01-04-2012 03:33 AM - edited 03-21-2019 05:08 AM
Hello.
How many Personal Address Book entries are supported on UC 540?
On CCME, it seems that the Corporate Directory allows 250 entries and the Personal Directory allows only 99 entries.
01-04-2012 04:59 AM
Correct, in any case, when using and Active Directory system, you have no limits to the number of directory entries.
You can then interface it using my module at www.ciscoscripts.com
02-26-2014 11:18 PM
Hello Paolo,
I'm also hunting information on max number of entries but for CUCM 8.6!
Do you know what is the limitation? How many entries can be stored maximum?
Thanks in advance!
Tibor
