SPA525G registering on CME 2901
Mohd SaberUddin
Hi all,
I want to register SPA525G on CME 2901. can anyone tell how to configure it.
thanks
johschaf
Level 4
Level 4
What version of CME are you running? I don't see any SPAs as being supported on the CME compatibility matrix.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html
You can check to see if you even have the type command for the phone under the ephone. The command would be
ephone XXX
type 525G or 525G2 depending on the model of 525 you have
-john
Hi John,
Thanks for your respose.
I found the solution for registering SPA525g models on CME. Below is the link please go through it and  it might help other people also.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps4625/spa_polycom_application.pdf
Mohammed SaberUddin
