-afe2-910169279666>
31844	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] app_macro.c: Spawn extension (macro-dial, s, 25) exited non-zero on 'SIP/Cosmote-0000039f' in macro 'dial'
31845	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Spawn extension (ext-group, 1, 18) exited non-zero on 'SIP/Cosmote-0000039f'
31846	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [h@ext-group:1] Macro("SIP/Cosmote-0000039f", "hangupcall,") in new stack
31847	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/Cosmote-0000039f", "1?theend") in new stack
31848	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx_builtins.c: Goto (macro-hangupcall,s,3)
31849	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/Cosmote-0000039f", "0?Set(CDR(recordingfile)=)") in new stack
31850	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] bridge_channel.c: Channel PJSIP/32-000009b7 left 'simple_bridge' basic-bridge <76d7119a-e294-4d3b-afe2-910169279666>
31851	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] app_stack.c: PJSIP/32-000009b7 Internal Gosub(crm-hangup,s,1) start
31852	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:1] NoOp("PJSIP/32-000009b7", "Sending Hangup to CRM") in new stack
31853	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:2] NoOp("PJSIP/32-000009b7", "HANGUP CAUSE: 16") in new stack
31854	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:3] ExecIf("PJSIP/32-000009b7", "0?Set(__CRM_VOICEMAIL=)") in new stack
31855	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:4] NoOp("PJSIP/32-000009b7", "MASTER CHANNEL: 1602155141.3415 = 1602155140.3413") in new stack
31856	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:5] GotoIf("PJSIP/32-000009b7", "1?return") in new stack
31857	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx_builtins.c: Goto (crm-hangup,s,8)
31858	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] pbx.c: Executing [s@crm-hangup:8] Return("PJSIP/32-000009b7", "") in new stack
31859	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] app_stack.c: Spawn extension (macro-dial, s, 1) exited non-zero on 'PJSIP/32-000009b7'
31860	[2020-10-08 14:06:17] VERBOSE[11847][C-000003a4] app_stack.c: PJSIP/32-000009b7 Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
31861	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:4] NoOp("SIP/Cosmote-0000039f", "PJSIP/33-000009b8 montior file= /var/spool/asterisk/monitor/2020/10/08/in-+302510620630-6944314710-20201008-140540-1602155140.3413.wav") in new stack
31862	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:5] GotoIf("SIP/Cosmote-0000039f", "0?skipagi") in new stack
31863	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:6] AGI("SIP/Cosmote-0000039f", "attendedtransfer-rec-restart.php,PJSIP/33-000009b8,/var/spool/asterisk/monitor/2020/10/08/in-+302510620630-6944314710-20201008-140540-1602155140.3413.wav") in new stack
31864	[2020-10-08 14:06:17] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/attendedtransfer-rec-restart.php
31865	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script attendedtransfer-rec-restart.php completed, returning 0
31866	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@macro-hangupcall:7] Hangup("SIP/Cosmote-0000039f", "") in new stack
31867	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_macro.c: Spawn extension (macro-hangupcall, s, 7) exited non-zero on 'SIP/Cosmote-0000039f' in macro 'hangupcall'
31868	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000039f'
31869	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: SIP/Cosmote-0000039f Internal Gosub(crm-hangup,s,1) start
31870	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:1] NoOp("SIP/Cosmote-0000039f", "Sending Hangup to CRM") in new stack
31871	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:2] NoOp("SIP/Cosmote-0000039f", "HANGUP CAUSE: 16") in new stack
31872	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:3] ExecIf("SIP/Cosmote-0000039f", "0?Set(__CRM_VOICEMAIL=)") in new stack
