UC320W drops incoming FXO calls randomly and reboots all phones
tech000019
I purchased a UC320W in January of this year and set it up here in the UK, with one FXO line and two SIP trunks from Sipgate.  It had v2.3.2 installed.
On testing the initial configuration, I experienced problems with the system randomly disconnecting incoming calls and rebooting.  I didn’t have time to undertake a detailed examination at the time, so I downgraded to the previous version of the firmware (2.2.2 (1)) and found the system to be extremely stable since.
Recently, I purchased a pair of SPA514G phones to add to the system, forcing me to upgrade to 2.3.2 (6) again.  The problems have reoccurred – some incoming calls disconnecting and then causing the system to reboot.
I did a lot of investigation online and have found other users reporting the same problem, but couldn’t find any conclusive resolution.
I then did a detailed investigation on the UC320W and while I couldn’t see any consistency on incoming call behaviour, I managed to establish a consistent pattern around call DISCONNECTIONS.  Whether the FXO call had been received or initiated didn’t make any difference to the results.
I found that when a call was disconnected from the UC320W side, it caused the system to reboot EVERY TIME.  If the remote end disconnected the call however, then the system NEVER rebooted.
This led me to do an impedance test, which suggested changing the Impedance Value and the Line Type from “EIA 0” to “2000 ft 22 awg”.  The results were the same, but I found that if I changed the Impedance Value to the one suggested and left the Line Type as “EIA 0”, the system performed very stably (perhaps 20-30 tests) with no rebooting on disconnection from either side.
Back to incoming calls however, I am still experiencing random disconnections and system reboots.
I’ve included a syslog extract of the most recent one.
Nov 29 19:38:38 UC320W user.debug voice: TP Parser error: 34
Nov 29 19:38:41 UC320W user.debug voice: TP Parser error: 34
Nov 29 19:38:47 UC320W user.debug voice: [9]RegOK. NextReg in 118 (1)
Nov 29 19:38:48 UC320W syslog.info -- MARK --
Nov 29 19:38:52 UC320W user.debug voice: TP Parser error: 34
Nov 29 19:38:56 UC320W user.debug voice: TP Parser error: 34
Nov 29 19:39:06 UC320W user.debug voice: received discard:58817235, 20000 from:101010a:6061
Nov 29 19:39:06 UC320W user.debug voice: TP Parser error: 34
Nov 29 19:39:07 UC320W user.debug voice: [5]RegOK. NextReg in 594 (1)
Nov 29 19:39:07 UC320W user.debug voice: [6]RegOK. NextReg in 594 (1)
Nov 29 19:39:11 UC320W user.debug voice: TP Parser error: 34
Nov 29 19:39:12 UC320W user.debug voice: POL REV 51 -50
Nov 29 19:39:12 UC320W user.debug voice: FXO[1]:OnHook PolRev
Nov 29 19:39:12 UC320W user.debug voice: fskd_reset: decoding caller id in bellcore format
Nov 29 19:39:12 UC320W user.debug voice: FXO[1]:Start CNDD
Nov 29 19:39:12 UC320W user.debug voice: FXO[1]:Ring start
Nov 29 19:39:12 UC320W user.debug voice: FXO[1]:Report:sesssion=0;cst=0
Nov 29 19:39:14 UC320W user.debug voice: pconly: 0
Nov 29 19:39:14 UC320W user.debug voice: n: 4
Nov 29 19:39:14 UC320W user.debug voice: clRemote: (nil), clLocal->ucNumAudioCodec: 4
Nov 29 19:39:14 UC320W user.debug voice: Calling:fxo1@10.1.1.1:6060, rc=0
Nov 29 19:39:14 UC320W user.debug voice: [1:0]AUD ALLOC CALL (port=16424)
Nov 29 19:39:14 UC320W user.debug voice: [1:0]RTP Rx Up
Nov 29 19:39:14 UC320W user.debug voice: AUD[1]:Stop PSTN Tone
Nov 29 19:39:14 UC320W user.debug voice: SIP msg from private user
Nov 29 19:39:14 UC320W user.debug voice: +++++ incoming hash=-1965226010;; 71754d5a-afba8ca1@192.168.10.225
Nov 29 19:39:14 UC320W user.debug voice: SAA_DBG:>>>>CheckAADateTime:0
Nov 29 19:39:14 UC320W user.debug voice: localtime is:2013-11-29, 19:39:14
Nov 29 19:39:14 UC320W user.debug voice: start time is:0-0-0
Nov 29 19:39:14 UC320W user.debug voice: end time is:0-0-0
Nov 29 19:39:14 UC320W user.debug voice: SAA_DBG: AA 3 scipt 0
Nov 29 19:39:14 UC320W user.debug voice: SAA_DBG:holiday cnt = 0
Nov 29 19:39:14 UC320W user.debug voice: today:2013-11-29
Nov 29 19:39:14 UC320W user.debug voice: SAA_DBG: AA 1 scipt 0
Nov 29 19:39:14 UC320W user.debug voice: SAA_DBG:daytime AA
