01-08-2010 12:46 PM - edited 03-21-2019 02:00 AM
Is this possible if so how?
01-08-2010 01:50 PM
Hi camronjohnson,
The Configuring Cisco SPA500S Attendant Console document describes both the manual and zero-touch configuration steps: https://www.myciscocommunity.com/docs/DOC-11522
The document is targeted at Asterisk as call-control, but the BLF information on pages 8 and 9 are relevant.
Patrick
01-08-2010 01:53 PM
Is there a way to do this without the use of the SPA500S Attendant Console and Use only the phone itself?
01-10-2010 06:09 AM
Hi camronjohnson,
Sorry, I thought you had a typo and meant to type "On SPA500S", turns out you really meant "No SPA500S"
Yes, unused line keys on SPA5xx IP phones support Broadsoft BLF. This is documented in the SPA5xx Admin Guide:
http://tools.cisco.com/search/display?url=http%3A%2F%2Fwww.cisco.com%2Fen%2FUS%2Fdocs%2Fvoice_ip_comm%2Fcsbpipp%2Fip_phones%2Fadministration%2Fguide%2Fspa500_admin.pdf&pos=1&strqueryid=2&websessionid=ehoQWTwEoaQg5MstdKDgz7A
Take a look at page 23, "Assigning Busy Lamp Field, Call Pickup, and Speed Dial Functions to Unused Lines on a Cisco SPA 500 Series IP Phone"
Phone related documents are linked from the Community phone page: https://www.myciscocommunity.com/docs/DOC-2148
Patrick
01-11-2010 06:58 AM
Ok, I have attempted to use that configuration, however I just see a flashing orange led for that line. What issues are usually associated with this type of error?
02-23-2010 06:30 AM
Hi camronjohnson,
What call-control and version are you using, Asterisk, Broadsoft, something else?
BLF functionality must be enabled on the server so that it sends SIP NOTIFY to the phone/s monitoring status.
Patrick
02-23-2010 06:54 AM
I believe I am using Broadsoft version 14. The BLF feature is enabled.
02-26-2010 06:06 PM
I wrote this document, hopefully it'll be of use to help you solve the BLF problem:
https://www.myciscocommunity.com/docs/DOC-15065
Patrick
03-01-2010 02:49 PM
This appears to have fixed the issue, after I managed to get the correct sub and user domain combination from the sip log messages. I am still attempting to acquire a SPA500S to get the automatic configuration update.
12-07-2010 08:56 AM
Did you ever get the Automatic configuration for the BLFs to work?
12-07-2010 09:26 AM
No, it was all still a manual configuration. We never ordered a SPA500S to test with and ultimately we went in a different equipment direction. Since it was all still a manual process any way.
03-22-2019 04:16 AM
I don't know much about Broadsoft, have you specified option 66 in your DHCP settings?
