SPA504G - InitializingNetwork
My SPA504G is not startign after i made some changes to the network setup (from DHCP to STATIC).
It just shows InitializingNetwork in the screen and gets stuck there.
Is there another way of reseting to factory default other than through the buttons on the phone as pressing any them has no effect at all.
I can loginto the phone but there is no reset button on the webinterface.
Also DHCP works on the PC port of the phone when i connect a laptop to it, it gets an address from my server.
Any ideas - or is the phone toast.
paolo bevilacqua
Wrong forum, try "small business - phones". You can move the post using the control panel on the right.
