04-11-2011 06:36 AM - edited 03-21-2019 03:55 AM
Hi There,
I have a UC540, with SP508G phones.
I have 3 times now had the following problem.
1. You receive voicemail
2. You listen to Voicemail
4. you delete Voicemail
5. Red light on phone and Flashing envelope icon show that you have new voice mail.
6. you login to mail box and no voicemail.
The only way I have found to clear this is to delete the user and mailbox, and recreate, but this is not ideal.
Any one know how to fix it?
Cheers
Graeme
Solved! Go to Solution.
04-11-2011 02:46 PM
Hi Graeme,
This from memory is a MWI (Message Waiting Indicator) issue and sometimes debugging is required to resolve the problem, or turning it on and off again flushes it out.
Basically what is happening is the MWI is not refreshing itself properly and thus keeps telling you that there is a VM waiting, usually another deposit can trigger the refresh event or as mentioned before turning it on and off in CCA can do this.
If it happens again I strongly suggest you contact SBS log case in on it, if enough people report a particular problem then a consensus is formed for it being a bug and I would assume resources are allocated in getting it resolved.
Cheers,
David.
04-11-2011 09:18 AM
Ok It would appear that if you then recevie another voicemail.
access it and delete it the light goes off.
need to remember that for future when it happens again.
Graeme
04-11-2011 02:46 PM
Hi Graeme,
Cheers,
David.
04-12-2011 12:50 AM
Thanks for the information
If it happens again I will log a call.
Graeme
