Telephony System Message
Chris Gabel
Hi all
A simple question, is it possible to remove the system message displayed on the ip phone spa525g2, so it won't block my background? I am using CCA 3.1.
I have tried removing all the text, but it reverts back to the Cisco default.
I have tried using only a "." and it works but the blue text box still covers my background.
Thanks and Regards,
Chris
acampbell
Chris,
You must have a value  on the CME/UC500  under the system message.
You cannot use NULL
If you do not overwrite the default Cisco words are used.
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Alex,
Thanks, but my original post already goes over that.
I'm looking for a way to completely remove the blue text bar, maybe in some kind of template.
ASAIK, there is no way. You can also try asking in "small business - UC500".
