Is there any plan to support SCC Advanced Client on Mac and on XenApp or VDI?
I have set up 1 phone number out of 8 to go to a specific extension. I want to be able to present that one number (when it is dialed directly or dialed from) to present itself to the receivers caller ID. All other numbers show up as the "main" number...
Seen few discussions here but still stuck on Cisco logoI've tried to press speaker buttons (several times) as soon as the cisco loge comes up but nothing.Last thing I did to the phone was changing the DST configuration. After reboot, stuck on cisco ...
Hi, we have a problem with some SPA525G2 and SPA502 registered to a Alcatel's Softswitch. The problem is that this phones can only make 3-Way conferences and we need them to be able to make N-party conferences. They are using SIP. Is there something ...
When an outside call is received on the UC320W and that same call is transferred to another outside number via an outbound trunk even after the call completes the outside trunks freeze and no one is able to use them until they are disconnected and re...
Can we use version cmterm-7921-sccp.1-4-1SR1 of 7921 on UC560 v8.1
Hello!We have ip phones cisco spa508g. We configured it and locked web-interface configuring. But how we can entirely block any configuration from physical device? So no one exept administrator through conf-file can change it. Can u help us?
SPA 9000 - Is it possible to use only the FXS lines (a la SPA2102) ? At this moment I have not received the 9x2 series phones I ordered, but am trying to set up the SPA9000.
We have been using a provisioning server to configure our population of SPA3102 ATAs. We have set up an XML file on the server based on examples provided by Cisco. This works perfectly for everything we have needed to set up so far. However we would ...
Hello,I would like to know if anyone has successfully configured a Cisco IP Conference Station Model 7937 to work with Spa9000. If you have any information about this can you please let me know.
Hi ThereI have a SPA9000 (and SPA400 but lets leave that aside for now), with two SPA922 handsets; and a analogue phone on Port 1 of the device.I bought this to be able to set these up to call between themselves. No plans to hook up to a VOIP provid...
Hello everyone,I have configured an SIP trunk - I have several DID #'s that I have configured under inbound calls.When the DID is called it will NOT route to the extension selected instead the call is routed to the default route.Attached is the scree...
I am trying to set up my attendant console (spa500) for my spa525g. We use intermedia.net as our hosted pbx and they are not willing to help on this issue. I have tried and tried to set it up and i keep getting the same errors. See attachments for se...
Hi,I am just learning the in's and out's of Voice World, and have a basic question about the UC320W. The design I am looking at is basic internet connectivity with a DSL line, and 5 analog lines w/one being a Fax line. If I want to use SPA303 phones,...
Hi, I have a very strange auto attendant issue. UC540, version 8.1.I have main number 100, if no one answers, that goes to auto attendant 198. The 198 autoattendant will be able to do "press 1 for dial by extension, press 2 for dial by name, press ...
