I have a UC540W with a Time Warner PRI. When I call someone outside the office the caller ID shows up as the first number in my DID block. Is it possible to be changed so it display my company name?
Hi everyone We're trying to set up a remote colleague's Cisco handset (SPA504G), which is behind a Cisco Firewall (ASA 5500) using NAT, to talk to an Asterisk server. The Asterisk server is on a public IP.We have a number of similar Cisco handsets wo...
Hi I have just added another SPA941 to a deployment of a SPA9K.The phone has registered and provisioned fine and shows up in the PBX status, with link working to get to phone configuration.The issue I am having is that there is no dial tone present o...
So the UC520W doesn't detect the SPA500DS 30 line console at all it seems. It detects the phone, and the side console comes online, however in the UC320W interface it doesn't detect.I logged into the phone, and the UC320W has locked down admin access...
I have bought several SPA508G & SPA509G IP Phones from eBay. But they are password protected when I'm trying to perform the Factory Reset on the phones. I just wonder if anyone could help me on this. Thanks.
Hi,I have an SPA504G firmware 7.4.4.Here are relevant options:I put 'dnd' and 'dir' either side of it to see what happened. The keys took place 3 and 4 so it is like it isnt seeing the button as being defined. I've tried giving it a specific position...
Hi guys.It seems my SPA504G is unable to power on using PoE? Using standard cable which came with the unit. Plugged into an Apple Express router, used a number of routers for that matter. Still nothing. Plugged into my 2013 macbook pro also. Nothing....
Hello,I am trying to find out if anyone has had any luck registering a 7945G via SSL VPN to a UC500? I read that there is no official support on this, but I am curious if anyone had any luck getting it to work via the CLI? As we all know the 7945 has...
Please tell me how to create a generic configuration file for Cisco SPA112 spa112.cfg file that could upload it to any device for SPA112 for preprovisioning? Command spc - xml xxx.xml - target aabbccdd1122 spa112.cfg not true, because the file will o...
CUCC 10.0 (Cisco Unified Configurator for Collaboration) is now available and it willMake BE6000/7000 deployments much fasterHelp configure Dial-Tone, Voicemail and SNR in under 15 minutesHelp Cisco win against competition more often Please watch the...
CUCC 10.0 (Cisco Unified Configurator for Collaboration) is now available and it willMake BE6000/7000 deployments much fasterHelp configure Dial-Tone, Voicemail and SNR in under 15 minutes (best case)Help Cisco win against competition more often Plea...
A client is requried to join a conference call hosted by third-party Genesys Conferencing (866.436.3797). My client accesses the teleconference through the speakerphone of their Cisco SPA525G2, lcoated in a Board Room. They have a UC-540 with the nex...
Why is it no longer possible to combine the starter bundle with migration SKUs in CCW (Cisco Commerce Workspace) configuration tool?Since the top-level part code R-CBE6K-K9 was updated to include the version 10.x options, it has not been possible to ...
We would like to add a new DB Profile.When we send the command: ccn subsystem edbs dbprofile dbprofilename Operation not allowed with current installed license How can we do this, since its not officially supported as mentioned by Cisco phone support...
