06-08-2018 09:50 PM - edited 03-21-2019 09:12 AM
I thought I would shared this since it has been killing about 150 of my phones. Major rollout, and all phones are connected. Going live the next morning. I reboot the asterisk server that night to increase RAM/etc. Go to the call-center in the morning, and every phone is orange and not registering.
I thought maybe asterisk was not running, so I restarted asterisk, still nothing. Most phones were froze up. time stopped, menu button lights display, but that is it. Mind you, all phones have 7.6.2d firmware, which as of today is latest.
A week later, did a brief server reboot, and same thing. Every phone locked up. Had to ask everyone to unplug phones to restart. Web interface does come up, but http://ip/advanced/reboot does not actually work.
I realize that my 10 spa 525G phones don't have the same issue, so I start going through the config. setting by setting, testing on a seperate network, disconnecting ethernet cable on switch, and running wireshark to watch what happens. I finally get to changing "Nat keep-alive" to NO on the spa504G. In every situation I've had, I've always set this to yes for phones behind a router. It was set to NO on the other phones, so I gave it a shot. Sure enough, after turning off, phones do not lock up. I can remove ethernet from switch and they don't lock up.
Some side notes. we have register expiry set to 30 seconds, so NAT keepalive is really not needed. We have the registry set to a low number so that our failover works much more quickly.
I'm not sure why the phones freeze. I've read some other posts about TTL and DNS possibly being an issue. On my home network it seems to take about 5 minutes before the phone stops trying to register and completely locks up. Hope this helps someone, or maybe someone can explain if this is a bad configuration on my part.
06-08-2018 11:54 PM
Well, it require a lot of work to identify true cause - remember - we are volunteers and enthusiast only, we have no access to neither source codes nor to developers tools.
All I can tell you now - we have few hundreds of SPA504G, with 7.5.5 firmware and ...
NAT_Keep_Alive_Intvl=55 NAT_Mapping_Enable_1=No NAT_Keep_Alive_Enable_1=Yes NAT_Keep_Alive_Msg_1=$NOTIFY
... and we are not facing the issue you described. I have just one SPA508G with 7.6.2SR4, same NAT configuration, and no issue even with it.
You may try this configuration on few phones - and if it will work, you may slowly slip, step-by-step, to your (failing) configuration. It may help to narrow cause, or it may disclose workaround.
I assume you verified it's phone issue e.g. packets are not lost by NAT engine on the path. It should be noted we have no NAT between phones and Asterisk server.
Also, you should turn on syslog&debug (highest level) and capture them - log may (but may not, of course) disclose something valuable.
06-09-2018 12:03 AM
Dan,
I appreciate your response. I've got my test setup in the office, so I will give that a try and re-test and provide results. Thanks!
Spencer
06-10-2018 11:23 PM
I tested with those settings. Still locks up. Here is what I do. Unplug the switch from the rest of the lan, wait about 10-15 minutes. Press Menu button on phone. You will see backlight go on, but no menu. Time is stuck. Phone is frozen. Web interface is accessible (as long as you are on that isolated part of the unplugged lan).
Here is my config if you care to take a look:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<flat-profile><Connection_Type group="Info/System_Information">DHCP</Connection_Type><Current_IP group="Info/System_Information">192.168.20.135</Current_IP><Host_Name group="Info/System_Information">SEP2C86D210F3AE</Host_Name><Domain group="Info/System_Information">twohandstech.local</Domain><Current_Netmask group="Info/System_Information">255.255.255.0</Current_Netmask><Current_Gateway group="Info/System_Information">192.168.20.1</Current_Gateway><Primary__DNS group="Info/System_Information">192.168.20.3</Primary__DNS><Secondary__DNS group="Info/System_Information">192.168.20.10 8.8.8.8 </Secondary__DNS><Product_Name group="Info/Product_Information">SPA504G</Product_Name><Serial_Number group="Info/Product_Information">CCQ21230777</Serial_Number><Software_Version group="Info/Product_Information">7.6.2d</Software_Version><Hardware_Version group="Info/Product_Information">1.1.0</Hardware_Version><MAC_Address group="Info/Product_Information">2C86D210F3AE</MAC_Address><Client_Certificate group="Info/Product_Information">Installed (2048 bits)</Client_Certificate><Customization group="Info/Product_Information">Open</Customization><Licenses group="Info/Product_Information">None</Licenses><Current_Time group="Info/Phone_Status">6/10/2018 23:03:01</Current_Time><Elapsed_Time group="Info/Phone_Status">00:21:24</Elapsed_Time><Broadcast_Pkts_Sent group="Info/Phone_Status">41</Broadcast_Pkts_Sent><Broadcast_Bytes_Sent group="Info/Phone_Status">3050</Broadcast_Bytes_Sent><Broadcast_Pkts_Recv group="Info/Phone_Status">1872</Broadcast_Pkts_Recv><Broadcast_Bytes_Recv group="Info/Phone_Status">143862</Broadcast_Bytes_Recv><Broadcast_Pkts_Dropped group="Info/Phone_Status">0</Broadcast_Pkts_Dropped><Broadcast_Bytes_Dropped group="Info/Phone_Status">0</Broadcast_Bytes_Dropped><RTP_Packets_Sent group="Info/Phone_Status">0</RTP_Packets_Sent><RTP_Bytes_Sent group="Info/Phone_Status">0</RTP_Bytes_Sent><RTP_Packets_Recv group="Info/Phone_Status">0</RTP_Packets_Recv><RTP_Bytes_Recv group="Info/Phone_Status">0</RTP_Bytes_Recv><SIP_Messages_Sent group="Info/Phone_Status">93</SIP_Messages_Sent><SIP_Bytes_Sent group="Info/Phone_Status">46599</SIP_Bytes_Sent><SIP_Messages_Recv group="Info/Phone_Status">90</SIP_Messages_Recv><SIP_Bytes_Recv group="Info/Phone_Status">52535</SIP_Bytes_Recv><External_IP group="Info/Phone_Status"/><Operational_VLAN_ID group="Info/Phone_Status">N/A</Operational_VLAN_ID><SW_Port group="Info/Phone_Status">100M Full Duplex</SW_Port><PC_Port group="Info/Phone_Status">Link Down</PC_Port><Registration_State group="Info/Ext_1_Status">Failed - Not Reachable</Registration_State><Last_Registration_At group="Info/Ext_1_Status">6/10/2018 22:52:10</Last_Registration_At><Next_Registration_In group="Info/Ext_1_Status">0 s</Next_Registration_In><Message_Waiting group="Info/Ext_1_Status">No</Message_Waiting><Mapped_SIP_Port group="Info/Ext_1_Status"/><Hoteling_State group="Info/Ext_1_Status">Disabled</Hoteling_State><Registration_State group="Info/Ext_2_Status">Not Registered</Registration_State><Last_Registration_At group="Info/Ext_2_Status"/><Next_Registration_In group="Info/Ext_2_Status"/><Message_Waiting group="Info/Ext_2_Status">No</Message_Waiting><Mapped_SIP_Port group="Info/Ext_2_Status"/><Hoteling_State group="Info/Ext_2_Status">Disabled</Hoteling_State><Registration_State group="Info/Ext_3_Status">Not Registered</Registration_State><Last_Registration_At group="Info/Ext_3_Status"/><Next_Registration_In group="Info/Ext_3_Status"/><Message_Waiting group="Info/Ext_3_Status">No</Message_Waiting><Mapped_SIP_Port group="Info/Ext_3_Status"/><Hoteling_State group="Info/Ext_3_Status">Disabled</Hoteling_State><Registration_State group="Info/Ext_4_Status">Not Registered</Registration_State><Last_Registration_At group="Info/Ext_4_Status"/><Next_Registration_In group="Info/Ext_4_Status"/><Message_Waiting group="Info/Ext_4_Status">No</Message_Waiting><Mapped_SIP_Port group="Info/Ext_4_Status"/><Hoteling_State group="Info/Ext_4_Status">Disabled</Hoteling_State><Call_State group="Info/Line_1_Call_1_Status">No Service</Call_State><Tone group="Info/Line_1_Call_1_Status">None</Tone><Encoder group="Info/Line_1_Call_1_Status"/><Decoder group="Info/Line_1_Call_1_Status"/><Type group="Info/Line_1_Call_1_Status"/><Remote_Hold group="Info/Line_1_Call_1_Status"/><Callback group="Info/Line_1_Call_1_Status"/><Peer_Name group="Info/Line_1_Call_1_Status"/><Peer_Phone group="Info/Line_1_Call_1_Status"/><Duration group="Info/Line_1_Call_1_Status"/><Packets_Sent group="Info/Line_1_Call_1_Status"/><Packets_Recv group="Info/Line_1_Call_1_Status"/><Bytes_Sent group="Info/Line_1_Call_1_Status"/><Bytes_Recv group="Info/Line_1_Call_1_Status"/><Mapped_RTP_Port group="Info/Line_1_Call_1_Status"/><Media_Loopback group="Info/Line_1_Call_1_Status"/><Decode_Latency group="Info/Line_1_Call_1_Status"/><Jitter group="Info/Line_1_Call_1_Status"/><Round_Trip_Delay group="Info/Line_1_Call_1_Status"/><End_System_Delay group="Info/Line_1_Call_1_Status"/><Packets_Lost group="Info/Line_1_Call_1_Status"/><Packet_Error group="Info/Line_1_Call_1_Status"/><Loss_Rate group="Info/Line_1_Call_1_Status"/><Discard_Rate group="Info/Line_1_Call_1_Status"/><Burst_Duration group="Info/Line_1_Call_1_Status"/><Gap_Duration group="Info/Line_1_Call_1_Status"/><R_Factor group="Info/Line_1_Call_1_Status"/><MOS_Listening group="Info/Line_1_Call_1_Status"/><MOS_Conversational group="Info/Line_1_Call_1_Status"/><Call_State group="Info/Line_1_Call_2_Status">No Service</Call_State><Tone group="Info/Line_1_Call_2_Status">None</Tone><Encoder group="Info/Line_1_Call_2_Status"/><Decoder group="Info/Line_1_Call_2_Status"/><Type group="Info/Line_1_Call_2_Status"/><Remote_Hold group="Info/Line_1_Call_2_Status"/><Callback group="Info/Line_1_Call_2_Status"/><Peer_Name group="Info/Line_1_Call_2_Status"/><Peer_Phone group="Info/Line_1_Call_2_Status"/><Duration group="Info/Line_1_Call_2_Status"/><Packets_Sent group="Info/Line_1_Call_2_Status"/><Packets_Recv group="Info/Line_1_Call_2_Status"/><Bytes_Sent group="Info/Line_1_Call_2_Status"/><Bytes_Recv group="Info/Line_1_Call_2_Status"/><Mapped_RTP_Port group="Info/Line_1_Call_2_Status"/><Media_Loopback group="Info/Line_1_Call_2_Status"/><Decode_Latency group="Info/Line_1_Call_2_Status"/><Jitter group="Info/Line_1_Call_2_Status"/><Round_Trip_Delay group="Info/Line_1_Call_2_Status"/><End_System_Delay group="Info/Line_1_Call_2_Status"/><Packets_Lost group="Info/Line_1_Call_2_Status"/><Packet_Error group="Info/Line_1_Call_2_Status"/><Loss_Rate group="Info/Line_1_Call_2_Status"/><Discard_Rate group="Info/Line_1_Call_2_Status"/><Burst_Duration group="Info/Line_1_Call_2_Status"/><Gap_Duration group="Info/Line_1_Call_2_Status"/><R_Factor group="Info/Line_1_Call_2_Status"/><MOS_Listening group="Info/Line_1_Call_2_Status"/><MOS_Conversational group="Info/Line_1_Call_2_Status"/><Call_State group="Info/Line_2_Call_1_Status">No Service</Call_State><Tone group="Info/Line_2_Call_1_Status">None</Tone><Encoder group="Info/Line_2_Call_1_Status"/><Decoder group="Info/Line_2_Call_1_Status"/><Type group="Info/Line_2_Call_1_Status"/><Remote_Hold group="Info/Line_2_Call_1_Status"/><Callback group="Info/Line_2_Call_1_Status"/><Peer_Name group="Info/Line_2_Call_1_Status"/><Peer_Phone group="Info/Line_2_Call_1_Status"/><Duration group="Info/Line_2_Call_1_Status"/><Packets_Sent group="Info/Line_2_Call_1_Status"/><Packets_Recv group="Info/Line_2_Call_1_Status"/><Bytes_Sent group="Info/Line_2_Call_1_Status"/><Bytes_Recv group="Info/Line_2_Call_1_Status"/><Mapped_RTP_Port group="Info/Line_2_Call_1_Status"/><Media_Loopback group="Info/Line_2_Call_1_Status"/><Decode_Latency group="Info/Line_2_Call_1_Status"/><Jitter group="Info/Line_2_Call_1_Status"/><Round_Trip_Delay group="Info/Line_2_Call_1_Status"/><End_System_Delay group="Info/Line_2_Call_1_Status"/><Packets_Lost group="Info/Line_2_Call_1_Status"/><Packet_Error group="Info/Line_2_Call_1_Status"/><Loss_Rate group="Info/Line_2_Call_1_Status"/><Discard_Rate group="Info/Line_2_Call_1_Status"/><Burst_Duration group="Info/Line_2_Call_1_Status"/><Gap_Duration group="Info/Line_2_Call_1_Status"/><R_Factor group="Info/Line_2_Call_1_Status"/><MOS_Listening group="Info/Line_2_Call_1_Status"/><MOS_Conversational group="Info/Line_2_Call_1_Status"/><Call_State group="Info/Line_2_Call_2_Status">No Service</Call_State><Tone group="Info/Line_2_Call_2_Status">None</Tone><Encoder group="Info/Line_2_Call_2_Status"/><Decoder group="Info/Line_2_Call_2_Status"/><Type group="Info/Line_2_Call_2_Status"/><Remote_Hold