31873	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:4] NoOp("SIP/Cosmote-0000039f", "MASTER CHANNEL: 1602155140.3413 = 1602155140.3413") in new stack
31874	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:5] GotoIf("SIP/Cosmote-0000039f", "0?return") in new stack
31875	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:6] Set("SIP/Cosmote-0000039f", "__CRM_HANGUP=1") in new stack
31876	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:7] AGI("SIP/Cosmote-0000039f", "sangomacrm.agi") in new stack
31877	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] res_agi.c: Launched AGI Script /var/lib/asterisk/agi-bin/sangomacrm.agi
31878	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] res_agi.c: <SIP/Cosmote-0000039f>AGI Script sangomacrm.agi completed, returning 0
31879	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] pbx.c: Executing [s@crm-hangup:8] Return("SIP/Cosmote-0000039f", "") in new stack
31880	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000039f'
31881	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: SIP/Cosmote-0000039f Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
31882	[2020-10-08 14:06:18] VERBOSE[11797][C-000003a4] app_mixmonitor.c: MixMonitor close filestream (mixed)
31883	[2020-10-08 14:06:18] VERBOSE[11797][C-000003a4] app_mixmonitor.c: End MixMonitor Recording SIP/Cosmote-0000039f
31884	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: Spawn extension (ext-group, h, 1) exited non-zero on 'SIP/Cosmote-0000039f'
31885	[2020-10-08 14:06:18] VERBOSE[11796][C-000003a4] app_stack.c: SIP/Cosmote-0000039f Internal Gosub(crm-hangup,s,1) complete GOSUB_RETVAL=
31886	[2020-10-08 14:06:18] VERBOSE[11797][C-000003a4] app_mixmonitor.c: MixMonitor close filestream (mixed)
31887	[2020-10-08 14:06:18] VERBOSE[11797][C-000003a4] app_mixmonitor.c: End MixMonitor Recording SIP/Cosmote-0000039f
31888	[2020-10-08 14:06:23] VERBOSE[2276] chan_sip.c: Reliably Transmitting (NAT) to 195.167.16.54:5060:
31889	OPTIONS sip:ims.otenet.gr SIP/2.0
31890	Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK4ec5aa78;rport
31891	Max-Forwards: 70
31892	From: "Unknown" <sip:+302510620630@192.168.1.5:5160>;tag=as14dcbd6a
31893	To: <sip:ims.otenet.gr>
31894	Contact: <sip:+302510620630@192.168.1.5:5160>
31895	Call-ID: 4681e72212c44cc67141f99a672420aa@192.168.1.5:5160
31896	CSeq: 102 OPTIONS
31897	User-Agent: FPBX-15.0.16.75(13.36.0)
31898	Date: Thu, 08 Oct 2020 11:06:23 GMT
31899	Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
31900	Supported: replaces, timer
31901	Content-Length: 0
31902
31903
31904	---
31905	[2020-10-08 14:06:23] VERBOSE[2276] chan_sip.c:
31906	<--- SIP read from UDP:195.167.16.54:5060 --->
31907	SIP/2.0 604 Does Not Exist Anywhere
31908	Via: SIP/2.0/UDP 192.168.1.5:5160;branch=z9hG4bK4ec5aa78;received=80.106.83.137;rport=5160
31909	Call-ID: 4681e72212c44cc67141f99a672420aa@192.168.1.5:5160
31910	From: "Unknown"<sip:+302510620630@192.168.1.5:5160>;tag=as14dcbd6a
31911	To: <sip:ims.otenet.gr>;tag=t3ngwaia
31912	CSeq: 102 OPTIONS
31913	Warning: 399 5244.684.I.261.12.342.0.13.24839.0.0.ims.otenet.gr "Unknown caller"
31914	Content-Length: 0
31915
31916	<------------->
31917	[2020-10-08 14:06:23] VERBOSE[2276] chan_sip.c: --- (8 headers 0 lines) ---
31918	[2020-10-08 14:06:23] VERBOSE[2276] chan_sip.c: Really destroying SIP dialog '4681e72212c44cc67141f99a672420aa@192.168.1.5:5160' Method: OPTIONS
31919	[2020-10-08 14:06:24] VERBOSE[2276] chan_sip.c: Really destroying SIP dialog 'asbcusccv0xxvxdueefcfwwd1yvxzsxc66yd@ATS.thes-ATS1.ims.otenet.gr.14' Method: BYE
31920	[2020-10-08 14:06:31] VERBOSE[2276] chan_sip.c:
31921	<--- SIP read from UDP:195.167.16.54:5060 --->
31922	hello
31923	<------------->
You captured SIP dialog between freePBX and the phone answering the call. It's not the phone you have issue with (unless I missed the topic). I wish to see SIP dialog (especially SIP CANCEL packet) between freePBX and the phone that stops ringing with no answer (because call has been answered elsewhere).
Does this capture from Wireshark help? 192.168.1.10 is my ip phone that shows answered calls as missed. I see in line 8379 SIP CANCEL.
