10-29-2010 01:46 PM - edited 03-21-2019 03:12 AM
I just installed my first UC 560 system on two PRI lines from Telepacific. My client wants to block outbound Caller ID. They would like those they call to get "Unknown Caller" or similar when they call out. I am using CCA 2.2.5 to configure the UC 560. Telepacific is blocking the Caller ID but says the UC 560 is overriding the block.
So, how do I prevent the UC 560 from sending out Caller ID information automatically? Is this possible in CCA?
Solved! Go to Solution.
10-29-2010 02:34 PM
Can't do this though CCA...
CLI:
Conf t
dial-peer voice xxx pots <--- xxx = dial-peer number.
clid strip
clid strip name
You will need to do this on all of your outgoing PRI dial-peers.
10-29-2010 02:34 PM
CLI:
Conf t
clid strip
clid strip name
