UC320 Remote Phone
Paul Norris
Beginner
Beginner
Just wondered if two cisco router with a classic VPN tunnel would work for remote phones on the UC320. I have heard that because of the UC320's provisioning of the handsets their needs to be a way of turning off things like the wifi settings or an SPA525g2 will try to connect to a local SSID when the handset is remote.
Any thoughts ?
Paul Norris
Christopher Edgeworth
Frequent Contributor
Hi Paul,
The UC320W doesn't support remote phones and I'm afraid one can not simply set up a VPN and expect them to work remotely.  Part of this is due to some internal messaging using IP multicast.  If the customer requires remote phones, then the UC500 series is a better feature fit.
Hope this helps.
Chris
