05-17-2012 10:14 AM - edited 03-21-2019 05:48 AM
Hello
anyone can help me. I'm trying to configure a UC540 AutoAttendant (The CUE), and configure the extension, both AutoAttendan and Promt Manager.
Digit extension Promt as Administrator enters the recording asking me the extension number is the digit and I do not accept or take what digit, the recording tells me that if Siguo there and ask me again etxension to manage the recording the AutoAttendant.
Solved! Go to Solution.
05-17-2012 10:46 AM
Google translation English is a bit difficult to understand, however you're most likely missing dtmf-relay sip-notify under CUE dial-peers.
05-17-2012 10:46 AM
05-17-2012 11:10 AM
That is Correct Paolo
Just not the dtmf-relay sip-notify is dtmf-relay rtp the-nte, but I found it thanks to your support.
Thank you very much.
05-17-2012 11:25 AM
Thanks for the nice rating and good luck!
