Transfer to voice mail
susan.gurney
Can a user transfer a caller directly into a voice mailbox as versus the extension?
Hi Susan,
Yes, you can.  Simply transfer the call to the user's direct voicemail extension.  Typically it is 7+ extension.  You can find the steering digit setting on the Internal Dialing page of the UC320W Configuration Utility (called Voicemail Prefix).
Hope this helps.
Chris
Hi Susan,
Hope this helps.
Chris
Thank you Chris.
That was exactly what I needed.