14	0.514953	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n
15	0.515013	192.168.1.2	192.168.1.10	ICMP	128	Destination unreachable (Port unreachable)
16	0.515468	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n
17	0.516010	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
18	0.516881	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
19	0.517335	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949de350 949de3a0 bcts:1 nRef:0\n
20	0.517643	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949de350 949de3a0 bcts:1 nRef:0\n
21	0.524978	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 9 state:3 \n
22	0.525358	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 9 state:3 \n
23	0.525738	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
24	0.526058	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
25	0.527050	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c8130 clean 0 9498c590 9498c5e0 bcts:1 nRef:0\n
26	0.527392	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c8130 clean 0 9498c590 9498c5e0 bcts:1 nRef:0\n
97	2.884972	192.168.1.10	192.168.1.2	Syslog	60	LOCAL2.DEBUG: CC:Clean Up\n
98	2.885027	192.168.1.2	192.168.1.10	ICMP	87	Destination unreachable (Port unreachable)
99	2.885708	192.168.1.10	192.168.1.2	Syslog	69	LOCAL2.DEBUG: --- OBJ POOL STAT ---\n
100	2.886122	192.168.1.10	192.168.1.2	Syslog	71	LOCAL2.DEBUG: OP:? =   6 (  8 1356)
101	2.886999	192.168.1.10	192.168.1.2	Syslog	60	LOCAL2.DEBUG: \n
7821	10.524867	192.168.1.10	192.168.1.2	Syslog	78	LOCAL3.DEBUG: regTimerCallBack 51 bTryAltReg\n
7822	10.524925	192.168.1.2	192.168.1.10	ICMP	106	Destination unreachable (Port unreachable)
7823	10.525688	192.168.1.10	192.168.1.2	Syslog	75	LOCAL3.DEBUG: #### create TS 1 0x949c9c10\n
7824	10.528228	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n
7825	10.529339	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n
7826	10.529999	192.168.1.10	192.168.1.2	Syslog	650	NOTIFY sip:192.168.1.5 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-352ac0dd\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nCSeq: 121839 NOTIFY\r\nMax-Forwards: 70\r\nAuthorization: Digest username="31",realm="asterisk",nonce="1606382095/4ef5caa98ec89c54d7a4993d8601031e",uri="sip:192.168.1.5",algorithm=MD5,response="aeb8b619fbb850c162ec603729590e75",opaque="528c3b9c588a9533",qop=auth,nc=00000002,cnonce="96ad59f6"\r\nContact: <sip:31@192.168.1.10:5060>\r\nEvent: keep-alive\r\nUser-Agent: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n
7827	10.530707	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
7828	10.531433	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
7829	10.533570	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
7830	10.533946	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
7831	10.534625	192.168.1.10	192.168.1.2	Syslog	377	SIP/2.0 501 Not Implemented\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;rport=5060;received=192.168.1.10;branch=z9hG4bK-352ac0dd\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>;tag=z9hG4bK-352ac0dd\r\nCSeq: 121839 NOTIFY\r\nServer: FPBX-15.0.16.81(13.36.0)\r\nContent-Length:  0\r\n\r\n
7832	10.535028	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
7833	10.535427	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
7834	10.535899	192.168.1.10	192.168.1.2	Syslog	101	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n
7835	10.536237	192.168.1.10	192.168.1.2	Syslog	101	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n
7836	10.537039	192.168.1.10	192.168.1.2	Syslog	69	LOCAL3.DEBUG: SIP_regTsEventProc 27\n
7837	10.537458	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: start TMR K\n
7838	10.537814	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: start TMR K\n
7839	10.538638	192.168.1.10	192.168.1.2	Syslog	69	LOCAL3.DEBUG: SIP_regTsEventProc 31\n
7842	11.024819	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n
7843	11.025165	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n
7854	13.444836	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c5d00 clean 0 949c76e0 949c77c0 bcts:0 nRef:0\n