group="Info/Line_2_Call_2_Status"/><Callback group="Info/Line_2_Call_2_Status"/><Peer_Name group="Info/Line_2_Call_2_Status"/><Peer_Phone group="Info/Line_2_Call_2_Status"/><Duration group="Info/Line_2_Call_2_Status"/><Packets_Sent group="Info/Line_2_Call_2_Status"/><Packets_Recv group="Info/Line_2_Call_2_Status"/><Bytes_Sent group="Info/Line_2_Call_2_Status"/><Bytes_Recv group="Info/Line_2_Call_2_Status"/><Mapped_RTP_Port group="Info/Line_2_Call_2_Status"/><Media_Loopback group="Info/Line_2_Call_2_Status"/><Decode_Latency group="Info/Line_2_Call_2_Status"/><Jitter group="Info/Line_2_Call_2_Status"/><Round_Trip_Delay group="Info/Line_2_Call_2_Status"/><End_System_Delay group="Info/Line_2_Call_2_Status"/><Packets_Lost group="Info/Line_2_Call_2_Status"/><Packet_Error group="Info/Line_2_Call_2_Status"/><Loss_Rate group="Info/Line_2_Call_2_Status"/><Discard_Rate group="Info/Line_2_Call_2_Status"/><Burst_Duration group="Info/Line_2_Call_2_Status"/><Gap_Duration group="Info/Line_2_Call_2_Status"/><R_Factor group="Info/Line_2_Call_2_Status"/><MOS_Listening group="Info/Line_2_Call_2_Status"/><MOS_Conversational group="Info/Line_2_Call_2_Status"/><Call_State group="Info/Line_3_Call_1_Status">No Service</Call_State><Tone group="Info/Line_3_Call_1_Status">None</Tone><Encoder group="Info/Line_3_Call_1_Status"/><Decoder group="Info/Line_3_Call_1_Status"/><Type group="Info/Line_3_Call_1_Status"/><Remote_Hold group="Info/Line_3_Call_1_Status"/><Callback group="Info/Line_3_Call_1_Status"/><Peer_Name group="Info/Line_3_Call_1_Status"/><Peer_Phone group="Info/Line_3_Call_1_Status"/><Duration group="Info/Line_3_Call_1_Status"/><Packets_Sent group="Info/Line_3_Call_1_Status"/><Packets_Recv group="Info/Line_3_Call_1_Status"/><Bytes_Sent group="Info/Line_3_Call_1_Status"/><Bytes_Recv group="Info/Line_3_Call_1_Status"/><Mapped_RTP_Port group="Info/Line_3_Call_1_Status"/><Media_Loopback group="Info/Line_3_Call_1_Status"/><Decode_Latency group="Info/Line_3_Call_1_Status"/><Jitter group="Info/Line_3_Call_1_Status"/><Round_Trip_Delay group="Info/Line_3_Call_1_Status"/><End_System_Delay group="Info/Line_3_Call_1_Status"/><Packets_Lost group="Info/Line_3_Call_1_Status"/><Packet_Error group="Info/Line_3_Call_1_Status"/><Loss_Rate group="Info/Line_3_Call_1_Status"/><Discard_Rate group="Info/Line_3_Call_1_Status"/><Burst_Duration group="Info/Line_3_Call_1_Status"/><Gap_Duration group="Info/Line_3_Call_1_Status"/><R_Factor group="Info/Line_3_Call_1_Status"/><MOS_Listening group="Info/Line_3_Call_1_Status"/><MOS_Conversational group="Info/Line_3_Call_1_Status"/><Call_State group="Info/Line_3_Call_2_Status">No Service</Call_State><Tone group="Info/Line_3_Call_2_Status">None</Tone><Encoder group="Info/Line_3_Call_2_Status"/><Decoder group="Info/Line_3_Call_2_Status"/><Type group="Info/Line_3_Call_2_Status"/><Remote_Hold group="Info/Line_3_Call_2_Status"/><Callback group="Info/Line_3_Call_2_Status"/><Peer_Name group="Info/Line_3_Call_2_Status"/><Peer_Phone group="Info/Line_3_Call_2_Status"/><Duration group="Info/Line_3_Call_2_Status"/><Packets_Sent group="Info/Line_3_Call_2_Status"/><Packets_Recv group="Info/Line_3_Call_2_Status"/><Bytes_Sent group="Info/Line_3_Call_2_Status"/><Bytes_Recv group="Info/Line_3_Call_2_Status"/><Mapped_RTP_Port group="Info/Line_3_Call_2_Status"/><Media_Loopback group="Info/Line_3_Call_2_Status"/><Decode_Latency group="Info/Line_3_Call_2_Status"/><Jitter group="Info/Line_3_Call_2_Status"/><Round_Trip_Delay group="Info/Line_3_Call_2_Status"/><End_System_Delay group="Info/Line_3_Call_2_Status"/><Packets_Lost group="Info/Line_3_Call_2_Status"/><Packet_Error group="Info/Line_3_Call_2_Status"/><Loss_Rate group="Info/Line_3_Call_2_Status"/><Discard_Rate group="Info/Line_3_Call_2_Status"/><Burst_Duration group="Info/Line_3_Call_2_Status"/><Gap_Duration group="Info/Line_3_Call_2_Status"/><R_Factor group="Info/Line_3_Call_2_Status"/><MOS_Listening group="Info/Line_3_Call_2_Status"/><MOS_Conversational group="Info/Line_3_Call_2_Status"/><Call_State group="Info/Line_4_Call_1_Status"/><Tone group="Info/Line_4_Call_1_Status"/><Encoder group="Info/Line_4_Call_1_Status"/><Decoder group="Info/Line_4_Call_1_Status"/><Type group="Info/Line_4_Call_1_Status"/><Remote_Hold group="Info/Line_4_Call_1_Status"/><Callback group="Info/Line_4_Call_1_Status"/><Peer_Name group="Info/Line_4_Call_1_Status"/><Peer_Phone group="Info/Line_4_Call_1_Status"/><Duration group="Info/Line_4_Call_1_Status"/><Packets_Sent group="Info/Line_4_Call_1_Status"/><Packets_Recv group="Info/Line_4_Call_1_Status"/><Bytes_Sent group="Info/Line_4_Call_1_Status"/><Bytes_Recv group="Info/Line_4_Call_1_Status"/><Mapped_RTP_Port group="Info/Line_4_Call_1_Status"/><Media_Loopback group="Info/Line_4_Call_1_Status"/><Decode_Latency group="Info/Line_4_Call_1_Status"/><Jitter group="Info/Line_4_Call_1_Status"/><Round_Trip_Delay group="Info/Line_4_Call_1_Status"/><End_System_Delay group="Info/Line_4_Call_1_Status"/><Packets_Lost group="Info/Line_4_Call_1_Status"/><Packet_Error group="Info/Line_4_Call_1_Status"/><Loss_Rate group="Info/Line_4_Call_1_Status"/><Discard_Rate group="Info/Line_4_Call_1_Status"/><Burst_Duration group="Info/Line_4_Call_1_Status"/><Gap_Duration group="Info/Line_4_Call_1_Status"/><R_Factor group="Info/Line_4_Call_1_Status"/><MOS_Listening group="Info/Line_4_Call_1_Status"/><MOS_Conversational group="Info/Line_4_Call_1_Status"/><Call_State group="Info/Line_4_Call_2_Status"/><Tone group="Info/Line_4_Call_2_Status"/><Encoder group="Info/Line_4_Call_2_Status"/><Decoder group="Info/Line_4_Call_2_Status"/><Type group="Info/Line_4_Call_2_Status"/><Remote_Hold group="Info/Line_4_Call_2_Status"/><Callback group="Info/Line_4_Call_2_Status"/><Peer_Name group="Info/Line_4_Call_2_Status"/><Peer_Phone group="Info/Line_4_Call_2_Status"/><Duration group="Info/Line_4_Call_2_Status"/><Packets_Sent group="Info/Line_4_Call_2_Status"/><Packets_Recv group="Info/Line_4_Call_2_Status"/><Bytes_Sent group="Info/Line_4_Call_2_Status"/><Bytes_Recv group="Info/Line_4_Call_2_Status"/><Mapped_RTP_Port group="Info/Line_4_Call_2_Status"/><Media_Loopback group="Info/Line_4_Call_2_Status"/><Decode_Latency group="Info/Line_4_Call_2_Status"/><Jitter group="Info/Line_4_Call_2_Status"/><Round_Trip_Delay group="Info/Line_4_Call_2_Status"/><End_System_Delay group="Info/Line_4_Call_2_Status"/><Packets_Lost group="Info/Line_4_Call_2_Status"/><Packet_Error group="Info/Line_4_Call_2_Status"/><Loss_Rate group="Info/Line_4_Call_2_Status"/><Discard_Rate group="Info/Line_4_Call_2_Status"/><Burst_Duration group="Info/Line_4_Call_2_Status"/><Gap_Duration group="Info/Line_4_Call_2_Status"/><R_Factor group="Info/Line_4_Call_2_Status"/><MOS_Listening group="Info/Line_4_Call_2_Status"/><MOS_Conversational group="Info/Line_4_Call_2_Status"/><Status group="Info/Downloaded_Ring_Tone">Idle</Status><Ring_Tone_1 group="Info/Downloaded_Ring_Tone">Not Installed</Ring_Tone_1><Ring_Tone_2 group="Info/Downloaded_Ring_Tone">Not Installed</Ring_Tone_2><Custom_CA_Provisioning_Status group="Info/Custom_CA_Status"/><Custom_CA_Info group="Info/Custom_CA_Status">Not Installed</Custom_CA_Info><Restricted_Access_Domains group="System/System_Configuration"/><Enable_Direct_Action_Url group="System/System_Configuration">Yes</Enable_Direct_Action_Url><Enable_Web_Server group="System/System_Configuration">Yes</Enable_Web_Server><Web_Server_Port group="System/System_Configuration">80</Web_Server_Port><Enable_Web_Admin_Access group="System/System_Configuration">Yes</Enable_Web_Admin_Access><Admin_Passwd group="System/System_Configuration">*************</Admin_Passwd><User_Password group="System/System_Configuration"/><User_Web_Password group="System/System_Configuration"/><Signaling_Protocol group="System/System_Configuration">SIP</Signaling_Protocol><SPCP_Auto-detect group="System/System_Configuration">Yes</SPCP_Auto-detect><Phone-UI-readonly group="System/System_Configuration">No</Phone-UI-readonly><Phone-UI-user-mode group="System/System_Configuration">No</Phone-UI-user-mode><PoE_Power_Required group="System/Power_Setting">Normal</PoE_Power_Required><Connection_Type group="System/Internet_Connection_Type_">DHCP</Connection_Type><Use_Backup_IP group="System/Internet_Connection_Type_">Yes</Use_Backup_IP><Static_IP group="System/_Static_IP_Settings"/><NetMask group="System/_Static_IP_Settings"/><Gateway group="System/_Static_IP_Settings"/><HostName group="System/Optional_Network_Configuration"/><Domain group="System/Optional_Network_Configuration"/><Primary_DNS group="System/Optional_Network_Configuration"/><Secondary_DNS group="System/Optional_Network_Configuration"/><DNS_Server_Order group="System/Optional_Network_Configuration">Manual</DNS_Server_Order><DNS_Query_Mode group="System/Optional_Network_Configuration">Parallel</DNS_Query_Mode><DNS_Query_TTL_Ignore group="System/Optional_Network_Configuration">No</DNS_Query_TTL_Ignore><Syslog_Server group="System/Optional_Network_Configuration">192.168.20.250</Syslog_Server><Debug_Server group="System/Optional_Network_Configuration">192.168.20.250</Debug_Server><Debug_Level group="System/Optional_Network_Configuration">3</Debug_Level><Layer_2_Logging group="System/Optional_Network_Configuration">Yes</Layer_2_Logging><NTP_Enable group="System/Optional_Network_Configuration">Yes</NTP_Enable><Primary_NTP_Server group="System/Optional_Network_Configuration">0.us.pool.ntp.org</Primary_NTP_Server><Secondary_NTP_Server group="System/Optional_Network_Configuration">1.us.pool.ntp.org</Secondary_NTP_Server><SSL_Key_Negotiation group="System/Optional_Network_Configuration">RSA</SSL_Key_Negotiation><Enable_SSLv3 group="System/Optional_Network_Configuration">No</Enable_SSLv3><Enable_VLAN group="System/VLAN_Settings">No</Enable_VLAN><Enable_CDP group="System/VLAN_Settings">Yes</Enable_CDP><Enable_LLDP-MED group="System/VLAN_Settings">Yes</Enable_LLDP-MED><Network_Startup_Delay group="System/VLAN_Settings">3</Network_Startup_Delay><VLAN_ID group="System/VLAN_Settings">1</VLAN_ID><PC_Port_VLAN_Highest_Priority group="System/VLAN_Settings">No Limit</PC_Port_VLAN_Highest_Priority><Enable_PC_Port_VLAN_Tagging group="System/VLAN_Settings">No</Enable_PC_Port_VLAN_Tagging><PC_Port_VLAN_ID group="System/VLAN_Settings">1</PC_Port_VLAN_ID><Asset_ID group="System/Inventory_Settings"/><Max_Forward group="SIP/SIP_Parameters">70</Max_Forward><Max_Redirection group="SIP/SIP_Parameters">5</Max_Redirection><Max_Auth group="SIP/SIP_Parameters">2</Max_Auth><SIP_User_Agent_Name group="SIP/SIP_Parameters">$VERSION</SIP_User_Agent_Name><SIP_Server_Name group="SIP/SIP_Parameters">$VERSION</SIP_Server_Name><SIP_Reg_User_Agent_Name group="SIP/SIP_Parameters"/><SIP_Accept_Language group="SIP/SIP_Parameters"/><DTMF_Relay_MIME_Type group="SIP/SIP_Parameters">application/dtmf-relay</DTMF_Relay_MIME_Type><Hook_Flash_MIME_Type group="SIP/SIP_Parameters">application/hook-flash</Hook_Flash_MIME_Type><Remove_Last_Reg group="SIP/SIP_Parameters">No</Remove_Last_Reg><Use_Compact_Header group="SIP/SIP_Parameters">No</Use_Compact_Header><Escape_Display_Name group="SIP/SIP_Parameters">No</Escape_Display_Name><Escape_Special_Character group="SIP/SIP_Parameters">Yes</Escape_Special_Character><SIP-B_Enable group="SIP/SIP_Parameters">No</SIP-B_Enable><Talk_Package group="SIP/SIP_Parameters">No</Talk_Package><Hold_Package group="SIP/SIP_Parameters">No</Hold_Package><Conference_Package group="SIP/SIP_Parameters">No</Conference_Package><Notify_Conference group="SIP/SIP_Parameters">No</Notify_Conference><RFC_2543_Call_Hold group="SIP/SIP_Parameters">Yes</RFC_2543_Call_Hold><Random_REG_CID_On_Reboot group="SIP/SIP_Parameters">No</Random_REG_CID_On_Reboot><Mark_All_AVT_Packets group="SIP/SIP_Parameters">Yes</Mark_All_AVT_Packets><SIP_TCP_Port_Min group="SIP/SIP_Parameters">5060</SIP_TCP_Port_Min><SIP_TCP_Port_Max group="SIP/SIP_Parameters">5080</SIP_TCP_Port_Max><CTI_Enable group="SIP/SIP_Parameters">No</CTI_Enable><Caller_ID_Header group="SIP/SIP_Parameters">PAID-RPID-FROM</Caller_ID_Header><SRTP_Method group="SIP/SIP_Parameters">s-descriptor</SRTP_Method><Hold_Target_Before_REFER