03-10-2011 09:06 AM - modifié 03-21-2019 03:46 AM
my spa9000 (Product Name: SPA9000 / Serial Number: FM700F202726 / Software Version: 6.1.5) is too hot everyday and sometimes the AA cannot anwser the call, during calls (dial out) the voice is only one way...
What we need to do? Move our office to 'North Pole'?
There is a way to monitor temperature like SNMP management??
tks,
Renato P
le 03-10-2011 11:32 AM
Renato,
That device should not be getting that hot. I would contact your support center and open up a case so they can troubleshoot with you.
le 03-10-2011 11:55 AM
Ok David,
what information do you need to move forward?
*tks for quick reply
Renato P
le 03-10-2011 12:13 PM
David,
can you help me, informing the correct power supply adapter (specs) for that device?
Now we are using an 'AD 5v/2F - PSM11R-500' model wich offer as the out '+5v/2A +)-'; I think that it´s the problem since it is the same adapter for SPA phones and after search on internet I found 12v adapter (http://www.amazon.co.uk/Linksys-SPA9000-replacement-supply-adaptor/dp/B002G273ZK)...
I was wrong?
tks,
Renato P.
le 03-10-2011 02:11 PM
Renato,
The spa9000 uses 5v as the power adapter.
le 03-11-2011 08:28 AM
David,
sorry but I dont understand your first post, do you wanna contact me?
le 03-11-2011 08:30 AM
tks for the information (power adapter specs)...
Renato P.
le 03-17-2011 12:54 PM
Mr. Pereira,
That is the spec's on the spa9000's power adapter.
If your using anything higher than 5v then it could be overheating the device.
I was stating in my earlier post that if your still having issues with the device to contact your local support center for troubleshooting on the device.
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