7855	13.444895	192.168.1.2	192.168.1.10	ICMP	133	Destination unreachable (Port unreachable)
7856	13.445348	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c5d00 clean 0 949c76e0 949c77c0 bcts:0 nRef:0\n
7867	15.544850	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n
7868	15.544910	192.168.1.2	192.168.1.10	ICMP	128	Destination unreachable (Port unreachable)
7869	15.545378	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n
7870	15.545919	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
7871	15.546259	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
7872	15.547167	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949c7850 949c78a0 bcts:1 nRef:0\n
7873	15.547509	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949c7850 949c78a0 bcts:1 nRef:0\n
7926	25.544876	192.168.1.10	192.168.1.2	Syslog	78	LOCAL3.DEBUG: regTimerCallBack 51 bTryAltReg\n
7927	25.544901	192.168.1.2	192.168.1.10	ICMP	106	Destination unreachable (Port unreachable)
7928	25.545710	192.168.1.10	192.168.1.2	Syslog	75	LOCAL3.DEBUG: #### create TS 1 0x949c9c10\n
7929	25.548506	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n
7930	25.549178	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n
7931	25.549744	192.168.1.10	192.168.1.2	Syslog	650	NOTIFY sip:192.168.1.5 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-b5a9f004\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nCSeq: 121840 NOTIFY\r\nMax-Forwards: 70\r\nAuthorization: Digest username="31",realm="asterisk",nonce="1606382095/4ef5caa98ec89c54d7a4993d8601031e",uri="sip:192.168.1.5",algorithm=MD5,response="caa58181846ac2088a70de10444fe565",opaque="528c3b9c588a9533",qop=auth,nc=00000003,cnonce="96ad59f6"\r\nContact: <sip:31@192.168.1.10:5060>\r\nEvent: keep-alive\r\nUser-Agent: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n
7932	25.550070	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
7933	25.551133	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
7934	25.553324	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
7935	25.553698	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
7936	25.554116	192.168.1.10	192.168.1.2	Syslog	377	SIP/2.0 501 Not Implemented\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;rport=5060;received=192.168.1.10;branch=z9hG4bK-b5a9f004\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>;tag=z9hG4bK-b5a9f004\r\nCSeq: 121840 NOTIFY\r\nServer: FPBX-15.0.16.81(13.36.0)\r\nContent-Length:  0\r\n\r\n
7937	25.554783	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
7938	25.555169	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
7939	25.555637	192.168.1.10	192.168.1.2	Syslog	101	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n
7940	25.555978	192.168.1.10	192.168.1.2	Syslog	101	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n
7941	25.556843	192.168.1.10	192.168.1.2	Syslog	69	LOCAL3.DEBUG: SIP_regTsEventProc 27\n
7942	25.557262	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: start TMR K\n
7943	25.557610	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: start TMR K\n
7944	25.558137	192.168.1.10	192.168.1.2	Syslog	69	LOCAL3.DEBUG: SIP_regTsEventProc 31\n
7945	26.044766	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n
7946	26.045118	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n
7979	30.564767	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n
7980	30.564795	192.168.1.2	192.168.1.10	ICMP	128	Destination unreachable (Port unreachable)
7981	30.565419	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n
7982	30.565810	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
7983	30.566138	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
7985	30.567050	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 9498c400 9498c450 bcts:1 nRef:0\n
7986	30.567399	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 9498c400 9498c450 bcts:1 nRef:0\n
8259	37.137348	192.168.1.10	192.168.1.2	Syslog	70	LOCAL2.DEBUG: SDP RTPMAP 111 --> 130\n
8260	37.137399	192.168.1.2	192.168.1.10	ICMP	98	Destination unreachable (Port unreachable)