group="SIP/SIP_Parameters">No</Hold_Target_Before_REFER><Dialog_SDP_Enable group="SIP/SIP_Parameters">No</Dialog_SDP_Enable><Keep_Referee_When_REFER_Failed group="SIP/SIP_Parameters">No</Keep_Referee_When_REFER_Failed><Display_Diversion_Info group="SIP/SIP_Parameters">No</Display_Diversion_Info><Display_Anonymous_From_Header group="SIP/SIP_Parameters">No</Display_Anonymous_From_Header><Sip_Accept_Encoding group="SIP/SIP_Parameters">none</Sip_Accept_Encoding><Disable_Local_Name_To_Header group="SIP/SIP_Parameters">No</Disable_Local_Name_To_Header><Caller_ID_Display_Length group="SIP/SIP_Parameters">long</Caller_ID_Display_Length><SIP_T1 group="SIP/SIP_Timer_Values__sec_">.5</SIP_T1><SIP_T2 group="SIP/SIP_Timer_Values__sec_">4</SIP_T2><SIP_T4 group="SIP/SIP_Timer_Values__sec_">5</SIP_T4><SIP_Timer_B group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_B><SIP_Timer_F group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_F><SIP_Timer_H group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_H><SIP_Timer_D group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_D><SIP_Timer_J group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_J><INVITE_Expires group="SIP/SIP_Timer_Values__sec_">240</INVITE_Expires><ReINVITE_Expires group="SIP/SIP_Timer_Values__sec_">30</ReINVITE_Expires><Reg_Min_Expires group="SIP/SIP_Timer_Values__sec_">1</Reg_Min_Expires><Reg_Max_Expires group="SIP/SIP_Timer_Values__sec_">7200</Reg_Max_Expires><Reg_Retry_Intvl group="SIP/SIP_Timer_Values__sec_">30</Reg_Retry_Intvl><Reg_Retry_Long_Intvl group="SIP/SIP_Timer_Values__sec_">1200</Reg_Retry_Long_Intvl><Reg_Retry_Random_Delay group="SIP/SIP_Timer_Values__sec_"/><Reg_Retry_Long_Random_Delay group="SIP/SIP_Timer_Values__sec_"/><Reg_Retry_Intvl_Cap group="SIP/SIP_Timer_Values__sec_"/><Sub_Min_Expires group="SIP/SIP_Timer_Values__sec_">10</Sub_Min_Expires><Sub_Max_Expires group="SIP/SIP_Timer_Values__sec_">7200</Sub_Max_Expires><Sub_Retry_Intvl group="SIP/SIP_Timer_Values__sec_">10</Sub_Retry_Intvl><SIT1_RSC group="SIP/Response_Status_Code_Handling"/><SIT2_RSC group="SIP/Response_Status_Code_Handling"/><SIT3_RSC group="SIP/Response_Status_Code_Handling"/><SIT4_RSC group="SIP/Response_Status_Code_Handling"/><Try_Backup_RSC group="SIP/Response_Status_Code_Handling"/><Retry_Reg_RSC group="SIP/Response_Status_Code_Handling"/><RTP_Port_Min group="SIP/RTP_Parameters">16384</RTP_Port_Min><RTP_Port_Max group="SIP/RTP_Parameters">16538</RTP_Port_Max><RTP_Packet_Size group="SIP/RTP_Parameters">0.030</RTP_Packet_Size><Max_RTP_ICMP_Err group="SIP/RTP_Parameters">0</Max_RTP_ICMP_Err><RTCP_Tx_Interval group="SIP/RTP_Parameters">0</RTCP_Tx_Interval><No_UDP_Checksum group="SIP/RTP_Parameters">No</No_UDP_Checksum><Symmetric_RTP group="SIP/RTP_Parameters">No</Symmetric_RTP><Stats_In_BYE group="SIP/RTP_Parameters">No</Stats_In_BYE><AVT_Dynamic_Payload group="SIP/SDP_Payload_Types">101</AVT_Dynamic_Payload><INFOREQ_Dynamic_Payload group="SIP/SDP_Payload_Types"/><G726r16_Dynamic_Payload group="SIP/SDP_Payload_Types">98</G726r16_Dynamic_Payload><G726r24_Dynamic_Payload group="SIP/SDP_Payload_Types">97</G726r24_Dynamic_Payload><G726r32_Dynamic_Payload group="SIP/SDP_Payload_Types">2</G726r32_Dynamic_Payload><G726r40_Dynamic_Payload group="SIP/SDP_Payload_Types">96</G726r40_Dynamic_Payload><G729b_Dynamic_Payload group="SIP/SDP_Payload_Types">99</G729b_Dynamic_Payload><EncapRTP_Dynamic_Payload group="SIP/SDP_Payload_Types">112</EncapRTP_Dynamic_Payload><RTP-Start-Loopback_Dynamic_Payload group="SIP/SDP_Payload_Types">113</RTP-Start-Loopback_Dynamic_Payload><RTP-Start-Loopback_Codec group="SIP/SDP_Payload_Types">G711u</RTP-Start-Loopback_Codec><AVT_Codec_Name group="SIP/SDP_Payload_Types">telephone-event</AVT_Codec_Name><G711u_Codec_Name group="SIP/SDP_Payload_Types">PCMU</G711u_Codec_Name><G711a_Codec_Name group="SIP/SDP_Payload_Types">PCMA</G711a_Codec_Name><G726r16_Codec_Name group="SIP/SDP_Payload_Types">G726-16</G726r16_Codec_Name><G726r24_Codec_Name group="SIP/SDP_Payload_Types">G726-24</G726r24_Codec_Name><G726r32_Codec_Name group="SIP/SDP_Payload_Types">G726-32</G726r32_Codec_Name><G726r40_Codec_Name group="SIP/SDP_Payload_Types">G726-40</G726r40_Codec_Name><G729a_Codec_Name group="SIP/SDP_Payload_Types">G729a</G729a_Codec_Name><G729b_Codec_Name group="SIP/SDP_Payload_Types">G729ab</G729b_Codec_Name><G722_Codec_Name group="SIP/SDP_Payload_Types">G722</G722_Codec_Name><EncapRTP_Codec_Name group="SIP/SDP_Payload_Types">encaprtp</EncapRTP_Codec_Name><Handle_VIA_received group="SIP/NAT_Support_Parameters">No</Handle_VIA_received><Handle_VIA_rport group="SIP/NAT_Support_Parameters">No</Handle_VIA_rport><Insert_VIA_received group="SIP/NAT_Support_Parameters">No</Insert_VIA_received><Insert_VIA_rport group="SIP/NAT_Support_Parameters">No</Insert_VIA_rport><Substitute_VIA_Addr group="SIP/NAT_Support_Parameters">No</Substitute_VIA_Addr><Send_Resp_To_Src_Port group="SIP/NAT_Support_Parameters">No</Send_Resp_To_Src_Port><STUN_Enable group="SIP/NAT_Support_Parameters">No</STUN_Enable><STUN_Test_Enable group="SIP/NAT_Support_Parameters">No</STUN_Test_Enable><STUN_Server group="SIP/NAT_Support_Parameters"/><EXT_IP group="SIP/NAT_Support_Parameters"/><EXT_RTP_Port_Min group="SIP/NAT_Support_Parameters"/><NAT_Keep_Alive_Intvl group="SIP/NAT_Support_Parameters">55</NAT_Keep_Alive_Intvl><Redirect_Keep_Alive group="SIP/NAT_Support_Parameters">No</Redirect_Keep_Alive><Linksys_Key_System group="SIP/Linksys_Key_System_Parameters">No</Linksys_Key_System><Multicast_Address group="SIP/Linksys_Key_System_Parameters">224.168.168.168:6061</Multicast_Address><Key_System_Auto_Discovery group="SIP/Linksys_Key_System_Parameters">Yes</Key_System_Auto_Discovery><Key_System_IP_Address group="SIP/Linksys_Key_System_Parameters"/><Force_LAN_Codec group="SIP/Linksys_Key_System_Parameters">none</Force_LAN_Codec><Auto_Ans_GrPage_On_Active_Call group="SIP/Linksys_Key_System_Parameters">Yes</Auto_Ans_GrPage_On_Active_Call><Provision_Enable group="Provisioning/Configuration_Profile">No</Provision_Enable><Resync_On_Reset group="Provisioning/Configuration_Profile">Yes</Resync_On_Reset><Resync_Random_Delay group="Provisioning/Configuration_Profile">2</Resync_Random_Delay><Resync_At__HHmm_ group="Provisioning/Configuration_Profile"/><Resync_At_Random_Delay group="Provisioning/Configuration_Profile">600</Resync_At_Random_Delay><Resync_Periodic group="Provisioning/Configuration_Profile">86400</Resync_Periodic><Resync_Error_Retry_Delay group="Provisioning/Configuration_Profile">0</Resync_Error_Retry_Delay><Forced_Resync_Delay group="Provisioning/Configuration_Profile">0</Forced_Resync_Delay><Resync_From_SIP group="Provisioning/Configuration_Profile">Yes</Resync_From_SIP><Resync_After_Upgrade_Attempt group="Provisioning/Configuration_Profile">Yes</Resync_After_Upgrade_Attempt><Resync_Trigger_1 group="Provisioning/Configuration_Profile"/><Resync_Trigger_2 group="Provisioning/Configuration_Profile"/><Resync_Fails_On_FNF group="Provisioning/Configuration_Profile">Yes</Resync_Fails_On_FNF><Profile_Rule group="Provisioning/Configuration_Profile">[--uid 3d1d0c34 --pwd a0ceb705d339a4eb] https://myvoipserveraddress:2443/spa$MA.xml</Profile_Rule><Profile_Rule_B group="Provisioning/Configuration_Profile"/><Profile_Rule_C group="Provisioning/Configuration_Profile"/><Profile_Rule_D group="Provisioning/Configuration_Profile"/><DHCP_Option_To_Use group="Provisioning/Configuration_Profile">66,160,159,150,60,43,125</DHCP_Option_To_Use><Transport_Protocol group="Provisioning/Configuration_Profile">https</Transport_Protocol><Log_Resync_Request_Msg group="Provisioning/Configuration_Profile">$PN $MAC -- Requesting resync $SCHEME://$SERVIP:$PORT$PATH</Log_Resync_Request_Msg><Log_Resync_Success_Msg group="Provisioning/Configuration_Profile">$PN $MAC -- Successful resync $SCHEME://$SERVIP:$PORT$PATH</Log_Resync_Success_Msg><Log_Resync_Failure_Msg group="Provisioning/Configuration_Profile">$PN $MAC -- Resync failed: $ERR</Log_Resync_Failure_Msg><HTTP_Report_Method group="Provisioning/Configuration_Profile">POST</HTTP_Report_Method><Report_Rule group="Provisioning/Configuration_Profile"/><User_Configurable_Resync group="Provisioning/Configuration_Profile">Yes</User_Configurable_Resync><Upgrade_Enable group="Provisioning/Firmware_Upgrade">Yes</Upgrade_Enable><Upgrade_Error_Retry_Delay group="Provisioning/Firmware_Upgrade">3600</Upgrade_Error_Retry_Delay><Downgrade_Rev_Limit group="Provisioning/Firmware_Upgrade">7.6.2</Downgrade_Rev_Limit><Upgrade_Rule group="Provisioning/Firmware_Upgrade">[--uid 3d1d0c34 --pwd a0ceb705d339a4eb] https://myvoipserveraddress:2443/cisco/2/spa50x.bin</Upgrade_Rule><Log_Upgrade_Request_Msg group="Provisioning/Firmware_Upgrade">$PN $MAC -- Requesting upgrade $SCHEME://$SERVIP:$PORT$PATH</Log_Upgrade_Request_Msg><Log_Upgrade_Success_Msg group="Provisioning/Firmware_Upgrade">$PN $MAC -- Successful upgrade $SCHEME://$SERVIP:$PORT$PATH -- $ERR</Log_Upgrade_Success_Msg><Log_Upgrade_Failure_Msg group="Provisioning/Firmware_Upgrade">$PN $MAC -- Upgrade failed: $ERR</Log_Upgrade_Failure_Msg><License_Keys group="Provisioning/Firmware_Upgrade"/><Custom_CA_RULE group="Provisioning/CA_Settings"/><GPP_A group="Provisioning/General_Purpose_Parameters"/><GPP_B group="Provisioning/General_Purpose_Parameters"/><GPP_C group="Provisioning/General_Purpose_Parameters"/><GPP_D group="Provisioning/General_Purpose_Parameters"/><GPP_E group="Provisioning/General_Purpose_Parameters"/><GPP_F group="Provisioning/General_Purpose_Parameters"/><GPP_G group="Provisioning/General_Purpose_Parameters"/><GPP_H group="Provisioning/General_Purpose_Parameters"/><GPP_I group="Provisioning/General_Purpose_Parameters"/><GPP_J group="Provisioning/General_Purpose_Parameters"/><GPP_K group="Provisioning/General_Purpose_Parameters"/><GPP_L group="Provisioning/General_Purpose_Parameters"/><GPP_M group="Provisioning/General_Purpose_Parameters"/><GPP_N group="Provisioning/General_Purpose_Parameters"/><GPP_O group="Provisioning/General_Purpose_Parameters"/><GPP_P group="Provisioning/General_Purpose_Parameters"/><Dial_Tone group="Regional/Call_Progress_Tones">350@-19,440@-19;10(*/0/1+2)</Dial_Tone><Outside_Dial_Tone group="Regional/Call_Progress_Tones">420@-16;10(*/0/1)</Outside_Dial_Tone><Prompt_Tone group="Regional/Call_Progress_Tones">520@-19,620@-19;10(*/0/1+2)</Prompt_Tone><Busy_Tone group="Regional/Call_Progress_Tones">480@-19,620@-19;10(.5/.5/1+2)</Busy_Tone><Reorder_Tone group="Regional/Call_Progress_Tones">480@-19,620@-19;10(.25/.25/1+2)</Reorder_Tone><Off_Hook_Warning_Tone group="Regional/Call_Progress_Tones">480@-10,620@0;10(.125/.125/1+2)</Off_Hook_Warning_Tone><Ring_Back_Tone group="Regional/Call_Progress_Tones">440@-19,480@-19;*(2/4/1+2)</Ring_Back_Tone><Call_Waiting_Tone group="Regional/Call_Progress_Tones">440@-10;30(.3/9.7/1)</Call_Waiting_Tone><Confirm_Tone group="Regional/Call_Progress_Tones">600@-16;1(.25/.25/1)</Confirm_Tone><SIT1_Tone group="Regional/Call_Progress_Tones">985@-16,1428@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)</SIT1_Tone><SIT2_Tone group="Regional/Call_Progress_Tones">914@-16,1371@-16,1777@-16;20(.274/0/1,.274/0/2,.380/0/3,0/4/0)</SIT2_Tone><SIT3_Tone group="Regional/Call_Progress_Tones">914@-16,1371@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)</SIT3_Tone><SIT4_Tone group="Regional/Call_Progress_Tones">985@-16,1371@-16,1777@-16;20(.380/0/1,.274/0/2,.380/0/3,0/4/0)</SIT4_Tone><MWI_Dial_Tone group="Regional/Call_Progress_Tones">350@-19,440@-19;2(.1/.1/1+2);10(*/0/1+2)</MWI_Dial_Tone><Cfwd_Dial_Tone group="Regional/Call_Progress_Tones">350@-19,440@-19;2(.2/.2/1+2);10(*/0/1+2)</Cfwd_Dial_Tone><Holding_Tone group="Regional/Call_Progress_Tones">600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)</Holding_Tone><Conference_Tone group="Regional/Call_Progress_Tones">350@-19;20(.1/.1/1,.1/9.7/1)</Conference_Tone><Secure_Call_Indication_Tone group="Regional/Call_Progress_Tones"/><Page_Tone group="Regional/Call_Progress_Tones">600@-16;.3(.05/0.05/1)</Page_Tone><Alert_Tone