02-10-2011 03:45 PM - edited 03-21-2019 03:40 AM
Sorry if this has been posted already or in a release note, I just have not found it yet. I have been looking into an issue with background images not showing up from my test phone with the 8.1 software pak. I see the pictures and xml files in the flash but I see two "TFTP-Server flash:" commands missing for the XML files. When I try to add, it gives the error below. I looked at the deafult config and it list out all 3 files in the TFTP-Server command.
Here is my flash
52 0 Jan 21 2011 23:50:10 Desktops
53 0 Jan 21 2011 23:50:10 Desktops/320x212x12
54 651 Jan 21 2011 23:50:12 Desktops/320x212x12/List.xml
55 0 Jan 21 2011 23:50:12 Desktops/320x212x16
56 651 Jan 21 2011 23:50:12 Desktops/320x212x16/List.xml
57 0 Jan 21 2011 23:50:12 Desktops/320x216x16
58 651 Jan 21 2011 23:50:14 Desktops/320x216x16/List.xml
59 131470 Jan 21 2011 23:50:14 Desktops/CampusNight.png
60 80565 Jan 21 2011 23:50:14 Desktops/CiscoFountain.png
61 8156 Jan 21 2011 23:50:16 Desktops/CiscoLogo.png
62 138278 Jan 21 2011 23:50:16 Desktops/Fountain.png
63 109076 Jan 21 2011 23:50:18 Desktops/MorroRock.png
64 108087 Jan 21 2011 23:50:18 Desktops/NantucketFlowers.png
65 10820 Jan 21 2011 23:50:20 Desktops/TN-CampusNight.png
66 9657 Jan 21 2011 23:50:20 Desktops/TN-CiscoFountain.png
67 2089 Jan 21 2011 23:50:20 Desktops/TN-CiscoLogo.png
68 7953 Jan 21 2011 23:50:20 Desktops/TN-Fountain.png
69 7274 Jan 21 2011 23:50:22 Desktops/TN-MorroRock.png
70 9933 Jan 21 2011 23:50:22 Desktops/TN-NantucketFlowers.png
And here is my TFTP Commands for the xml files
tftp-server flash:Desktops/320x212x16/List.xml
When I try to add the other two commands that are in all my other boxes, I get the error below
SD_Lab(config)#tftp-server flash:Desktops/320x212x16/List.xml
SD_Lab(config)#tftp-server flash:Desktops/320x212x12/List.xml
File with same name already being served
SD_Lab(config)#tftp-server flash:Desktops/320x216x16/List.xml
Did something change?
Solved! Go to Solution.
02-11-2011 08:12 AM
It may just accept the command, issues a warning, but put in the 'invalid' command in the config anyway. Will not work, but it's there. I was running 8.1, and seem CME ignore what I put in for the path of List.xml (found under debug tftp). I used alias to tell it where to actually look for.
02-11-2011 08:12 AM
02-11-2011 11:45 AM
Thanks for the info. I did the debug and this is what it was looking for, so I changed the TFTP server command to that file and it works. I will try with a few other phone types to verrify they are looking for the same file. This was with a 7970.
SD_Lab#debug tftp events
TFTP Event debugging is on
000102: Feb 11 19:44:57.695: TFTP: Looking for Desktops/320x212x12/List.xml
SD_Lab(config)#no tftp-server flash:Desktops/320x212x16/List.xml
Thanks again