8261	37.138967	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8262	37.139322	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8263	37.139900	192.168.1.10	192.168.1.2	Syslog	1052	INVITE sip:31@192.168.1.10:5060 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;rport;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nTo: <sip:31@192.168.1.10>\r\nContact: <sip:asterisk@192.168.1.5:5060>\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 INVITE\r\nAllow: OPTIONS, SUBSCRIBE, NOTIFY, PUBLISH, INVITE, ACK, BYE, CANCEL, UPDATE, PRACK, REGISTER, MESSAGE, REFER\r\nSupported: 100rel, timer, replaces, norefersub\r\nSession-Expires: 1800\r\nMin-SE: 90\r\nP-Asserted-Identity: "6949719941" <sip:6949719941@192.168.1.5>\r\nMax-Forwards: 70\r\nUser-Agent: FPBX-15.0.16.81(13.36.0)\r\nContent-Type: application/sdp\r\nContent-Length:   279\r\n\r\nv=0\r\no=- 613651335 613651335 IN IP4 192.168.1.5\r\ns=Asterisk\r\nc=IN IP4 192.168.1.5\r\nt=0 0\r\nm=audio 11878 RTP/AVP 0 8 3 111 9\r\na=rtpmap:0 PCMU/8000\r\na=rtpmap:8 PCMA/8000\r\na=rtpmap:3 GSM/8000\r\na=rtpmap:111 G726-32/8000\r\na=rtpmap:9 G722/8000\r\na=ptime:20\r\na=maxptime:150\r\na=sendrecv\r\n
8264	37.140576	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8265	37.141264	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8266	37.143961	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{343)\n
8267	37.144571	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{343)\n
8268	37.144998	192.168.1.10	192.168.1.2	Syslog	385	SIP/2.0 100 Trying\r\nTo: <sip:31@192.168.1.10>\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 INVITE\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nServer: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n
8269	37.145389	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8270	37.145760	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8271	37.146677	192.168.1.10	192.168.1.2	Syslog	80	LOCAL3.DEBUG: >>>> SIP: SIP_getRemotePartyId 0\n
8272	37.147109	192.168.1.10	192.168.1.2	Syslog	102	LOCAL3.DEBUG: ucCallerIdHeader 0 bUseFromOnly 0 bNoFrom 0 bPrivacy 0\n
8273	37.147502	192.168.1.10	192.168.1.2	Syslog	105	LOCAL3.DEBUG: SIP_getRemotePartyId(), 1 pna->uri.hp.strHose=192.168.1.5\n
8274	37.147948	192.168.1.10	192.168.1.2	Syslog	94	LOCAL3.DEBUG: SIP_getRemotePartyId(), 1 pna->uri.hp.usPort=0\n
8275	37.148675	192.168.1.10	192.168.1.2	Syslog	97	LOCAL3.DEBUG: SIP_getRemotePartyId(), 1 lid=0 call_log_domain=0\n
8276	37.149075	192.168.1.10	192.168.1.2	Syslog	99	LOCAL3.DEBUG: SIP_getRemotePartyId(), 1 cinf->strPhone=6949719941\n
8277	37.149466	192.168.1.10	192.168.1.2	Syslog	105	LOCAL3.DEBUG: [SIP_getRemotePartyId] name="6949719941" phone=6949719941\n
8278	37.149929	192.168.1.10	192.168.1.2	Syslog	84	LOCAL3.DEBUG: [SIP_getRemotePartyId] splash attr=0\n
8279	37.151025	192.168.1.10	192.168.1.2	Syslog	89	LOCAL3.DEBUG: [SIP_getRemotePartyId] try to call id_map\n
8280	37.151485	192.168.1.10	192.168.1.2	Syslog	99	LOCAL3.DEBUG: SIP_getRemotePartyId(), 4 cinf->strPhone=6949719941\n
8281	37.151880	192.168.1.10	192.168.1.2	Syslog	97	LOCAL3.DEBUG: SIP_getRemotePartyId(), cinf->strPhone=6949719941\n
8282	37.152486	192.168.1.10	192.168.1.2	Syslog	96	LOCAL3.DEBUG: SIP_getRemotePartyId(), cinf->strName=6949719941\n
8283	37.152947	192.168.1.10	192.168.1.2	Syslog	81	LOCAL3.DEBUG: <<<< 2 SIP: SIP_getRemotePartyId \n
8284	37.153558	192.168.1.10	192.168.1.2	Syslog	92	LOCAL0.INFO: +++++ find idle call i = 0, caid=0 (asked 0)\n
8285	37.153907	192.168.1.10	192.168.1.2	Syslog	92	LOCAL0.INFO: +++++ find idle call i = 0, caid=0 (asked 0)\n
8286	37.154768	192.168.1.10	192.168.1.2	Syslog	71	LOCAL0.INFO: [0]CC:NewCallState 10/0\n
8287	37.155120	192.168.1.10	192.168.1.2	Syslog	71	LOCAL0.INFO: [0]CC:NewCallState 10/0\n
8288	37.155535	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8289	37.155906	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8290	37.157518	192.168.1.10	192.168.1.2	Syslog	97	LOCAL3.DEBUG: [CCTRL]record lcr phone=6949719941 exten=0 type=0\n
8291	37.158055	192.168.1.10	192.168.1.2	Syslog	72	LOCAL0.INFO: START_RING in CC_refresh\n