group="Regional/Call_Progress_Tones">600@-19;.2(.05/0.05/1)</Alert_Tone><Call_Pickup_Tone group="Regional/Call_Progress_Tones">440@-10;30(.3/9.7/1)</Call_Pickup_Tone><Cadence_1 group="Regional/Distinctive_Ring_Patterns">60(2/4)</Cadence_1><Cadence_2 group="Regional/Distinctive_Ring_Patterns">60(.3/.2,1/.2,.3/4)</Cadence_2><Cadence_3 group="Regional/Distinctive_Ring_Patterns">60(.8/.4,.8/4)</Cadence_3><Cadence_4 group="Regional/Distinctive_Ring_Patterns">60(.4/.2,.3/.2,.8/4)</Cadence_4><Cadence_5 group="Regional/Distinctive_Ring_Patterns">60(.2/.2,.2/.2,.2/.2,1/4)</Cadence_5><Cadence_6 group="Regional/Distinctive_Ring_Patterns">60(.2/.4,.2/.4,.2/4)</Cadence_6><Cadence_7 group="Regional/Distinctive_Ring_Patterns">60(4.5/4)</Cadence_7><Cadence_8 group="Regional/Distinctive_Ring_Patterns">60(0.25/9.75)</Cadence_8><Cadence_9 group="Regional/Distinctive_Ring_Patterns">60(.4/.2,.4/2)</Cadence_9><Reorder_Delay group="Regional/Control_Timer_Values__sec_">255</Reorder_Delay><Call_Back_Expires group="Regional/Control_Timer_Values__sec_">1800</Call_Back_Expires><Call_Back_Retry_Intvl group="Regional/Control_Timer_Values__sec_">30</Call_Back_Retry_Intvl><Call_Back_Delay group="Regional/Control_Timer_Values__sec_">.5</Call_Back_Delay><Interdigit_Long_Timer group="Regional/Control_Timer_Values__sec_">10</Interdigit_Long_Timer><Interdigit_Short_Timer group="Regional/Control_Timer_Values__sec_">3</Interdigit_Short_Timer><Call_Return_Code group="Regional/Vertical_Service_Activation_Codes"/><Blind_Transfer_Code group="Regional/Vertical_Service_Activation_Codes"/><Call_Back_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><Call_Back_Deact_Code group="Regional/Vertical_Service_Activation_Codes"/><Cfwd_All_Act_Code group="Regional/Vertical_Service_Activation_Codes">*72</Cfwd_All_Act_Code><Cfwd_All_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*73</Cfwd_All_Deact_Code><Cfwd_Busy_Act_Code group="Regional/Vertical_Service_Activation_Codes">*90</Cfwd_Busy_Act_Code><Cfwd_Busy_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*91</Cfwd_Busy_Deact_Code><Cfwd_No_Ans_Act_Code group="Regional/Vertical_Service_Activation_Codes">*52</Cfwd_No_Ans_Act_Code><Cfwd_No_Ans_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*53</Cfwd_No_Ans_Deact_Code><CW_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><CW_Deact_Code group="Regional/Vertical_Service_Activation_Codes"/><CW_Per_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><CW_Per_Call_Deact_Code group="Regional/Vertical_Service_Activation_Codes"/><Block_CID_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><Block_CID_Deact_Code group="Regional/Vertical_Service_Activation_Codes"/><Block_CID_Per_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><Block_CID_Per_Call_Deact_Code group="Regional/Vertical_Service_Activation_Codes"/><Block_ANC_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><Block_ANC_Deact_Code group="Regional/Vertical_Service_Activation_Codes"/><DND_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><DND_Deact_Code group="Regional/Vertical_Service_Activation_Codes"/><Secure_All_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><Secure_No_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><Secure_One_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes"/><Secure_One_Call_Deact_Code group="Regional/Vertical_Service_Activation_Codes"/><Paging_Code group="Regional/Vertical_Service_Activation_Codes"/><Call_Park_Code group="Regional/Vertical_Service_Activation_Codes">*38</Call_Park_Code><Call_Pickup_Code group="Regional/Vertical_Service_Activation_Codes">**#</Call_Pickup_Code><Call_UnPark_Code group="Regional/Vertical_Service_Activation_Codes">*39</Call_UnPark_Code><Group_Call_Pickup_Code group="Regional/Vertical_Service_Activation_Codes">*37</Group_Call_Pickup_Code><Media_Loopback_Code group="Regional/Vertical_Service_Activation_Codes"/><Referral_Services_Codes group="Regional/Vertical_Service_Activation_Codes"/><Feature_Dial_Services_Codes group="Regional/Vertical_Service_Activation_Codes"/><Service_Annc_Base_Number group="Regional/Vertical_Service_Announcement_Codes"/><Service_Annc_Extension_Codes group="Regional/Vertical_Service_Announcement_Codes"/><Prefer_G711u_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*017110</Prefer_G711u_Code><Force_G711u_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*027110</Force_G711u_Code><Prefer_G711a_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*017111</Prefer_G711a_Code><Force_G711a_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*027111</Force_G711a_Code><Prefer_G722_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*01722</Prefer_G722_Code><Force_G722_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*02722</Force_G722_Code><Prefer_G726r16_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0172616</Prefer_G726r16_Code><Force_G726r16_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0272616</Force_G726r16_Code><Prefer_G726r24_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0172624</Prefer_G726r24_Code><Force_G726r24_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0272624</Force_G726r24_Code><Prefer_G726r32_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0172632</Prefer_G726r32_Code><Force_G726r32_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0272632</Force_G726r32_Code><Prefer_G726r40_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0172640</Prefer_G726r40_Code><Force_G726r40_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0272640</Force_G726r40_Code><Prefer_G729a_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*01729</Prefer_G729a_Code><Force_G729a_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*02729</Force_G729a_Code><Set_Local_Date__mm_dd_ group="Regional/Miscellaneous"/><Set_Local_Time__HH_mm_ group="Regional/Miscellaneous"/><Time_Zone group="Regional/Miscellaneous">GMT-08:00</Time_Zone><Time_Offset__HH_mm_ group="Regional/Miscellaneous"/><Ignore_DHCP_Time_Offset group="Regional/Miscellaneous">Yes</Ignore_DHCP_Time_Offset><Daylight_Saving_Time_Rule group="Regional/Miscellaneous">start=3/8/7/02:0:0;end=11/1/7/02:0:0;save=1</Daylight_Saving_Time_Rule><Daylight_Saving_Time_Enable group="Regional/Miscellaneous">Yes</Daylight_Saving_Time_Enable><DTMF_Playback_Level group="Regional/Miscellaneous">-16</DTMF_Playback_Level><DTMF_Playback_Length group="Regional/Miscellaneous">.1</DTMF_Playback_Length><Inband_DTMF_Boost group="Regional/Miscellaneous">12dB</Inband_DTMF_Boost><Dictionary_Server_Script group="Regional/Miscellaneous"/><Language_Selection group="Regional/Miscellaneous"/><Default_Character_Encoding group="Regional/Miscellaneous">ISO-8859-1</Default_Character_Encoding><Locale group="Regional/Miscellaneous">en-US</Locale><Show_DTMF_Digits_When_Connected group="Regional/Miscellaneous">No</Show_DTMF_Digits_When_Connected><Station_Name group="Phone/General"/><Station_Display_Name group="Phone/General">Spencer Test</Station_Display_Name><Voice_Mail_Number group="Phone/General">*97</Voice_Mail_Number><Text_Logo group="Phone/General"/><BMP_Picture_Download_URL group="Phone/General">http://myimagelocation.bmp</BMP_Picture_Download_URL><Select_Logo group="Phone/General">Default</Select_Logo><Select_Background_Picture group="Phone/General">BMP Picture</Select_Background_Picture><Softkey_Labels_Font group="Phone/General">Auto</Softkey_Labels_Font><Screen_Saver_Enable group="Phone/General">No</Screen_Saver_Enable><Screen_Saver_Wait group="Phone/General">300</Screen_Saver_Wait><Screen_Saver_Icon group="Phone/General">Background Picture</Screen_Saver_Icon><Extension_1_ group="Phone/Line_Key_1">1</Extension_1_><Short_Name_1_ group="Phone/Line_Key_1">1800</Short_Name_1_><Share_Call_Appearance_1_ group="Phone/Line_Key_1">shared</Share_Call_Appearance_1_><Extended_Function_1_ group="Phone/Line_Key_1"/><Extension_2_ group="Phone/Line_Key_2">1</Extension_2_><Short_Name_2_ group="Phone/Line_Key_2">1800</Short_Name_2_><Share_Call_Appearance_2_ group="Phone/Line_Key_2">shared</Share_Call_Appearance_2_><Extended_Function_2_ group="Phone/Line_Key_2"/><Extension_3_ group="Phone/Line_Key_3">1</Extension_3_><Short_Name_3_ group="Phone/Line_Key_3">1800</Short_Name_3_><Share_Call_Appearance_3_ group="Phone/Line_Key_3">shared</Share_Call_Appearance_3_><Extended_Function_3_ group="Phone/Line_Key_3"/><Extension_4_ group="Phone/Line_Key_4">Disabled</Extension_4_><Short_Name_4_ group="Phone/Line_Key_4">24403</Short_Name_4_><Share_Call_Appearance_4_ group="Phone/Line_Key_4">shared</Share_Call_Appearance_4_><Extended_Function_4_ group="Phone/Line_Key_4">fnc=blf+sd;sub=*451800*24403@$PROXY:5061;nme=24403</Extended_Function_4_><Line_ID_Mapping group="Phone/Miscellaneous_Line_Key_Settings">Vertical First</Line_ID_Mapping><SCA_Barge-In_Enable group="Phone/Miscellaneous_Line_Key_Settings">No</SCA_Barge-In_Enable><SCA_Sticky_Auto_Line_Seize group="Phone/Miscellaneous_Line_Key_Settings">No</SCA_Sticky_Auto_Line_Seize><Line_Navigation group="Phone/Miscellaneous_Line_Key_Settings">Per Line</Line_Navigation><Call_Appearance_Per_Line group="Phone/Miscellaneous_Line_Key_Settings">2</Call_Appearance_Per_Line><Softkey_Navigation_Style group="Phone/Miscellaneous_Line_Key_Settings">Scrollable</Softkey_Navigation_Style><Idle_LED group="Phone/Line_Key_LED_Pattern"/><Remote_Undefined_LED group="Phone/Line_Key_LED_Pattern"/><Local_Seized_LED group="Phone/Line_Key_LED_Pattern"/><Remote_Seized_LED group="Phone/Line_Key_LED_Pattern"/><Local_Progressing_LED group="Phone/Line_Key_LED_Pattern"/><Remote_Progressing_LED group="Phone/Line_Key_LED_Pattern"/><Local_Ringing_LED group="Phone/Line_Key_LED_Pattern"/><Remote_Ringing_LED group="Phone/Line_Key_LED_Pattern"/><Local_Active_LED group="Phone/Line_Key_LED_Pattern"/><Remote_Active_LED group="Phone/Line_Key_LED_Pattern"/><Local_Held_LED group="Phone/Line_Key_LED_Pattern"/><Remote_Held_LED group="Phone/Line_Key_LED_Pattern"/><Register_Failed_LED group="Phone/Line_Key_LED_Pattern"/><Disabled_LED group="Phone/Line_Key_LED_Pattern"/><Registering_LED group="Phone/Line_Key_LED_Pattern"/><Call_Back_Active_LED group="Phone/Line_Key_LED_Pattern"/><Trunk_In-use_LED group="Phone/Line_Key_LED_Pattern"/><Trunk_No_Service_LED group="Phone/Line_Key_LED_Pattern"/><Trunk_Reserved_LED group="Phone/Line_Key_LED_Pattern"/><Conference_Serv group="Phone/Supplementary_Services">Yes</Conference_Serv><Attn_Transfer_Serv group="Phone/Supplementary_Services">Yes</Attn_Transfer_Serv><Blind_Transfer_Serv group="Phone/Supplementary_Services">Yes</Blind_Transfer_Serv><DND_Serv group="Phone/Supplementary_Services">Yes</DND_Serv><Block_ANC_Serv group="Phone/Supplementary_Services">Yes</Block_ANC_Serv><Call_Back_Serv group="Phone/Supplementary_Services">Yes</Call_Back_Serv><Block_CID_Serv group="Phone/Supplementary_Services">Yes</Block_CID_Serv><Secure_Call_Serv group="Phone/Supplementary_Services">Yes</Secure_Call_Serv><Cfwd_All_Serv group="Phone/Supplementary_Services">Yes</Cfwd_All_Serv><Cfwd_Busy_Serv group="Phone/Supplementary_Services">Yes</Cfwd_Busy_Serv><Cfwd_No_Ans_Serv group="Phone/Supplementary_Services">Yes</Cfwd_No_Ans_Serv><Paging_Serv group="Phone/Supplementary_Services">Yes</Paging_Serv><Call_Park_Serv group="Phone/Supplementary_Services">Yes</Call_Park_Serv><Call_Pick_Up_Serv group="Phone/Supplementary_Services">Yes</Call_Pick_Up_Serv><ACD_Login_Serv group="Phone/Supplementary_Services">No</ACD_Login_Serv><Group_Call_Pick_Up_Serv group="Phone/Supplementary_Services">Yes</Group_Call_Pick_Up_Serv><ACD_Ext group="Phone/Supplementary_Services">1</ACD_Ext><Service_Annc_Serv group="Phone/Supplementary_Services">Yes</Service_Annc_Serv><Ring1 group="Phone/Ring_Tone">n=Classic-1;w=3;c=1</Ring1><Ring2 group="Phone/Ring_Tone">n=Classic-2;w=3;c=2</Ring2><Ring3 group="Phone/Ring_Tone">n=Classic-3;w=3;c=3</Ring3><Ring4 group="Phone/Ring_Tone">n=Classic-4;w=3;c=4</Ring4><Ring5 group="Phone/Ring_Tone">n=Simple-1;w=2;c=1</Ring5><Ring6 group="Phone/Ring_Tone">n=Simple-2;w=2;c=2</Ring6><Ring7 group="Phone/Ring_Tone">n=Simple-3;w=2;c=3</Ring7><Ring8 