SR520-T1 support Frame Relay?
Daniel Hoffman
Can the SR520-T1 be used to connect to a frame relay network? Our carrier uses frame relay encap on its data T1 service.
Maulik Shah
Level 5
Level 5
This is not supported currently - please email me directly on the opportunity.
We just purchased a Cisco SR520-T1 and we discovered that our ISP (in this case it is Verizon) currently only supports Frame Relay as the Data Link Encapsulation for one of our remote locations.
Is there anything we can do? Or should we return the router? If we return the router, is there a comparable Cisco router that will support Frame Relay that we should be looking into?
Thank you in advance,
-Mike
Kevin Truex
I beg to differ, I have 10 locations that have Verizon FR circuits in place. Configed like any other FR encap circuit. No problems at all.