8292	37.158722	192.168.1.10	192.168.1.2	Syslog	72	LOCAL0.INFO: START_RING in CC_refresh\n
8293	37.173715	192.168.1.10	192.168.1.2	Syslog	70	LOCAL2.DEBUG: SDP RTPMAP 111 --> 130\n
8294	37.175004	192.168.1.10	192.168.1.2	Syslog	72	LOCAL1.DEBUG: In InitRemoteVoipMetrics\n
8295	37.176282	192.168.1.10	192.168.1.2	Syslog	66	LOCAL1.DEBUG: In InitVoipMetrics\n
8296	37.177245	192.168.1.10	192.168.1.2	Syslog	80	LOCAL2.DEBUG: [0:0]AUD ALLOC CALL (port=16456)\n
8297	37.179501	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{404)\n
8298	37.179787	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{404)\n
8299	37.180553	192.168.1.10	192.168.1.2	Syslog	446	SIP/2.0 180 Ringing\r\nTo: <sip:31@192.168.1.10>;tag=2740b794e6461544i0\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 INVITE\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nContact: <sip:31@192.168.1.10:5060>\r\nServer: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n
8300	37.181277	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8301	37.181657	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8325	40.564826	192.168.1.10	192.168.1.2	Syslog	78	LOCAL3.DEBUG: regTimerCallBack 51 bTryAltReg\n
8326	40.564886	192.168.1.2	192.168.1.10	ICMP	106	Destination unreachable (Port unreachable)
8327	40.565820	192.168.1.10	192.168.1.2	Syslog	75	LOCAL3.DEBUG: #### create TS 1 0x949c9c10\n
8328	40.569453	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n
8329	40.569788	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n
8330	40.570879	192.168.1.10	192.168.1.2	Syslog	650	NOTIFY sip:192.168.1.5 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-d022af1e\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nCSeq: 121841 NOTIFY\r\nMax-Forwards: 70\r\nAuthorization: Digest username="31",realm="asterisk",nonce="1606382095/4ef5caa98ec89c54d7a4993d8601031e",uri="sip:192.168.1.5",algorithm=MD5,response="1abacb1a1e33cbff8fbb8e3df475b821",opaque="528c3b9c588a9533",qop=auth,nc=00000004,cnonce="96ad59f6"\r\nContact: <sip:31@192.168.1.10:5060>\r\nEvent: keep-alive\r\nUser-Agent: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n
8331	40.571635	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8332	40.572130	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8333	40.574664	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8334	40.575055	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8335	40.575528	192.168.1.10	192.168.1.2	Syslog	531	SIP/2.0 401 Unauthorized\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;rport=5060;received=192.168.1.10;branch=z9hG4bK-d022af1e\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>;tag=z9hG4bK-d022af1e\r\nCSeq: 121841 NOTIFY\r\nWWW-Authenticate: Digest realm="asterisk",nonce="1606382140/0478c70f3207912a9692ff956501dc4c",opaque="0038606e68597775",stale=true,algorithm=md5,qop="auth"\r\nServer: FPBX-15.0.16.81(13.36.0)\r\nContent-Length:  0\r\n\r\n
8336	40.575898	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8337	40.576768	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8338	40.577197	192.168.1.10	192.168.1.2	Syslog	101	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n
8339	40.577548	192.168.1.10	192.168.1.2	Syslog	101	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 27 state:1 \n
8340	40.578016	192.168.1.10	192.168.1.2	Syslog	69	LOCAL3.DEBUG: SIP_regTsEventProc 27\n
8341	40.578885	192.168.1.10	192.168.1.2	Syslog	124	LOCAL3.DEBUG: SIP_getAuthState callid=d04af86c-375ac0a0@192.168.1.10 realm=asterisk type=0\n
8342	40.579339	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: start TMR K\n
8343	40.579682	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: start TMR K\n
8344	40.580182	192.168.1.10	192.168.1.2	Syslog	69	LOCAL3.DEBUG: SIP_regTsEventProc 31\n
8345	40.581471	192.168.1.10	192.168.1.2	Syslog	78	LOCAL3.DEBUG: regTimerCallBack 51 bTryAltReg\n
8346	40.581980	192.168.1.10	192.168.1.2	Syslog	75	LOCAL3.DEBUG: #### create TS 1 0x949c8130\n
8347	40.584172	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n
8348	40.584989	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{608)\n