group="Phone/Ring_Tone">n=Simple-4;w=2;c=4</Ring8><Ring9 group="Phone/Ring_Tone">n=Simple-5;w=2;c=5</Ring9><Ring10 group="Phone/Ring_Tone">n=Office;w=4;c=1</Ring10><Ring11 group="Phone/Ring_Tone">n=Pulse;w=5;c=1</Ring11><Ring12 group="Phone/Ring_Tone">n=Du-dut;w=6;c=1</Ring12><Silent_Ring_Duration group="Phone/Ring_Tone">60</Silent_Ring_Duration><Handset_Input_Gain group="Phone/Audio_Input_Gain__dB_">0</Handset_Input_Gain><Headset_Input_Gain group="Phone/Audio_Input_Gain__dB_">6</Headset_Input_Gain><Speakerphone_Input_Gain group="Phone/Audio_Input_Gain__dB_">0</Speakerphone_Input_Gain><Handset_Additional_Input_Gain group="Phone/Audio_Input_Gain__dB_">0</Handset_Additional_Input_Gain><Headset_Additional_Input_Gain group="Phone/Audio_Input_Gain__dB_">0</Headset_Additional_Input_Gain><Speakerphone_Additional_Input_Gain group="Phone/Audio_Input_Gain__dB_">0</Speakerphone_Additional_Input_Gain><Group_Paging_Script group="Phone/Multiple_Paging_Group_Parameters">pggrp=224.168.168.168:34560;name=All;num=800;listen=yes;</Group_Paging_Script><Directory_Enable group="Phone/Broadsoft_Settings">No</Directory_Enable><XSI_Host_Server group="Phone/Broadsoft_Settings"/><Directory_Name group="Phone/Broadsoft_Settings"/><Directory_Type group="Phone/Broadsoft_Settings">Enterprise</Directory_Type><Directory_UserID group="Phone/Broadsoft_Settings"/><Directory_Password group="Phone/Broadsoft_Settings"/><LDAP_Dir_Enable group="Phone/LDAP_Corporate_Directory_Search">No</LDAP_Dir_Enable><LDAP_Corp_Dir_Name group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Server group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Auth_Method group="Phone/LDAP_Corporate_Directory_Search">None</LDAP_Auth_Method><LDAP_Client_DN group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Username group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Password group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Search_Base group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Last_Name_Filter group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_First_Name_Filter group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Search_Item_3 group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Item_3_Filter group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Search_Item_4 group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_item_4_Filter group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Display_Attrs group="Phone/LDAP_Corporate_Directory_Search"/><LDAP_Number_Mapping group="Phone/LDAP_Corporate_Directory_Search"/><XML_Directory_Service_Name group="Phone/XML_Service"/><XML_Directory_Service_URL group="Phone/XML_Service"/><XML_Application_Service_Name group="Phone/XML_Service"/><XML_Application_Service_URL group="Phone/XML_Service"/><XML_User_Name group="Phone/XML_Service"/><XML_Password group="Phone/XML_Service"/><CISCO_XML_EXE_Enable group="Phone/XML_Service">No</CISCO_XML_EXE_Enable><CISCO_XML_EXE_Auth_Mode group="Phone/XML_Service">Trusted</CISCO_XML_EXE_Auth_Mode><EM_Enable group="Phone/Extension_Mobility">No</EM_Enable><EM_User_Domain group="Phone/Extension_Mobility"/><Programmable_Softkey_Enable group="Phone/Programmable_Softkeys">Yes</Programmable_Softkey_Enable><Idle_Key_List group="Phone/Programmable_Softkeys">em_login;acd_login;acd_logout;astate;avail;unavail;redial;dir;cfwd;dnd;lcr;pickup;gpickup;unpark;em_logout;</Idle_Key_List><Missed_Call_Key_List group="Phone/Programmable_Softkeys">lcr|1;miss|4;</Missed_Call_Key_List><Off_Hook_Key_List group="Phone/Programmable_Softkeys">option;redial;dir;cfwd;dnd;lcr;unpark;pickup;gpickup;</Off_Hook_Key_List><Dialing_Input_Key_List group="Phone/Programmable_Softkeys">option|1;dial|2;delchr|3;cancel|4;</Dialing_Input_Key_List><Progressing_Key_List group="Phone/Programmable_Softkeys">endcall|2;</Progressing_Key_List><Connected_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;conf|3;xfer|4;crdstart;crdstop;bxfer;confLx;xferLx;park;phold;flash;</Connected_Key_List><Start-Xfer_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;xfer|4;crdstart;crdstop;</Start-Xfer_Key_List><Start-Conf_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;conf|3;crdstart;crdstop;</Start-Conf_Key_List><Conferencing_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;join|4;crdstart;crdstop;</Conferencing_Key_List><Releasing_Key_List group="Phone/Programmable_Softkeys">endcall|2;</Releasing_Key_List><Hold_Key_List group="Phone/Programmable_Softkeys">resume|1;endcall|2;newcall|3;redial;dir;cfwd;dnd;crdstart;crdstop;</Hold_Key_List><Ringing_Key_List group="Phone/Programmable_Softkeys">answer|1;ignore|2;</Ringing_Key_List><Shared_Active_Key_List group="Phone/Programmable_Softkeys">newcall|1;barge|2;cfwd|3;dnd|4;crdstart;crdstop;</Shared_Active_Key_List><Shared_Held_Key_List group="Phone/Programmable_Softkeys">resume|1;barge|2;cfwd|3;dnd|4;crdstart;crdstop;</Shared_Held_Key_List><PSK_1 group="Phone/Programmable_Softkeys"/><PSK_2 group="Phone/Programmable_Softkeys"/><PSK_3 group="Phone/Programmable_Softkeys"/><PSK_4 group="Phone/Programmable_Softkeys"/><PSK_5 group="Phone/Programmable_Softkeys"/><PSK_6 group="Phone/Programmable_Softkeys"/><PSK_7 group="Phone/Programmable_Softkeys"/><PSK_8 group="Phone/Programmable_Softkeys"/><PSK_9 group="Phone/Programmable_Softkeys"/><PSK_10 group="Phone/Programmable_Softkeys"/><PSK_11 group="Phone/Programmable_Softkeys"/><PSK_12 group="Phone/Programmable_Softkeys"/><PSK_13 group="Phone/Programmable_Softkeys"/><PSK_14 group="Phone/Programmable_Softkeys"/><PSK_15 group="Phone/Programmable_Softkeys"/><PSK_16 group="Phone/Programmable_Softkeys"/><Line_Enable_1_ group="Ext_1/General">Yes</Line_Enable_1_><Share_Ext_1_ group="Ext_1/Share_Line_Appearance">private</Share_Ext_1_><Shared_User_ID_1_ group="Ext_1/Share_Line_Appearance"/><Subscription_Expires_1_ group="Ext_1/Share_Line_Appearance">3600</Subscription_Expires_1_><Restrict_MWI_1_ group="Ext_1/Share_Line_Appearance">No</Restrict_MWI_1_><Monitor_User_ID_1_ group="Ext_1/Share_Line_Appearance"/><SCA_Unseize_Delay_1_ group="Ext_1/Share_Line_Appearance">0</SCA_Unseize_Delay_1_><NAT_Mapping_Enable_1_ group="Ext_1/NAT_Settings">No</NAT_Mapping_Enable_1_><NAT_Keep_Alive_Enable_1_ group="Ext_1/NAT_Settings">Yes</NAT_Keep_Alive_Enable_1_><NAT_Keep_Alive_Msg_1_ group="Ext_1/NAT_Settings">$NOTIFY</NAT_Keep_Alive_Msg_1_><NAT_Keep_Alive_Dest_1_ group="Ext_1/NAT_Settings">$PROXY</NAT_Keep_Alive_Dest_1_><SIP_TOS_DiffServ_Value_1_ group="Ext_1/Network_Settings">0x68</SIP_TOS_DiffServ_Value_1_><SIP_CoS_Value_1_ group="Ext_1/Network_Settings">3</SIP_CoS_Value_1_><RTP_TOS_DiffServ_Value_1_ group="Ext_1/Network_Settings">0xb8</RTP_TOS_DiffServ_Value_1_><RTP_CoS_Value_1_ group="Ext_1/Network_Settings">6</RTP_CoS_Value_1_><Network_Jitter_Level_1_ group="Ext_1/Network_Settings">high</Network_Jitter_Level_1_><Jitter_Buffer_Adjustment_1_ group="Ext_1/Network_Settings">up and down</Jitter_Buffer_Adjustment_1_><SIP_Transport_1_ group="Ext_1/SIP_Settings">TLS</SIP_Transport_1_><SIP_Port_1_ group="Ext_1/SIP_Settings">5060</SIP_Port_1_><SIP_100REL_Enable_1_ group="Ext_1/SIP_Settings">No</SIP_100REL_Enable_1_><EXT_SIP_Port_1_ group="Ext_1/SIP_Settings"/><Auth_Resync-Reboot_1_ group="Ext_1/SIP_Settings">Yes</Auth_Resync-Reboot_1_><SIP_Proxy-Require_1_ group="Ext_1/SIP_Settings"/><SIP_Remote-Party-ID_1_ group="Ext_1/SIP_Settings">No</SIP_Remote-Party-ID_1_><Referor_Bye_Delay_1_ group="Ext_1/SIP_Settings">4</Referor_Bye_Delay_1_><Refer-To_Target_Contact_1_ group="Ext_1/SIP_Settings">No</Refer-To_Target_Contact_1_><Referee_Bye_Delay_1_ group="Ext_1/SIP_Settings">0</Referee_Bye_Delay_1_><SIP_Debug_Option_1_ group="Ext_1/SIP_Settings">full</SIP_Debug_Option_1_><Refer_Target_Bye_Delay_1_ group="Ext_1/SIP_Settings">0</Refer_Target_Bye_Delay_1_><Sticky_183_1_ group="Ext_1/SIP_Settings">No</Sticky_183_1_><Auth_INVITE_1_ group="Ext_1/SIP_Settings">No</Auth_INVITE_1_><Ntfy_Refer_On_1xx-To-Inv_1_ group="Ext_1/SIP_Settings">Yes</Ntfy_Refer_On_1xx-To-Inv_1_><Use_Anonymous_With_RPID_1_ group="Ext_1/SIP_Settings">Yes</Use_Anonymous_With_RPID_1_><Set_G729_annexb_1_ group="Ext_1/SIP_Settings">none</Set_G729_annexb_1_><Voice_Quality_Report_Address_1_ group="Ext_1/SIP_Settings"/><User_Equal_Phone_1_ group="Ext_1/SIP_Settings">No</User_Equal_Phone_1_><Blind_Attn-Xfer_Enable_1_ group="Ext_1/Call_Feature_Settings">No</Blind_Attn-Xfer_Enable_1_><MOH_Server_1_ group="Ext_1/Call_Feature_Settings"/><Message_Waiting_1_ group="Ext_1/Call_Feature_Settings">No</Message_Waiting_1_><Auth_Page_1_ group="Ext_1/Call_Feature_Settings">No</Auth_Page_1_><Default_Ring__1__ group="Ext_1/Call_Feature_Settings">5</Default_Ring__1__><Auth_Page_Realm_1_ group="Ext_1/Call_Feature_Settings"/><Conference_Bridge_URL_1_ group="Ext_1/Call_Feature_Settings"/><Auth_Page_Password_1_ group="Ext_1/Call_Feature_Settings"/><Mailbox_ID_1_ group="Ext_1/Call_Feature_Settings"/><Voice_Mail_Server_1_ group="Ext_1/Call_Feature_Settings"/><Voice_Mail_Subscribe_Interval_1_ group="Ext_1/Call_Feature_Settings">86400</Voice_Mail_Subscribe_Interval_1_><State_Agent_1_ group="Ext_1/Call_Feature_Settings"/><CFWD_Notify_Serv_1_ group="Ext_1/Call_Feature_Settings">No</CFWD_Notify_Serv_1_><CFWD_Notifier_1_ group="Ext_1/Call_Feature_Settings"/><User_ID_with_Domain_1_ group="Ext_1/Call_Feature_Settings">No</User_ID_with_Domain_1_><Broadsoft_ACD_1_ group="Ext_1/Call_Feature_Settings">No</Broadsoft_ACD_1_><Auto_Ans_Page_On_Active_Call_1_ group="Ext_1/Call_Feature_Settings">Yes</Auto_Ans_Page_On_Active_Call_1_><Feature_Key_Sync_1_ group="Ext_1/Call_Feature_Settings">No</Feature_Key_Sync_1_><HuaWei_SBC_1_ group="Ext_1/Call_Feature_Settings">No</HuaWei_SBC_1_><Call_Park_Monitor_Enable_1_ group="Ext_1/Call_Feature_Settings">Yes</Call_Park_Monitor_Enable_1_><Enable_Broadsoft_Hoteling_1_ group="Ext_1/Call_Feature_Settings">No</Enable_Broadsoft_Hoteling_1_><Hoteling_Subscription_Expires_1_ group="Ext_1/Call_Feature_Settings">3600</Hoteling_Subscription_Expires_1_><Proxy_1_ group="Ext_1/Proxy_and_Registration">myvoipserveraddress:5061</Proxy_1_><Outbound_Proxy_1_ group="Ext_1/Proxy_and_Registration"/><Alternate_Proxy_1_ group="Ext_1/Proxy_and_Registration">myalternatevoipserver:5061</Alternate_Proxy_1_><Alternate_Outbound_Proxy_1_ group="Ext_1/Proxy_and_Registration">0</Alternate_Outbound_Proxy_1_><Use_Outbound_Proxy_1_ group="Ext_1/Proxy_and_Registration">No</Use_Outbound_Proxy_1_><Use_OB_Proxy_In_Dialog_1_ group="Ext_1/Proxy_and_Registration">Yes</Use_OB_Proxy_In_Dialog_1_><Register_1_ group="Ext_1/Proxy_and_Registration">Yes</Register_1_><Make_Call_Without_Reg_1_ group="Ext_1/Proxy_and_Registration">No</Make_Call_Without_Reg_1_><Register_Expires_1_ group="Ext_1/Proxy_and_Registration">60</Register_Expires_1_><Ans_Call_Without_Reg_1_ group="Ext_1/Proxy_and_Registration">No</Ans_Call_Without_Reg_1_><Use_DNS_SRV_1_ group="Ext_1/Proxy_and_Registration">No</Use_DNS_SRV_1_><DNS_SRV_Auto_Prefix_1_ group="Ext_1/Proxy_and_Registration">No</DNS_SRV_Auto_Prefix_1_><Proxy_Fallback_Intvl_1_ group="Ext_1/Proxy_and_Registration">30</Proxy_Fallback_Intvl_1_><Proxy_Redundancy_Method_1_ group="Ext_1/Proxy_and_Registration">Normal</Proxy_Redundancy_Method_1_><Dual_Registration_1_ group="Ext_1/Proxy_and_Registration">Yes</Dual_Registration_1_><Auto_Register_When_Failover_1_ group="Ext_1/Proxy_and_Registration">Yes</Auto_Register_When_Failover_1_><Display_Name_1_ group="Ext_1/Subscriber_Information">1800</Display_Name_1_><User_ID_1_ group="Ext_1/Subscriber_Information">1800</User_ID_1_><Password_1_ group="Ext_1/Subscriber_Information">*************</Password_1_><Use_Auth_ID_1_ group="Ext_1/Subscriber_Information">No</Use_Auth_ID_1_><Auth_ID_1_ group="Ext_1/Subscriber_Information"/><Reversed_Auth_Realm_1_ group="Ext_1/Subscriber_Information"/><Mini_Certificate_1_ group="Ext_1/Subscriber_Information"/><SRTP_Private_Key_1_ group="Ext_1/Subscriber_Information"/><Resident_Online_Number_1_ group="Ext_1/Subscriber_Information"/><SIP_URI_1_ group="Ext_1/Subscriber_Information"/><Preferred_Codec_1_ group="Ext_1/Audio_Configuration">G729a</Preferred_Codec_1_><Use_Pref_Codec_Only_1_ group="Ext_1/Audio_Configuration">No</Use_Pref_Codec_Only_1_><Second_Preferred_Codec_1_ group="Ext_1/Audio_Configuration">G711u</Second_Preferred_Codec_1_><Third_Preferred_Codec_1_ group="Ext_1/Audio_Configuration">Unspecified</Third_Preferred_Codec_1_><G711u_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G711u_Enable_1_><G711a_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G711a_Enable_1_><G729a_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G729a_Enable_1_><G722_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G722_Enable_1_><G726-16_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G726-16_Enable_1_><G726-24_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G726-24_Enable_1_><G726-32_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G726-32_Enable_1_><G726-40_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G726-40_Enable_1_><Release_Unused_Codec_1_ group="Ext_1/Audio_Configuration">Yes</Release_Unused_Codec_1_><DTMF_Process_AVT_1_ group="Ext_1/Audio_Configuration">Yes</DTMF_Process_AVT_1_><Silence_Supp_Enable_1_ group="Ext_1/Audio_Configuration">No</Silence_Supp_Enable_1_><DTMF_Tx_Method_1_ group="Ext_1/Audio_Configuration">Auto</DTMF_Tx_Method_1_><DTMF_Tx_Volume_for_AVT_Packet_1_ group="Ext_1/Audio_Configuration">0</DTMF_Tx_Volume_for_AVT_Packet_1_><DTMF_AVT_Packet_Interval_1_ group="Ext_1/Audio_Configuration">0</DTMF_AVT_Packet_Interval_1_><Use_Remote_Pref_Codec_1_ group="Ext_1/Audio_Configuration">No</Use_Remote_Pref_Codec_1_><Codec_Negotiation_1_ group="Ext_1/Audio_Configuration">Default</Codec_Negotiation_1_><Rx_Payload_In_18x_Media_Session_1_ group="Ext_1/Audio_Configuration">Use Local SDP</Rx_Payload_In_18x_Media_Session_1_><Dial_Plan_1_ group="Ext_1/Dial_Plan">(*45xxxx*xxxxx|*x.