SPA962 hang on boot / reset
p.bettinelli
after a change of setting (an extension in theSPA932 consolle) the phone don't reboot correctly (  the display blink, all the lights are turn on and is unreachable from the network).... i have remove the SPA932, use an external power supply... but no luck...
there is something to do?
Thnaks
nseto
Level 6
Level 6
Are you able to factory reset the phone from the phone menu?
Hi NSeto,
I have the same problem. I'm not able to enter the menu. The Phone is like a pulsar with the screen and the top 4 led's.
Is there a standard key combination to set factory defaults during power up?
Thx,
Carlo
