I've had a problem with my spa112 ever since I moved to vdsl.Calls Are ended After 35 seconds.sometimes l cant dial and get call.Any help?
I am needing to configure the FXO ports on a UC 520 to accept 2 numbers instead of just 1, is this possible?
Using a UC520 as DHCP server. We have about 50 wired and wireless clients. Problem started to occur that certain clients couldn't get IP. I'd reset the IP binding, and all would be good again for a few days and the same thing would start happening...
I am having an issue with getting an SPA525g2 to connect from a remote location back to the UC540 and register. I went through the process on CCA where I had the phone connected locally to the UC540 and it worked fine. I ran the Remote Phone wizard...
is it possible to configure skype account on SPA504G? I have checked out manyforums and websites but can't seem to get this to work.Thanks
Hi There,I was wondering if it was possible to have vlan tagging turned off for voice but turned on for the PC? I can't seem to get it to work that way. It looks like if I want to tag PC traffic I have to tag voice traffic as well. I don't want to ha...
does any one have full setting and configuration for SPA400 Setting with the screen shot. Note my call drops every 1 min and I have to reboot the SPA400 in order to make new call. also note I need configuration for IRAN
Good afternoon.Series phones have SPA50x standard connector 2.5 stereo headset. I have a headset Jabra PRO 920 and huchu connected through the standard connector to the phone.But for this you need an adapter Jack 2,5 -> RJ12. One such adapter I made ...
Hi there,I am wondering if there is any way we can add mac address of SPA Phone into its syslog sent to server? Thanks.
UC560 with PRISPA509G phone just stopped working one day. No dial tone, appears to be online and registered. Tried a brand new phone with no luck. Updated phone firmware to 7.5.6a with no change. I checked several areas with no luck. Deleted use...
I have a UC560 running Unity Express 8.0.3 that is having voicemail issues. After a CUE reload, if a call goes to voicemail the caller gets a message saying "your recording is too short, record a longer message"; at this moment, an error shows up in ...
hi, all I have purchase two SPA525G2 phones. both are on the last firmware.I setup SIP info and both phones are working.I don't have a UNIFIED device and not planning to purchase one. the question is how can I setup both phones (more than one, in cas...
Hello, How are you? I am Matt.Since this morning my PAP2T is in SOS mod! His version is 5.1.6 LSI was looking for any recovery tool for this version but i just find for the 5.1.5 version.Is it possible to help me to fix the problem please? or do you ...
Good day!We have phones Cisco spa303.I downloaded and installed the new firmware on one phone.For this I used code in the provisioning file: <Dictionary_Server_Script ua="">serv=tftp://x.x.x.x/; d0=English; x0=303/spa50x_30x_ru_v756.xml; d1=Russian;...
I have forgotten my password to my voicemail. How do I reset this?