Nov 29 19:39:14 UC320W user.debug voice: #### contact list = !28
dst=!28
Nov 29 19:39:14 UC320W user.debug voice: #### hunt interval=15
Nov 29 19:39:14 UC320W user.debug voice: #### hunt expire=15
Nov 29 19:39:14 UC320W user.debug voice: ++++ signaling events: 56 c4001 41ee8ea8
Nov 29 19:39:14 UC320W user.debug voice: pri--180-->BCC--180-->pub
Nov 29 19:39:14 UC320W user.debug voice: CC:Ringback
Nov 29 19:39:14 UC320W user.debug voice: [1:0]RTP Rx Dn
Nov 29 19:39:14 UC320W user.debug voice: AUD[1]:Play PSTN Tone 9
Nov 29 19:39:20 UC320W user.debug voice: 5[12]No ack to pri yet, waiting for pub ack:cc001
Nov 29 19:39:20 UC320W user.debug voice: ++++ signaling events: 47 c4001 41ee90b0
Nov 29 19:39:20 UC320W user.debug voice: ++++ signaling events: 54 c4001 0
Nov 29 19:39:20 UC320W user.debug voice: [1:0]ENC INIT 0
Nov 29 19:39:20 UC320W user.debug voice: [1:0]RTP Tx Up (pt=0->0101010a:16428)
Nov 29 19:39:20 UC320W user.debug voice: [1:0]RTCP Tx Up
Nov 29 19:39:20 UC320W user.debug voice: CC:Remote Resume
Nov 29 19:39:20 UC320W user.debug voice: AUD[1]:Play PSTN Tone 9
Nov 29 19:39:20 UC320W user.debug voice: CC:Connected
Nov 29 19:39:20 UC320W user.debug voice: [1]AUD_setDigitCollectMode: ddm mode=1
Nov 29 19:39:20 UC320W user.debug voice: AUD[1]:Stop PSTN Tone
Nov 29 19:39:20 UC320W user.debug voice: [1:0]RTP Rx Up
Nov 29 19:39:20 UC320W user.debug voice: FXO[1]:Voip Connected
Nov 29 19:39:20 UC320W user.debug voice: 0: 0x28643c is OffHook: 1
Nov 29 19:39:20 UC320W user.debug voice: FXO[1]:Off Hook
Nov 29 19:39:20 UC320W user.debug voice: FXO[1]:Stop CNDD
Nov 29 19:39:20 UC320W user.debug voice: FXO[1]:Report:sesssion=4274f868;cst=8
Nov 29 19:39:20 UC320W user.debug voice: SIP msg from private user
Nov 29 19:39:20 UC320W user.debug voice: ++++ signaling events: 74 c0503 41ee9568
Nov 29 19:39:20 UC320W user.debug voice: 5[12]Relying pub ack:cc001
Nov 29 19:39:20 UC320W user.debug voice: [1:0]RTP Rx 1st PKT @16424(3)
Nov 29 19:39:20 UC320W user.debug voice: [1:0]DEC INIT 0
Nov 29 19:39:20 UC320W user.debug voice: System going down with reboot reason: S111
Nov 29 19:39:20 UC320W user.warn kernel: Closing phone channel-0
Nov 29 19:39:20 UC320W user.warn kernel: Closing phone channel-1
Nov 29 19:39:20 UC320W user.warn kernel: Closing phone channel-3
Nov 29 19:39:20 UC320W user.warn kernel: Closing phone channel-4
Nov 29 19:39:20 UC320W user.warn kernel: Closing pcm device
Nov 29 19:39:22 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Nov 29 19:39:23 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Nov 29 19:39:23 UC320W user.warn kernel: >>update group 224.168.168.168 cache vif range as 12~13
Nov 29 19:39:30 UC320W user.warn kernel: Opening phone channel-0
Nov 29 19:39:30 UC320W user.warn kernel: PHONE_PLAY_START
Nov 29 19:39:30 UC320W user.warn kernel: PHONE_REC_START
Nov 29 19:39:30 UC320W user.warn kernel: Opening phone channel-1
The key part seems to be the message "System going down with reboot reason: S111"
The system has the following PMFs applied, mainly as a result of addressing various problems.
  • •1.       FXO_Overload_disable  (v1);
  • •2.       Disable Missed Call Banner on all Phones  (v2);
  • •3.       classic-2_ring_tone_fix  (v2);
  • •4.       UK FXO DTMF Gain Adjustment  (v2);
  • •5.       Use Dial Tone for disconnect  (v1);
  • •6.       Caller ID FSK Bellcore  (v4)
Earlier posts have all implied there is a known fix for this issue, but I can’t see it’s ever been published.
Please help!  This is making my life hell!
Kind regards
Leslie
16 Replies 16
Hi Nima,
The SMB TAC Engineer could not extract the logs so at this moment i am upgradeing the firmware and hopefully it fixes my problem, if not i will have to return the unit under the RMA they issued. The system dropped about five times today during FXO calls, thanks again for your assistance and i will see how it goes tomorrow
ftc232356tyui
Hi All, I cant thank Nima enough, the bug fix worked and the system has been stable for several weeks now, the fix has saved me lots of money in travel to remote Australia and even better the customer has a fully operational / stable telephone system.
Thanks again
