01-24-2013
01:06 PM
- last edited on
03-25-2019
11:04 PM
by
ciscomoderator
I have a UC320W setup with no auto-attendant, and 5 phones that share two FXO lines for inbound and outbound. It seems that if you answer from any phone on either line during the second ring, the call drops. If you answer between rings, after the first or after the second, it answers fine. Has anyone seen this issue before?
thanks,
Marc
01-24-2013 01:51 PM
Oh yes I have. Please let me save you around 2 weeks of support calls and config changes. In my case it was both with inbound and outbound dialing. If they are standard fxo lines I would say you have two issues going on.
1. Line impedance issues( you can fix this directly from the uc320 but you needs to run test line by line. Each line and carrier has a different impedance match.
Them after you did this see if the issues is fixed.
If not your tip and ring might be backwards. I know with other systems This does not matter but with all uc320 and 500s it does. You might be able to fix this, but I all depends our your technical skills.
I hope that helps.
01-24-2013 01:54 PM
Hi Marc,
Could you please collect FXO syslog at Status-> Support Tools in Configure Utility when the call is dropped? Please send it to me at wenyang@cisco.com.
Best regards,
Wendy Yang
01-31-2013 09:22 AM
So how do i test this on the lines?
01-31-2013 09:55 AM
Hi Marc,
If making an inbound FXO call and the call is dropped, the syslog will be displayed at Status-> Support Tools in Configure Utility. Please copy the syslog in the email and send it to me at wenyang@cisco.com.
I believe that you hit to a bug, just would like to confirm from the syslog. If it is, I will send you an PMF to fix it.
Best regards,
Wendy
01-31-2013 08:10 PM
Yes getting the syslog will help. But my bet is on the tip and ring reversal. I know you can't test for it but I have seen this same thing before on the uc320 and since the fxo is then converted to a sip connection strange things happen.
02-01-2013 09:18 AM
sosmallbusinesstech, should I literally reverse the wires in the pair on the BIX? THat's how it's connected. I have it from a BIX using a single CAT5e pair and then terminates with a RJ11 connector into the UC320
02-01-2013 09:23 AM
Ho Marc,
You have hit to a bug and I have sent you the PMF to resolve it.
Best regards,
Wendy
11-29-2013 01:24 PM
Excuse me - as you will see in a post I made earlier, I also have this problem. Please may I have a copy of the PMF also?
Thanks in anticipation.
Kind regards
Leslie
03-31-2014 07:03 PM
06-16-2016 01:04 PM
This started happening to me about a year ago and until recently calls went to voicemail. Cisco's response under my service contract was to reboot. Have done that regularly, but now all calls are dropping and not even going to voicemail. Rebooting no loonger helps, and since support ended and I couldn't renew my agreement I'm up the creek without a paddle right now. Was this issue ever solved?
I'd attach syslof, but can't see how to save it for posting. Any help would be appreciated.