8349	40.585678	192.168.1.10	192.168.1.2	Syslog	650	NOTIFY sip:192.168.1.5 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-76604572\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nCSeq: 121842 NOTIFY\r\nMax-Forwards: 70\r\nAuthorization: Digest username="31",realm="asterisk",nonce="1606382140/0478c70f3207912a9692ff956501dc4c",uri="sip:192.168.1.5",algorithm=MD5,response="82ffd4317cddb47689715904526296ef",opaque="0038606e68597775",qop=auth,nc=00000001,cnonce="74f47497"\r\nContact: <sip:31@192.168.1.10:5060>\r\nEvent: keep-alive\r\nUser-Agent: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n
8350	40.586038	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8351	40.586842	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8352	40.589499	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8353	40.589871	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8354	40.590656	192.168.1.10	192.168.1.2	Syslog	377	SIP/2.0 501 Not Implemented\r\nVia: SIP/2.0/UDP 192.168.1.10:5060;rport=5060;received=192.168.1.10;branch=z9hG4bK-76604572\r\nCall-ID: d04af86c-375ac0a0@192.168.1.10\r\nFrom: <sip:31@192.168.1.5>;tag=4656af7ca523f4d0o0\r\nTo: <sip:192.168.1.5>;tag=z9hG4bK-76604572\r\nCSeq: 121842 NOTIFY\r\nServer: FPBX-15.0.16.81(13.36.0)\r\nContent-Length:  0\r\n\r\n
8355	40.591384	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8356	40.591758	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8357	40.592428	192.168.1.10	192.168.1.2	Syslog	101	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 27 state:1 \n
8358	40.592846	192.168.1.10	192.168.1.2	Syslog	101	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 27 state:1 \n
8359	40.593267	192.168.1.10	192.168.1.2	Syslog	69	LOCAL3.DEBUG: SIP_regTsEventProc 27\n
8360	40.593678	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: start TMR K\n
8361	40.594022	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: start TMR K\n
8362	40.594740	192.168.1.10	192.168.1.2	Syslog	69	LOCAL3.DEBUG: SIP_regTsEventProc 31\n
8367	41.074740	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n
8368	41.075117	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 3 state:3 \n
8369	41.084710	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 3 state:3 \n
8370	41.085034	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 3 state:3 \n
8376	42.086855	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8377	42.086916	192.168.1.2	192.168.1.10	ICMP	102	Destination unreachable (Port unreachable)
8378	42.087365	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8379	42.088083	192.168.1.10	192.168.1.2	Syslog	518	CANCEL sip:31@192.168.1.10:5060 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;rport;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nTo: <sip:31@192.168.1.10>\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 CANCEL\r\nReason: SIP;cause=200;text="Call completed elsewhere"\r\nReason: Q.850;cause=26\r\nMax-Forwards: 70\r\nUser-Agent: FPBX-15.0.16.81(13.36.0)\r\nContent-Length:  0\r\n\r\n
8380	42.089097	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8381	42.089483	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8382	42.092173	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{378)\n
8383	42.092779	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{378)\n
8384	42.093206	192.168.1.10	192.168.1.2	Syslog	420	SIP/2.0 487 Request Terminated\r\nTo: <sip:31@192.168.1.10>;tag=2740b794e6461544i0\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 INVITE\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nServer: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n
8385	42.093908	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8386	42.094579	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8387	42.097093	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{362)\n
8388	42.097440	192.168.1.10	192.168.1.2	Syslog	79	LOCAL0.INFO: [0:5060]->192.168.1.5:5060{362)\n
8389	42.097908	192.168.1.10	192.168.1.2	Syslog	404	SIP/2.0 200 OK\r\nTo: <sip:31@192.168.1.10>;tag=2740b794e6461544i0\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 CANCEL\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nServer: Cisco/SPA504G-7.6.2g\r\nContent-Length: 0\r\n\r\n