|**xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_1_><Caller_ID_Map_1_ group="Ext_1/Dial_Plan"/><Enable_IP_Dialing_1_ group="Ext_1/Dial_Plan">Yes</Enable_IP_Dialing_1_><Emergency_Number_1_ group="Ext_1/Dial_Plan"/><Line_Enable_2_ group="Ext_2/General">No</Line_Enable_2_><Share_Ext_2_ group="Ext_2/Share_Line_Appearance">private</Share_Ext_2_><Shared_User_ID_2_ group="Ext_2/Share_Line_Appearance"/><Subscription_Expires_2_ group="Ext_2/Share_Line_Appearance">3600</Subscription_Expires_2_><Restrict_MWI_2_ group="Ext_2/Share_Line_Appearance">No</Restrict_MWI_2_><Monitor_User_ID_2_ group="Ext_2/Share_Line_Appearance"/><SCA_Unseize_Delay_2_ group="Ext_2/Share_Line_Appearance">0</SCA_Unseize_Delay_2_><NAT_Mapping_Enable_2_ group="Ext_2/NAT_Settings">No</NAT_Mapping_Enable_2_><NAT_Keep_Alive_Enable_2_ group="Ext_2/NAT_Settings">No</NAT_Keep_Alive_Enable_2_><NAT_Keep_Alive_Msg_2_ group="Ext_2/NAT_Settings">$NOTIFY</NAT_Keep_Alive_Msg_2_><NAT_Keep_Alive_Dest_2_ group="Ext_2/NAT_Settings">$PROXY</NAT_Keep_Alive_Dest_2_><SIP_TOS_DiffServ_Value_2_ group="Ext_2/Network_Settings">0x68</SIP_TOS_DiffServ_Value_2_><SIP_CoS_Value_2_ group="Ext_2/Network_Settings">3</SIP_CoS_Value_2_><RTP_TOS_DiffServ_Value_2_ group="Ext_2/Network_Settings">0xb8</RTP_TOS_DiffServ_Value_2_><RTP_CoS_Value_2_ group="Ext_2/Network_Settings">6</RTP_CoS_Value_2_><Network_Jitter_Level_2_ group="Ext_2/Network_Settings">high</Network_Jitter_Level_2_><Jitter_Buffer_Adjustment_2_ group="Ext_2/Network_Settings">up and down</Jitter_Buffer_Adjustment_2_><SIP_Transport_2_ group="Ext_2/SIP_Settings">UDP</SIP_Transport_2_><SIP_Port_2_ group="Ext_2/SIP_Settings">5070</SIP_Port_2_><SIP_100REL_Enable_2_ group="Ext_2/SIP_Settings">No</SIP_100REL_Enable_2_><EXT_SIP_Port_2_ group="Ext_2/SIP_Settings"/><Auth_Resync-Reboot_2_ group="Ext_2/SIP_Settings">Yes</Auth_Resync-Reboot_2_><SIP_Proxy-Require_2_ group="Ext_2/SIP_Settings"/><SIP_Remote-Party-ID_2_ group="Ext_2/SIP_Settings">No</SIP_Remote-Party-ID_2_><Referor_Bye_Delay_2_ group="Ext_2/SIP_Settings">4</Referor_Bye_Delay_2_><Refer-To_Target_Contact_2_ group="Ext_2/SIP_Settings">No</Refer-To_Target_Contact_2_><Referee_Bye_Delay_2_ group="Ext_2/SIP_Settings">0</Referee_Bye_Delay_2_><SIP_Debug_Option_2_ group="Ext_2/SIP_Settings">none</SIP_Debug_Option_2_><Refer_Target_Bye_Delay_2_ group="Ext_2/SIP_Settings">0</Refer_Target_Bye_Delay_2_><Sticky_183_2_ group="Ext_2/SIP_Settings">No</Sticky_183_2_><Auth_INVITE_2_ group="Ext_2/SIP_Settings">No</Auth_INVITE_2_><Ntfy_Refer_On_1xx-To-Inv_2_ group="Ext_2/SIP_Settings">Yes</Ntfy_Refer_On_1xx-To-Inv_2_><Use_Anonymous_With_RPID_2_ group="Ext_2/SIP_Settings">Yes</Use_Anonymous_With_RPID_2_><Set_G729_annexb_2_ group="Ext_2/SIP_Settings">none</Set_G729_annexb_2_><Voice_Quality_Report_Address_2_ group="Ext_2/SIP_Settings"/><User_Equal_Phone_2_ group="Ext_2/SIP_Settings">No</User_Equal_Phone_2_><Blind_Attn-Xfer_Enable_2_ group="Ext_2/Call_Feature_Settings">No</Blind_Attn-Xfer_Enable_2_><MOH_Server_2_ group="Ext_2/Call_Feature_Settings"/><Message_Waiting_2_ group="Ext_2/Call_Feature_Settings">No</Message_Waiting_2_><Auth_Page_2_ group="Ext_2/Call_Feature_Settings">No</Auth_Page_2_><Default_Ring__2__ group="Ext_2/Call_Feature_Settings">1</Default_Ring__2__><Auth_Page_Realm_2_ group="Ext_2/Call_Feature_Settings"/><Conference_Bridge_URL_2_ group="Ext_2/Call_Feature_Settings"/><Auth_Page_Password_2_ group="Ext_2/Call_Feature_Settings"/><Mailbox_ID_2_ group="Ext_2/Call_Feature_Settings"/><Voice_Mail_Server_2_ group="Ext_2/Call_Feature_Settings"/><Voice_Mail_Subscribe_Interval_2_ group="Ext_2/Call_Feature_Settings">86400</Voice_Mail_Subscribe_Interval_2_><State_Agent_2_ group="Ext_2/Call_Feature_Settings"/><CFWD_Notify_Serv_2_ group="Ext_2/Call_Feature_Settings">No</CFWD_Notify_Serv_2_><CFWD_Notifier_2_ group="Ext_2/Call_Feature_Settings"/><User_ID_with_Domain_2_ group="Ext_2/Call_Feature_Settings">No</User_ID_with_Domain_2_><Broadsoft_ACD_2_ group="Ext_2/Call_Feature_Settings">No</Broadsoft_ACD_2_><Auto_Ans_Page_On_Active_Call_2_ group="Ext_2/Call_Feature_Settings">Yes</Auto_Ans_Page_On_Active_Call_2_><Feature_Key_Sync_2_ group="Ext_2/Call_Feature_Settings">No</Feature_Key_Sync_2_><HuaWei_SBC_2_ group="Ext_2/Call_Feature_Settings">Yes</HuaWei_SBC_2_><Call_Park_Monitor_Enable_2_ group="Ext_2/Call_Feature_Settings">Yes</Call_Park_Monitor_Enable_2_><Enable_Broadsoft_Hoteling_2_ group="Ext_2/Call_Feature_Settings">No</Enable_Broadsoft_Hoteling_2_><Hoteling_Subscription_Expires_2_ group="Ext_2/Call_Feature_Settings">3600</Hoteling_Subscription_Expires_2_><Proxy_2_ group="Ext_2/Proxy_and_Registration"/><Outbound_Proxy_2_ group="Ext_2/Proxy_and_Registration"/><Alternate_Proxy_2_ group="Ext_2/Proxy_and_Registration"/><Alternate_Outbound_Proxy_2_ group="Ext_2/Proxy_and_Registration">0</Alternate_Outbound_Proxy_2_><Use_Outbound_Proxy_2_ group="Ext_2/Proxy_and_Registration">No</Use_Outbound_Proxy_2_><Use_OB_Proxy_In_Dialog_2_ group="Ext_2/Proxy_and_Registration">Yes</Use_OB_Proxy_In_Dialog_2_><Register_2_ group="Ext_2/Proxy_and_Registration">Yes</Register_2_><Make_Call_Without_Reg_2_ group="Ext_2/Proxy_and_Registration">No</Make_Call_Without_Reg_2_><Register_Expires_2_ group="Ext_2/Proxy_and_Registration">60</Register_Expires_2_><Ans_Call_Without_Reg_2_ group="Ext_2/Proxy_and_Registration">No</Ans_Call_Without_Reg_2_><Use_DNS_SRV_2_ group="Ext_2/Proxy_and_Registration">Yes</Use_DNS_SRV_2_><DNS_SRV_Auto_Prefix_2_ group="Ext_2/Proxy_and_Registration">No</DNS_SRV_Auto_Prefix_2_><Proxy_Fallback_Intvl_2_ group="Ext_2/Proxy_and_Registration">3600</Proxy_Fallback_Intvl_2_><Proxy_Redundancy_Method_2_ group="Ext_2/Proxy_and_Registration">Normal</Proxy_Redundancy_Method_2_><Dual_Registration_2_ group="Ext_2/Proxy_and_Registration">No</Dual_Registration_2_><Auto_Register_When_Failover_2_ group="Ext_2/Proxy_and_Registration">No</Auto_Register_When_Failover_2_><Display_Name_2_ group="Ext_2/Subscriber_Information"/><User_ID_2_ group="Ext_2/Subscriber_Information"/><Password_2_ group="Ext_2/Subscriber_Information"/><Use_Auth_ID_2_ group="Ext_2/Subscriber_Information">No</Use_Auth_ID_2_><Auth_ID_2_ group="Ext_2/Subscriber_Information"/><Reversed_Auth_Realm_2_ group="Ext_2/Subscriber_Information"/><Mini_Certificate_2_ group="Ext_2/Subscriber_Information"/><SRTP_Private_Key_2_ group="Ext_2/Subscriber_Information"/><Resident_Online_Number_2_ group="Ext_2/Subscriber_Information"/><SIP_URI_2_ group="Ext_2/Subscriber_Information"/><Preferred_Codec_2_ group="Ext_2/Audio_Configuration">G711u</Preferred_Codec_2_><Use_Pref_Codec_Only_2_ group="Ext_2/Audio_Configuration">No</Use_Pref_Codec_Only_2_><Second_Preferred_Codec_2_ group="Ext_2/Audio_Configuration">Unspecified</Second_Preferred_Codec_2_><Third_Preferred_Codec_2_ group="Ext_2/Audio_Configuration">Unspecified</Third_Preferred_Codec_2_><G711u_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G711u_Enable_2_><G711a_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G711a_Enable_2_><G729a_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G729a_Enable_2_><G722_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G722_Enable_2_><G726-16_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G726-16_Enable_2_><G726-24_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G726-24_Enable_2_><G726-32_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G726-32_Enable_2_><G726-40_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G726-40_Enable_2_><Release_Unused_Codec_2_ group="Ext_2/Audio_Configuration">Yes</Release_Unused_Codec_2_><DTMF_Process_AVT_2_ group="Ext_2/Audio_Configuration">Yes</DTMF_Process_AVT_2_><Silence_Supp_Enable_2_ group="Ext_2/Audio_Configuration">No</Silence_Supp_Enable_2_><DTMF_Tx_Method_2_ group="Ext_2/Audio_Configuration">Auto</DTMF_Tx_Method_2_><DTMF_Tx_Volume_for_AVT_Packet_2_ group="Ext_2/Audio_Configuration">0</DTMF_Tx_Volume_for_AVT_Packet_2_><DTMF_AVT_Packet_Interval_2_ group="Ext_2/Audio_Configuration">0</DTMF_AVT_Packet_Interval_2_><Use_Remote_Pref_Codec_2_ group="Ext_2/Audio_Configuration">No</Use_Remote_Pref_Codec_2_><Codec_Negotiation_2_ group="Ext_2/Audio_Configuration">Default</Codec_Negotiation_2_><Rx_Payload_In_18x_Media_Session_2_ group="Ext_2/Audio_Configuration">Use Local SDP</Rx_Payload_In_18x_Media_Session_2_><Dial_Plan_2_ group="Ext_2/Dial_Plan">(*45xxxx*xxxxx|*x.|**xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_2_><Caller_ID_Map_2_ group="Ext_2/Dial_Plan"/><Enable_IP_Dialing_2_ group="Ext_2/Dial_Plan">Yes</Enable_IP_Dialing_2_><Emergency_Number_2_ group="Ext_2/Dial_Plan"/><Line_Enable_3_ group="Ext_3/General">No</Line_Enable_3_><Share_Ext_3_ group="Ext_3/Share_Line_Appearance">private</Share_Ext_3_><Shared_User_ID_3_ group="Ext_3/Share_Line_Appearance"/><Subscription_Expires_3_ group="Ext_3/Share_Line_Appearance">3600</Subscription_Expires_3_><Restrict_MWI_3_ group="Ext_3/Share_Line_Appearance">No</Restrict_MWI_3_><Monitor_User_ID_3_ group="Ext_3/Share_Line_Appearance"/><SCA_Unseize_Delay_3_ group="Ext_3/Share_Line_Appearance">0</SCA_Unseize_Delay_3_><NAT_Mapping_Enable_3_ group="Ext_3/NAT_Settings">No</NAT_Mapping_Enable_3_><NAT_Keep_Alive_Enable_3_ group="Ext_3/NAT_Settings">No</NAT_Keep_Alive_Enable_3_><NAT_Keep_Alive_Msg_3_ group="Ext_3/NAT_Settings">$NOTIFY</NAT_Keep_Alive_Msg_3_><NAT_Keep_Alive_Dest_3_ group="Ext_3/NAT_Settings">$PROXY</NAT_Keep_Alive_Dest_3_><SIP_TOS_DiffServ_Value_3_ group="Ext_3/Network_Settings">0x68</SIP_TOS_DiffServ_Value_3_><SIP_CoS_Value_3_ group="Ext_3/Network_Settings">3</SIP_CoS_Value_3_><RTP_TOS_DiffServ_Value_3_ group="Ext_3/Network_Settings">0xb8</RTP_TOS_DiffServ_Value_3_><RTP_CoS_Value_3_ group="Ext_3/Network_Settings">6</RTP_CoS_Value_3_><Network_Jitter_Level_3_ group="Ext_3/Network_Settings">high</Network_Jitter_Level_3_><Jitter_Buffer_Adjustment_3_ group="Ext_3/Network_Settings">up and down</Jitter_Buffer_Adjustment_3_><SIP_Transport_3_ group="Ext_3/SIP_Settings">UDP</SIP_Transport_3_><SIP_Port_3_ group="Ext_3/SIP_Settings">5080</SIP_Port_3_><SIP_100REL_Enable_3_ group="Ext_3/SIP_Settings">No</SIP_100REL_Enable_3_><EXT_SIP_Port_3_ group="Ext_3/SIP_Settings"/><Auth_Resync-Reboot_3_ group="Ext_3/SIP_Settings">Yes</Auth_Resync-Reboot_3_><SIP_Proxy-Require_3_ group="Ext_3/SIP_Settings"/><SIP_Remote-Party-ID_3_ group="Ext_3/SIP_Settings">No</SIP_Remote-Party-ID_3_><Referor_Bye_Delay_3_ group="Ext_3/SIP_Settings">4</Referor_Bye_Delay_3_><Refer-To_Target_Contact_3_ group="Ext_3/SIP_Settings">No</Refer-To_Target_Contact_3_><Referee_Bye_Delay_3_ group="Ext_3/SIP_Settings">0</Referee_Bye_Delay_3_><SIP_Debug_Option_3_ group="Ext_3/SIP_Settings">none</SIP_Debug_Option_3_><Refer_Target_Bye_Delay_3_ group="Ext_3/SIP_Settings">0</Refer_Target_Bye_Delay_3_><Sticky_183_3_ group="Ext_3/SIP_Settings">No</Sticky_183_3_><Auth_INVITE_3_ group="Ext_3/SIP_Settings">No</Auth_INVITE_3_><Ntfy_Refer_On_1xx-To-Inv_3_ group="Ext_3/SIP_Settings">Yes</Ntfy_Refer_On_1xx-To-Inv_3_><Use_Anonymous_With_RPID_3_ group="Ext_3/SIP_Settings">Yes</Use_Anonymous_With_RPID_3_><Set_G729_annexb_3_ group="Ext_3/SIP_Settings">none</Set_G729_annexb_3_><Voice_Quality_Report_Address_3_ group="Ext_3/SIP_Settings"/><User_Equal_Phone_3_ group="Ext_3/SIP_Settings">No</User_Equal_Phone_3_><Blind_Attn-Xfer_Enable_3_ group="Ext_3/Call_Feature_Settings">No</Blind_Attn-Xfer_Enable_3_><MOH_Server_3_ group="Ext_3/Call_Feature_Settings"/><Message_Waiting_3_ group="Ext_3/Call_Feature_Settings">No</Message_Waiting_3_><Auth_Page_3_ group="Ext_3/Call_Feature_Settings">No</Auth_Page_3_><Default_Ring__3__ group="Ext_3/Call_Feature_Settings">1</Default_Ring__3__><Auth_Page_Realm_3_ group="Ext_3/Call_Feature_Settings"/><Conference_Bridge_URL_3_ group="Ext_3/Call_Feature_Settings"/><Auth_Page_Password_3_ group="Ext_3/Call_Feature_Settings"/><Mailbox_ID_3_ group="Ext_3/Call_Feature_Settings"/><Voice_Mail_Server_3_ group="Ext_3/Call_Feature_Settings"/><Voice_Mail_Subscribe_Interval_3_ group="Ext_3/Call_Feature_Settings">86400</Voice_Mail_Subscribe_Interval_3_><State_Agent_3_ group="Ext_3/Call_Feature_Settings"/><CFWD_Notify_Serv_3_ group="Ext_3/Call_Feature_Settings">No</CFWD_Notify_Serv_3_><CFWD_Notifier_3_ group="Ext_3/Call_Feature_Settings"/><User_ID_with_Domain_3_ group="Ext_3/Call_Feature_Settings">No</User_ID_with_Domain_3_><Broadsoft_ACD_3_ group="Ext_3/Call_Feature_Settings">No</Broadsoft_ACD_3_><Auto_Ans_Page_On_Active_Call_3_ group="Ext_3/Call_Feature_Settings">Yes</Auto_Ans_Page_On_Active_Call_3_><Feature_Key_Sync_3_ group="Ext_3/Call_Feature_Settings">No</Feature_Key_Sync_3_><HuaWei_SBC_3_ group="Ext_3/Call_Feature_Settings">Yes</HuaWei_SBC_3_><Call_Park_Monitor_Enable_3_ group="Ext_3/Call_Feature_Settings">Yes</Call_Park_Monitor_Enable_3_><Enable_Broadsoft_Hoteling_3_ group="Ext_3/Call_Feature_Settings">No</Enable_Broadsoft_Hoteling_3_><Hoteling_Subscription_Expires_3_ group="Ext_3/Call_Feature_Settings">3600</Hoteling_Subscription_Expires_3_><Proxy_3_ group="Ext_3/Proxy_and_Registration"/><Outbound_Proxy_3_ group="Ext_3/Proxy_and_Registration"/><Alternate_Proxy_3_ group="Ext_3/Proxy_and_Registration"/><Alternate_Outbound_Proxy_3_ group="Ext_3/Proxy_and_Registration">0</Alternate_Outbound_Proxy_3_><Use_Outbound_Proxy_3_ group="Ext_3/Proxy_and_Registration">No</Use_Outbound_Proxy_3_><Use_OB_Proxy_In_Dialog_3_ group="Ext_3/Proxy_and_Registration">Yes</Use_OB_Proxy_In_Dialog_3_><Register_3_ group="Ext_3/Proxy_and_Registration">Yes</Register_3_><Make_Call_Without_Reg_3_ group="Ext_3/Proxy_and_Registration">No</Make_Call_Without_Reg_3_><Register_Expires_3_ group="Ext_3/Proxy_and_Registration">60</Register_Expires_3_><Ans_Call_Without_Reg_3_ group="Ext_3/Proxy_and_Registration">No</Ans_Call_Without_Reg_3_><Use_DNS_SRV_3_ group="Ext_3/Proxy_and_Registration">Yes</Use_DNS_SRV_3_><DNS_SRV_Auto_Prefix_3_ group="Ext_3/Proxy_and_Registration">No</DNS_SRV_Auto_Prefix_3_><Proxy_Fallback_Intvl_3_ group="Ext_3/Proxy_and_Registration">3600</Proxy_Fallback_Intvl_3_><Proxy_Redundancy_Method_3_ group="Ext_3/Proxy_and_Registration">Normal</Proxy_Redundancy_Method_3_><Dual_Registration_3_ group="Ext_3/Proxy_and_Registration">No</Dual_Registration_3_><Auto_Register_When_Failover_3_ group="Ext_3/Proxy_and_Registration">No</Auto_Register_When_Failover_3_><Display_Name_3_ group="Ext_3/Subscriber_Information"/><User_ID_3_ group="Ext_3/Subscriber_Information"/><Password_3_ group="Ext_3/Subscriber_Information"/><Use_Auth_ID_3_ group="Ext_3/Subscriber_Information">No</Use_Auth_ID_3_><Auth_ID_3_ group="Ext_3/Subscriber_Information"/><Reversed_Auth_Realm_3_ group="Ext_3/Subscriber_Information"/><Mini_Certificate_3_ group="Ext_3/Subscriber_Information"/><SRTP_Private_Key_3_ group="Ext_3/Subscriber_Information"/><Resident_Online_Number_3_ group="Ext_3/Subscriber_Information"/><SIP_URI_3_ group="Ext_3/Subscriber_Information"/><Preferred_Codec_3_ group="Ext_3/Audio_Configuration">G711u</Preferred_Codec_3_><Use_Pref_Codec_Only_3_ group="Ext_3/Audio_Configuration">No</Use_Pref_Codec_Only_3_><Second_Preferred_Codec_3_ group="Ext_3/Audio_Configuration">Unspecified</Second_Preferred_Codec_3_><Third_Preferred_Codec_3_ group="Ext_3/Audio_Configuration">Unspecified</Third_Preferred_Codec_3_><G711u_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G711u_Enable_3_><G711a_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G711a_Enable_3_><G729a_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G729a_Enable_3_><G722_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G722_Enable_3_><G726-16_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G726-16_Enable_3_><G726-24_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G726-24_Enable_3_><G726-32_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G726-32_Enable_3_><G726-40_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G726-40_Enable_3_><Release_Unused_Codec_3_ group="Ext_3/Audio_Configuration">Yes</Release_Unused_Codec_3_><DTMF_Process_AVT_3_ group="Ext_3/Audio_Configuration">Yes</DTMF_Process_AVT_3_><Silence_Supp_Enable_3_ group="Ext_3/Audio_Configuration">No</Silence_Supp_Enable_3_><DTMF_Tx_Method_3_ group="Ext_3/Audio_Configuration">Auto</DTMF_Tx_Method_3_><DTMF_Tx_Volume_for_AVT_Packet_3_ group="Ext_3/Audio_Configuration">0</DTMF_Tx_Volume_for_AVT_Packet_3_><DTMF_AVT_Packet_Interval_3_ group="Ext_3/Audio_Configuration">0</DTMF_AVT_Packet_Interval_3_><Use_Remote_Pref_Codec_3_ group="Ext_3/Audio_Configuration">No</Use_Remote_Pref_Codec_3_><Codec_Negotiation_3_ group="Ext_3/Audio_Configuration">Default</Codec_Negotiation_3_><Rx_Payload_In_18x_Media_Session_3_ group="Ext_3/Audio_Configuration">Use Local SDP</Rx_Payload_In_18x_Media_Session_3_><Dial_Plan_3_ group="Ext_3/Dial_Plan">(*45xxxx*xxxxx|*x.|**xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_3_><Caller_ID_Map_3_ group="Ext_3/Dial_Plan"/><Enable_IP_Dialing_3_ group="Ext_3/Dial_Plan">Yes</Enable_IP_Dialing_3_><Emergency_Number_3_ group="Ext_3/Dial_Plan"/><Line_Enable_4_ group="Ext_4/General">No</Line_Enable_4_><Share_Ext_4_ group="Ext_4/Share_Line_Appearance">private</Share_Ext_4_><Shared_User_ID_4_ group="Ext_4/Share_Line_Appearance"/><Subscription_Expires_4_ group="Ext_4/Share_Line_Appearance">3600</Subscription_Expires_4_><Restrict_MWI_4_ group="Ext_4/Share_Line_Appearance">No</Restrict_MWI_4_><Monitor_User_ID_4_ group="Ext_4/Share_Line_Appearance"/><SCA_Unseize_Delay_4_ group="Ext_4/Share_Line_Appearance">0</SCA_Unseize_Delay_4_><NAT_Mapping_Enable_4_ group="Ext_4/NAT_Settings">No</NAT_Mapping_Enable_4_><NAT_Keep_Alive_Enable_4_ group="Ext_4/NAT_Settings">No</NAT_Keep_Alive_Enable_4_><NAT_Keep_Alive_Msg_4_ group="Ext_4/NAT_Settings">$NOTIFY</NAT_Keep_Alive_Msg_4_><NAT_Keep_Alive_Dest_4_ group="Ext_4/NAT_Settings">$PROXY</NAT_Keep_Alive_Dest_4_><SIP_TOS_DiffServ_Value_4_ group="Ext_4/Network_Settings">0x68</SIP_TOS_DiffServ_Value_4_><SIP_CoS_Value_4_ group="Ext_4/Network_Settings">3</SIP_CoS_Value_4_><RTP_TOS_DiffServ_Value_4_ group="Ext_4/Network_Settings">0xb8</RTP_TOS_DiffServ_Value_4_><RTP_CoS_Value_4_ group="Ext_4/Network_Settings">6</RTP_CoS_Value_4_><Network_Jitter_Level_4_ group="Ext_4/Network_Settings">high</Network_Jitter_Level_4_><Jitter_Buffer_Adjustment_4_ group="Ext_4/Network_Settings">up and down</Jitter_Buffer_Adjustment_4_><SIP_Transport_4_ group="Ext_4/SIP_Settings">UDP</SIP_Transport_4_><SIP_Port_4_ group="Ext_4/SIP_Settings">5090</SIP_Port_4_><SIP_100REL_Enable_4_ group="Ext_4/SIP_Settings">No</SIP_100REL_Enable_4_><EXT_SIP_Port_4_ group="Ext_4/SIP_Settings"/><Auth_Resync-Reboot_4_ group="Ext_4/SIP_Settings">Yes</Auth_Resync-Reboot_4_><SIP_Proxy-Require_4_ group="Ext_4/SIP_Settings"/><SIP_Remote-Party-ID_4_ group="Ext_4/SIP_Settings">No</SIP_Remote-Party-ID_4_><Referor_Bye_Delay_4_ group="Ext_4/SIP_Settings">4</Referor_Bye_Delay_4_><Refer-To_Target_Contact_4_ group="Ext_4/SIP_Settings">No</Refer-To_Target_Contact_4_><Referee_Bye_Delay_4_ group="Ext_4/SIP_Settings">0</Referee_Bye_Delay_4_><SIP_Debug_Option_4_ group="Ext_4/SIP_Settings">none</SIP_Debug_Option_4_><Refer_Target_Bye_Delay_4_ group="Ext_4/SIP_Settings">0</Refer_Target_Bye_Delay_4_><Sticky_183_4_ group="Ext_4/SIP_Settings">No</Sticky_183_4_><Auth_INVITE_4_ group="Ext_4/SIP_Settings">No</Auth_INVITE_4_><Ntfy_Refer_On_1xx-To-Inv_4_ group="Ext_4/SIP_Settings">Yes</Ntfy_Refer_On_1xx-To-Inv_4_><Use_Anonymous_With_RPID_4_ group="Ext_4/SIP_Settings">Yes</Use_Anonymous_With_RPID_4_><Set_G729_annexb_4_ group="Ext_4/SIP_Settings">none</Set_G729_annexb_4_><Voice_Quality_Report_Address_4_ group="Ext_4/SIP_Settings"/><User_Equal_Phone_4_ group="Ext_4/SIP_Settings">No</User_Equal_Phone_4_><Blind_Attn-Xfer_Enable_4_ group="Ext_4/Call_Feature_Settings">No</Blind_Attn-Xfer_Enable_4_><MOH_Server_4_ group="Ext_4/Call_Feature_Settings"/><Message_Waiting_4_ group="Ext_4/Call_Feature_Settings">No</Message_Waiting_4_><Auth_Page_4_ group="Ext_4/Call_Feature_Settings">No</Auth_Page_4_><Default_Ring__4__ group="Ext_4/Call_Feature_Settings">1</Default_Ring__4__><Auth_Page_Realm_4_ group="Ext_4/Call_Feature_Settings"/><Conference_Bridge_URL_4_ group="Ext_4/Call_Feature_Settings"/><Auth_Page_Password_4_ group="Ext_4/Call_Feature_Settings"/><Mailbox_ID_4_ group="Ext_4/Call_Feature_Settings"/><Voice_Mail_Server_4_ group="Ext_4/Call_Feature_Settings"/><Voice_Mail_Subscribe_Interval_4_ group="Ext_4/Call_Feature_Settings">86400</Voice_Mail_Subscribe_Interval_4_><State_Agent_4_ group="Ext_4/Call_Feature_Settings"/><CFWD_Notify_Serv_4_ group="Ext_4/Call_Feature_Settings">No</CFWD_Notify_Serv_4_><CFWD_Notifier_4_ group="Ext_4/Call_Feature_Settings"/><User_ID_with_Domain_4_ group="Ext_4/Call_Feature_Settings">No</User_ID_with_Domain_4_><Broadsoft_ACD_4_ group="Ext_4/Call_Feature_Settings">No</Broadsoft_ACD_4_><Auto_Ans_Page_On_Active_Call_4_ group="Ext_4/Call_Feature_Settings">Yes</Auto_Ans_Page_On_Active_Call_4_><Feature_Key_Sync_4_ group="Ext_4/Call_Feature_Settings">No</Feature_Key_Sync_4_><HuaWei_SBC_4_ group="Ext_4/Call_Feature_Settings">Yes</HuaWei_SBC_4_><Call_Park_Monitor_Enable_4_ group="Ext_4/Call_Feature_Settings">Yes</Call_Park_Monitor_Enable_4_><Enable_Broadsoft_Hoteling_4_ group="Ext_4/Call_Feature_Settings">No</Enable_Broadsoft_Hoteling_4_><Hoteling_Subscription_Expires_4_ group="Ext_4/Call_Feature_Settings">3600</Hoteling_Subscription_Expires_4_><Proxy_4_ group="Ext_4/Proxy_and_Registration"/><Outbound_Proxy_4_ group="Ext_4/Proxy_and_Registration"/><Alternate_Proxy_4_ group="Ext_4/Proxy_and_Registration"/><Alternate_Outbound_Proxy_4_ group="Ext_4/Proxy_and_Registration">0</Alternate_Outbound_Proxy_4_><Use_Outbound_Proxy_4_ group="Ext_4/Proxy_and_Registration">No</Use_Outbound_Proxy_4_><Use_OB_Proxy_In_Dialog_4_ group="Ext_4/Proxy_and_Registration">Yes</Use_OB_Proxy_In_Dialog_4_><Register_4_ group="Ext_4/Proxy_and_Registration">Yes</Register_4_><Make_Call_Without_Reg_4_ group="Ext_4/Proxy_and_Registration">No</Make_Call_Without_Reg_4_><Register_Expires_4_ group="Ext_4/Proxy_and_Registration">60</Register_Expires_4_><Ans_Call_Without_Reg_4_ group="Ext_4/Proxy_and_Registration">No</Ans_Call_Without_Reg_4_><Use_DNS_SRV_4_ group="Ext_4/Proxy_and_Registration">Yes</Use_DNS_SRV_4_><DNS_SRV_Auto_Prefix_4_ group="Ext_4/Proxy_and_Registration">No</DNS_SRV_Auto_Prefix_4_><Proxy_Fallback_Intvl_4_ group="Ext_4/Proxy_and_Registration">3600</Proxy_Fallback_Intvl_4_><Proxy_Redundancy_Method_4_ group="Ext_4/Proxy_and_Registration">Normal</Proxy_Redundancy_Method_4_><Dual_Registration_4_ group="Ext_4/Proxy_and_Registration">No</Dual_Registration_4_><Auto_Register_When_Failover_4_ group="Ext_4/Proxy_and_Registration">No</Auto_Register_When_Failover_4_><Display_Name_4_ group="Ext_4/Subscriber_Information"/><User_ID_4_ group="Ext_4/Subscriber_Information"/><Password_4_ group="Ext_4/Subscriber_Information"/><Use_Auth_ID_4_ group="Ext_4/Subscriber_Information">No</Use_Auth_ID_4_><Auth_ID_4_ group="Ext_4/Subscriber_Information"/><Reversed_Auth_Realm_4_ group="Ext_4/Subscriber_Information"/><Mini_Certificate_4_ group="Ext_4/Subscriber_Information"/><SRTP_Private_Key_4_ group="Ext_4/Subscriber_Information"/><Resident_Online_Number_4_ group="Ext_4/Subscriber_Information"/><SIP_URI_4_ group="Ext_4/Subscriber_Information"/><Preferred_Codec_4_ group="Ext_4/Audio_Configuration">G711u</Preferred_Codec_4_><Use_Pref_Codec_Only_4_ group="Ext_4/Audio_Configuration">No</Use_Pref_Codec_Only_4_><Second_Preferred_Codec_4_ group="Ext_4/Audio_Configuration">Unspecified</Second_Preferred_Codec_4_><Third_Preferred_Codec_4_ group="Ext_4/Audio_Configuration">Unspecified</Third_Preferred_Codec_4_><G711u_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G711u_Enable_4_><G711a_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G711a_Enable_4_><G729a_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G729a_Enable_4_><G722_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G722_Enable_4_><G726-16_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G726-16_Enable_4_><G726-24_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G726-24_Enable_4_><G726-32_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G726-32_Enable_4_><G726-40_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G726-40_Enable_4_><Release_Unused_Codec_4_ group="Ext_4/Audio_Configuration">Yes</Release_Unused_Codec_4_><DTMF_Process_AVT_4_ group="Ext_4/Audio_Configuration">Yes</DTMF_Process_AVT_4_><Silence_Supp_Enable_4_ group="Ext_4/Audio_Configuration">No</Silence_Supp_Enable_4_><DTMF_Tx_Method_4_ group="Ext_4/Audio_Configuration">Auto</DTMF_Tx_Method_4_><DTMF_Tx_Volume_for_AVT_Packet_4_ group="Ext_4/Audio_Configuration">0</DTMF_Tx_Volume_for_AVT_Packet_4_><DTMF_AVT_Packet_Interval_4_ group="Ext_4/Audio_Configuration">0</DTMF_AVT_Packet_Interval_4_><Use_Remote_Pref_Codec_4_ group="Ext_4/Audio_Configuration">No</Use_Remote_Pref_Codec_4_><Codec_Negotiation_4_ group="Ext_4/Audio_Configuration">Default</Codec_Negotiation_4_><Rx_Payload_In_18x_Media_Session_4_ group="Ext_4/Audio_Configuration">Use Local SDP</Rx_Payload_In_18x_Media_Session_4_><Dial_Plan_4_ group="Ext_4/Dial_Plan">(*45xxxx*xxxxx|*x.|**xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_4_><Caller_ID_Map_4_ group="Ext_4/Dial_Plan"/><Enable_IP_Dialing_4_ group="Ext_4/Dial_Plan">Yes</Enable_IP_Dialing_4_><Emergency_Number_4_ group="Ext_4/Dial_Plan"/><Cfwd_Setting group="User/Call_Forward">Yes</Cfwd_Setting><Cfwd_All_Dest group="User/Call_Forward"/><Cfwd_Busy_Dest group="User/Call_Forward"/><Cfwd_No_Ans_Dest group="User/Call_Forward"/><Cfwd_No_Ans_Delay group="User/Call_Forward">20</Cfwd_No_Ans_Delay><Speed_Dial_2 group="User/Speed_Dial"/><Speed_Dial_3 group="User/Speed_Dial"/><Speed_Dial_4 group="User/Speed_Dial"/><Speed_Dial_5 group="User/Speed_Dial"/><Speed_Dial_6 group="User/Speed_Dial"/><Speed_Dial_7 group="User/Speed_Dial"/><Speed_Dial_8 group="User/Speed_Dial"/><Speed_Dial_9 group="User/Speed_Dial"/><CW_Setting group="User/Supplementary_Services">Yes</CW_Setting><Block_CID_Setting group="User/Supplementary_Services">No</Block_CID_Setting><Block_ANC_Setting group="User/Supplementary_Services">No</Block_ANC_Setting><DND_Setting group="User/Supplementary_Services">No</DND_Setting><Secure_Call_Setting group="User/Supplementary_Services">Yes</Secure_Call_Setting><Dial_Assistance group="User/Supplementary_Services">No</Dial_Assistance><Auto_Answer_Page group="User/Supplementary_Services">Yes</Auto_Answer_Page><Preferred_Audio_Device group="User/Supplementary_Services">Speaker</Preferred_Audio_Device><Send_Audio_To_Speaker group="User/Supplementary_Services">No</Send_Audio_To_Speaker><Time_Format group="User/Supplementary_Services">12hr</Time_Format><Date_Format group="User/Supplementary_Services">month/day</Date_Format><Miss_Call_Shortcut group="User/Supplementary_Services">Yes</Miss_Call_Shortcut><Miss_Call_Banner group="User/Supplementary_Services">Yes</Miss_Call_Banner><Accept_Media_Loopback_Request group="User/Supplementary_Services">automatic</Accept_Media_Loopback_Request><Media_Loopback_Mode group="User/Supplementary_Services">source</Media_Loopback_Mode><Media_Loopback_Type group="User/Supplementary_Services">media</Media_Loopback_Type><Text_Message group="User/Supplementary_Services">Yes</Text_Message><Text_Message_From_3rd_Party group="User/Supplementary_Services">No</Text_Message_From_3rd_Party><Alert_Tone_Off group="User/Supplementary_Services">No</Alert_Tone_Off><Log_Missed_Calls_for_EXT_1 group="User/Supplementary_Services">Yes</Log_Missed_Calls_for_EXT_1><Log_Missed_Calls_for_EXT_2 group="User/Supplementary_Services">Yes</Log_Missed_Calls_for_EXT_2><Log_Missed_Calls_for_EXT_3 group="User/Supplementary_Services">Yes</Log_Missed_Calls_for_EXT_3><Log_Missed_Calls_for_EXT_4 group="User/Supplementary_Services">Yes</Log_Missed_Calls_for_EXT_4><Shared_Line_DND_Cfwd_Enable group="User/Supplementary_Services">Yes</Shared_Line_DND_Cfwd_Enable><Ringer_Volume group="User/Audio">8</Ringer_Volume><Speaker_Volume group="User/Audio">8</Speaker_Volume><Handset_Volume group="User/Audio">10</Handset_Volume><Headset_Volume group="User/Audio">10</Headset_Volume><Handset_Version group="User/Audio">Auto</Handset_Version><Deep_Bass group="User/Audio">Default</Deep_Bass><Speakerphone_Enable group="User/Audio">Yes</Speakerphone_Enable><Mute_Enable group="User/Audio">Yes</Mute_Enable><LCD_Contrast group="User/LCD">8</LCD_Contrast><Back_Light_Timer group="User/LCD">10 s</Back_Light_Timer><Subscribe_Expires group="Attendant_Console/General">1800</Subscribe_Expires><Subscribe_Retry_Interval group="Attendant_Console/General">30</Subscribe_Retry_Interval><Unit_1_Enable group="Attendant_Console/General">Yes</Unit_1_Enable><Subscribe_Delay group="Attendant_Console/General">1</Subscribe_Delay><Unit_2_Enable group="Attendant_Console/General">Yes</Unit_2_Enable><Server_Type group="Attendant_Console/General">Asterisk</Server_Type><Test_Mode_Enable group="Attendant_Console/General">No</Test_Mode_Enable><Attendant_Console_Call_Pickup_Code group="Attendant_Console/General">**#</Attendant_Console_Call_Pickup_Code><Attendant_Console_Call_Park_Code group="Attendant_Console/General">*68</Attendant_Console_Call_Park_Code><Attendant_Console_Call_unPark_Code group="Attendant_Console/General">*88</Attendant_Console_Call_unPark_Code><BLF_List_URI group="Attendant_Console/General"/><Use_Line_Keys_For_BLF_List group="Attendant_Console/General">No</Use_Line_Keys_For_BLF_List><Call_Pickup_Audio_Notification group="Attendant_Console/General">No</Call_Pickup_Audio_Notification><Attendant_Console_Font_Size group="Attendant_Console/General">10</Attendant_Console_Font_Size><Attendant_Console_LCD_Contrast group="Attendant_Console/General">7</Attendant_Console_LCD_Contrast><BXfer_To_Starcode_Enable group="Attendant_Console/General">No</BXfer_To_Starcode_Enable><BXfer_On_Speed_Dial_Enable group="Attendant_Console/General">Yes</BXfer_On_Speed_Dial_Enable><BLF_Label_Display_Mode group="Attendant_Console/General">Name</BLF_Label_Display_Mode><Application_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><Serv_Subscribe_Failed_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><Serv_Subscribing_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><SNRM_Day_Mode_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><SNRM_Night_Mode_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><Parking_Lot_Idle_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><Parking_Lot_Busy_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><BLF_Idle_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><BLF_Ringing_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><BLF_Busy_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><BLF_Held_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/><Unit_1_Key_1 group="Attendant_Console/Unit_1"/><Unit_1_Key_2 group="Attendant_Console/Unit_1"/><Unit_1_Key_3 group="Attendant_Console/Unit_1"/><Unit_1_Key_4 group="Attendant_Console/Unit_1"/><Unit_1_Key_5 group="Attendant_Console/Unit_1"/><Unit_1_Key_6 group="Attendant_Console/Unit_1"/><Unit_1_Key_7 group="Attendant_Console/Unit_1"/><Unit_1_Key_8 group="Attendant_Console/Unit_1"/><Unit_1_Key_9 group="Attendant_Console/Unit_1"/><Unit_1_Key_10 group="Attendant_Console/Unit_1"/><Unit_1_Key_11 group="Attendant_Console/Unit_1"/><Unit_1_Key_12 group="Attendant_Console/Unit_1"/><Unit_1_Key_13 group="Attendant_Console/Unit_1"/><Unit_1_Key_14 group="Attendant_Console/Unit_1"/><Unit_1_Key_15 group="Attendant_Console/Unit_1"/><Unit_1_Key_16 group="Attendant_Console/Unit_1"/><Unit_1_Key_17 group="Attendant_Console/Unit_1"/><Unit_1_Key_18 group="Attendant_Console/Unit_1"/><Unit_1_Key_19 group="Attendant_Console/Unit_1"/><Unit_1_Key_20 group="Attendant_Console/Unit_1"/><Unit_1_Key_21 group="Attendant_Console/Unit_1"/><Unit_1_Key_22 group="Attendant_Console/Unit_1"/><Unit_1_Key_23 group="Attendant_Console/Unit_1"/><Unit_1_Key_24 group="Attendant_Console/Unit_1"/><Unit_1_Key_25 group="Attendant_Console/Unit_1"/><Unit_1_Key_26 group="Attendant_Console/Unit_1"/><Unit_1_Key_27 group="Attendant_Console/Unit_1"/><Unit_1_Key_28 group="Attendant_Console/Unit_1"/><Unit_1_Key_29 group="Attendant_Console/Unit_1"/><Unit_1_Key_30 group="Attendant_Console/Unit_1"/><Unit_1_Key_31 group="Attendant_Console/Unit_1"/><Unit_1_Key_32 group="Attendant_Console/Unit_1"/><Unit_2_Key_1 group="Attendant_Console/Unit_2"/><Unit_2_Key_2 group="Attendant_Console/Unit_2"/><Unit_2_Key_3 group="Attendant_Console/Unit_2"/><Unit_2_Key_4 group="Attendant_Console/Unit_2"/><Unit_2_Key_5 group="Attendant_Console/Unit_2"/><Unit_2_Key_6 group="Attendant_Console/Unit_2"/><Unit_2_Key_7 group="Attendant_Console/Unit_2"/><Unit_2_Key_8 group="Attendant_Console/Unit_2"/><Unit_2_Key_9 group="Attendant_Console/Unit_2"/><Unit_2_Key_10 group="Attendant_Console/Unit_2"/><Unit_2_Key_11 group="Attendant_Console/Unit_2"/><Unit_2_Key_12 group="Attendant_Console/Unit_2"/><Unit_2_Key_13 group="Attendant_Console/Unit_2"/><Unit_2_Key_14 group="Attendant_Console/Unit_2"/><Unit_2_Key_15 group="Attendant_Console/Unit_2"/><Unit_2_Key_16 group="Attendant_Console/Unit_2"/><Unit_2_Key_17 group="Attendant_Console/Unit_2"/><Unit_2_Key_18 group="Attendant_Console/Unit_2"/><Unit_2_Key_19 group="Attendant_Console/Unit_2"/><Unit_2_Key_20 group="Attendant_Console/Unit_2"/><Unit_2_Key_21 group="Attendant_Console/Unit_2"/><Unit_2_Key_22 group="Attendant_Console/Unit_2"/><Unit_2_Key_23 group="Attendant_Console/Unit_2"/><Unit_2_Key_24 group="Attendant_Console/Unit_2"/><Unit_2_Key_25 group="Attendant_Console/Unit_2"/><Unit_2_Key_26 group="Attendant_Console/Unit_2"/><Unit_2_Key_27 group="Attendant_Console/Unit_2"/><Unit_2_Key_28 group="Attendant_Console/Unit_2"/><Unit_2_Key_29 group="Attendant_Console/Unit_2"/><Unit_2_Key_30 group="Attendant_Console/Unit_2"/><Unit_2_Key_31 group="Attendant_Console/Unit_2"/><Unit_2_Key_32 group="Attendant_Console/Unit_2"/></flat-profile>
06-11-2018 02:07 AM - edited 06-11-2018 02:10 AM
Please consider the edit of previous comment - remove configuration from text and attach it as file/attachment (it needs to have .txt extension, so I recommend you to name it <something>.xml.txt). It will make thread more readable. Thanks.
OK. So, your phone still locks, while our works like a charm. So try downgrade a phone to 7.5.5 firmware, the same we are using, and test. It will or will not help with the issue, but in both cases it will help us with analysis.
This post contain information related to other's site thus it may contain information considered Sensitive or Confidential. |
