02-18-2011 06:56 PM - edited 03-21-2019 03:42 AM
We had to default a UC560 and now the remote spa525g phones will not register. The VPN connects but it is unable to register the set. We have the latest software on both the UC560 and set load. I tried selecting TFTP on the set but there now is nowhere to enter an IP address. Any ideas?
-Terry
Solved! Go to Solution.
02-21-2011 10:24 AM
Hi Terry;
Have you tried to access the web UI interface? My suggestion would be (1) perform factory reset, (2) set the phone to SPCP call control mode, (3) Set:
That should make the trick and phone should get configuration. Note phone (with its MAC address) should be configured at UC500 first.
Alberto
02-21-2011 10:24 AM
Hi Terry;
Alberto
02-21-2011 03:25 PM
Alberto,
Thanks. I didn't realize it defaulted to SIP. There is actually two places you have to enter the vpn setup on the UC500. Once that was done it came up right away. TFTP must also be set.
-Terry