8390	42.098668	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8391	42.099043	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8392	42.099953	192.168.1.10	192.168.1.2	Syslog	65	LOCAL2.DEBUG: [0:0]AUD Rel Call\n
8393	42.119413	192.168.1.10	192.168.1.2	Syslog	90	LOCAL3.DEBUG: [CCTRL]record lcr phone=6949719941 exten=0\n
8394	42.119847	192.168.1.10	192.168.1.2	Syslog	71	LOCAL0.INFO: [0]CC:NewCallState 0/10\n
8395	42.120524	192.168.1.10	192.168.1.2	Syslog	71	LOCAL0.INFO: [0]CC:NewCallState 0/10\n
8396	42.121266	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8397	42.121649	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8398	42.137098	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8399	42.137454	192.168.1.10	192.168.1.2	Syslog	74	LOCAL0.INFO: [0:5060]<<192.168.1.5:5060\n
8400	42.137949	192.168.1.10	192.168.1.2	Syslog	456	ACK sip:31@192.168.1.10:5060 SIP/2.0\r\nVia: SIP/2.0/UDP 192.168.1.5:5060;rport;branch=z9hG4bKPje5d55bab-cee8-4280-8f81-b7d6af59438f\r\nFrom: "6949719941" <sip:6949719941@192.168.1.5>;tag=25d50b3e-3e0f-44bf-b7f6-ebfb4daa3c07\r\nTo: <sip:31@192.168.1.10>;tag=2740b794e6461544i0\r\nCall-ID: ae7ec849-dc34-41c4-bda1-6e405b03dbf1\r\nCSeq: 26799 ACK\r\nMax-Forwards: 70\r\nUser-Agent: FPBX-15.0.16.81(13.36.0)\r\nContent-Length:  0\r\n\r\n
8401	42.138690	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8402	42.139066	192.168.1.10	192.168.1.2	Syslog	60	LOCAL0.INFO: \n
8438	45.584701	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n
8439	45.584761	192.168.1.2	192.168.1.10	ICMP	128	Destination unreachable (Port unreachable)
8440	45.585210	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c9c10 event 9 state:3 \n
8441	45.585747	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
8442	45.586078	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
8443	45.587005	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949c76c0 949de200 bcts:1 nRef:0\n
8444	45.587347	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c9c10 clean 0 949c76c0 949de200 bcts:1 nRef:0\n
8445	45.594862	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 9 state:3 \n
8446	45.595234	192.168.1.10	192.168.1.2	Syslog	100	LOCAL0.INFO: SIP_tsClientEventProc ts:0x949c8130 event 9 state:3 \n
8447	45.595609	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
8448	45.595939	192.168.1.10	192.168.1.2	Syslog	61	LOCAL0.INFO: Timer K Fires\n
8449	45.596878	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c8130 clean 0 9498c5a0 9498c5f0 bcts:1 nRef:0\n
8450	45.597221	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c8130 clean 0 9498c5a0 9498c5f0 bcts:1 nRef:0\n
8483	47.144819	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c5d00 clean 0 949c77f0 9498c440 bcts:0 nRef:0\n
8484	47.144880	192.168.1.2	192.168.1.10	ICMP	133	Destination unreachable (Port unreachable)
8485	47.145340	192.168.1.10	192.168.1.2	Syslog	105	LOCAL0.INFO: +++ ts 0x949c5d00 clean 0 949c77f0 9498c440 bcts:0 nRef:0\n
192.168.1.10	-> 192.168.1.2
CSeq: 26799 CANCEL
Max-Forwards: 70
Content-Length:  0
Looks good. Phone's firmware is recent enough (7.6.2g while feature has been implemented in 7.4.7), CANCEL contain SIP;cause=200;text="Call completed elsewhere" reason. So the last condition - have you the line in question configured as "shared" (Share Call Appearance = shared) ? It doesn't work for private (non shared) lines.
Thank you for reply!
In Phone/Line Key 1/Share Call Appearance my setting in all phones was private (with this setting I had no problem when extension was configured as chan_sip in freepbx).
I changed this setting to Shared in all my phones but still Answered calls appear as Missed... So the problem remains..
PS. There is also an option Voice/Ext 1/Share Line Appearance/Share Ext: which is also set to Private. Is it OK?
Since freepbx is sending correctly SIP Cancel, SPA504G is responsible for still showing missed calls? Any idea what setting could interfere with that? Thank you.
